6616 討論
OpenVino inference time become slow when startup multiple processes
User1578037094245524
4,142 檢視
I use OpenVino to infer a ResNet50 model. When I start only one process, inference time is  about 300ms.
But When I start another process(just make a copy), both processes inference time become 600ms.
Inference time of different processes affect each other? Could you give me some information about it?
Thanks a lot!
0 積分
1 解決方案
4,113 檢視
Hi Aznie,
Thanks a lot for your reply.
I fixed the issue by SetConfig({ { CONFIG_KEY(CPU_BIND_THREAD), "NO" } }, "CPU"). It seems that CPU_BIND_THREAD default config is "YES".  It works well on Windows but on Linux the two processes seem to bind same cpu core and inference time turns dobule. After I set it to NO in the code, both Windows and Linux work well.
在原始文章中檢視解決方案
4 回應
IntelSupport
管理員
4,131 檢視
Hi Lei yan,
Could you provide me the details on what program you are running? Which sample or demo of OpenVINO Toolkit you are rusing? Also, please provide me the environment of your machine and the version of OpenVINO Toolkit.
Aznie
4,114 檢視
Hi Aznie,
IntelSupport
管理員
4,102 檢視
Hi Lei Yan,
Thank you for sharing the solution. For more information, you also can test the program on the benchmark app and have a look at the parameter of the benchmark app to compare the inference time. This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
agarcia
初學者
3,602 檢視
For OpenVINO 2.0, if you want to disable the thread binding you can use these.
ov::Core core;
core.set_property("CPU", ov::affinity(ov::Affinity::NONE));
Full information can be found here. I hope it is useful.
回覆
