OpenVino without SSSE3, SSE4.x or AVX
mdimmo
I want to run OpenVino on my Ununtu desktop which has an older AMD CPU with NCS (v1). I followed the installation steps, but when running the samples, it crashes with this error message:
* FATAL ERROR:                                                   *
* This OpenCV build doesn't support current CPU/HW configuration *
* Use OPENCV_DUMP_CONFIG=1 environment variable for details      *
Required baseline features:
SSE - OK
SSE2 - OK
SSE3 - OK
SSSE3 - NOT AVAILABLE
SSE4.1 - NOT AVAILABLE
POPCNT - OK
SSE4.2 - NOT AVAILABLE
terminate called after throwing an instance of 'cv::Exception'
  what():  OpenCV(4.0.1-openvino) /home/jenkins/workspace/OpenCV/OpenVINO/build/opencv/modules/core/src/system.cpp:538: error: (-215:Assertion failed) Missing support for required CPU baseline features. Check OpenCV build configuration and required CPU/HW setup. in function 'initialize'
Obviously, this is because the installed OpenCV has been built for Intel CPU instructions that my machine does not have.
How can I recompile OpenVino's OpenCV to not use these instructions?
Note: I actually already have OpenCV 4.0 installed on my computer, but OpenVino seems to use its own version (which, considering /home/jenkins/ does not exist, I'm guessing is installed in some docker image somewhere?)
mdimmo
I figured it out: when installing openvino, customise the installation so that opencv is not installed and it will pick up on whatever version of opencv is already installed (just make sure you have 4.0 installed).
I can now run the classification demo, but the security example still fails. Not sure why, will update later on results.
nikos1
Valued Contributor I
Hi Matt,
Good to hear it worked on an older non-SSE 4.1/4.2 CPU.  Was the result / accuracy good?
Could you post perf counters if you use the -pc parameter of the classification sample?
What is the error? Could you post the output?
cheers,
nikos
mdimmo
I figured it most of it out; The problem was that I was trying to run the demo on the CPU. You have to specify the "-d MYRIAD" option. It now completes successfully.
However, is it possible to run the security example on an AMD CPU? (It would be really helpful if it compatable)
Here is the error log when I run the security demo on CPU:
Run Inference Engine security_barrier_camera demo
Run ./security_barrier_camera_demo -d CPU -d_va CPU -d_lpr CPU -i /opt/intel/computer_vision_sdk/deployment_tools/demo/car_1.bmp -m /opt/intel//computer_vision_sdk_2018.5.445/deployment_tools/intel_models/vehicle-license-plate-detection-barrier-0106/FP32/vehicle-license-plate-detection-barrier-0106.xml -m_va /opt/intel//computer_vision_sdk_2018.5.445/deployment_tools/intel_models/vehicle-attributes-recognition-barrier-0039/FP32/vehicle-attributes-recognition-barrier-0039.xml -m_lpr /opt/intel//computer_vision_sdk_2018.5.445/deployment_tools/intel_models/license-plate-recognition-barrier-0001/FP32/license-plate-recognition-barrier-0001.xml
[ INFO ] InferenceEngine:
	API version ............ 1.4
	Build .................. 19154
[ INFO ] Parsing input parameters
[ INFO ] Capturing video streams from the video files or loading images
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/computer_vision_sdk/deployment_tools/demo/car_1.bmp
[ INFO ] Number of input image files: 1
[ INFO ] Number of input video files: 0
[ INFO ] Number of input channels:    1
[ INFO ] Loading plugin CPU
	API version ............ 1.5
	Build .................. lnx_20181004
	Description ....... MKLDNNPlugin
[ INFO ] Loading network files for VehicleDetection
[ INFO ] Batch size is forced to  1
[ INFO ] Checking Vehicle Detection inputs
[ INFO ] Checking Vehicle Detection outputs
[ INFO ] Loading Vehicle Detection model to the CPU plugin
[ ERROR ] Supported primitive descriptors list is empty for node: MobilenetV2/expanded_conv_2/expand/Conv2D
Error on or near line 154; exiting with status 1
nikos wrote:
Hi Matt,
As requested, Nikos, here is the output of the classification example using -pc
./classification_sample -d CPU -i /opt/intel/computer_vision_sdk/deployment_tools/demo/car.png -m /home/matt/openvino_models/ir/FP32//classification/squeezenet/1.1/caffe/squeezenet1.1.xml -pc
[ INFO ]     /opt/intel/computer_vision_sdk/deployment_tools/demo/car.png
[ INFO ] Loading network files:
	/home/matt/openvino_models/ir/FP32//classification/squeezenet/1.1/caffe/squeezenet1.1.bin
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the plugin
[ INFO ] Starting inference (1 iterations)
[ INFO ] Processing output blobs
Top 10 results:
Image /opt/intel/computer_vision_sdk/deployment_tools/demo/car.png
817 0.8363344 label sports car, sport car
511 0.0946487 label convertible
479 0.0419132 label car wheel
751 0.0091070 label racer, race car, racing car
436 0.0068161 label beach wagon, station wagon, wagon, estate car, beach waggon, station waggon, waggon
656 0.0037564 label minivan
586 0.0025741 label half track
717 0.0016069 label pickup, pickup truck
864 0.0012027 label tow truck, tow car, wrecker
581 0.0005882 label grille, radiator grille
total inference time: 69.5377886
Average running time of one iteration: 69.5377886 ms
Throughput: 14.3806701 FPS
performance counts:
conv1                         EXECUTED       layerType: Convolution        realTime: 8791       cpu: 8791           execType: gemm_blas_FP32
conv10                        EXECUTED       layerType: Convolution        realTime: 5294       cpu: 5294           execType: gemm_blas_FP32
data_U8_FP32_conv1            EXECUTED       layerType: Reorder            realTime: 141        cpu: 141            execType: reorder_I8
fire2/concat                  EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
fire2/expand1x1               EXECUTED       layerType: Convolution        realTime: 1181       cpu: 1181           execType: gemm_blas_FP32
fire2/expand3x3               EXECUTED       layerType: Convolution        realTime: 4181       cpu: 4181           execType: gemm_blas_FP32
fire2/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire2/relu_expand3x3          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire2/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire2/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 612        cpu: 612            execType: gemm_blas_FP32
fire3/concat                  EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
fire3/expand1x1               EXECUTED       layerType: Convolution        realTime: 1356       cpu: 1356           execType: gemm_blas_FP32
fire3/expand3x3               EXECUTED       layerType: Convolution        realTime: 4019       cpu: 4019           execType: gemm_blas_FP32
fire3/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire3/relu_expand3x3          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire3/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire3/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 5253       cpu: 5253           execType: gemm_blas_FP32
fire4/concat                  NOT_RUN        layerType: Concat             realTime: 0          cpu: 0              execType: unknown_FP32
fire4/expand1x1               EXECUTED       layerType: Convolution        realTime: 736        cpu: 736            execType: gemm_blas_FP32
fire4/expand3x3               EXECUTED       layerType: Convolution        realTime: 2461       cpu: 2461           execType: gemm_blas_FP32
fire4/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire4/relu_expand3x3          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire4/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire4/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 404        cpu: 404            execType: gemm_blas_FP32
fire5/concat                  NOT_RUN        layerType: Concat             realTime: 0          cpu: 0              execType: unknown_FP32
fire5/expand1x1               EXECUTED       layerType: Convolution        realTime: 775        cpu: 775            execType: gemm_blas_FP32
fire5/expand3x3               EXECUTED       layerType: Convolution        realTime: 2524       cpu: 2524           execType: gemm_blas_FP32
fire5/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire5/relu_expand3x3          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire5/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire5/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 581        cpu: 581            execType: gemm_blas_FP32
fire6/concat                  NOT_RUN        layerType: Concat             realTime: 0          cpu: 0              execType: unknown_FP32
fire6/expand1x1               EXECUTED       layerType: Convolution        realTime: 420        cpu: 420            execType: gemm_blas_FP32
fire6/expand3x3               EXECUTED       layerType: Convolution        realTime: 1354       cpu: 1354           execType: gemm_blas_FP32
fire6/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire6/relu_expand3x3          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire6/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire6/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 294        cpu: 294            execType: gemm_blas_FP32
fire7/concat                  NOT_RUN        layerType: Concat             realTime: 0          cpu: 0              execType: unknown_FP32
fire7/expand1x1               EXECUTED       layerType: Convolution        realTime: 466        cpu: 466            execType: gemm_blas_FP32
fire7/expand3x3               EXECUTED       layerType: Convolution        realTime: 1310       cpu: 1310           execType: gemm_blas_FP32
fire7/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire7/relu_expand3x3          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire7/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire7/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 344        cpu: 344            execType: gemm_blas_FP32
fire8/concat                  NOT_RUN        layerType: Concat             realTime: 0          cpu: 0              execType: unknown_FP32
fire8/expand1x1               EXECUTED       layerType: Convolution        realTime: 507        cpu: 507            execType: gemm_blas_FP32
fire8/expand3x3               EXECUTED       layerType: Convolution        realTime: 1980       cpu: 1980           execType: gemm_blas_FP32
fire8/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire8/relu_expand3x3          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire8/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire8/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 448        cpu: 448            execType: gemm_blas_FP32
fire9/concat                  NOT_RUN        layerType: Concat             realTime: 0          cpu: 0              execType: unknown_FP32
fire9/expand1x1               EXECUTED       layerType: Convolution        realTime: 385        cpu: 385            execType: gemm_blas_FP32
fire9/expand3x3               EXECUTED       layerType: Convolution        realTime: 2035       cpu: 2035           execType: gemm_blas_FP32
fire9/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire9/relu_expand3x3          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire9/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire9/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 539        cpu: 539            execType: gemm_blas_FP32
out_prob                      NOT_RUN        layerType: Output             realTime: 0          cpu: 0              execType: unknown_FP32
pool1                         EXECUTED       layerType: Pooling            realTime: 12898      cpu: 12898          execType: ref_any_FP32
pool10                        EXECUTED       layerType: Pooling            realTime: 217        cpu: 217            execType: ref_any_FP32
pool3                         EXECUTED       layerType: Pooling            realTime: 5265       cpu: 5265           execType: ref_any_FP32
pool5                         EXECUTED       layerType: Pooling            realTime: 2497       cpu: 2497           execType: ref_any_FP32
prob                          EXECUTED       layerType: SoftMax            realTime: 55         cpu: 55             execType: ref_any_FP32
relu_conv1                    NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
relu_conv10                   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
Total time: 69325    microseconds
[ INFO ] Execution successful
nikos1
Hi Matt,
Thank you very much for the data, appreciate this. Looks good on the slow side of course since no avx/sse4.
I believe it is possible but may have to do with how we compile cpu extensions.
Before that I would try the object detection ssd sample that is also using the cpu extensions library. This is the next step up from the classification sample. If that works we will debug security_barrier_camera_demo which is more complicated.
Cheers,
nikos
mdimmo
Thanks Nikos,
I tried the SSD example, and it "works" in that it does not crash, but it's bounding boxes are very wrong. Below are the outputs with CPU and MYRIAD. It is using the person detection model that ships with OpenVino.
CPU OUTPUT:
./object_detection_sample_ssd -i /home/matt/tensorflow/projects/hand_retrain/test_dataset/test_data/images/VOC2007_100.jpg -m /opt/intel/computer_vision_sdk/deployment_tools/intel_models/person-detection-retail-0002/FP32/person-detection-retail-0002.xml -d CPU
[ INFO ]     /home/matt/tensorflow/projects/hand_retrain/test_dataset/test_data/images/VOC2007_100.jpg
	/opt/intel/computer_vision_sdk/deployment_tools/intel_models/person-detection-retail-0002/FP32/person-detection-retail-0002.bin
[ WARNING ] Image is resized from (500, 375) to (992, 544)
[ INFO ] Start inference (1 iterations)
[0,1] element, prob = 0.997059    (198.944,49.4925)-(219.276,60.7977) batch id : 0 WILL BE PRINTED!
[1,1] element, prob = 0.927988    (258.948,79.5939)-(289.136,109.581) batch id : 0 WILL BE PRINTED!
[2,1] element, prob = 0.868948    (203.756,72.253)-(236.033,84.8551) batch id : 0 WILL BE PRINTED!
[3,1] element, prob = 0.73473    (254.07,24.1409)-(290.428,118.06) batch id : 0 WILL BE PRINTED!
[4,1] element, prob = 0.696809    (167.899,38.0656)-(289.686,60.9464) batch id : 0 WILL BE PRINTED!
[5,1] element, prob = 0.656888    (232.191,105.045)-(246.819,251.06) batch id : 0 WILL BE PRINTED!
[6,1] element, prob = 0.600668    (272.92,254.929)-(300.49,367.563) batch id : 0 WILL BE PRINTED!
[7,1] element, prob = 0.589226    (238.853,101.062)-(273.306,120.175) batch id : 0 WILL BE PRINTED!
[8,1] element, prob = 0.543612    (-0.540293,206.189)-(28.5708,373.679) batch id : 0 WILL BE PRINTED!
[9,1] element, prob = 0.512038    (100.436,134.471)-(120.95,208.303) batch id : 0 WILL BE PRINTED!
[10,1] element, prob = 0.494639    (97.4799,143.287)-(137.773,288.46) batch id : 0
[11,1] element, prob = 0.475628    (296.093,118.677)-(325.188,221.652) batch id : 0
[12,1] element, prob = 0.472245    (76.4503,169.14)-(109.343,282.465) batch id : 0
[13,1] element, prob = 0.464155    (273.746,132.849)-(300.481,238.612) batch id : 0
[14,1] element, prob = 0.461489    (285.18,138.167)-(309.018,205.9) batch id : 0
[15,1] element, prob = 0.461268    (6.91155,292.572)-(33.6672,373.561) batch id : 0
[16,1] element, prob = 0.44778    (2.77317,302.017)-(19.562,370.847) batch id : 0
[17,1] element, prob = 0.433631    (32.209,306.957)-(59.11,367.342) batch id : 0
[18,1] element, prob = 0.425371    (267.803,163.125)-(349.075,376.553) batch id : 0
[19,1] element, prob = 0.41391    (236.758,153.695)-(261.329,227.025) batch id : 0
[20,1] element, prob = 0.408685    (227.462,68.9116)-(232.516,101.289) batch id : 0
[21,1] element, prob = 0.401777    (53.9914,276.421)-(99.5851,373.516) batch id : 0
[22,1] element, prob = 0.394756    (248.825,117.151)-(274.229,156.856) batch id : 0
[23,1] element, prob = 0.388094    (109.485,288.936)-(139.626,370.241) batch id : 0
[24,1] element, prob = 0.386988    (160.353,129.19)-(187.861,221.348) batch id : 0
[25,1] element, prob = 0.373398    (102.758,64.7022)-(146.696,241.039) batch id : 0
[26,1] element, prob = 0.367827    (243.563,144.918)-(277.473,247.367) batch id : 0
[27,1] element, prob = 0.367335    (262.208,211.172)-(292.827,329.078) batch id : 0
[28,1] element, prob = 0.365246    (257.796,258.17)-(285.643,362.341) batch id : 0
[29,1] element, prob = 0.352192    (236.151,176.897)-(272.537,290.058) batch id : 0
[30,1] element, prob = 0.347749    (313.102,111.362)-(338.638,181.063) batch id : 0
[31,1] element, prob = 0.346787    (93.4459,71.9557)-(124.412,183.308) batch id : 0
[32,1] element, prob = 0.345738    (93.3228,188.158)-(115.233,251.933) batch id : 0
[33,1] element, prob = 0.33277    (130.735,24.8596)-(152.065,89.5862) batch id : 0
[34,1] element, prob = 0.331915    (21.3781,222.7)-(49.9692,340.019) batch id : 0
[35,1] element, prob = 0.331621    (272.782,174.05)-(302.151,283.888) batch id : 0
[36,1] element, prob = 0.331253    (168.733,42.62)-(225.767,57.8462) batch id : 0
[37,1] element, prob = 0.330918    (267.758,314.019)-(289.286,368.094) batch id : 0
[38,1] element, prob = 0.316481    (394.979,111.317)-(420.917,126.304) batch id : 0
[39,1] element, prob = 0.310588    (291.984,302.402)-(312.224,369.669) batch id : 0
[40,1] element, prob = 0.308719    (63.2228,225.288)-(140.382,375.026) batch id : 0
[41,1] element, prob = 0.306981    (96.2652,309.812)-(123.38,371.922) batch id : 0
[42,1] element, prob = 0.297819    (47.6316,285.68)-(76.6014,374.411) batch id : 0
[43,1] element, prob = 0.288995    (199.329,121.588)-(227.785,222.345) batch id : 0
[44,1] element, prob = 0.279405    (232.479,213.545)-(261.96,318.653) batch id : 0
[45,1] element, prob = 0.272762    (234.052,87.7652)-(241.749,155.365) batch id : 0
[46,1] element, prob = 0.268494    (237.29,35.9435)-(265.502,126.149) batch id : 0
[47,1] element, prob = 0.263486    (328.204,202.915)-(357.192,325.484) batch id : 0
[48,1] element, prob = 0.254045    (129.256,27.111)-(169.596,180.299) batch id : 0
[49,1] element, prob = 0.250443    (248.134,220.315)-(278.143,322.187) batch id : 0
[50,1] element, prob = 0.246692    (244.405,236.129)-(265.584,306.774) batch id : 0
[51,1] element, prob = 0.241511    (167.899,89.608)-(211.266,264.019) batch id : 0
[52,1] element, prob = 0.24036    (197.477,169.255)-(227.94,271.303) batch id : 0
[53,1] element, prob = 0.235643    (3.98774,57.6659)-(34.5258,221.089) batch id : 0
[54,1] element, prob = 0.234506    (59.727,66.4823)-(125.548,339.596) batch id : 0
[55,1] element, prob = 0.232519    (88.8708,32.0207)-(118.346,143.062) batch id : 0
[56,1] element, prob = 0.227354    (306.574,133.906)-(330.315,197.765) batch id : 0
[57,1] element, prob = 0.226478    (182.834,14.5971)-(226.534,51.4968) batch id : 0
[58,1] element, prob = 0.221481    (481.88,261.071)-(497.344,360.504) batch id : 0
[59,1] element, prob = 0.211941    (235.909,26.2306)-(259.371,84.0575) batch id : 0
[60,1] element, prob = 0.211006    (345.108,251.314)-(370.334,308.851) batch id : 0
[61,1] element, prob = 0.200583    (221.839,234.993)-(240.033,304.188) batch id : 0
[62,1] element, prob = 0.194168    (373.915,45.7846)-(395.055,107.968) batch id : 0
[63,1] element, prob = 0.191798    (15.2243,143.426)-(41.0938,261.594) batch id : 0
[64,1] element, prob = 0.186198    (2.55513,121.611)-(62.4949,373.768) batch id : 0
[65,1] element, prob = 0.173679    (293.876,179.336)-(326.412,305.333) batch id : 0
[66,1] element, prob = 0.172543    (366.433,46.2567)-(398.23,162.856) batch id : 0
[67,1] element, prob = 0.172276    (366.393,81.6878)-(385.207,154.013) batch id : 0
[68,1] element, prob = 0.170581    (480.252,115.226)-(497.381,229.424) batch id : 0
[69,1] element, prob = 0.168224    (293.729,85.0198)-(313.581,155.656) batch id : 0
[70,1] element, prob = 0.164963    (389.298,48.9445)-(411.87,104.968) batch id : 0
[71,1] element, prob = 0.162953    (53.2706,158.323)-(203.364,377.209) batch id : 0
[72,1] element, prob = 0.161525    (8.04805,5.91219)-(157.17,250.166) batch id : 0
[73,1] element, prob = 0.140037    (133.628,78.7744)-(211.463,369.723) batch id : 0
[74,1] element, prob = 0.139577    (40.88,-2.04585)-(68.0719,116.271) batch id : 0
[75,1] element, prob = 0.137961    (207.549,273.405)-(236.447,373.803) batch id : 0
[76,1] element, prob = 0.1368    (35.4129,208.465)-(72.2991,366.682) batch id : 0
[77,1] element, prob = 0.128557    (384.566,141.372)-(402.126,176.344) batch id : 0
[78,1] element, prob = 0.125769    (281.337,128.888)-(287.822,148.246) batch id : 0
[79,1] element, prob = 0.124974    (210.598,1.57618)-(238.714,36.6062) batch id : 0
[80,1] element, prob = 0.105082    (77.3688,86.2662)-(108.515,202.769) batch id : 0
[81,1] element, prob = 0.104047    (473.124,31.8527)-(496.814,199.322) batch id : 0
[82,1] element, prob = 0.103322    (24.6542,25.7562)-(51.0006,143.718) batch id : 0
[83,1] element, prob = 0.10052    (48.4786,31.1006)-(75.9011,157.556) batch id : 0
[84,1] element, prob = 0.0957587    (2.90126,39.8842)-(20.3039,152.983) batch id : 0
[85,1] element, prob = 0.0922709    (55.4088,1.28828)-(95.5319,89.8101) batch id : 0
[86,1] element, prob = 0.0878628    (41.5833,120.383)-(68.5695,241.958) batch id : 0
[87,1] element, prob = 0.0836319    (177.934,3.83617)-(266.508,49.4962) batch id : 0
[88,1] element, prob = 0.082015    (150.56,29.0788)-(195.207,197.327) batch id : 0
[89,1] element, prob = 0.0793932    (377.088,9.43593)-(406.853,108.755) batch id : 0
[90,1] element, prob = 0.07786    (245.752,1.48766)-(266.309,42.7834) batch id : 0
[91,1] element, prob = 0.0772734    (473.115,173.503)-(496.202,276.44) batch id : 0
[92,1] element, prob = 0.0736602    (439.486,99.4262)-(469.659,195.836) batch id : 0
[93,1] element, prob = 0.0674021    (276.081,13.7846)-(308.229,113.969) batch id : 0
[94,1] element, prob = 0.0638556    (128.147,200.134)-(171.338,369.176) batch id : 0
[95,1] element, prob = 0.0621899    (144.03,4.49122)-(173.022,61.2716) batch id : 0
[96,1] element, prob = 0.0572652    (243.854,83.4662)-(249.81,129.346) batch id : 0
[97,1] element, prob = 0.0494299    (3.56377,-0.10272)-(42.1816,88.9625) batch id : 0
[98,1] element, prob = 0.0491901    (476.355,241.046)-(497.765,311.325) batch id : 0
[99,1] element, prob = 0.048757    (50.0681,98.5335)-(91.2925,281.272) batch id : 0
[100,1] element, prob = 0.0484611    (329.177,95.815)-(457.758,113.492) batch id : 0
[101,1] element, prob = 0.0430711    (211.355,68.0001)-(232.585,305.027) batch id : 0
[102,1] element, prob = 0.0412185    (19.6584,-1.88588)-(58.6687,92.2611) batch id : 0
[103,1] element, prob = 0.0404651    (228.841,85.3283)-(279.531,297.863) batch id : 0
[104,1] element, prob = 0.0399879    (473.352,8.34259)-(495.469,105.57) batch id : 0
[105,1] element, prob = 0.0326501    (216.183,93.9635)-(238.017,129.239) batch id : 0
[106,1] element, prob = 0.0279986    (308.153,85.237)-(329.855,162.498) batch id : 0
[107,1] element, prob = 0.0238666    (461.267,294.376)-(493.977,380.614) batch id : 0
[108,1] element, prob = 0.019164    (291.347,62.4018)-(329.237,192.667) batch id : 0
[109,1] element, prob = 0.014518    (346.556,17.3668)-(373.228,133.976) batch id : 0
[110,1] element, prob = 0.00701878    (456.884,123.246)-(495.633,261.598) batch id : 0
[111,1] element, prob = 0.00367822    (198.269,90.8855)-(230.4,137.295) batch id : 0
[112,1] element, prob = 0.00346408    (461.108,186.609)-(481.239,243.638) batch id : 0
[113,1] element, prob = 0.000881145    (231.924,124.212)-(270.234,167.823) batch id : 0
[114,1] element, prob = 8.02014e-05    (177.487,79.7558)-(222.458,134.819) batch id : 0
[115,1] element, prob = 6.51032e-07    (385.348,276.61)-(479.338,441.781) batch id : 0
[ INFO ] Image out_0.bmp created!
total inference time: 1495.93
Average running time of one iteration: 1495.93 ms
Throughput: 0.66848 FPS
CPU ssd ouput
MYRIAD OUTPUT
./object_detection_sample_ssd -i /home/matt/tensorflow/projects/hand_retrain/test_dataset/test_data/images/VOC2007_100.jpg -m /opt/intel/computer_vision_sdk/deployment_tools/intel_models/person-detection-retail-0002/FP16/person-detection-retail-0002.xml -d MYRIAD
	Description ....... myriadPlugin
	/opt/intel/computer_vision_sdk/deployment_tools/intel_models/person-detection-retail-0002/FP16/person-detection-retail-0002.bin
[0,1] element, prob = 0.937012    (-7.21741,189.697)-(44.3115,373.169) batch id : 0 WILL BE PRINTED!
[1,1] element, prob = 0.79541    (74.1577,164.978)-(167.725,378.662) batch id : 0 WILL BE PRINTED!
[2,1] element, prob = 0.714844    (267.09,119.385)-(369.629,386.719) batch id : 0 WILL BE PRINTED!
[3,1] element, prob = 0.569824    (156.494,115.906)-(234.619,377.197) batch id : 0 WILL BE PRINTED!
[4,1] element, prob = 0.379395    (115.112,178.894)-(156.372,338.562) batch id : 0
[5,1] element, prob = 0.301758    (228.516,150.33)-(285.645,377.93) batch id : 0
[6,1] element, prob = 0.253418    (75.6226,194.458)-(113.586,368.042) batch id : 0
[7,1] element, prob = 0.191895    (92.3462,221.375)-(146.973,364.929) batch id : 0
[8,1] element, prob = 0.174805    (2.0752,187.866)-(35.7666,273.56) batch id : 0
[9,1] element, prob = 0.126465    (66.3452,66.8335)-(301.758,370.422) batch id : 0
[10,1] element, prob = 0.103516    (118.042,115.265)-(193.97,356.689) batch id : 0
[11,1] element, prob = 0.0961914    (166.504,138.336)-(349.609,385.986) batch id : 0
[12,1] element, prob = 0.0927734    (217.651,126.984)-(235.474,177.155) batch id : 0
[13,1] element, prob = 0.0859375    (179.443,141.998)-(227.295,246.094) batch id : 0
[14,1] element, prob = 0.0839844    (230.347,128.723)-(248.657,184.021) batch id : 0
[15,1] element, prob = 0.0751953    (200.195,213.684)-(249.756,360.168) batch id : 0
[16,1] element, prob = 0.0615234    (396.973,11.7188)-(416.504,53.7415) batch id : 0
[17,1] element, prob = 0.0585938    (96.4966,120.85)-(151.001,289.307) batch id : 0
[18,1] element, prob = 0.0561523    (63.9648,-29.1138)-(569.824,411.621) batch id : 0
[19,1] element, prob = 0.0537109    (238.159,120.026)-(281.738,257.812) batch id : 0
[20,1] element, prob = 0.0507812    (330.322,135.681)-(382.568,281.067) batch id : 0
[21,1] element, prob = 0.050293    (38.6963,-7.46155)-(81.1157,134.216) batch id : 0
[22,1] element, prob = 0.0493164    (222.534,101.99)-(255.859,194.824) batch id : 0
[23,1] element, prob = 0.0473633    (298.828,112.244)-(359.375,277.039) batch id : 0
[24,1] element, prob = 0.0429688    (36.2549,267.7)-(233.521,362.549) batch id : 0
[25,1] element, prob = 0.0429688    (289.795,220.825)-(360.596,366.943) batch id : 0
[26,1] element, prob = 0.0410156    (28.5034,23.6206)-(175.781,360.535) batch id : 0
[27,1] element, prob = 0.034668    (437.012,86.6089)-(508.301,331.604) batch id : 0
[28,1] element, prob = 0.034668    (269.043,230.347)-(317.383,360.718) batch id : 0
[29,1] element, prob = 0.0332031    (137.695,221.191)-(185.547,364.014) batch id : 0
[30,1] element, prob = 0.0322266    (170.166,20.6795)-(188.477,63.9038) batch id : 0
[31,1] element, prob = 0.0322266    (289.551,124.603)-(337.402,225.952) batch id : 0
[32,1] element, prob = 0.03125    (210.327,83.8165)-(269.531,261.108) batch id : 0
[33,1] element, prob = 0.0292969    (164.795,16.1247)-(180.42,60.1044) batch id : 0
[34,1] element, prob = 0.0219727    (-14.0076,217.346)-(105.347,361.267) batch id : 0
[35,1] element, prob = 0.0209961    (117.798,269.897)-(324.219,366.211) batch id : 0
[36,1] element, prob = 0.019043    (136.963,21.4233)-(255.615,291.687) batch id : 0
[37,1] element, prob = 0.019043    (14.3356,154.449)-(25.7568,196.655) batch id : 0
[38,1] element, prob = 0.0170898    (249.756,61.0657)-(326.416,292.969) batch id : 0
[39,1] element, prob = 0.0170898    (154.907,20.5765)-(172.241,58.2275) batch id : 0
[40,1] element, prob = 0.0107422    (486.572,11.6272)-(498.779,349.731) batch id : 0
[41,1] element, prob = 0.0107422    (181.274,17.8528)-(197.632,68.0237) batch id : 0
[42,1] element, prob = 0.00976562    (191.284,3.43323)-(254.639,138.428) batch id : 0
[43,1] element, prob = 0.00878906    (9.00269,173.95)-(28.656,229.248) batch id : 0
[44,1] element, prob = 0.0078125    (182.861,25.1312)-(209.717,80.8868) batch id : 0
[45,1] element, prob = 0.000976562    (262.939,1.83105)-(453.857,425.903) batch id : 0
[46,1] element, prob = 0    (392.09,217.529)-(511.719,381.958) batch id : 0
[47,1] element, prob = 0    (283.203,123.871)-(625.977,284.18) batch id : 0
[48,1] element, prob = 0    (322.266,-45.2271)-(533.203,156.738) batch id : 0
[49,1] element, prob = 0    (191.772,213.501)-(522.461,424.805) batch id : 0
[50,1] element, prob = 0    (-23.1934,153.442)-(792.969,446.411) batch id : 0
[51,1] element, prob = 0    (361.816,99.7009)-(428.223,265.137) batch id : 0
total inference time: 463.569
Average running time of one iteration: 463.569 ms
Throughput: 2.15718 FPS
MYRIAD SSD output
nikos1
Hi Matt,
So it seems MYRIAD works but old CPU produces wrong results, correct? Could you post -pc output for SSD CPU path? It may reveal the layer that has issues. May be an issue with the extension library (cpu_extension_avx2.dll). In the old SDK there used to be an non-avx version. You could try to build from source ( is it the C:\Intel\computer_vision_sdk_2018.5.456\deployment_tools\inference_engine\src\extension project ?  You could build from the samples solution without any SSE/AVX flags after you cmake on your system ).
Also do you have an Ubuntu partition on this system? Would be interesting to see of the issue is there too. In any case the system does not meet the requirements but it is worth trying if there are no other options.
https://software.intel.com/en-us/openvino-toolkit/documentation/system-requirements
nikos
mdimmo
Hello Nikos,
Correct.
See end of this post.
Im on Ubuntu, so it's the "/opt/intel/computer_vision_sdk/inference_engine/samples/object_detection_sample_ssd" project. How can I turn off SSE/AVX instructions when building them (surely they would use native compile flags by default)? Surely the bigger problem would not be the examples, but the binaries that are linked to the examples which (I'm guessing) are distributed with the installation. Is there any instructions on building these from source?
I am on an Ubuntu computer - that is all I have. I am not surprised that it does not work on my computer, but, it seems so close, that it is unfortunate that it does not. Also, since it is not prodice an illegal instruction exception, I see no reason for it to fail. Here are exact specs for reference:
CPU: AMD Phenom II N970 Quad-Core Processor × 4 (do you remember the days when quad core was awesome)
GPU (not using): AMD TURKS (DRM 2.43.0 / 4.4.0-141-generic, LLVM 6.0.0)
RAM: 7.8 Gb
OS: Ubuntu 16.04 64bit
Of-course, I'm also using a Movidius Neural Compute Stick (v1) over usb 2.
CPU SSD -pc output (the created image is the exact same as the CPU image given in the previous post):
./object_detection_sample_ssd -i /home/matt/tensorflow/projects/hand_retrain/test_dataset/test_data/images/VOC2007_100.jpg -m /opt/intel/computer_vision_sdk/deployment_tools/intel_models/person-detection-retail-0002/FP32/person-detection-retail-0002.xml -d CPU -pc
total inference time: 1771.05
Average running time of one iteration: 1771.05 ms
Throughput: 0.564638 FPS
performance counts:
Add_                          EXECUTED       layerType: ScaleShift         realTime: 164762     cpu: 164762         execType: ref_any_FP32
Pooling_                      EXECUTED       layerType: Pooling            realTime: 5567       cpu: 5567           execType: ref_any_FP32
Pooling_687                   EXECUTED       layerType: Pooling            realTime: 6750       cpu: 6750           execType: ref_any_FP32
bbox_pred_reshape             NOT_RUN        layerType: Reshape            realTime: 0          cpu: 0              execType: unknown_FP32
cls_prob                      EXECUTED       layerType: SoftMax            realTime: 14         cpu: 14             execType: ref_any_FP32
cls_prob_reshape              NOT_RUN        layerType: Reshape            realTime: 0          cpu: 0              execType: unknown_FP32
concat_convf                  EXECUTED       layerType: Concat             realTime: 2          cpu: 2              execType: unknown_FP32
conv1_1/concat                EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv1_1/conv                  EXECUTED       layerType: Convolution        realTime: 93141      cpu: 93141          execType: gemm_blas_FP32
conv1_1/neg                   EXECUTED       layerType: Power              realTime: 2551       cpu: 2551           execType: unknown_FP32
conv1_1/relu                  EXECUTED       layerType: ReLU               realTime: 3770       cpu: 3770           execType: ref_any_FP32
conv1_1/scale/Mul_/FusedSc... EXECUTED       layerType: ScaleShift         realTime: 186693     cpu: 186693         execType: ref_any_FP32
conv2_1                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv2_1/1/conv                EXECUTED       layerType: Convolution        realTime: 4905       cpu: 4905           execType: gemm_blas_FP32
conv2_1/1/relu                NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv2_1/2/concat              EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv2_1/2/conv                EXECUTED       layerType: Convolution        realTime: 31647      cpu: 31647          execType: gemm_blas_FP32
conv2_1/2/neg                 EXECUTED       layerType: Power              realTime: 978        cpu: 978            execType: unknown_FP32
conv2_1/2/relu                EXECUTED       layerType: ReLU               realTime: 1633       cpu: 1633           execType: ref_any_FP32
conv2_1/2/scale/Mul_/Fused... EXECUTED       layerType: ScaleShift         realTime: 71689      cpu: 71689          execType: ref_any_FP32
conv2_1/3/conv                EXECUTED       layerType: Convolution        realTime: 8236       cpu: 8236           execType: gemm_blas_FP32
conv2_1/proj                  EXECUTED       layerType: Convolution        realTime: 9468       cpu: 9468           execType: gemm_blas_FP32
conv2_2                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv2_2/1/conv                EXECUTED       layerType: Convolution        realTime: 8110       cpu: 8110           execType: gemm_blas_FP32
conv2_2/1/relu                NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv2_2/2/concat              EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv2_2/2/conv                EXECUTED       layerType: Convolution        realTime: 32230      cpu: 32230          execType: gemm_blas_FP32
conv2_2/2/neg                 EXECUTED       layerType: Power              realTime: 1379       cpu: 1379           execType: unknown_FP32
conv2_2/2/relu                EXECUTED       layerType: ReLU               realTime: 1641       cpu: 1641           execType: ref_any_FP32
conv2_2/2/scale/Mul_/Fused... EXECUTED       layerType: ScaleShift         realTime: 78181      cpu: 78181          execType: ref_any_FP32
conv2_2/3/conv                EXECUTED       layerType: Convolution        realTime: 8385       cpu: 8385           execType: gemm_blas_FP32
conv2_3                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv2_3/1/conv                EXECUTED       layerType: Convolution        realTime: 7420       cpu: 7420           execType: gemm_blas_FP32
conv2_3/1/relu                NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv2_3/2/concat              NOT_RUN        layerType: Concat             realTime: 0          cpu: 0              execType: unknown_FP32
conv2_3/2/conv                EXECUTED       layerType: Convolution        realTime: 32235      cpu: 32235          execType: gemm_blas_FP32
conv2_3/2/neg                 EXECUTED       layerType: Power              realTime: 980        cpu: 980            execType: unknown_FP32
conv2_3/2/relu                EXECUTED       layerType: ReLU               realTime: 451        cpu: 451            execType: ref_any_FP32
conv2_3/2/scale/Mul_/Fused... EXECUTED       layerType: ScaleShift         realTime: 17851      cpu: 17851          execType: ref_any_FP32
conv2_3/3/conv                EXECUTED       layerType: Convolution        realTime: 2180       cpu: 2180           execType: gemm_blas_FP32
conv3_1                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv3_1/1/conv                EXECUTED       layerType: Convolution        realTime: 3831       cpu: 3831           execType: gemm_blas_FP32
conv3_1/1/relu                NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv3_1/2/concat              NOT_RUN        layerType: Concat             realTime: 0          cpu: 0              execType: unknown_FP32
conv3_1/2/conv                EXECUTED       layerType: Convolution        realTime: 20507      cpu: 20507          execType: gemm_blas_FP32
conv3_1/2/neg                 EXECUTED       layerType: Power              realTime: 535        cpu: 535            execType: unknown_FP32
conv3_1/2/relu                EXECUTED       layerType: ReLU               realTime: 968        cpu: 968            execType: ref_any_FP32
conv3_1/2/scale/Mul_/Fused... EXECUTED       layerType: ScaleShift         realTime: 35028      cpu: 35028          execType: ref_any_FP32
conv3_1/3/conv                EXECUTED       layerType: Convolution        realTime: 6377       cpu: 6377           execType: gemm_blas_FP32
conv3_1/proj                  EXECUTED       layerType: Convolution        realTime: 6251       cpu: 6251           execType: gemm_blas_FP32
conv3_2                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv3_2/1/conv                EXECUTED       layerType: Convolution        realTime: 6354       cpu: 6354           execType: gemm_blas_FP32
conv3_2/1/relu                NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv3_2/2/concat              EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv3_2/2/conv                EXECUTED       layerType: Convolution        realTime: 18325      cpu: 18325          execType: gemm_blas_FP32
conv3_2/2/neg                 EXECUTED       layerType: Power              realTime: 1703       cpu: 1703           execType: unknown_FP32
conv3_2/2/relu                EXECUTED       layerType: ReLU               realTime: 954        cpu: 954            execType: ref_any_FP32
conv3_2/2/scale/Mul_/Fused... EXECUTED       layerType: ScaleShift         realTime: 36966      cpu: 36966          execType: ref_any_FP32
conv3_2/3/conv                EXECUTED       layerType: Convolution        realTime: 6400       cpu: 6400           execType: gemm_blas_FP32
conv3_3                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv3_3/1/conv                EXECUTED       layerType: Convolution        realTime: 5636       cpu: 5636           execType: gemm_blas_FP32
conv3_3/1/relu                NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv3_3/2/concat              EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv3_3/2/conv                EXECUTED       layerType: Convolution        realTime: 18510      cpu: 18510          execType: gemm_blas_FP32
conv3_3/2/neg                 EXECUTED       layerType: Power              realTime: 541        cpu: 541            execType: unknown_FP32
conv3_3/2/relu                EXECUTED       layerType: ReLU               realTime: 1087       cpu: 1087           execType: ref_any_FP32
conv3_3/2/scale/Mul_/Fused... EXECUTED       layerType: ScaleShift         realTime: 33217      cpu: 33217          execType: ref_any_FP32
conv3_3/3/conv                EXECUTED       layerType: Convolution        realTime: 6427       cpu: 6427           execType: gemm_blas_FP32
conv3_4                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv3_4/1/conv                EXECUTED       layerType: Convolution        realTime: 5774       cpu: 5774           execType: gemm_blas_FP32
conv3_4/1/relu                NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv3_4/2/concat              EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv3_4/2/conv                EXECUTED       layerType: Convolution        realTime: 19172      cpu: 19172          execType: gemm_blas_FP32
conv3_4/2/neg                 EXECUTED       layerType: Power              realTime: 536        cpu: 536            execType: unknown_FP32
conv3_4/2/relu                EXECUTED       layerType: ReLU               realTime: 1288       cpu: 1288           execType: ref_any_FP32
conv3_4/2/scale/Mul_/Fused... EXECUTED       layerType: ScaleShift         realTime: 33306      cpu: 33306          execType: ref_any_FP32
conv3_4/3/conv                EXECUTED       layerType: Convolution        realTime: 6314       cpu: 6314           execType: gemm_blas_FP32
conv4_1                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv4_1/incep                 EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv4_1/incep/0/conv          EXECUTED       layerType: Convolution        realTime: 2801       cpu: 2801           execType: gemm_blas_FP32
conv4_1/incep/0/relu          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_1/incep/1_0/conv        EXECUTED       layerType: Convolution        realTime: 9798       cpu: 9798           execType: gemm_blas_FP32
conv4_1/incep/1_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_1/incep/1_reduce/conv   EXECUTED       layerType: Convolution        realTime: 2240       cpu: 2240           execType: gemm_blas_FP32
conv4_1/incep/1_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_1/incep/2_0/conv        EXECUTED       layerType: Convolution        realTime: 3123       cpu: 3123           execType: gemm_blas_FP32
conv4_1/incep/2_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_1/incep/2_1/conv        EXECUTED       layerType: Convolution        realTime: 5200       cpu: 5200           execType: gemm_blas_FP32
conv4_1/incep/2_1/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_1/incep/2_reduce/conv   EXECUTED       layerType: Convolution        realTime: 2583       cpu: 2583           execType: gemm_blas_FP32
conv4_1/incep/2_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_1/incep/pool            EXECUTED       layerType: Pooling            realTime: 15285      cpu: 15285          execType: ref_any_FP32
conv4_1/incep/poolproj/conv   EXECUTED       layerType: Convolution        realTime: 3091       cpu: 3091           execType: gemm_blas_FP32
conv4_1/incep/poolproj/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_1/out/conv              EXECUTED       layerType: Convolution        realTime: 10064      cpu: 10064          execType: gemm_blas_FP32
conv4_1/proj                  EXECUTED       layerType: Convolution        realTime: 5161       cpu: 5161           execType: gemm_blas_FP32
conv4_2                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv4_2/incep                 EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv4_2/incep/0/conv          EXECUTED       layerType: Convolution        realTime: 3890       cpu: 3890           execType: gemm_blas_FP32
conv4_2/incep/0/relu          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_2/incep/1_0/conv        EXECUTED       layerType: Convolution        realTime: 12798      cpu: 12798          execType: gemm_blas_FP32
conv4_2/incep/1_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_2/incep/1_reduce/conv   EXECUTED       layerType: Convolution        realTime: 3046       cpu: 3046           execType: gemm_blas_FP32
conv4_2/incep/1_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_2/incep/2_0/conv        EXECUTED       layerType: Convolution        realTime: 3642       cpu: 3642           execType: gemm_blas_FP32
conv4_2/incep/2_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_2/incep/2_1/conv        EXECUTED       layerType: Convolution        realTime: 5126       cpu: 5126           execType: gemm_blas_FP32
conv4_2/incep/2_1/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_2/incep/2_reduce/conv   EXECUTED       layerType: Convolution        realTime: 2056       cpu: 2056           execType: gemm_blas_FP32
conv4_2/incep/2_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_2/out/conv              EXECUTED       layerType: Convolution        realTime: 6829       cpu: 6829           execType: gemm_blas_FP32
conv4_3                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv4_3/incep                 EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv4_3/incep/0/conv          EXECUTED       layerType: Convolution        realTime: 4141       cpu: 4141           execType: gemm_blas_FP32
conv4_3/incep/0/relu          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_3/incep/1_0/conv        EXECUTED       layerType: Convolution        realTime: 12751      cpu: 12751          execType: gemm_blas_FP32
conv4_3/incep/1_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_3/incep/1_reduce/conv   EXECUTED       layerType: Convolution        realTime: 3133       cpu: 3133           execType: gemm_blas_FP32
conv4_3/incep/1_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_3/incep/2_0/conv        EXECUTED       layerType: Convolution        realTime: 3953       cpu: 3953           execType: gemm_blas_FP32
conv4_3/incep/2_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_3/incep/2_1/conv        EXECUTED       layerType: Convolution        realTime: 5355       cpu: 5355           execType: gemm_blas_FP32
conv4_3/incep/2_1/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_3/incep/2_reduce/conv   EXECUTED       layerType: Convolution        realTime: 1636       cpu: 1636           execType: gemm_blas_FP32
conv4_3/incep/2_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_3/out/conv              EXECUTED       layerType: Convolution        realTime: 6681       cpu: 6681           execType: gemm_blas_FP32
conv4_4                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv4_4/incep                 EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv4_4/incep/0/conv          EXECUTED       layerType: Convolution        realTime: 6987       cpu: 6987           execType: gemm_blas_FP32
conv4_4/incep/0/relu          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_4/incep/1_0/conv        EXECUTED       layerType: Convolution        realTime: 24093      cpu: 24093          execType: gemm_blas_FP32
conv4_4/incep/1_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_4/incep/1_reduce/conv   EXECUTED       layerType: Convolution        realTime: 3635       cpu: 3635           execType: gemm_blas_FP32
conv4_4/incep/1_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_4/incep/2_0/conv        EXECUTED       layerType: Convolution        realTime: 3504       cpu: 3504           execType: gemm_blas_FP32
conv4_4/incep/2_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_4/incep/2_1/conv        EXECUTED       layerType: Convolution        realTime: 14905      cpu: 14905          execType: gemm_blas_FP32
conv4_4/incep/2_1/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_4/incep/2_reduce/conv   EXECUTED       layerType: Convolution        realTime: 26684      cpu: 26684          execType: gemm_blas_FP32
conv4_4/incep/2_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv4_4/out/conv              EXECUTED       layerType: Convolution        realTime: 10457      cpu: 10457          execType: gemm_blas_FP32
conv4_4/out/conv___concat     EXECUTED       layerType: Reorder            realTime: 57357      cpu: 57357          execType: reorder_FP32
conv5_1                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv5_1/incep                 EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv5_1/incep/0/conv          EXECUTED       layerType: Convolution        realTime: 2999       cpu: 2999           execType: gemm_blas_FP32
conv5_1/incep/0/relu          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_1/incep/1_0/conv        EXECUTED       layerType: Convolution        realTime: 18939      cpu: 18939          execType: gemm_blas_FP32
conv5_1/incep/1_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_1/incep/1_reduce/conv   EXECUTED       layerType: Convolution        realTime: 3152       cpu: 3152           execType: gemm_blas_FP32
conv5_1/incep/1_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_1/incep/2_0/conv        EXECUTED       layerType: Convolution        realTime: 1067       cpu: 1067           execType: gemm_blas_FP32
conv5_1/incep/2_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_1/incep/2_1/conv        EXECUTED       layerType: Convolution        realTime: 37750      cpu: 37750          execType: gemm_blas_FP32
conv5_1/incep/2_1/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_1/incep/2_reduce/conv   EXECUTED       layerType: Convolution        realTime: 1009       cpu: 1009           execType: gemm_blas_FP32
conv5_1/incep/2_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_1/incep/pool            EXECUTED       layerType: Pooling            realTime: 7447       cpu: 7447           execType: ref_any_FP32
conv5_1/incep/poolproj/conv   EXECUTED       layerType: Convolution        realTime: 2090       cpu: 2090           execType: gemm_blas_FP32
conv5_1/incep/poolproj/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_1/out/conv              EXECUTED       layerType: Convolution        realTime: 11036      cpu: 11036          execType: gemm_blas_FP32
conv5_1/proj                  EXECUTED       layerType: Convolution        realTime: 18351      cpu: 18351          execType: gemm_blas_FP32
conv5_2                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv5_2/incep                 EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv5_2/incep/0/conv          EXECUTED       layerType: Convolution        realTime: 1018       cpu: 1018           execType: gemm_blas_FP32
conv5_2/incep/0/relu          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_2/incep/1_0/conv        EXECUTED       layerType: Convolution        realTime: 6264       cpu: 6264           execType: gemm_blas_FP32
conv5_2/incep/1_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_2/incep/1_reduce/conv   EXECUTED       layerType: Convolution        realTime: 8474       cpu: 8474           execType: gemm_blas_FP32
conv5_2/incep/1_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_2/incep/2_0/conv        EXECUTED       layerType: Convolution        realTime: 9413       cpu: 9413           execType: gemm_blas_FP32
conv5_2/incep/2_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_2/incep/2_1/conv        EXECUTED       layerType: Convolution        realTime: 6611       cpu: 6611           execType: gemm_blas_FP32
conv5_2/incep/2_1/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_2/incep/2_reduce/conv   EXECUTED       layerType: Convolution        realTime: 678        cpu: 678            execType: gemm_blas_FP32
conv5_2/incep/2_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_2/out/conv              EXECUTED       layerType: Convolution        realTime: 7590       cpu: 7590           execType: gemm_blas_FP32
conv5_3                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv5_3/incep                 EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
conv5_3/incep/0/conv          EXECUTED       layerType: Convolution        realTime: 5322       cpu: 5322           execType: gemm_blas_FP32
conv5_3/incep/0/relu          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_3/incep/1_0/conv        EXECUTED       layerType: Convolution        realTime: 6560       cpu: 6560           execType: gemm_blas_FP32
conv5_3/incep/1_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_3/incep/1_reduce/conv   EXECUTED       layerType: Convolution        realTime: 1330       cpu: 1330           execType: gemm_blas_FP32
conv5_3/incep/1_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_3/incep/2_0/conv        EXECUTED       layerType: Convolution        realTime: 5939       cpu: 5939           execType: gemm_blas_FP32
conv5_3/incep/2_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_3/incep/2_1/conv        EXECUTED       layerType: Convolution        realTime: 2061       cpu: 2061           execType: gemm_blas_FP32
conv5_3/incep/2_1/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_3/incep/2_reduce/conv   EXECUTED       layerType: Convolution        realTime: 1578       cpu: 1578           execType: gemm_blas_FP32
conv5_3/incep/2_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_3/out/conv              EXECUTED       layerType: Convolution        realTime: 7146       cpu: 7146           execType: gemm_blas_FP32
conv5_4                       NOT_RUN        layerType: Eltwise            realTime: 0          cpu: 0              execType: undef
conv5_4/incep                 EXECUTED       layerType: Concat             realTime: 2          cpu: 2              execType: unknown_FP32
conv5_4/incep/0/conv          EXECUTED       layerType: Convolution        realTime: 6841       cpu: 6841           execType: gemm_blas_FP32
conv5_4/incep/0/relu          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_4/incep/1_0/conv        EXECUTED       layerType: Convolution        realTime: 13535      cpu: 13535          execType: gemm_blas_FP32
conv5_4/incep/1_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_4/incep/1_reduce/conv   EXECUTED       layerType: Convolution        realTime: 8847       cpu: 8847           execType: gemm_blas_FP32
conv5_4/incep/1_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_4/incep/2_0/conv        EXECUTED       layerType: Convolution        realTime: 2026       cpu: 2026           execType: gemm_blas_FP32
conv5_4/incep/2_0/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_4/incep/2_1/conv        EXECUTED       layerType: Convolution        realTime: 6721       cpu: 6721           execType: gemm_blas_FP32
conv5_4/incep/2_1/relu        NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_4/incep/2_reduce/conv   EXECUTED       layerType: Convolution        realTime: 19120      cpu: 19120          execType: gemm_blas_FP32
conv5_4/incep/2_reduce/relu   NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
conv5_4/out/conv              EXECUTED       layerType: Convolution        realTime: 16855      cpu: 16855          execType: gemm_blas_FP32
convf_2                       EXECUTED       layerType: Convolution        realTime: 13172      cpu: 13172          execType: gemm_blas_FP32
convf_rpn                     EXECUTED       layerType: Convolution        realTime: 12927      cpu: 12927          execType: gemm_blas_FP32
data_U8_FP32_Add_             EXECUTED       layerType: Reorder            realTime: 1379       cpu: 1379           execType: reorder_I8
detection_out                 EXECUTED       layerType: DetectionOutput    realTime: 238        cpu: 238            execType: unknown_FP32
detector/bbox/ave_pred        EXECUTED       layerType: Pooling            realTime: 104        cpu: 104            execType: ref_any_FP32
detector/bbox/bbox            EXECUTED       layerType: Convolution        realTime: 12827      cpu: 12827          execType: gemm_blas_FP32
detector/bbox/ps_roi_pooling  EXECUTED       layerType: PSROIPooling       realTime: 3511       cpu: 3511           execType: unknown_FP32
detector/cls/ave_pred         EXECUTED       layerType: Pooling            realTime: 45         cpu: 45             execType: ref_any_FP32
detector/cls/cls              EXECUTED       layerType: Convolution        realTime: 3551       cpu: 3551           execType: gemm_blas_FP32
detector/cls/ps_roi_pooling   EXECUTED       layerType: PSROIPooling       realTime: 791        cpu: 791            execType: unknown_FP32
downsample                    EXECUTED       layerType: Pooling            realTime: 15438      cpu: 15438          execType: ref_any_FP32
im_info                       EXECUTED       layerType: Input              realTime: 1          cpu: 1              execType: unknown
out_detection_out             NOT_RUN        layerType: Output             realTime: 0          cpu: 0              execType: unknown_FP32
pool1                         EXECUTED       layerType: Pooling            realTime: 58854      cpu: 58854          execType: ref_any_FP32
proposal                      EXECUTED       layerType: Proposal           realTime: 19166      cpu: 19166          execType: unknown_FP32
reluf_2                       NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
reluf_rpn                     NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
rois_reshape                  EXECUTED       layerType: Reshape            realTime: 1          cpu: 1              execType: unknown_FP32
rpn_bbox_pred                 EXECUTED       layerType: Convolution        realTime: 3222       cpu: 3222           execType: gemm_blas_FP32
rpn_cls_prob                  EXECUTED       layerType: SoftMax            realTime: 9721       cpu: 9721           execType: ref_any_FP32
rpn_cls_prob_reshape          NOT_RUN        layerType: Reshape            realTime: 0          cpu: 0              execType: unknown_FP32
rpn_cls_score                 EXECUTED       layerType: Convolution        realTime: 588        cpu: 588            execType: gemm_blas_FP32
rpn_cls_score_reshape         EXECUTED       layerType: Reshape            realTime: 1          cpu: 1              execType: unknown_FP32
rpn_conv1                     EXECUTED       layerType: Convolution        realTime: 9789       cpu: 9789           execType: gemm_blas_FP32
rpn_relu1                     NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
upsample                      EXECUTED       layerType: Deconvolution      realTime: 16680      cpu: 16680          execType: gemm_blas_FP32
Total time: 1770652  microseconds
nikos1
Hi Matt,
Could be an MKLDNN issue (either a bug or a non-supported / implemented feature).  We have the source code so I think the next step is to see if we can pass the unit tests on your system. I have good test results on some of my new systems but failing a few unit tests on older systems. That would help us further assess the situation if you really want to invest on getting this to run on an older unsupported system.
git clone https://github.com/opencv/dldt.git
cd dldt/inference-engine/
git submodule init
git submodule update --recursive
mkdir build
cd build
cmake -DCMAKE_BUILD_TYPE=Release ..
make -j13
 ../bin/intel64/Release/InferenceEngineUnitTests
I can pass all unit tests on a supported system
[----------] Global test environment tear-down
[==========] 1662 tests from 145 test cases ran. (42707 ms total)
[  PASSED  ] 1662 tests.
I am failing a few tests on older systems and some of the failed tests are relevant to SSD as in your case here:
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/11, where GetParam() = 104-byte object  . . .
What is your result?
Cheers,
nikos
mdimmo
Here's the result of the tests:
Running main() from gtest_main.cc
[==========] Running 1662 tests from 145 test cases.
[----------] Global test environment set-up.
[----------] 8 tests from GraphCopyTests
[ RUN      ] GraphCopyTests.copyNetworkPreserveBasicParams
[       OK ] GraphCopyTests.copyNetworkPreserveBasicParams (1 ms)
[ RUN      ] GraphCopyTests.canPreserveBatchWhenCopyNetwork
[       OK ] GraphCopyTests.canPreserveBatchWhenCopyNetwork (0 ms)
[ RUN      ] GraphCopyTests.canPreserveInputs
[       OK ] GraphCopyTests.canPreserveInputs (0 ms)
[ RUN      ] GraphCopyTests.canPreserveOutputs
[       OK ] GraphCopyTests.canPreserveOutputs (0 ms)
[ RUN      ] GraphCopyTests.canPreserveAttributes
[       OK ] GraphCopyTests.canPreserveAttributes (0 ms)
[ RUN      ] GraphCopyTests.canPreserveGetData
[       OK ] GraphCopyTests.canPreserveGetData (1 ms)
[ RUN      ] GraphCopyTests.canPreserveTopology
[       OK ] GraphCopyTests.canPreserveTopology (0 ms)
[ RUN      ] GraphCopyTests.canQuantizeTopology
[       OK ] GraphCopyTests.canQuantizeTopology (0 ms)
[----------] 8 tests from GraphCopyTests (2 ms total)
[----------] 3 tests from CNNSpecificGraphCopyTests
[ RUN      ] CNNSpecificGraphCopyTests.copyNetworkWithClampLayer
[       OK ] CNNSpecificGraphCopyTests.copyNetworkWithClampLayer (0 ms)
[ RUN      ] CNNSpecificGraphCopyTests.copyPreprocess
[       OK ] CNNSpecificGraphCopyTests.copyPreprocess (0 ms)
[ RUN      ] CNNSpecificGraphCopyTests.copyNetworkWithDeconvolution
[       OK ] CNNSpecificGraphCopyTests.copyNetworkWithDeconvolution (0 ms)
[----------] 3 tests from CNNSpecificGraphCopyTests (1 ms total)
[----------] 33 tests from GraphToolsTest
[ RUN      ] GraphToolsTest.canRunSimpleDFS
[       OK ] GraphToolsTest.canRunSimpleDFS (0 ms)
[ RUN      ] GraphToolsTest.canRunCycleDFS
[       OK ] GraphToolsTest.canRunCycleDFS (0 ms)
[ RUN      ] GraphToolsTest.canRunBFS
[       OK ] GraphToolsTest.canRunBFS (0 ms)
[ RUN      ] GraphToolsTest.canRunNBFS
[       OK ] GraphToolsTest.canRunNBFS (0 ms)
[ RUN      ] GraphToolsTest.canSortTopologically
[       OK ] GraphToolsTest.canSortTopologically (0 ms)
[ RUN      ] GraphToolsTest.canDetectLoopsWhileSortTing
[       OK ] GraphToolsTest.canDetectLoopsWhileSortTing (0 ms)
[ RUN      ] GraphToolsTest.canSortIfInputsPointsToLayerWithMultiInputs
[       OK ] GraphToolsTest.canSortIfInputsPointsToLayerWithMultiInputs (0 ms)
[ RUN      ] GraphToolsTest.canGetAllMemoryInputsLayersFromStandardInputs
[       OK ] GraphToolsTest.canGetAllMemoryInputsLayersFromStandardInputs (1 ms)
[ RUN      ] GraphToolsTest.canGetSingleInputLayer
[       OK ] GraphToolsTest.canGetSingleInputLayer (0 ms)
[ RUN      ] GraphToolsTest.canIterateOverCNNNetwork
[       OK ] GraphToolsTest.canIterateOverCNNNetwork (0 ms)
[ RUN      ] GraphToolsTest.canIterateOverCNNNetworkWithCycle
[       OK ] GraphToolsTest.canIterateOverCNNNetworkWithCycle (0 ms)
[ RUN      ] GraphToolsTest.canCompareCNNNetworkIterators
[       OK ] GraphToolsTest.canCompareCNNNetworkIterators (0 ms)
[ RUN      ] GraphToolsTest.canIterateOverEmptyNetwork
[       OK ] GraphToolsTest.canIterateOverEmptyNetwork (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersThrowsForNullPointers
[       OK ] GraphToolsTest.CNNNetSwapLayersThrowsForNullPointers (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSwapWithItself
[       OK ] GraphToolsTest.CNNNetSwapLayersSwapWithItself (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSimpleCase_1
[       OK ] GraphToolsTest.CNNNetSwapLayersSimpleCase_1 (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSimpleCase_2
[       OK ] GraphToolsTest.CNNNetSwapLayersSimpleCase_2 (1 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSimpleCase_3
[       OK ] GraphToolsTest.CNNNetSwapLayersSimpleCase_3 (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersDoesSwapDims
[       OK ] GraphToolsTest.CNNNetSwapLayersDoesSwapDims (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSimpleCase_4
[       OK ] GraphToolsTest.CNNNetSwapLayersSimpleCase_4 (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSplit
[       OK ] GraphToolsTest.CNNNetSwapLayersSplit (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSplit_2
[       OK ] GraphToolsTest.CNNNetSwapLayersSplit_2 (1 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSplit_3
[       OK ] GraphToolsTest.CNNNetSwapLayersSplit_3 (0 ms)
[ RUN      ] GraphToolsTest.CNNNetSwapLayersSplit_4
[       OK ] GraphToolsTest.CNNNetSwapLayersSplit_4 (0 ms)
[ RUN      ] GraphToolsTest.CNNNetworkInsertLayerThrowsForNullPointers
[       OK ] GraphToolsTest.CNNNetworkInsertLayerThrowsForNullPointers (0 ms)
[ RUN      ] GraphToolsTest.CanNotInsertLayerIntoNonAdjiacendLayers
[       OK ] GraphToolsTest.CanNotInsertLayerIntoNonAdjiacendLayers (0 ms)
[ RUN      ] GraphToolsTest.CNNNetworkInsertLayerSimpleCase
[       OK ] GraphToolsTest.CNNNetworkInsertLayerSimpleCase (1 ms)
[ RUN      ] GraphToolsTest.CNNNetworkInsertLayerSimpleCaseWithMultipleOutputs
[       OK ] GraphToolsTest.CNNNetworkInsertLayerSimpleCaseWithMultipleOutputs (0 ms)
[ RUN      ] GraphToolsTest.CNNNetworkInsertLayerSimpleCaseWithMultipleInputs
[       OK ] GraphToolsTest.CNNNetworkInsertLayerSimpleCaseWithMultipleInputs (0 ms)
[ RUN      ] GraphToolsTest.CNNNetworkInsertAfterLastLayer
[       OK ] GraphToolsTest.CNNNetworkInsertAfterLastLayer (0 ms)
[ RUN      ] GraphToolsTest.CNNNetworkInsertAfterAll
[       OK ] GraphToolsTest.CNNNetworkInsertAfterAll (0 ms)
[ RUN      ] GraphToolsTest.CNNNetworkInsertAllAfterSplit
[       OK ] GraphToolsTest.CNNNetworkInsertAllAfterSplit (1 ms)
[ RUN      ] GraphToolsTest.CNNNetworkInsert1AfterSplit
[       OK ] GraphToolsTest.CNNNetworkInsert1AfterSplit (0 ms)
[----------] 33 tests from GraphToolsTest (5 ms total)
[----------] 4 tests from PreProcessTests
[ RUN      ] PreProcessTests.throwsOnSettingNullMeanImage
[       OK ] PreProcessTests.throwsOnSettingNullMeanImage (0 ms)
[ RUN      ] PreProcessTests.throwsOnSetting2DMeanImage
[       OK ] PreProcessTests.throwsOnSetting2DMeanImage (0 ms)
[ RUN      ] PreProcessTests.throwsOnSettingWrongSizeMeanImage
[       OK ] PreProcessTests.throwsOnSettingWrongSizeMeanImage (0 ms)
[ RUN      ] PreProcessTests.noThrowWithCorrectSizeMeanImage
[       OK ] PreProcessTests.noThrowWithCorrectSizeMeanImage (0 ms)
[----------] 4 tests from PreProcessTests (0 ms total)
[----------] 3 tests from PreallocatorTests
[ RUN      ] PreallocatorTests.canAccessPreAllocatedMemory
[       OK ] PreallocatorTests.canAccessPreAllocatedMemory (0 ms)
[ RUN      ] PreallocatorTests.canNotAllocateMoreMemory
[       OK ] PreallocatorTests.canNotAllocateMoreMemory (0 ms)
[ RUN      ] PreallocatorTests.canNotLockWrongHandle
[       OK ] PreallocatorTests.canNotLockWrongHandle (0 ms)
[----------] 3 tests from PreallocatorTests (0 ms total)
[----------] 7 tests from ResponseBufferTests
[ RUN      ] ResponseBufferTests.canCreateResponseMessage
[       OK ] ResponseBufferTests.canCreateResponseMessage (0 ms)
[ RUN      ] ResponseBufferTests.canReportError
[       OK ] ResponseBufferTests.canReportError (0 ms)
[ RUN      ] ResponseBufferTests.savePreviosMessage
[       OK ] ResponseBufferTests.savePreviosMessage (0 ms)
[ RUN      ] ResponseBufferTests.canHandleBigMessage
[       OK ] ResponseBufferTests.canHandleBigMessage (0 ms)
[ RUN      ] ResponseBufferTests.canHandleNotNullTerminatedInput
[       OK ] ResponseBufferTests.canHandleNotNullTerminatedInput (0 ms)
[ RUN      ] ResponseBufferTests.canHandlePredefined
[       OK ] ResponseBufferTests.canHandlePredefined (0 ms)
[ RUN      ] ResponseBufferTests.canHandleNotNullTerminatedPredefined
[       OK ] ResponseBufferTests.canHandleNotNullTerminatedPredefined (0 ms)
[----------] 7 tests from ResponseBufferTests (0 ms total)
[----------] 18 tests from ExceptionTests
[ RUN      ] ExceptionTests.canThrowUsingMacro
[       OK ] ExceptionTests.canThrowUsingMacro (0 ms)
[ RUN      ] ExceptionTests.canThrowScoringException
[       OK ] ExceptionTests.canThrowScoringException (0 ms)
[ RUN      ] ExceptionTests.canDefineExceptionContent
[       OK ] ExceptionTests.canDefineExceptionContent (0 ms)
[ RUN      ] ExceptionTests.exceptionShowsCorrectMessage
[       OK ] ExceptionTests.exceptionShowsCorrectMessage (0 ms)
[ RUN      ] ExceptionTests.exceptionCanBeCoughtAsStandard
[       OK ] ExceptionTests.exceptionCanBeCoughtAsStandard (0 ms)
[ RUN      ] ExceptionTests.canThrowStatusCode
[       OK ] ExceptionTests.canThrowStatusCode (0 ms)
[ RUN      ] ExceptionTests.handleOnlyFirstStatus
[       OK ] ExceptionTests.handleOnlyFirstStatus (0 ms)
[ RUN      ] ExceptionTests.ignoreNotStatusCodeEnumAfterManip
[       OK ] ExceptionTests.ignoreNotStatusCodeEnumAfterManip (0 ms)
[ RUN      ] ExceptionTests.canUseManipulatorStandalone
[       OK ] ExceptionTests.canUseManipulatorStandalone (0 ms)
[ RUN      ] ExceptionTests.statusCodeNotAppearInMessageAfterCatch
[       OK ] ExceptionTests.statusCodeNotAppearInMessageAfterCatch (0 ms)
[ RUN      ] ExceptionTests.statusCodeAppearInMessageAfterCatch
[       OK ] ExceptionTests.statusCodeAppearInMessageAfterCatch (0 ms)
[ RUN      ] ExceptionTests.canConvertToStatus
[       OK ] ExceptionTests.canConvertToStatus (0 ms)
[ RUN      ] ExceptionTests.canConvertStatusToException
[       OK ] ExceptionTests.canConvertStatusToException (0 ms)
[ RUN      ] ExceptionTests.throwAfterConvertStatusToClassContainMessage
[       OK ] ExceptionTests.throwAfterConvertStatusToClassContainMessage (0 ms)
[ RUN      ] ExceptionTests.exceptionWithAssertThrowsNothingIfTrue
[       OK ] ExceptionTests.exceptionWithAssertThrowsNothingIfTrue (0 ms)
[ RUN      ] ExceptionTests.exceptionWithAssertThrowsNothingIfExpressionTrue
[       OK ] ExceptionTests.exceptionWithAssertThrowsNothingIfExpressionTrue (0 ms)
[ RUN      ] ExceptionTests.exceptionWithAssertThrowsExceptionIfFalse
[       OK ] ExceptionTests.exceptionWithAssertThrowsExceptionIfFalse (0 ms)
[ RUN      ] ExceptionTests.exceptionWithAssertThrowsExceptionIfFalseExpession
[       OK ] ExceptionTests.exceptionWithAssertThrowsExceptionIfFalseExpession (0 ms)
[----------] 18 tests from ExceptionTests (1 ms total)
[----------] 6 tests from PluginTest
[ RUN      ] PluginTest.canCreatePlugin
[       OK ] PluginTest.canCreatePlugin (0 ms)
[ RUN      ] PluginTest.canCreatePluginUsingSmartPtr
[       OK ] PluginTest.canCreatePluginUsingSmartPtr (0 ms)
[ RUN      ] PluginTest.shouldThrowExceptionIfPluginNotExist
[       OK ] PluginTest.shouldThrowExceptionIfPluginNotExist (1 ms)
[ RUN      ] PluginTest.canCallErrorHandlerIfNecessary
[       OK ] PluginTest.canCallErrorHandlerIfNecessary (0 ms)
[ RUN      ] PluginTest.canForwardPluginEnginePtr
[       OK ] PluginTest.canForwardPluginEnginePtr (0 ms)
[ RUN      ] PluginTest.canSetConfiguration
[       OK ] PluginTest.canSetConfiguration (0 ms)
[----------] 6 tests from PluginTest (1 ms total)
[----------] 8 tests from PrecisionTests
[ RUN      ] PrecisionTests.ShowsCorrectPrecisionNames
[       OK ] PrecisionTests.ShowsCorrectPrecisionNames (0 ms)
[ RUN      ] PrecisionTests.sizeIsCorrect
[       OK ] PrecisionTests.sizeIsCorrect (0 ms)
[ RUN      ] PrecisionTests.is_float
[       OK ] PrecisionTests.is_float (0 ms)
[ RUN      ] PrecisionTests.constructFromSTR
[       OK ] PrecisionTests.constructFromSTR (0 ms)
[ RUN      ] PrecisionTests.canCompareCustomPrecisions
[       OK ] PrecisionTests.canCompareCustomPrecisions (0 ms)
[ RUN      ] PrecisionTests.canUseInIfs
[       OK ] PrecisionTests.canUseInIfs (0 ms)
[ RUN      ] PrecisionTests.canCreateFromStruct
[       OK ] PrecisionTests.canCreateFromStruct (0 ms)
[ RUN      ] PrecisionTests.canCreateMoreThan255bitsPrecisions
[       OK ] PrecisionTests.canCreateMoreThan255bitsPrecisions (0 ms)
[----------] 8 tests from PrecisionTests (0 ms total)
[----------] 1 test from SoPointerTests
[ RUN      ] SoPointerTests.assignObjThenLoader
[       OK ] SoPointerTests.assignObjThenLoader (0 ms)
[----------] 1 test from SoPointerTests (0 ms total)
[----------] 12 tests from BlobProxyTests
[ RUN      ] BlobProxyTests.convertByteBlobToFloat
[       OK ] BlobProxyTests.convertByteBlobToFloat (0 ms)
[ RUN      ] BlobProxyTests.shouldNotDeAllocate
[       OK ] BlobProxyTests.shouldNotDeAllocate (0 ms)
[ RUN      ] BlobProxyTests.canAccessProxyBlobUsingBaseMethod
[       OK ] BlobProxyTests.canAccessProxyBlobUsingBaseMethod (1 ms)
[ RUN      ] BlobProxyTests.canAccessProxyBlobUsingHelpers
[       OK ] BlobProxyTests.canAccessProxyBlobUsingHelpers (0 ms)
[ RUN      ] BlobProxyTests.canCreateProxyBlobFromDifferentBaseBlobType
[       OK ] BlobProxyTests.canCreateProxyBlobFromDifferentBaseBlobType (0 ms)
[ RUN      ] BlobProxyTests.canNotCreateBlobWithOffsetOfSizeOutOfOriginal
[       OK ] BlobProxyTests.canNotCreateBlobWithOffsetOfSizeOutOfOriginal (0 ms)
[ RUN      ] BlobProxyTests.canAccessBothArraysAfterProxying
[       OK ] BlobProxyTests.canAccessBothArraysAfterProxying (0 ms)
[ RUN      ] BlobProxyTests.convertTwoByteBlobToFloat
[       OK ] BlobProxyTests.convertTwoByteBlobToFloat (0 ms)
[ RUN      ] BlobProxyTests.throwsIfSmallProxyObjectSize
[       OK ] BlobProxyTests.throwsIfSmallProxyObjectSize (0 ms)
[ RUN      ] BlobProxyTests.canReturnConstantData
[       OK ] BlobProxyTests.canReturnConstantData (0 ms)
[ RUN      ] BlobProxyTests.canIterateOverData
[       OK ] BlobProxyTests.canIterateOverData (0 ms)
[ RUN      ] BlobProxyTests.canIterateOverReadOnly
[       OK ] BlobProxyTests.canIterateOverReadOnly (0 ms)
[----------] 12 tests from BlobProxyTests (1 ms total)
[----------] 14 tests from DataTests
[ RUN      ] DataTests.canSetEmptyDimsForDataDefault
[       OK ] DataTests.canSetEmptyDimsForDataDefault (0 ms)
[ RUN      ] DataTests.canSetEmptyDimsForDataBlocked
[       OK ] DataTests.canSetEmptyDimsForDataBlocked (0 ms)
[ RUN      ] DataTests.canSetNotEmptyDimsForDataBlocked
[       OK ] DataTests.canSetNotEmptyDimsForDataBlocked (0 ms)
[ RUN      ] DataTests.canSetNotEmptyDimsForDataNCHW
[       OK ] DataTests.canSetNotEmptyDimsForDataNCHW (0 ms)
[ RUN      ] DataTests.canSetEmptyDimsForTensorDescNCHW
[       OK ] DataTests.canSetEmptyDimsForTensorDescNCHW (0 ms)
[ RUN      ] DataTests.canSetEmptyDimsForTensorDescBlocked
[       OK ] DataTests.canSetEmptyDimsForTensorDescBlocked (0 ms)
[ RUN      ] DataTests.canSetNotEmptyDimsForTensorDescBlocked
[       OK ] DataTests.canSetNotEmptyDimsForTensorDescBlocked (0 ms)
[ RUN      ] DataTests.canSetEmptyDimsForBlockingDescOrder
[       OK ] DataTests.canSetEmptyDimsForBlockingDescOrder (0 ms)
[ RUN      ] DataTests.throwOnFillDescByEmptyDimsForBlockingDesc
[       OK ] DataTests.throwOnFillDescByEmptyDimsForBlockingDesc (0 ms)
[ RUN      ] DataTests.throwOnSetEmptyDimsForBlockingDescBlocked
[       OK ] DataTests.throwOnSetEmptyDimsForBlockingDescBlocked (0 ms)
[ RUN      ] DataTests.throwOnSetEmptyDimsForBlockingDescNCHW
[       OK ] DataTests.throwOnSetEmptyDimsForBlockingDescNCHW (0 ms)
[ RUN      ] DataTests.canSetNotEmptyDimsForBlockingDescBlocked
[       OK ] DataTests.canSetNotEmptyDimsForBlockingDescBlocked (0 ms)
[ RUN      ] DataTests.canSetNotEmptyDimsForBlockingDescNCHW
[       OK ] DataTests.canSetNotEmptyDimsForBlockingDescNCHW (0 ms)
[ RUN      ] DataTests.setPrecision
[       OK ] DataTests.setPrecision (0 ms)
[----------] 14 tests from DataTests (0 ms total)
[----------] 2 tests from SystemAllocatorTests
[ RUN      ] SystemAllocatorTests.canAllocate
[       OK ] SystemAllocatorTests.canAllocate (0 ms)
[ RUN      ] SystemAllocatorTests.canLockAllocatedMemory
[       OK ] SystemAllocatorTests.canLockAllocatedMemory (0 ms)
[----------] 2 tests from SystemAllocatorTests (0 ms total)
[----------] 5 tests from CaselessTests
[ RUN      ] CaselessTests.emptyAreEqual
[       OK ] CaselessTests.emptyAreEqual (0 ms)
[ RUN      ] CaselessTests.canIgnoreCase
[       OK ] CaselessTests.canIgnoreCase (0 ms)
[ RUN      ] CaselessTests.emptyIsNotEqualNotEmpty
[       OK ] CaselessTests.emptyIsNotEqualNotEmpty (0 ms)
[ RUN      ] CaselessTests.canFindCaslessInMap
[       OK ] CaselessTests.canFindCaslessInMap (0 ms)
[ RUN      ] CaselessTests.canFindCaslessInUnordered
[       OK ] CaselessTests.canFindCaslessInUnordered (0 ms)
[----------] 5 tests from CaselessTests (0 ms total)
[----------] 6 tests from TensorDescTests
[ RUN      ] TensorDescTests.CreateBlobWithIncorrectLayout
[       OK ] TensorDescTests.CreateBlobWithIncorrectLayout (0 ms)
[ RUN      ] TensorDescTests.CreateEmptyBlob
[       OK ] TensorDescTests.CreateEmptyBlob (0 ms)
[ RUN      ] TensorDescTests.CreateBlockedBlobNCHW
[       OK ] TensorDescTests.CreateBlockedBlobNCHW (0 ms)
[ RUN      ] TensorDescTests.CreateBlockedBlobNCDHW
[       OK ] TensorDescTests.CreateBlockedBlobNCDHW (0 ms)
[ RUN      ] TensorDescTests.CompareNHWCandNCHWLayouts
[       OK ] TensorDescTests.CompareNHWCandNCHWLayouts (0 ms)
[ RUN      ] TensorDescTests.CompareNDHWCandNCDHWLayouts
[       OK ] TensorDescTests.CompareNDHWCandNCDHWLayouts (0 ms)
[----------] 6 tests from TensorDescTests (0 ms total)
[----------] 15 tests from UtilTests
[ RUN      ] UtilTests.contains
[       OK ] UtilTests.contains (0 ms)
[ RUN      ] UtilTests.groupSubraphsEmpty
[       OK ] UtilTests.groupSubraphsEmpty (0 ms)
[ RUN      ] UtilTests.groupSubraphsNoSplit
[       OK ] UtilTests.groupSubraphsNoSplit (1 ms)
[ RUN      ] UtilTests.groupSubraphsAlwaysSplit
[       OK ] UtilTests.groupSubraphsAlwaysSplit (0 ms)
[ RUN      ] UtilTests.groupSubraphsUnconnectedSubgraphs
[       OK ] UtilTests.groupSubraphsUnconnectedSubgraphs (0 ms)
[ RUN      ] UtilTests.groupSubraphsLinear
[       OK ] UtilTests.groupSubraphsLinear (0 ms)
[ RUN      ] UtilTests.groupSubraphsDeadBranch
[       OK ] UtilTests.groupSubraphsDeadBranch (0 ms)
[ RUN      ] UtilTests.cloneData
[       OK ] UtilTests.cloneData (0 ms)
[ RUN      ] UtilTests.cloneLayers
[       OK ] UtilTests.cloneLayers (0 ms)
[ RUN      ] UtilTests.cloneNet
[       OK ] UtilTests.cloneNet (0 ms)
[ RUN      ] UtilTests.cloneNet_input
[       OK ] UtilTests.cloneNet_input (0 ms)
[ RUN      ] UtilTests.cloneNet_const
[       OK ] UtilTests.cloneNet_const (0 ms)
[ RUN      ] UtilTests.getRootDataObjects
[       OK ] UtilTests.getRootDataObjects (1 ms)
[ RUN      ] UtilTests.networkComplexity
[       OK ] UtilTests.networkComplexity (2 ms)
[ RUN      ] UtilTests.replaceLayerWithNewLayer
[       OK ] UtilTests.replaceLayerWithNewLayer (0 ms)
[----------] 15 tests from UtilTests (4 ms total)
[----------] 3 tests from RangeIteratorTests
[ RUN      ] RangeIteratorTests.canCompareSameStringsInsensitive
[       OK ] RangeIteratorTests.canCompareSameStringsInsensitive (0 ms)
[ RUN      ] RangeIteratorTests.canCompareNotSameStringsInsensitive
[       OK ] RangeIteratorTests.canCompareNotSameStringsInsensitive (0 ms)
[ RUN      ] RangeIteratorTests.cannotDereferenceEndIterator
[       OK ] RangeIteratorTests.cannotDereferenceEndIterator (0 ms)
[----------] 3 tests from RangeIteratorTests (0 ms total)
[----------] 5 tests from SharedObjectLoaderTests
[ RUN      ] SharedObjectLoaderTests.canLoadExistedPlugin
MEM_USAGE=56728KB
[       OK ] SharedObjectLoaderTests.canLoadExistedPlugin (0 ms)
[ RUN      ] SharedObjectLoaderTests.loaderThrowsIfNoPlugin
MEM_USAGE=56728KB
[       OK ] SharedObjectLoaderTests.loaderThrowsIfNoPlugin (1 ms)
[ RUN      ] SharedObjectLoaderTests.canFindExistedMethod
MEM_USAGE=56728KB
[       OK ] SharedObjectLoaderTests.canFindExistedMethod (0 ms)
[ RUN      ] SharedObjectLoaderTests.throwIfMethodNofFoundInLibrary
MEM_USAGE=56728KB
[       OK ] SharedObjectLoaderTests.throwIfMethodNofFoundInLibrary (0 ms)
[ RUN      ] SharedObjectLoaderTests.canCallExistedMethod
MEM_USAGE=56728KB
[       OK ] SharedObjectLoaderTests.canCallExistedMethod (0 ms)
[----------] 5 tests from SharedObjectLoaderTests (1 ms total)
[----------] 30 tests from LayersTests
[ RUN      ] LayersTests.canCreateLayersWithDefaultParams
[       OK ] LayersTests.canCreateLayersWithDefaultParams (0 ms)
[ RUN      ] LayersTests.throwsOnExpiredDataPtr
[       OK ] LayersTests.throwsOnExpiredDataPtr (0 ms)
[ RUN      ] LayersTests.copyConvolution
[       OK ] LayersTests.copyConvolution (0 ms)
[ RUN      ] LayersTests.copyDeconvolution
[       OK ] LayersTests.copyDeconvolution (0 ms)
[ RUN      ] LayersTests.copyPooling
[       OK ] LayersTests.copyPooling (0 ms)
[ RUN      ] LayersTests.canNotInserOutOfBounds
[       OK ] LayersTests.canNotInserOutOfBounds (0 ms)
[ RUN      ] LayersTests.canInsertIntoExistedAxis
[       OK ] LayersTests.canInsertIntoExistedAxis (1 ms)
[ RUN      ] LayersTests.canRemoveProperty
[       OK ] LayersTests.canRemoveProperty (0 ms)
[ RUN      ] LayersTests.cannotRemovePropertyOutOfRange
[       OK ] LayersTests.cannotRemovePropertyOutOfRange (0 ms)
[ RUN      ] LayersTests.convIRv2BackwardCompatibility
[       OK ] LayersTests.convIRv2BackwardCompatibility (0 ms)
[ RUN      ] LayersTests.deconvIRv2BackwardCompatibility
[       OK ] LayersTests.deconvIRv2BackwardCompatibility (0 ms)
[ RUN      ] LayersTests.poolIRv2BackwardCompatibility
[       OK ] LayersTests.poolIRv2BackwardCompatibility (0 ms)
[ RUN      ] LayersTests.canGetPadBeginForConvolution
[       OK ] LayersTests.canGetPadBeginForConvolution (0 ms)
[ RUN      ] LayersTests.canGetPadEndForConvolution
[       OK ] LayersTests.canGetPadEndForConvolution (0 ms)
[ RUN      ] LayersTests.canGetPad3DBeginForConvolution
[       OK ] LayersTests.canGetPad3DBeginForConvolution (0 ms)
[ RUN      ] LayersTests.canGetPad3DEndForConvolution
[       OK ] LayersTests.canGetPad3DEndForConvolution (0 ms)
[ RUN      ] LayersTests.returnDefaultPadForEmptyConvolution
[       OK ] LayersTests.returnDefaultPadForEmptyConvolution (0 ms)
[ RUN      ] LayersTests.returnEmptyPadForValidPadConvolution
[       OK ] LayersTests.returnEmptyPadForValidPadConvolution (0 ms)
[ RUN      ] LayersTests.throwOnSamePadForEmptyConvolution
[       OK ] LayersTests.throwOnSamePadForEmptyConvolution (0 ms)
[ RUN      ] LayersTests.throwOnInvalidDimsSamePadForConvolution
[       OK ] LayersTests.throwOnInvalidDimsSamePadForConvolution (0 ms)
[ RUN      ] LayersTests.throwOn2DSamePadForConvolution
[       OK ] LayersTests.throwOn2DSamePadForConvolution (0 ms)
[ RUN      ] LayersTests.throwWithNotEnoughParamsSamePadForConvolution
[       OK ] LayersTests.throwWithNotEnoughParamsSamePadForConvolution (0 ms)
[ RUN      ] LayersTests.canGetSamePadForConvolutionEvenInput
[       OK ] LayersTests.canGetSamePadForConvolutionEvenInput (0 ms)
[ RUN      ] LayersTests.canGetSamePadForConvolutionEvenInput3D
[       OK ] LayersTests.canGetSamePadForConvolutionEvenInput3D (0 ms)
[ RUN      ] LayersTests.canGetSamePadForConvolutionOddInput
[       OK ] LayersTests.canGetSamePadForConvolutionOddInput (0 ms)
[ RUN      ] LayersTests.canGetSamePadForDeConvolutionEvenInput
[       OK ] LayersTests.canGetSamePadForDeConvolutionEvenInput (0 ms)
[ RUN      ] LayersTests.canGetSamePadForDeConvolutionOddInput
[       OK ] LayersTests.canGetSamePadForDeConvolutionOddInput (0 ms)
[ RUN      ] LayersTests.canGetSamePadForPoolingEvenInput
[       OK ] LayersTests.canGetSamePadForPoolingEvenInput (0 ms)
[ RUN      ] LayersTests.canGetSamePadForPoolingOddInput
[       OK ] LayersTests.canGetSamePadForPoolingOddInput (0 ms)
[ RUN      ] LayersTests.cannotGetPadForUnsupportedLayer
[       OK ] LayersTests.cannotGetPadForUnsupportedLayer (0 ms)
[----------] 30 tests from LayersTests (1 ms total)
[----------] 3 tests from LockedMemoryTest
[ RUN      ] LockedMemoryTest.canUnlockMemoryAfterUsage
MEM_USAGE=56728KB
[       OK ] LockedMemoryTest.canUnlockMemoryAfterUsage (0 ms)
[ RUN      ] LockedMemoryTest.canReadFromLockedMemory
MEM_USAGE=56728KB
[       OK ] LockedMemoryTest.canReadFromLockedMemory (0 ms)
[ RUN      ] LockedMemoryTest.canWriteToLockedMemory
MEM_USAGE=56728KB
[       OK ] LockedMemoryTest.canWriteToLockedMemory (0 ms)
[----------] 3 tests from LockedMemoryTest (0 ms total)
[----------] 30 tests from BlobTests
[ RUN      ] BlobTests.canCreateBlobUsingDefaultAllocator
[       OK ] BlobTests.canCreateBlobUsingDefaultAllocator (1 ms)
[ RUN      ] BlobTests.secondAllocateWontMemLeak
[       OK ] BlobTests.secondAllocateWontMemLeak (0 ms)
[ RUN      ] BlobTests.doesNotUnlockIfLockFailed
[       OK ] BlobTests.doesNotUnlockIfLockFailed (0 ms)
[ RUN      ] BlobTests.canAccessDataUsingAllocator
[       OK ] BlobTests.canAccessDataUsingAllocator (0 ms)
[ RUN      ] BlobTests.canLockReadOnlyDataForRead
[       OK ] BlobTests.canLockReadOnlyDataForRead (0 ms)
[ RUN      ] BlobTests.canAccessDataUsingBufferBaseMethod
[       OK ] BlobTests.canAccessDataUsingBufferBaseMethod (0 ms)
[ RUN      ] BlobTests.canMoveFromTBlobWithSameType
[       OK ] BlobTests.canMoveFromTBlobWithSameType (0 ms)
[ RUN      ] BlobTests.saveDimsAndSizeAfterMove
[       OK ] BlobTests.saveDimsAndSizeAfterMove (0 ms)
[ RUN      ] BlobTests.canSetAfterFree
[       OK ] BlobTests.canSetAfterFree (0 ms)
[ RUN      ] BlobTests.canSetAfterFreeNonAllocated
[       OK ] BlobTests.canSetAfterFreeNonAllocated (0 ms)
[ RUN      ] BlobTests.canCopyBlob
[       OK ] BlobTests.canCopyBlob (0 ms)
[ RUN      ] BlobTests.canCompareToNullPtrWithoutDereferencing
[       OK ] BlobTests.canCompareToNullPtrWithoutDereferencing (0 ms)
[       OK ] BlobTests.canCreateBlob (0 ms)
[ RUN      ] BlobTests.canAllocateBlob
[       OK ] BlobTests.canAllocateBlob (0 ms)
[ RUN      ] BlobTests.canDeallocateBlob
[       OK ] BlobTests.canDeallocateBlob (0 ms)
[ RUN      ] BlobTests.canCreateBlobWithoutDims
[       OK ] BlobTests.canCreateBlobWithoutDims (0 ms)
[ RUN      ] BlobTests.canSetToBlobWithoutDims
[       OK ] BlobTests.canSetToBlobWithoutDims (0 ms)
[ RUN      ] BlobTests.canReadDataFromConstBlob
[       OK ] BlobTests.canReadDataFromConstBlob (0 ms)
[ RUN      ] BlobTests.canMakeSharedBlob
[       OK ] BlobTests.canMakeSharedBlob (0 ms)
[ RUN      ] BlobTests.canUseBlobInMoveSemantics
[       OK ] BlobTests.canUseBlobInMoveSemantics (0 ms)
[ RUN      ] BlobTests.canCreateBlobOnExistedMemory
[       OK ] BlobTests.canCreateBlobOnExistedMemory (0 ms)
[ RUN      ] BlobTests.preAllocatorWillnotWorkIfPtrNotAlocated
[       OK ] BlobTests.preAllocatorWillnotWorkIfPtrNotAlocated (0 ms)
[ RUN      ] BlobTests.cannotIncreaseSizeOfPreallocated
[       OK ] BlobTests.cannotIncreaseSizeOfPreallocated (0 ms)
[ RUN      ] BlobTests.canAcceptpreallocatedSize
[       OK ] BlobTests.canAcceptpreallocatedSize (0 ms)
[ RUN      ] BlobTests.ifBlobCannotReleaseItWillReuseOldMemory
[       OK ] BlobTests.ifBlobCannotReleaseItWillReuseOldMemory (0 ms)
[ RUN      ] BlobTests.ifBlobCannotReleaseItWillReuseOldMemoryOnlyIfAllocated
[       OK ] BlobTests.ifBlobCannotReleaseItWillReuseOldMemoryOnlyIfAllocated (0 ms)
[ RUN      ] BlobTests.canModifyDataInRangedFor
[       OK ] BlobTests.canModifyDataInRangedFor (0 ms)
[ RUN      ] BlobTests.makeRoiBlobNchw
[       OK ] BlobTests.makeRoiBlobNchw (0 ms)
[ RUN      ] BlobTests.makeRoiBlobNhwc
[       OK ] BlobTests.makeRoiBlobNhwc (0 ms)
[ RUN      ] BlobTests.makeRoiBlobWrongSize
[       OK ] BlobTests.makeRoiBlobWrongSize (0 ms)
[----------] 30 tests from BlobTests (1 ms total)
[----------] 1 test from PointerTests
[ RUN      ] PointerTests.InferenceEnginePtrStoresValues
[       OK ] PointerTests.InferenceEnginePtrStoresValues (0 ms)
[----------] 1 test from PointerTests (0 ms total)
[----------] 5 tests from DeviceTests
[ RUN      ] DeviceTests.internalFindThrowsOnBadDevice
[       OK ] DeviceTests.internalFindThrowsOnBadDevice (1 ms)
[ RUN      ] DeviceTests.externalFindReturnsErrorStatus
[       OK ] DeviceTests.externalFindReturnsErrorStatus (0 ms)
[ RUN      ] DeviceTests.externalFindPopulatesResult
[       OK ] DeviceTests.externalFindPopulatesResult (0 ms)
[ RUN      ] DeviceTests.internalFindReturnsResponse
[       OK ] DeviceTests.internalFindReturnsResponse (0 ms)
[ RUN      ] DeviceTests.returnsProperDeviceName
[       OK ] DeviceTests.returnsProperDeviceName (0 ms)
[----------] 5 tests from DeviceTests (1 ms total)
[----------] 1 test from CNNNetworkTests
[ RUN      ] CNNNetworkTests.throwsOnInitWithNull
[       OK ] CNNNetworkTests.throwsOnInitWithNull (0 ms)
[----------] 1 test from CNNNetworkTests (0 ms total)
[----------] 9 tests from LayerTransformTest
[ RUN      ] LayerTransformTest.canInjectIntoConvolutionLayer
[       OK ] LayerTransformTest.canInjectIntoConvolutionLayer (0 ms)
[ RUN      ] LayerTransformTest.canInjectValue
[       OK ] LayerTransformTest.canInjectValue (0 ms)
[ RUN      ] LayerTransformTest.canAccessInjectedValue
[       OK ] LayerTransformTest.canAccessInjectedValue (0 ms)
[ RUN      ] LayerTransformTest.returnNullIfNotInjected
[       OK ] LayerTransformTest.returnNullIfNotInjected (0 ms)
[ RUN      ] LayerTransformTest.canInjectStruct
[       OK ] LayerTransformTest.canInjectStruct (0 ms)
[ RUN      ] LayerTransformTest.injectioWillCopyOutData
[       OK ] LayerTransformTest.injectioWillCopyOutData (0 ms)
[ RUN      ] LayerTransformTest.injectioWillCopyInputData
[       OK ] LayerTransformTest.injectioWillCopyInputData (0 ms)
[ RUN      ] LayerTransformTest.transformWillOnlyTransformOnce
[       OK ] LayerTransformTest.transformWillOnlyTransformOnce (0 ms)
[ RUN      ] LayerTransformTest.transformCanGoToParentIfChildTransformNotImplemented
[       OK ] LayerTransformTest.transformCanGoToParentIfChildTransformNotImplemented (0 ms)
[----------] 9 tests from LayerTransformTest (0 ms total)
[----------] 2 tests from DebugTests
[ RUN      ] DebugTests.tolowerWorksWithEmptyString
[       OK ] DebugTests.tolowerWorksWithEmptyString (0 ms)
[ RUN      ] DebugTests.shouldConvertToLowerCase
[       OK ] DebugTests.shouldConvertToLowerCase (0 ms)
[----------] 2 tests from DebugTests (0 ms total)
[----------] 6 tests from InferenceEngineTests
[ RUN      ] InferenceEngineTests.checkZeroInput
[       OK ] InferenceEngineTests.checkZeroInput (0 ms)
[ RUN      ] InferenceEngineTests.testInsertSort
[       OK ] InferenceEngineTests.testInsertSort (0 ms)
[ RUN      ] InferenceEngineTests.testInsertSortOverDraft
[       OK ] InferenceEngineTests.testInsertSortOverDraft (0 ms)
[ RUN      ] InferenceEngineTests.testThrowsOnCopyToBadBlob
[       OK ] InferenceEngineTests.testThrowsOnCopyToBadBlob (0 ms)
[ RUN      ] InferenceEngineTests.testThrowsOnCopyToBlobWithBadSize
[       OK ] InferenceEngineTests.testThrowsOnCopyToBlobWithBadSize (0 ms)
[ RUN      ] InferenceEngineTests.canCopyToProperBlob
[       OK ] InferenceEngineTests.canCopyToProperBlob (0 ms)
[----------] 6 tests from InferenceEngineTests (0 ms total)
[----------] 5 tests from PluginDispatcherTests
[ RUN      ] PluginDispatcherTests.canLoadMockPlugin
[       OK ] PluginDispatcherTests.canLoadMockPlugin (0 ms)
[ RUN      ] PluginDispatcherTests.throwsOnUnknownPlugin
[       OK ] PluginDispatcherTests.throwsOnUnknownPlugin (1 ms)
[ RUN      ] PluginDispatcherTests.throwsOnDeviceWithoutPlugins
[       OK ] PluginDispatcherTests.throwsOnDeviceWithoutPlugins (0 ms)
[ RUN      ] PluginDispatcherTests.triesToLoadEveryPluginSuitableForDevice
[       OK ] PluginDispatcherTests.triesToLoadEveryPluginSuitableForDevice (0 ms)
[ RUN      ] PluginDispatcherTests.returnsIfLoadSuccessfull
[       OK ] PluginDispatcherTests.returnsIfLoadSuccessfull (0 ms)
[----------] 5 tests from PluginDispatcherTests (1 ms total)
[----------] 11 tests from CallbackManagerTests
[ RUN      ] CallbackManagerTests.disabledByDefault
[       OK ] CallbackManagerTests.disabledByDefault (0 ms)
[ RUN      ] CallbackManagerTests.disabledIfCallbackNotSet
[       OK ] CallbackManagerTests.disabledIfCallbackNotSet (0 ms)
[ RUN      ] CallbackManagerTests.canStartTask
[       OK ] CallbackManagerTests.canStartTask (0 ms)
[ RUN      ] CallbackManagerTests.canSetCallback
[       OK ] CallbackManagerTests.canSetCallback (0 ms)
[ RUN      ] CallbackManagerTests.failToRunForEmptyRequest
[       OK ] CallbackManagerTests.failToRunForEmptyRequest (0 ms)
[ RUN      ] CallbackManagerTests.callbackIsNotCalledIfWasNotSet
[       OK ] CallbackManagerTests.callbackIsNotCalledIfWasNotSet (0 ms)
[ RUN      ] CallbackManagerTests.canRunCallback
[       OK ] CallbackManagerTests.canRunCallback (0 ms)
[ RUN      ] CallbackManagerTests.canDisableCallback
[       OK ] CallbackManagerTests.canDisableCallback (0 ms)
[ RUN      ] CallbackManagerTests.canSetException
[       OK ] CallbackManagerTests.canSetException (0 ms)
[ RUN      ] CallbackManagerTests.canSetStatus
[       OK ] CallbackManagerTests.canSetStatus (0 ms)
[ RUN      ] CallbackManagerTests.initResetStatusAndException
[       OK ] CallbackManagerTests.initResetStatusAndException (0 ms)
[----------] 11 tests from CallbackManagerTests (0 ms total)
[----------] 19 tests from PluginBaseTests
[ RUN      ] PluginBaseTests.canReportVersion
[       OK ] PluginBaseTests.canReportVersion (0 ms)
[ RUN      ] PluginBaseTests.canForwardLoadNetwork
[       OK ] PluginBaseTests.canForwardLoadNetwork (0 ms)
[ RUN      ] PluginBaseTests.canReportErrorInLoadNetwork
[       OK ] PluginBaseTests.canReportErrorInLoadNetwork (0 ms)
[ RUN      ] PluginBaseTests.canCatchUnknownErrorInLoadNetwork
[       OK ] PluginBaseTests.canCatchUnknownErrorInLoadNetwork (0 ms)
[ RUN      ] PluginBaseTests.canForwardLoadExeNetwork
[       OK ] PluginBaseTests.canForwardLoadExeNetwork (0 ms)
[ RUN      ] PluginBaseTests.canReportErrorInLoadExeNetwork
[       OK ] PluginBaseTests.canReportErrorInLoadExeNetwork (1 ms)
[ RUN      ] PluginBaseTests.canCatchUnknownErrorInLoadExeNetwork
[       OK ] PluginBaseTests.canCatchUnknownErrorInLoadExeNetwork (0 ms)
[ RUN      ] PluginBaseTests.canForwarInfer
[       OK ] PluginBaseTests.canForwarInfer (0 ms)
[ RUN      ] PluginBaseTests.canReportErrorInInfer
[       OK ] PluginBaseTests.canReportErrorInInfer (0 ms)
[ RUN      ] PluginBaseTests.canCatchUnknownErrorInInfer
[       OK ] PluginBaseTests.canCatchUnknownErrorInInfer (0 ms)
[ RUN      ] PluginBaseTests.canForwarBlobMapInfer
[       OK ] PluginBaseTests.canForwarBlobMapInfer (0 ms)
[ RUN      ] PluginBaseTests.canReportErrorInBlobMapInfer
[       OK ] PluginBaseTests.canReportErrorInBlobMapInfer (0 ms)
[ RUN      ] PluginBaseTests.canCatchUnknownErrorInBlobMapInfer
[       OK ] PluginBaseTests.canCatchUnknownErrorInBlobMapInfer (0 ms)
[ RUN      ] PluginBaseTests.canForwarGetPerformanceCounts
[       OK ] PluginBaseTests.canForwarGetPerformanceCounts (0 ms)
[ RUN      ] PluginBaseTests.canReportErrorInGetPerformanceCounts
[       OK ] PluginBaseTests.canReportErrorInGetPerformanceCounts (0 ms)
[ RUN      ] PluginBaseTests.canCatchUnknownErrorInGetPerformanceCounts
[       OK ] PluginBaseTests.canCatchUnknownErrorInGetPerformanceCounts (0 ms)
[ RUN      ] PluginBaseTests.canForwarSetConfig
[       OK ] PluginBaseTests.canForwarSetConfig (0 ms)
[ RUN      ] PluginBaseTests.canReportErrorInSetConfig
[       OK ] PluginBaseTests.canReportErrorInSetConfig (0 ms)
[ RUN      ] PluginBaseTests.canCatchUnknownErrorInSetConfig
[       OK ] PluginBaseTests.canCatchUnknownErrorInSetConfig (0 ms)
[----------] 19 tests from PluginBaseTests (1 ms total)
[----------] 3 tests from TaskTests
[ RUN      ] TaskTests.canRunWithTaskSync
[       OK ] TaskTests.canRunWithTaskSync (0 ms)
[ RUN      ] TaskTests.canRunWithTaskSyncAndWait
[       OK ] TaskTests.canRunWithTaskSyncAndWait (0 ms)
[ RUN      ] TaskTests.canSyncNThreadsUsingTaskSync
[       OK ] TaskTests.canSyncNThreadsUsingTaskSync (1 ms)
[----------] 3 tests from TaskTests (1 ms total)
[----------] 3 tests from ExecutableNetworkThreadSafeTests
[ RUN      ] ExecutableNetworkThreadSafeTests.createInferRequestCallsThreadSafeImplAndSetNetworkIO
[       OK ] ExecutableNetworkThreadSafeTests.createInferRequestCallsThreadSafeImplAndSetNetworkIO (0 ms)
[ RUN      ] ExecutableNetworkThreadSafeTests.returnErrorIfInferThrowsException
[       OK ] ExecutableNetworkThreadSafeTests.returnErrorIfInferThrowsException (1 ms)
[ RUN      ] ExecutableNetworkThreadSafeTests.returnErrorIfStartAsyncThrowsException
[       OK ] ExecutableNetworkThreadSafeTests.returnErrorIfStartAsyncThrowsException (0 ms)
[----------] 3 tests from ExecutableNetworkThreadSafeTests (1 ms total)
[----------] 21 tests from InferRequestTests
[ RUN      ] InferRequestTests.canForwardStartAsync
[       OK ] InferRequestTests.canForwardStartAsync (1 ms)
[ RUN      ] InferRequestTests.throwsIfStartAsyncReturnNotOK
[       OK ] InferRequestTests.throwsIfStartAsyncReturnNotOK (0 ms)
[ RUN      ] InferRequestTests.canForwardWait
[       OK ] InferRequestTests.canForwardWait (0 ms)
[ RUN      ] InferRequestTests.canForwardStatusFromWait
[       OK ] InferRequestTests.canForwardStatusFromWait (0 ms)
[ RUN      ] InferRequestTests.canForwardInfer
[       OK ] InferRequestTests.canForwardInfer (0 ms)
[ RUN      ] InferRequestTests.throwsIfInferReturnNotOK
[       OK ] InferRequestTests.throwsIfInferReturnNotOK (0 ms)
[ RUN      ] InferRequestTests.canForwardGetPerformanceCounts
[       OK ] InferRequestTests.canForwardGetPerformanceCounts (0 ms)
[ RUN      ] InferRequestTests.throwsIfGetPerformanceCountsReturnNotOK
[       OK ] InferRequestTests.throwsIfGetPerformanceCountsReturnNotOK (0 ms)
[ RUN      ] InferRequestTests.getInputCallsSetBlob
[       OK ] InferRequestTests.getInputCallsSetBlob (0 ms)
[ RUN      ] InferRequestTests.throwsIfSetInputReturnNotOK
[       OK ] InferRequestTests.throwsIfSetInputReturnNotOK (0 ms)
[ RUN      ] InferRequestTests.getOutputCallsSetBlob
[       OK ] InferRequestTests.getOutputCallsSetBlob (0 ms)
[ RUN      ] InferRequestTests.canForwardGetBlob
[       OK ] InferRequestTests.canForwardGetBlob (0 ms)
[ RUN      ] InferRequestTests.throwsIfGetBlobReturnNotOK
[       OK ] InferRequestTests.throwsIfGetBlobReturnNotOK (0 ms)
[ RUN      ] InferRequestTests.canForwardSetBlob
[       OK ] InferRequestTests.canForwardSetBlob (0 ms)
[ RUN      ] InferRequestTests.throwsIfSetBlobReturnNotOK
[       OK ] InferRequestTests.throwsIfSetBlobReturnNotOK (0 ms)
[ RUN      ] InferRequestTests.throwsIfSetOutputReturnNotOK
[       OK ] InferRequestTests.throwsIfSetOutputReturnNotOK (0 ms)
[ RUN      ] InferRequestTests.canForwardCompletionCallback
[       OK ] InferRequestTests.canForwardCompletionCallback (0 ms)
[ RUN      ] InferRequestTests.canForwardAnyCallback
[       OK ] InferRequestTests.canForwardAnyCallback (0 ms)
[ RUN      ] InferRequestTests.failToSetInputWithInCorrectName
[       OK ] InferRequestTests.failToSetInputWithInCorrectName (0 ms)
[ RUN      ] InferRequestTests.failToSetOutputWithInCorrectName
[       OK ] InferRequestTests.failToSetOutputWithInCorrectName (0 ms)
[ RUN      ] InferRequestTests.failToSetInputWithNotAllocatedInput
[       OK ] InferRequestTests.failToSetInputWithNotAllocatedInput (0 ms)
[----------] 21 tests from InferRequestTests (2 ms total)
[----------] 15 tests from InferRequestThreadSafeDefaultTests
[ RUN      ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnStartAsync
[       OK ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnStartAsync (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.canResetBusyStatusIfStartAsyncTaskFails
[       OK ] InferRequestThreadSafeDefaultTests.canResetBusyStatusIfStartAsyncTaskFails (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.canResetBusyStatusIfInitNextTaskFails
[       OK ] InferRequestThreadSafeDefaultTests.canResetBusyStatusIfInitNextTaskFails (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnGetUserData
[       OK ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnGetUserData (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnSetUserData
[       OK ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnSetUserData (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.returnInferNotStartedOnWait
[       OK ] InferRequestThreadSafeDefaultTests.returnInferNotStartedOnWait (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnInfer
[       OK ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnInfer (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.canResetBusyStatusIfInferFails
[       OK ] InferRequestThreadSafeDefaultTests.canResetBusyStatusIfInferFails (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnGetPerformanceCounts
[       OK ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnGetPerformanceCounts (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnGetBlob
[       OK ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnGetBlob (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnSetBlob
[       OK ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnSetBlob (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnSetCompletionCallback
[       OK ] InferRequestThreadSafeDefaultTests.returnRequestBusyOnSetCompletionCallback (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.callbackTakesOKIfAsyncRequestWasOK
[       OK ] InferRequestThreadSafeDefaultTests.callbackTakesOKIfAsyncRequestWasOK (0 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.callbackIsCalledIfAsyncRequestFailed
[       OK ] InferRequestThreadSafeDefaultTests.callbackIsCalledIfAsyncRequestFailed (1 ms)
[ RUN      ] InferRequestThreadSafeDefaultTests.canCatchExceptionIfAsyncRequestFailedAndNoCallback
[       OK ] InferRequestThreadSafeDefaultTests.canCatchExceptionIfAsyncRequestFailedAndNoCallback (0 ms)
[----------] 15 tests from InferRequestThreadSafeDefaultTests (2 ms total)
[----------] 9 tests from TaskSynchronizerTests
[ RUN      ] TaskSynchronizerTests.canLockAndUnlockRequestSync
[       OK ] TaskSynchronizerTests.canLockAndUnlockRequestSync (0 ms)
[ RUN      ] TaskSynchronizerTests.canCallUnlockMoreThanLock
[       OK ] TaskSynchronizerTests.canCallUnlockMoreThanLock (0 ms)
[ RUN      ] TaskSynchronizerTests.canUseScopeRequestForMoreThanMaxInQueueTimes
[       OK ] TaskSynchronizerTests.canUseScopeRequestForMoreThanMaxInQueueTimes (0 ms)
[ RUN      ] TaskSynchronizerTests.canSyncMaxNumThreadsUsingRequestSync
[       OK ] TaskSynchronizerTests.canSyncMaxNumThreadsUsingRequestSync (1002 ms)
[ RUN      ] TaskSynchronizerTests.throwExceptionOnLockMoreThanMaxUsingRequestSync
[       OK ] TaskSynchronizerTests.throwExceptionOnLockMoreThanMaxUsingRequestSync (1003 ms)
[ RUN      ] TaskSynchronizerTests.canSyncNThreadsUsingRequestSync
[       OK ] TaskSynchronizerTests.canSyncNThreadsUsingRequestSync (8 ms)
[ RUN      ] TaskSynchronizerTests.canSyncNThreadsUsingScopeSync
[       OK ] TaskSynchronizerTests.canSyncNThreadsUsingScopeSync (1 ms)
[ RUN      ] TaskSynchronizerTests.callAddToQueueAndWaitOnLock
[       OK ] TaskSynchronizerTests.callAddToQueueAndWaitOnLock (0 ms)
[ RUN      ] TaskSynchronizerTests.callLockOnCreation
[       OK ] TaskSynchronizerTests.callLockOnCreation (0 ms)
[----------] 9 tests from TaskSynchronizerTests (2014 ms total)
[----------] 9 tests from ExecutableNetworkBaseTests
[ RUN      ] ExecutableNetworkBaseTests.canForwardCreateInferRequest
[       OK ] ExecutableNetworkBaseTests.canForwardCreateInferRequest (0 ms)
[ RUN      ] ExecutableNetworkBaseTests.canReportErrorInCreateInferRequest
[       OK ] ExecutableNetworkBaseTests.canReportErrorInCreateInferRequest (0 ms)
[ RUN      ] ExecutableNetworkBaseTests.canCatchUnknownErrorInCreateInferRequest
[       OK ] ExecutableNetworkBaseTests.canCatchUnknownErrorInCreateInferRequest (1 ms)
[ RUN      ] ExecutableNetworkBaseTests.canForwardExport
[       OK ] ExecutableNetworkBaseTests.canForwardExport (0 ms)
[ RUN      ] ExecutableNetworkBaseTests.canReportErrorInExport
[       OK ] ExecutableNetworkBaseTests.canReportErrorInExport (0 ms)
[ RUN      ] ExecutableNetworkBaseTests.canCatchUnknownErrorInExport
[       OK ] ExecutableNetworkBaseTests.canCatchUnknownErrorInExport (0 ms)
[ RUN      ] ExecutableNetworkBaseTests.canForwardGetMappedTopology
[       OK ] ExecutableNetworkBaseTests.canForwardGetMappedTopology (0 ms)
[ RUN      ] ExecutableNetworkBaseTests.canReportErrorInCreateInferRequestGetMappedTopology
[       OK ] ExecutableNetworkBaseTests.canReportErrorInCreateInferRequestGetMappedTopology (0 ms)
[ RUN      ] ExecutableNetworkBaseTests.canCatchUnknownErrorInGetMappedTopology
[       OK ] ExecutableNetworkBaseTests.canCatchUnknownErrorInGetMappedTopology (0 ms)
[----------] 9 tests from ExecutableNetworkBaseTests (1 ms total)
[----------] 6 tests from TaskWithStagesTests
[ RUN      ] TaskWithStagesTests.canCreateTask
[       OK ] TaskWithStagesTests.canCreateTask (0 ms)
[ RUN      ] TaskWithStagesTests.runNoThrowMakeTaskPostponeWithStages
[       OK ] TaskWithStagesTests.runNoThrowMakeTaskPostponeWithStages (0 ms)
[ RUN      ] TaskWithStagesTests.stageDoneReducesStages
[       OK ] TaskWithStagesTests.stageDoneReducesStages (0 ms)
[ RUN      ] TaskWithStagesTests.runNoThrowMakesTaskDoneAfterCallStageDone
[       OK ] TaskWithStagesTests.runNoThrowMakesTaskDoneAfterCallStageDone (0 ms)
[ RUN      ] TaskWithStagesTests.canResetStages
[       OK ] TaskWithStagesTests.canResetStages (0 ms)
[ RUN      ] TaskWithStagesTests.throwExceptionIfCalledStageDoneMoreThanStagesTimes
[       OK ] TaskWithStagesTests.throwExceptionIfCalledStageDoneMoreThanStagesTimes (0 ms)
[----------] 6 tests from TaskWithStagesTests (0 ms total)
[----------] 14 tests from MemoryStateTests
[ RUN      ] MemoryStateTests.ExecutableNetworkCanConvertOneMemoryStateFromCppToAPI
[       OK ] MemoryStateTests.ExecutableNetworkCanConvertOneMemoryStateFromCppToAPI (0 ms)
[ RUN      ] MemoryStateTests.ExecutableNetworkCanConvertZeroMemoryStateFromCppToAPI
[       OK ] MemoryStateTests.ExecutableNetworkCanConvertZeroMemoryStateFromCppToAPI (1 ms)
[ RUN      ] MemoryStateTests.ExecutableNetworkCanConvert2MemoryStatesFromCPPtoAPI
[       OK ] MemoryStateTests.ExecutableNetworkCanConvert2MemoryStatesFromCPPtoAPI (0 ms)
[ RUN      ] MemoryStateTests.MemoryStatePropagatesReset
[       OK ] MemoryStateTests.MemoryStatePropagatesReset (0 ms)
[ RUN      ] MemoryStateTests.MemoryStatePropagatesExceptionsFromReset
[       OK ] MemoryStateTests.MemoryStatePropagatesExceptionsFromReset (0 ms)
[ RUN      ] MemoryStateTests.MemoryStatePropagatesGetName
[       OK ] MemoryStateTests.MemoryStatePropagatesGetName (0 ms)
[ RUN      ] MemoryStateTests.MemoryStatePropagatesGetNameWithZeroLen
[       OK ] MemoryStateTests.MemoryStatePropagatesGetNameWithZeroLen (0 ms)
[ RUN      ] MemoryStateTests.MemoryStatePropagatesGetNameWithLenOfOne
[       OK ] MemoryStateTests.MemoryStatePropagatesGetNameWithLenOfOne (0 ms)
[ RUN      ] MemoryStateTests.MemoryStatePropagatesGetNameWithLenOfTwo
[       OK ] MemoryStateTests.MemoryStatePropagatesGetNameWithLenOfTwo (0 ms)
[ RUN      ] MemoryStateTests.MemoryStateCanPropagateSetState
[       OK ] MemoryStateTests.MemoryStateCanPropagateSetState (0 ms)
[ RUN      ] MemoryStateTests.MemoryStateCanPropagateGetLastState
[       OK ] MemoryStateTests.MemoryStateCanPropagateGetLastState (0 ms)
[ RUN      ] MemoryStateTests.MemoryStateInternalCanSaveName
[       OK ] MemoryStateTests.MemoryStateInternalCanSaveName (0 ms)
[ RUN      ] MemoryStateTests.MemoryStateInternalCanSaveState
[       OK ] MemoryStateTests.MemoryStateInternalCanSaveState (0 ms)
[ RUN      ] MemoryStateTests.MemoryStateInternalCanSaveStateByReference
[       OK ] MemoryStateTests.MemoryStateInternalCanSaveStateByReference (0 ms)
[----------] 14 tests from MemoryStateTests (1 ms total)
[----------] 3 tests from ExecutorManagerTests
[ RUN      ] ExecutorManagerTests.canCreateSingleExecutorManager
[       OK ] ExecutorManagerTests.canCreateSingleExecutorManager (0 ms)
[ RUN      ] ExecutorManagerTests.createDifferentExecutorsForDifferentDevices
[       OK ] ExecutorManagerTests.createDifferentExecutorsForDifferentDevices (1 ms)
[ RUN      ] ExecutorManagerTests.returnTheSameExecutorForTheSameDevice
[       OK ] ExecutorManagerTests.returnTheSameExecutorForTheSameDevice (0 ms)
[----------] 3 tests from ExecutorManagerTests (1 ms total)
[----------] 4 tests from ExecutableNetworkTests
[ RUN      ] ExecutableNetworkTests.canForwardCreateInferRequest
[       OK ] ExecutableNetworkTests.canForwardCreateInferRequest (0 ms)
[ RUN      ] ExecutableNetworkTests.throwsIfCreateInferRequestReturnNotOK
[       OK ] ExecutableNetworkTests.throwsIfCreateInferRequestReturnNotOK (0 ms)
[ RUN      ] ExecutableNetworkTests.canForwardCreateInferRequestPtr
[       OK ] ExecutableNetworkTests.canForwardCreateInferRequestPtr (0 ms)
[ RUN      ] ExecutableNetworkTests.throwsIfCreateInferRequestPtrReturnNotOK
[       OK ] ExecutableNetworkTests.throwsIfCreateInferRequestPtrReturnNotOK (0 ms)
[----------] 4 tests from ExecutableNetworkTests (0 ms total)
[----------] 7 tests from InferenceEnginePluginInternalTest
[ RUN      ] InferenceEnginePluginInternalTest.canUseNewInferViaOldAPI
[       OK ] InferenceEnginePluginInternalTest.canUseNewInferViaOldAPI (1 ms)
[ RUN      ] InferenceEnginePluginInternalTest.loadExeNetworkCallsSetNetworkIO
[       OK ] InferenceEnginePluginInternalTest.loadExeNetworkCallsSetNetworkIO (0 ms)
[ RUN      ] InferenceEnginePluginInternalTest.failToSetBlobWithInCorrectName
[       OK ] InferenceEnginePluginInternalTest.failToSetBlobWithInCorrectName (0 ms)
[ RUN      ] InferenceEnginePluginInternalTest.failToSetBlobWithNullPtr
[       OK ] InferenceEnginePluginInternalTest.failToSetBlobWithNullPtr (1 ms)
[ RUN      ] InferenceEnginePluginInternalTest.failToSetNullPtr
[       OK ] InferenceEnginePluginInternalTest.failToSetNullPtr (0 ms)
[ RUN      ] InferenceEnginePluginInternalTest.failToSetEmptyBlob
[       OK ] InferenceEnginePluginInternalTest.failToSetEmptyBlob (1 ms)
[ RUN      ] InferenceEnginePluginInternalTest.failToSetNotAllocatedBlob
[       OK ] InferenceEnginePluginInternalTest.failToSetNotAllocatedBlob (1 ms)
[----------] 7 tests from InferenceEnginePluginInternalTest (4 ms total)
[----------] 4 tests from InferenceEnginePluginInternal2Test
[ RUN      ] InferenceEnginePluginInternal2Test.loadExeNetworkWithEmptyNetworkReturnsError
[       OK ] InferenceEnginePluginInternal2Test.loadExeNetworkWithEmptyNetworkReturnsError (1 ms)
[ RUN      ] InferenceEnginePluginInternal2Test.canForwardGetPerfCount
[       OK ] InferenceEnginePluginInternal2Test.canForwardGetPerfCount (0 ms)
[ RUN      ] InferenceEnginePluginInternal2Test.deprecatedInferCallsSetterAndInfer
[       OK ] InferenceEnginePluginInternal2Test.deprecatedInferCallsSetterAndInfer (0 ms)
[ RUN      ] InferenceEnginePluginInternal2Test.deprecatedLoadNetworkCallsCreateInferRequest
[       OK ] InferenceEnginePluginInternal2Test.deprecatedLoadNetworkCallsCreateInferRequest (0 ms)
[----------] 4 tests from InferenceEnginePluginInternal2Test (1 ms total)
[----------] 12 tests from TaskExecutorTests
[ RUN      ] TaskExecutorTests.canCreateTaskExecutor
[       OK ] TaskExecutorTests.canCreateTaskExecutor (0 ms)
[ RUN      ] TaskExecutorTests.canCatchException
[       OK ] TaskExecutorTests.canCatchException (2 ms)
[ RUN      ] TaskExecutorTests.canRunDefaultTask
[       OK ] TaskExecutorTests.canRunDefaultTask (0 ms)
[ RUN      ] TaskExecutorTests.canRunDefaultTaskWithoutStop
[       OK ] TaskExecutorTests.canRunDefaultTaskWithoutStop (0 ms)
[ RUN      ] TaskExecutorTests.canRunDefaultTaskWithoutWait
[       OK ] TaskExecutorTests.canRunDefaultTaskWithoutWait (0 ms)
[ RUN      ] TaskExecutorTests.canRunCustomFunction
[       OK ] TaskExecutorTests.canRunCustomFunction (0 ms)
[ RUN      ] TaskExecutorTests.canRun2FunctionsOneByOne
[       OK ] TaskExecutorTests.canRun2FunctionsOneByOne (0 ms)
[ RUN      ] TaskExecutorTests.returnFalseIfRunTaskWhichIsRunning
[       OK ] TaskExecutorTests.returnFalseIfRunTaskWhichIsRunning (501 ms)
[ RUN      ] TaskExecutorTests.canRun2FunctionsOneByOneWithoutWait
[       OK ] TaskExecutorTests.canRun2FunctionsOneByOneWithoutWait (1001 ms)
[ RUN      ] TaskExecutorTests.canRunMultipleTasksWithExceptionInside
[       OK ] TaskExecutorTests.canRunMultipleTasksWithExceptionInside (1 ms)
[ RUN      ] TaskExecutorTests.executorNotReleasedUntilTasksAreDone
[       OK ] TaskExecutorTests.executorNotReleasedUntilTasksAreDone (0 ms)
[ RUN      ] TaskExecutorTests.callWaitOnTaskDtorIfProcessed
[       OK ] TaskExecutorTests.callWaitOnTaskDtorIfProcessed (500 ms)
[----------] 12 tests from TaskExecutorTests (2006 ms total)
[----------] 12 tests from AsyncInferRequestThreadSafeInternalTests
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnStartAsync
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnStartAsync (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.canResetBusyStatusIfStartAsyncTaskFails
[       OK ] AsyncInferRequestThreadSafeInternalTests.canResetBusyStatusIfStartAsyncTaskFails (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.deviceBusyAfterStartAsync
[       OK ] AsyncInferRequestThreadSafeInternalTests.deviceBusyAfterStartAsync (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnGetUserData
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnGetUserData (1 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnSetUserData
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnSetUserData (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnInferNotStartedOnWait
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnInferNotStartedOnWait (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnInfer
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnInfer (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.canResetBusyStatusIfInferFails
[       OK ] AsyncInferRequestThreadSafeInternalTests.canResetBusyStatusIfInferFails (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnGetPerformanceCounts
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnGetPerformanceCounts (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnGetBlob
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnGetBlob (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnSetBlob
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnSetBlob (0 ms)
[ RUN      ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnSetCompletionCallback
[       OK ] AsyncInferRequestThreadSafeInternalTests.returnRequestBusyOnSetCompletionCallback (0 ms)
[----------] 12 tests from AsyncInferRequestThreadSafeInternalTests (1 ms total)
[----------] 5 tests from ExecutableNetworkThreadSafeAsyncOnlyTests
[ RUN      ] ExecutableNetworkThreadSafeAsyncOnlyTests.createAsyncInferRequestCallsThreadSafeImplAndSetNetworkIO
[       OK ] ExecutableNetworkThreadSafeAsyncOnlyTests.createAsyncInferRequestCallsThreadSafeImplAndSetNetworkIO (0 ms)
[ RUN      ] ExecutableNetworkThreadSafeAsyncOnlyTests.returnErrorIfInferThrowsException
[       OK ] ExecutableNetworkThreadSafeAsyncOnlyTests.returnErrorIfInferThrowsException (0 ms)
[ RUN      ] ExecutableNetworkThreadSafeAsyncOnlyTests.returnErrorIfStartAsyncThrowsException
[       OK ] ExecutableNetworkThreadSafeAsyncOnlyTests.returnErrorIfStartAsyncThrowsException (0 ms)
[ RUN      ] ExecutableNetworkThreadSafeAsyncOnlyTests.canForwardStartAsyncAndInfer
[       OK ] ExecutableNetworkThreadSafeAsyncOnlyTests.canForwardStartAsyncAndInfer (0 ms)
[ RUN      ] ExecutableNetworkThreadSafeAsyncOnlyTests.canForwardInferAndStartAsync
[       OK ] ExecutableNetworkThreadSafeAsyncOnlyTests.canForwardInferAndStartAsync (0 ms)
[----------] 5 tests from ExecutableNetworkThreadSafeAsyncOnlyTests (0 ms total)
[----------] 26 tests from InferRequestBaseTests
[ RUN      ] InferRequestBaseTests.canForwardStartAsync
[       OK ] InferRequestBaseTests.canForwardStartAsync (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInStartAsync
[       OK ] InferRequestBaseTests.canReportErrorInStartAsync (0 ms)
[ RUN      ] InferRequestBaseTests.canCatchUnknownErrorInStartAsync
[       OK ] InferRequestBaseTests.canCatchUnknownErrorInStartAsync (0 ms)
[ RUN      ] InferRequestBaseTests.canForwardGetUserData
[       OK ] InferRequestBaseTests.canForwardGetUserData (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInGetUserData
[       OK ] InferRequestBaseTests.canReportErrorInGetUserData (0 ms)
[ RUN      ] InferRequestBaseTests.canCatchUnknownErrorInGetUserData
[       OK ] InferRequestBaseTests.canCatchUnknownErrorInGetUserData (0 ms)
[ RUN      ] InferRequestBaseTests.canForwardSetUserData
[       OK ] InferRequestBaseTests.canForwardSetUserData (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInSetUserData
[       OK ] InferRequestBaseTests.canReportErrorInSetUserData (0 ms)
[ RUN      ] InferRequestBaseTests.canCatchUnknownErrorInSetUserData
[       OK ] InferRequestBaseTests.canCatchUnknownErrorInSetUserData (0 ms)
[ RUN      ] InferRequestBaseTests.canForwardWait
[       OK ] InferRequestBaseTests.canForwardWait (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInWait
[       OK ] InferRequestBaseTests.canReportErrorInWait (0 ms)
[ RUN      ] InferRequestBaseTests.canCatchUnknownErrorInWait
[       OK ] InferRequestBaseTests.canCatchUnknownErrorInWait (0 ms)
[ RUN      ] InferRequestBaseTests.canForwardInfer
[       OK ] InferRequestBaseTests.canForwardInfer (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInInfer
[       OK ] InferRequestBaseTests.canReportErrorInInfer (0 ms)
[ RUN      ] InferRequestBaseTests.canCatchUnknownErrorInInfer
[       OK ] InferRequestBaseTests.canCatchUnknownErrorInInfer (0 ms)
[ RUN      ] InferRequestBaseTests.canForwardGetPerformanceCounts
[       OK ] InferRequestBaseTests.canForwardGetPerformanceCounts (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInGetPerformanceCounts
[       OK ] InferRequestBaseTests.canReportErrorInGetPerformanceCounts (0 ms)
[ RUN      ] InferRequestBaseTests.canCatchUnknownErrorInGetPerformanceCounts
[       OK ] InferRequestBaseTests.canCatchUnknownErrorInGetPerformanceCounts (1 ms)
[ RUN      ] InferRequestBaseTests.canForwardGetBlob
[       OK ] InferRequestBaseTests.canForwardGetBlob (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInGetBlob
[       OK ] InferRequestBaseTests.canReportErrorInGetBlob (0 ms)
[ RUN      ] InferRequestBaseTests.canCatchUnknownErrorInGetBlob
[       OK ] InferRequestBaseTests.canCatchUnknownErrorInGetBlob (0 ms)
[ RUN      ] InferRequestBaseTests.canForwardSetBlob
[       OK ] InferRequestBaseTests.canForwardSetBlob (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInSetBlob
[       OK ] InferRequestBaseTests.canReportErrorInSetBlob (0 ms)
[ RUN      ] InferRequestBaseTests.canCatchUnknownErrorInSetBlob
[       OK ] InferRequestBaseTests.canCatchUnknownErrorInSetBlob (0 ms)
[ RUN      ] InferRequestBaseTests.canForwardSetCompletionCallback
[       OK ] InferRequestBaseTests.canForwardSetCompletionCallback (0 ms)
[ RUN      ] InferRequestBaseTests.canReportErrorInSetCompletionCallback
[       OK ] InferRequestBaseTests.canReportErrorInSetCompletionCallback (0 ms)
[----------] 26 tests from InferRequestBaseTests (2 ms total)
[----------] 12 tests from MemSolverTest
[ RUN      ] MemSolverTest.LinearAndEven
[       OK ] MemSolverTest.LinearAndEven (0 ms)
[ RUN      ] MemSolverTest.LinearAndNotEven
[       OK ] MemSolverTest.LinearAndNotEven (0 ms)
[ RUN      ] MemSolverTest.LinearWithEmptyExecIndexes
[       OK ] MemSolverTest.LinearWithEmptyExecIndexes (0 ms)
[ RUN      ] MemSolverTest.OverlappingBoxes
[       OK ] MemSolverTest.OverlappingBoxes (0 ms)
[ RUN      ] MemSolverTest.EndOnSeveralBegins
[       OK ] MemSolverTest.EndOnSeveralBegins (0 ms)
[ RUN      ] MemSolverTest.ToEndBoxes
[       OK ] MemSolverTest.ToEndBoxes (0 ms)
[ RUN      ] MemSolverTest.LastAndToEndBox
[       OK ] MemSolverTest.LastAndToEndBox (0 ms)
[ RUN      ] MemSolverTest.OptimalAlexnet
[       OK ] MemSolverTest.OptimalAlexnet (0 ms)
[ RUN      ] MemSolverTest.GetOffsets
[       OK ] MemSolverTest.GetOffsets (0 ms)
[ RUN      ] MemSolverTest.GetOffsetThows
[       OK ] MemSolverTest.GetOffsetThows (0 ms)
[ RUN      ] MemSolverTest.NoOverlapping
[       OK ] MemSolverTest.NoOverlapping (0 ms)
[ RUN      ] MemSolverTest.BestSolution1
[       OK ] MemSolverTest.BestSolution1 (0 ms)
[----------] 12 tests from MemSolverTest (1 ms total)
[----------] 7 tests from CNNNetReaderImplTest
[ RUN      ] CNNNetReaderImplTest.validateIsCalled
[       OK ] CNNNetReaderImplTest.validateIsCalled (0 ms)
[ RUN      ] CNNNetReaderImplTest.cycleIsDetectedInReader
[       OK ] CNNNetReaderImplTest.cycleIsDetectedInReader (5 ms)
[ RUN      ] CNNNetReaderImplTest.canRead3DConvolution
[       OK ] CNNNetReaderImplTest.canRead3DConvolution (0 ms)
[ RUN      ] CNNNetReaderImplTest.canRead3DPooling
[       OK ] CNNNetReaderImplTest.canRead3DPooling (0 ms)
[ RUN      ] CNNNetReaderImplTest.canParseWithoutInput_1to2
[       OK ] CNNNetReaderImplTest.canParseWithoutInput_1to2 (1 ms)
[ RUN      ] CNNNetReaderImplTest.canParseWithoutInput_2to1
[       OK ] CNNNetReaderImplTest.canParseWithoutInput_2to1 (0 ms)
[ RUN      ] CNNNetReaderImplTest.canParseSimpleTI
[       OK ] CNNNetReaderImplTest.canParseSimpleTI (0 ms)
[----------] 7 tests from CNNNetReaderImplTest (6 ms total)
[----------] 12 tests from CNNNetworkImplTest
[ RUN      ] CNNNetworkImplTest.throwOnWrongInputType
[       OK ] CNNNetworkImplTest.throwOnWrongInputType (0 ms)
[ RUN      ] CNNNetworkImplTest.severalRightInputTypes
[       OK ] CNNNetworkImplTest.severalRightInputTypes (0 ms)
[ RUN      ] CNNNetworkImplTest.noCreatorLayers
[       OK ] CNNNetworkImplTest.noCreatorLayers (1 ms)
[ RUN      ] CNNNetworkImplTest.dataHasNoCreatorLayerButItIs
[       OK ] CNNNetworkImplTest.dataHasNoCreatorLayerButItIs (0 ms)
[ RUN      ] CNNNetworkImplTest.layerNameIsNotUnique
[       OK ] CNNNetworkImplTest.layerNameIsNotUnique (0 ms)
[ RUN      ] CNNNetworkImplTest.dataNameIsNotUnique
[       OK ] CNNNetworkImplTest.dataNameIsNotUnique (0 ms)
[ RUN      ] CNNNetworkImplTest.layerDoesNotHaveInputData
[       OK ] CNNNetworkImplTest.layerDoesNotHaveInputData (0 ms)
[ RUN      ] CNNNetworkImplTest.layerDataNotCoresspondEachOtherOneInput
[       OK ] CNNNetworkImplTest.layerDataNotCoresspondEachOtherOneInput (1 ms)
[ RUN      ] CNNNetworkImplTest.layerDataNotCoresspondEachOtherTwoInputs
[       OK ] CNNNetworkImplTest.layerDataNotCoresspondEachOtherTwoInputs (0 ms)
[ RUN      ] CNNNetworkImplTest.canGetName
[       OK ] CNNNetworkImplTest.canGetName (0 ms)
[ RUN      ] CNNNetworkImplTest.canGetNameStr
[       OK ] CNNNetworkImplTest.canGetNameStr (0 ms)
[ RUN      ] CNNNetworkImplTest.cycleIsDetectedInNetwork
[       OK ] CNNNetworkImplTest.cycleIsDetectedInNetwork (0 ms)
[----------] 12 tests from CNNNetworkImplTest (2 ms total)
[----------] 4 tests from LayoutTest
[ RUN      ] LayoutTest.offsetNCHW
[       OK ] LayoutTest.offsetNCHW (0 ms)
[ RUN      ] LayoutTest.offsetNCHW2
[       OK ] LayoutTest.offsetNCHW2 (0 ms)
[ RUN      ] LayoutTest.offsetNHWC
[       OK ] LayoutTest.offsetNHWC (0 ms)
[ RUN      ] LayoutTest.convertNCHWtoNHWC
[       OK ] LayoutTest.convertNCHWtoNHWC (0 ms)
[----------] 4 tests from LayoutTest (0 ms total)
[----------] 48 tests from V2FormatParserTest
[ RUN      ] V2FormatParserTest.invalidXml_ShouldThrow
[       OK ] V2FormatParserTest.invalidXml_ShouldThrow (0 ms)
[ RUN      ] V2FormatParserTest.canParseDims
[       OK ] V2FormatParserTest.canParseDims (1 ms)
[ RUN      ] V2FormatParserTest.failWhenNoDims
[       OK ] V2FormatParserTest.failWhenNoDims (0 ms)
[ RUN      ] V2FormatParserTest.failOnZeroDim
[       OK ] V2FormatParserTest.failOnZeroDim (0 ms)
[ RUN      ] V2FormatParserTest.canParseMeanImageValues
[       OK ] V2FormatParserTest.canParseMeanImageValues (0 ms)
[ RUN      ] V2FormatParserTest.canParseScaleValuesOnly
[       OK ] V2FormatParserTest.canParseScaleValuesOnly (1 ms)
[ RUN      ] V2FormatParserTest.failIfOneOfMeanImageIdsMissed
[       OK ] V2FormatParserTest.failIfOneOfMeanImageIdsMissed (0 ms)
[ RUN      ] V2FormatParserTest.failIfValueAttributeIsNotValid
[       OK ] V2FormatParserTest.failIfValueAttributeIsNotValid (0 ms)
[ RUN      ] V2FormatParserTest.failIfMeanValueIsNotSpecified
[       OK ] V2FormatParserTest.failIfMeanValueIsNotSpecified (1 ms)
[ RUN      ] V2FormatParserTest.failIfMeanValueNotSpecifiedInPreProcessing
[       OK ] V2FormatParserTest.failIfMeanValueNotSpecifiedInPreProcessing (0 ms)
[ RUN      ] V2FormatParserTest.failIfIdLessThanZero
[       OK ] V2FormatParserTest.failIfIdLessThanZero (0 ms)
[ RUN      ] V2FormatParserTest.failIfIdMoreThanNumChannels
[       OK ] V2FormatParserTest.failIfIdMoreThanNumChannels (1 ms)
[ RUN      ] V2FormatParserTest.failIfIdIsDuplicated
[       OK ] V2FormatParserTest.failIfIdIsDuplicated (0 ms)
[ RUN      ] V2FormatParserTest.failParseMeanImageWithoutSpecifyingPrecision
[       OK ] V2FormatParserTest.failParseMeanImageWithoutSpecifyingPrecision (0 ms)
[ RUN      ] V2FormatParserTest.failIfOneOfMeanImageIfMeanNotSpecified
[       OK ] V2FormatParserTest.failIfOneOfMeanImageIfMeanNotSpecified (0 ms)
[ RUN      ] V2FormatParserTest.failIfOffsetValueMissing
[       OK ] V2FormatParserTest.failIfOffsetValueMissing (1 ms)
[ RUN      ] V2FormatParserTest.failIfSizeValueMissing
[       OK ] V2FormatParserTest.failIfSizeValueMissing (0 ms)
[ RUN      ] V2FormatParserTest.throwsIfSizeOfMeanElementsMismatchWithExpected
[       OK ] V2FormatParserTest.throwsIfSizeOfMeanElementsMismatchWithExpected (1 ms)
[ RUN      ] V2FormatParserTest.canHandleQ78MeanValues
[       OK ] V2FormatParserTest.canHandleQ78MeanValues (0 ms)
[ RUN      ] V2FormatParserTest.canParseBinFileWithMeanImageUINT8Values
[       OK ] V2FormatParserTest.canParseBinFileWithMeanImageUINT8Values (0 ms)
[ RUN      ] V2FormatParserTest.canParseBinFileWithMeanImageI16Values
[       OK ] V2FormatParserTest.canParseBinFileWithMeanImageI16Values (1 ms)
[ RUN      ] V2FormatParserTest.canParseBinFileWithMeanImageFloatValues
[       OK ] V2FormatParserTest.canParseBinFileWithMeanImageFloatValues (0 ms)
[ RUN      ] V2FormatParserTest.throwIfSizeDoesNotMatchExpectedMeanSize
[       OK ] V2FormatParserTest.throwIfSizeDoesNotMatchExpectedMeanSize (0 ms)
[ RUN      ] V2FormatParserTest.failIfSizeExceedBinaryFileSize
[       OK ] V2FormatParserTest.failIfSizeExceedBinaryFileSize (1 ms)
[ RUN      ] V2FormatParserTest.failIfMixedAttributesAreSet
[       OK ] V2FormatParserTest.failIfMixedAttributesAreSet (0 ms)
[ RUN      ] V2FormatParserTest.parseSucceedIfMixedButAllValuesSet
[       OK ] V2FormatParserTest.parseSucceedIfMixedButAllValuesSet (0 ms)
[ RUN      ] V2FormatParserTest.parseTileLayer
[       OK ] V2FormatParserTest.parseTileLayer (1 ms)
[ RUN      ] V2FormatParserTest.checkPreProcessWithRefName
[       OK ] V2FormatParserTest.checkPreProcessWithRefName (0 ms)
[ RUN      ] V2FormatParserTest.failWhenPreProcessNameMissing
[       OK ] V2FormatParserTest.failWhenPreProcessNameMissing (0 ms)
[ RUN      ] V2FormatParserTest.cannotParseUnknownEltwiseOperation
[       OK ] V2FormatParserTest.cannotParseUnknownEltwiseOperation (0 ms)
[ RUN      ] V2FormatParserTest.asserOnUnknownEltwiseOperation
[       OK ] V2FormatParserTest.asserOnUnknownEltwiseOperation (1 ms)
[ RUN      ] V2FormatParserTest.canParseEmptyElementwiseNodeAsSum
[       OK ] V2FormatParserTest.canParseEmptyElementwiseNodeAsSum (0 ms)
[ RUN      ] V2FormatParserTest.canParseEmptyElementwiseNodeAsSumAmazonIR
[       OK ] V2FormatParserTest.canParseEmptyElementwiseNodeAsSumAmazonIR (0 ms)
[ RUN      ] V2FormatParserTest.canParseMissedElementwiseOperationNodeAsSum
[       OK ] V2FormatParserTest.canParseMissedElementwiseOperationNodeAsSum (0 ms)
[ RUN      ] V2FormatParserTest.canParseMissedElementwiseDataNodeAsSum
[       OK ] V2FormatParserTest.canParseMissedElementwiseDataNodeAsSum (0 ms)
[ RUN      ] V2FormatParserTest.canParseProdInElementwiseNode
[       OK ] V2FormatParserTest.canParseProdInElementwiseNode (1 ms)
[ RUN      ] V2FormatParserTest.canParseMulInElementwiseNode
[       OK ] V2FormatParserTest.canParseMulInElementwiseNode (0 ms)
[ RUN      ] V2FormatParserTest.canParseSumInElementwiseNode
[       OK ] V2FormatParserTest.canParseSumInElementwiseNode (0 ms)
[ RUN      ] V2FormatParserTest.parsesNumberOfLayersCorrectly
[       OK ] V2FormatParserTest.parsesNumberOfLayersCorrectly (0 ms)
[ RUN      ] V2FormatParserTest.canThrowExceptionIfUnknownActivation
[       OK ] V2FormatParserTest.canThrowExceptionIfUnknownActivation (1 ms)
[ RUN      ] V2FormatParserTest.canThrowExceptionIfNoType
[       OK ] V2FormatParserTest.canThrowExceptionIfNoType (0 ms)
[ RUN      ] V2FormatParserTest.canThrowExceptionIfMultipleTypes
[       OK ] V2FormatParserTest.canThrowExceptionIfMultipleTypes (0 ms)
[ RUN      ] V2FormatParserTest.canConvertActivationLayerAsTanH
[       OK ] V2FormatParserTest.canConvertActivationLayerAsTanH (0 ms)
[ RUN      ] V2FormatParserTest.canConvertActivationLayerAsELU
[       OK ] V2FormatParserTest.canConvertActivationLayerAsELU (0 ms)
[ RUN      ] V2FormatParserTest.canConvertActivationLayerAsRelu
[       OK ] V2FormatParserTest.canConvertActivationLayerAsRelu (1 ms)
[ RUN      ] V2FormatParserTest.canConvertActivationLayerAsPRelu
[       OK ] V2FormatParserTest.canConvertActivationLayerAsPRelu (0 ms)
[ RUN      ] V2FormatParserTest.canConvertActivationLayerAsSigmoid
[       OK ] V2FormatParserTest.canConvertActivationLayerAsSigmoid (0 ms)
[ RUN      ] V2FormatParserTest.canConvertActivationLayerAsClamp
[       OK ] V2FormatParserTest.canConvertActivationLayerAsClamp (0 ms)
[----------] 48 tests from V2FormatParserTest (13 ms total)
[----------] 7 tests from XMLFatherF
[ RUN      ] XMLFatherF.canCreateValidXmlNode
[       OK ] XMLFatherF.canCreateValidXmlNode (0 ms)
[ RUN      ] XMLFatherF.canCreateValidNodeWithName
[       OK ] XMLFatherF.canCreateValidNodeWithName (0 ms)
[ RUN      ] XMLFatherF.canCreateValidXmlNodeWithContent
[       OK ] XMLFatherF.canCreateValidXmlNodeWithContent (0 ms)
[ RUN      ] XMLFatherF.canCreateValidXmlNodeWithAdvancedContent
[       OK ] XMLFatherF.canCreateValidXmlNodeWithAdvancedContent (0 ms)
[ RUN      ] XMLFatherF.canCreateLevel2Hierarchy
[       OK ] XMLFatherF.canCreateLevel2Hierarchy (0 ms)
[ RUN      ] XMLFatherF.canContinueAfterTrivialNode
[       OK ] XMLFatherF.canContinueAfterTrivialNode (0 ms)
[ RUN      ] XMLFatherF.canContinueAfterNodeWithSubnodes
[       OK ] XMLFatherF.canContinueAfterNodeWithSubnodes (0 ms)
[----------] 7 tests from XMLFatherF (0 ms total)
[----------] 7 tests from V3FormatParserTest
[ RUN      ] V3FormatParserTest.cannotParseUnknownEltwiseOperation
[       OK ] V3FormatParserTest.cannotParseUnknownEltwiseOperation (1 ms)
[ RUN      ] V3FormatParserTest.canParseProdInElementwiseNode
[       OK ] V3FormatParserTest.canParseProdInElementwiseNode (0 ms)
[ RUN      ] V3FormatParserTest.canParseMulInElementwiseNode
[       OK ] V3FormatParserTest.canParseMulInElementwiseNode (0 ms)
[ RUN      ] V3FormatParserTest.canParse5Dinput
[       OK ] V3FormatParserTest.canParse5Dinput (0 ms)
[ RUN      ] V3FormatParserTest.DISABLE_conv3DInvalidKernel
[       OK ] V3FormatParserTest.DISABLE_conv3DInvalidKernel (0 ms)
[ RUN      ] V3FormatParserTest.LargeWeights
[       OK ] V3FormatParserTest.LargeWeights (0 ms)
[ RUN      ] V3FormatParserTest.IncorrectWeights
[       OK ] V3FormatParserTest.IncorrectWeights (0 ms)
[----------] 7 tests from V3FormatParserTest (1 ms total)
[----------] 15 tests from OutputControllerTest
[ RUN      ] OutputControllerTest.failedToCreateWithEmptyOutData
[       OK ] OutputControllerTest.failedToCreateWithEmptyOutData (0 ms)
[ RUN      ] OutputControllerTest.failedToCreateWithNullOutData
[       OK ] OutputControllerTest.failedToCreateWithNullOutData (0 ms)
[ RUN      ] OutputControllerTest.canCreateOutputController
[       OK ] OutputControllerTest.canCreateOutputController (1 ms)
[ RUN      ] OutputControllerTest.canGetChanges
[       OK ] OutputControllerTest.canGetChanges (0 ms)
[ RUN      ] OutputControllerTest.canSetShapes
[       OK ] OutputControllerTest.canSetShapes (0 ms)
[ RUN      ] OutputControllerTest.noThrowOnGetWithExcessShapes
[       OK ] OutputControllerTest.noThrowOnGetWithExcessShapes (0 ms)
[ RUN      ] OutputControllerTest.throwOnPropagateWithNotEnoughShapes
[       OK ] OutputControllerTest.throwOnPropagateWithNotEnoughShapes (0 ms)
[ RUN      ] OutputControllerTest.throwOnPropagateWithExcessShapes
[       OK ] OutputControllerTest.throwOnPropagateWithExcessShapes (0 ms)
[ RUN      ] OutputControllerTest.throwOnPropagateWithEmptyLaunchers
[       OK ] OutputControllerTest.throwOnPropagateWithEmptyLaunchers (0 ms)
[ RUN      ] OutputControllerTest.throwOnPropagateWithoutProperLauncher
[       OK ] OutputControllerTest.throwOnPropagateWithoutProperLauncher (0 ms)
[ RUN      ] OutputControllerTest.canPropagateShapes
[       OK ] OutputControllerTest.canPropagateShapes (0 ms)
[ RUN      ] OutputControllerTest.throwOnApplyWithNotEnoughShapes
[       OK ] OutputControllerTest.throwOnApplyWithNotEnoughShapes (0 ms)
[ RUN      ] OutputControllerTest.throwOnApplyWithExcessShapes
[       OK ] OutputControllerTest.throwOnApplyWithExcessShapes (0 ms)
[ RUN      ] OutputControllerTest.canApplyChanges
[       OK ] OutputControllerTest.canApplyChanges (0 ms)
[ RUN      ] OutputControllerTest.canResetShapes
[       OK ] OutputControllerTest.canResetShapes (0 ms)
[----------] 15 tests from OutputControllerTest (1 ms total)
[----------] 2 tests from ShapeInferHolderTest
[ RUN      ] ShapeInferHolderTest.canCreateHolder
[       OK ] ShapeInferHolderTest.canCreateHolder (0 ms)
[ RUN      ] ShapeInferHolderTest.returnNullForNotKnown
[       OK ] ShapeInferHolderTest.returnNullForNotKnown (0 ms)
[----------] 2 tests from ShapeInferHolderTest (0 ms total)
[----------] 15 tests from InputReshapeLauncherTest
[ RUN      ] InputReshapeLauncherTest.failedToCreateWithNullLayer
[       OK ] InputReshapeLauncherTest.failedToCreateWithNullLayer (0 ms)
[ RUN      ] InputReshapeLauncherTest.failedToCreateWithEmptyOutData
[       OK ] InputReshapeLauncherTest.failedToCreateWithEmptyOutData (0 ms)
[ RUN      ] InputReshapeLauncherTest.failedToCreateWithNullOutData
[       OK ] InputReshapeLauncherTest.failedToCreateWithNullOutData (0 ms)
[ RUN      ] InputReshapeLauncherTest.failedToCreateWithNotInputType
[       OK ] InputReshapeLauncherTest.failedToCreateWithNotInputType (0 ms)
[ RUN      ] InputReshapeLauncherTest.canCreateReshapeLauncher
[       OK ] InputReshapeLauncherTest.canCreateReshapeLauncher (0 ms)
[ RUN      ] InputReshapeLauncherTest.canPushShapes
[       OK ] InputReshapeLauncherTest.canPushShapes (0 ms)
[ RUN      ] InputReshapeLauncherTest.canPropagateWithNotEnoughShapes
[       OK ] InputReshapeLauncherTest.canPropagateWithNotEnoughShapes (0 ms)
[ RUN      ] InputReshapeLauncherTest.throwOnPropagateWithEmptyLaunchers
[       OK ] InputReshapeLauncherTest.throwOnPropagateWithEmptyLaunchers (0 ms)
[ RUN      ] InputReshapeLauncherTest.throwOnPropagateWithoutProperLauncher
[       OK ] InputReshapeLauncherTest.throwOnPropagateWithoutProperLauncher (0 ms)
[       OK ] InputReshapeLauncherTest.canPropagate (0 ms)
[ RUN      ] InputReshapeLauncherTest.canReset
[       OK ] InputReshapeLauncherTest.canReset (0 ms)
[ RUN      ] InputReshapeLauncherTest.canApplyWithoutSettingShapes
[       OK ] InputReshapeLauncherTest.canApplyWithoutSettingShapes (0 ms)
[ RUN      ] InputReshapeLauncherTest.canNotApplyForLayerWithAnotherName
[       OK ] InputReshapeLauncherTest.canNotApplyForLayerWithAnotherName (0 ms)
[ RUN      ] InputReshapeLauncherTest.canApplyChanges
[       OK ] InputReshapeLauncherTest.canApplyChanges (0 ms)
[ RUN      ] InputReshapeLauncherTest.canGetShapesFromLayer
[       OK ] InputReshapeLauncherTest.canGetShapesFromLayer (1 ms)
[----------] 15 tests from InputReshapeLauncherTest (1 ms total)
[----------] 10 tests from InputControllerTest
[ RUN      ] InputControllerTest.failedToCreateWithEmptyInsData
[       OK ] InputControllerTest.failedToCreateWithEmptyInsData (0 ms)
[ RUN      ] InputControllerTest.failedToCreateWithNullData
[       OK ] InputControllerTest.failedToCreateWithNullData (0 ms)
[ RUN      ] InputControllerTest.canCreateInputController
[       OK ] InputControllerTest.canCreateInputController (0 ms)
[ RUN      ] InputControllerTest.canPushShapes
[       OK ] InputControllerTest.canPushShapes (0 ms)
[ RUN      ] InputControllerTest.throwOnGetWithNotEnoughShapes
[       OK ] InputControllerTest.throwOnGetWithNotEnoughShapes (0 ms)
[ RUN      ] InputControllerTest.canGetWithNotEnoughShapes
[       OK ] InputControllerTest.canGetWithNotEnoughShapes (0 ms)
[ RUN      ] InputControllerTest.canGetChanges
[       OK ] InputControllerTest.canGetChanges (0 ms)
[ RUN      ] InputControllerTest.throwOnApplyWithNotEnoughShapes
[       OK ] InputControllerTest.throwOnApplyWithNotEnoughShapes (0 ms)
[ RUN      ] InputControllerTest.canApplyChanges
[       OK ] InputControllerTest.canApplyChanges (0 ms)
[ RUN      ] InputControllerTest.canResetShapes
[       OK ] InputControllerTest.canResetShapes (0 ms)
[----------] 10 tests from InputControllerTest (0 ms total)
[----------] 16 tests from ReshapeLauncherTest
[ RUN      ] ReshapeLauncherTest.failedToCreateWithNullLayer
[       OK ] ReshapeLauncherTest.failedToCreateWithNullLayer (0 ms)
[ RUN      ] ReshapeLauncherTest.failedToCreateWithNullInsData
[       OK ] ReshapeLauncherTest.failedToCreateWithNullInsData (0 ms)
[ RUN      ] ReshapeLauncherTest.failedToCreateWithExpiredInsData
[       OK ] ReshapeLauncherTest.failedToCreateWithExpiredInsData (0 ms)
[ RUN      ] ReshapeLauncherTest.failedToCreateWithEmptyOutData
[       OK ] ReshapeLauncherTest.failedToCreateWithEmptyOutData (0 ms)
[ RUN      ] ReshapeLauncherTest.failedToCreateWithNullOutData
[       OK ] ReshapeLauncherTest.failedToCreateWithNullOutData (0 ms)
[ RUN      ] ReshapeLauncherTest.failedToCreateWithEmptyImpl
[       OK ] ReshapeLauncherTest.failedToCreateWithEmptyImpl (0 ms)
[ RUN      ] ReshapeLauncherTest.canCreateReshapeLauncher
[       OK ] ReshapeLauncherTest.canCreateReshapeLauncher (0 ms)
[ RUN      ] ReshapeLauncherTest.throwOnReshapeWihtNotEnoughShapes
[       OK ] ReshapeLauncherTest.throwOnReshapeWihtNotEnoughShapes (0 ms)
[ RUN      ] ReshapeLauncherTest.implIsCalledOnReshape
[       OK ] ReshapeLauncherTest.implIsCalledOnReshape (0 ms)
[ RUN      ] ReshapeLauncherTest.canApplyChanges
[       OK ] ReshapeLauncherTest.canApplyChanges (0 ms)
[ RUN      ] ReshapeLauncherTest.throwOnApplyingWithNotEnoughOutput
[       OK ] ReshapeLauncherTest.throwOnApplyingWithNotEnoughOutput (0 ms)
[ RUN      ] ReshapeLauncherTest.throwOnApplyingWithNotEnoughShapes
[       OK ] ReshapeLauncherTest.throwOnApplyingWithNotEnoughShapes (0 ms)
[ RUN      ] ReshapeLauncherTest.canNotApplyForLayerWithAnotherName
[       OK ] ReshapeLauncherTest.canNotApplyForLayerWithAnotherName (0 ms)
[ RUN      ] ReshapeLauncherTest.canNotApplyForLayerWithEmptyInShapes
[       OK ] ReshapeLauncherTest.canNotApplyForLayerWithEmptyInShapes (1 ms)
[ RUN      ] ReshapeLauncherTest.canNotApplyForLayerWithEmptyOutShapes
[       OK ] ReshapeLauncherTest.canNotApplyForLayerWithEmptyOutShapes (0 ms)
[ RUN      ] ReshapeLauncherTest.canReset
[       OK ] ReshapeLauncherTest.canReset (0 ms)
[----------] 16 tests from ReshapeLauncherTest (1 ms total)
[----------] 6 tests from ReshaperTest
[ RUN      ] ReshaperTest.canCreateReshaper
[       OK ] ReshaperTest.canCreateReshaper (0 ms)
[ RUN      ] ReshaperTest.throwOnAddNullExtension
[       OK ] ReshaperTest.throwOnAddNullExtension (0 ms)
[ RUN      ] ReshaperTest.canAddExtensionWithNotRegistered
[       OK ] ReshaperTest.canAddExtensionWithNotRegistered (0 ms)
[ RUN      ] ReshaperTest.throwOnExtensionWithAlreadyRegisteredImpl
[       OK ] ReshaperTest.throwOnExtensionWithAlreadyRegisteredImpl (1 ms)
[ RUN      ] ReshaperTest.canResetOnReshape
[       OK ] ReshaperTest.canResetOnReshape (1 ms)
[ RUN      ] ReshaperTest.canUpdateFakeImpl
[       OK ] ReshaperTest.canUpdateFakeImpl (0 ms)
[----------] 6 tests from ReshaperTest (2 ms total)
[----------] 12 tests from V2TopologyVerificationTests
[ RUN      ] V2TopologyVerificationTests.testNoThrow
[       OK ] V2TopologyVerificationTests.testNoThrow (0 ms)
[ RUN      ] V2TopologyVerificationTests.testDefaultPrecisionsForFP16InputAndOutputLayers
[       OK ] V2TopologyVerificationTests.testDefaultPrecisionsForFP16InputAndOutputLayers (0 ms)
[ RUN      ] V2TopologyVerificationTests.testDefaultPrecisionsFP32InputAndOutputLayers
[       OK ] V2TopologyVerificationTests.testDefaultPrecisionsFP32InputAndOutputLayers (1 ms)
[ RUN      ] V2TopologyVerificationTests.testDefaultPrecisionsForQ78InputAndOutputLayers
[       OK ] V2TopologyVerificationTests.testDefaultPrecisionsForQ78InputAndOutputLayers (0 ms)
[ RUN      ] V2TopologyVerificationTests.testCheckConvolutionInputDim_More
[       OK ] V2TopologyVerificationTests.testCheckConvolutionInputDim_More (0 ms)
[ RUN      ] V2TopologyVerificationTests.testCheckConvolutionInputDim_Less
[       OK ] V2TopologyVerificationTests.testCheckConvolutionInputDim_Less (0 ms)
[ RUN      ] V2TopologyVerificationTests.testCheckPoolingInputDim_Less
[       OK ] V2TopologyVerificationTests.testCheckPoolingInputDim_Less (1 ms)
[ RUN      ] V2TopologyVerificationTests.testCheckPoolingInputDim_More
[       OK ] V2TopologyVerificationTests.testCheckPoolingInputDim_More (0 ms)
[ RUN      ] V2TopologyVerificationTests.testLeayerPrecisionIsNotMIXED
[       OK ] V2TopologyVerificationTests.testLeayerPrecisionIsNotMIXED (0 ms)
[ RUN      ] V2TopologyVerificationTests.testMixedPrecisionIfLayerAndNetworkPrecisionsDiffer
[       OK ] V2TopologyVerificationTests.testMixedPrecisionIfLayerAndNetworkPrecisionsDiffer (1 ms)
[ RUN      ] V2TopologyVerificationTests.throwsIfCropDimIsTooBig
[       OK ] V2TopologyVerificationTests.throwsIfCropDimIsTooBig (0 ms)
[ RUN      ] V2TopologyVerificationTests.testNoThrowWithProperCropParameters
[       OK ] V2TopologyVerificationTests.testNoThrowWithProperCropParameters (0 ms)
[----------] 12 tests from V2TopologyVerificationTests (3 ms total)
[----------] 2 tests from GNAAllocatorTest
[ RUN      ] GNAAllocatorTest.canAllocateStdMemory
[       OK ] GNAAllocatorTest.canAllocateStdMemory (0 ms)
[ RUN      ] GNAAllocatorTest.canAllocateGNAMemory
[       OK ] GNAAllocatorTest.canAllocateGNAMemory (0 ms)
[----------] 2 tests from GNAAllocatorTest (0 ms total)
[----------] 3 tests from GNAAOTTests
[ RUN      ] GNAAOTTests.AffineWith2AffineOutputs_canbe_export_imported
[       OK ] GNAAOTTests.AffineWith2AffineOutputs_canbe_export_imported (2 ms)
[ RUN      ] GNAAOTTests.AffineWith2AffineOutputs_canbe_imported_verify_structure
[       OK ] GNAAOTTests.AffineWith2AffineOutputs_canbe_imported_verify_structure (2 ms)
[ RUN      ] GNAAOTTests.CanConvertFromAOTtoSueModel
[       OK ] GNAAOTTests.CanConvertFromAOTtoSueModel (1 ms)
[----------] 3 tests from GNAAOTTests (5 ms total)
[----------] 5 tests from I8QuantisationTest
[ RUN      ] I8QuantisationTest.canQuantizeFCLayer
[       OK ] I8QuantisationTest.canQuantizeFCLayer (0 ms)
[ RUN      ] I8QuantisationTest.canQuantizeActivation
[       OK ] I8QuantisationTest.canQuantizeActivation (1 ms)
[ RUN      ] I8QuantisationTest.inputPrecisionIs16Bits
[       OK ] I8QuantisationTest.inputPrecisionIs16Bits (0 ms)
[ RUN      ] I8QuantisationTest.failIfFCDimensionIs1
[       OK ] I8QuantisationTest.failIfFCDimensionIs1 (0 ms)
[ RUN      ] I8QuantisationTest.outputAffinePrecisionIs32Bits
[       OK ] I8QuantisationTest.outputAffinePrecisionIs32Bits (0 ms)
[----------] 5 tests from I8QuantisationTest (1 ms total)
[----------] 16 tests from PWLAproximationTest
[ RUN      ] PWLAproximationTest.forTanhOnRecursiveAlgoWithPrecisionThresholdIsSuccess
[       OK ] PWLAproximationTest.forTanhOnRecursiveAlgoWithPrecisionThresholdIsSuccess (4 ms)
[ RUN      ] PWLAproximationTest.forSigmoidOnRecursiveAlgoWithPrecisionThresholdIsSuccess
[       OK ] PWLAproximationTest.forSigmoidOnRecursiveAlgoWithPrecisionThresholdIsSuccess (6 ms)
[ RUN      ] PWLAproximationTest.forReLUonRecursiveAlgoWithPrecisionThresholdIsSuccess
[       OK ] PWLAproximationTest.forReLUonRecursiveAlgoWithPrecisionThresholdIsSuccess (0 ms)
[ RUN      ] PWLAproximationTest.forLeakyReLUonRecursiveAlgoWithPrecisionThresholdIsSuccess
[       OK ] PWLAproximationTest.forLeakyReLUonRecursiveAlgoWithPrecisionThresholdIsSuccess (1 ms)
[ RUN      ] PWLAproximationTest.forClampOnRecursiveAlgoWithPrecisionThresholdIsSuccess
[       OK ] PWLAproximationTest.forClampOnRecursiveAlgoWithPrecisionThresholdIsSuccess (3 ms)
[ RUN      ] PWLAproximationTest.forTanhOnUniformAlgoWithPrecisionThresholdIsSuccess
[       OK ] PWLAproximationTest.forTanhOnUniformAlgoWithPrecisionThresholdIsSuccess (3 ms)
[ RUN      ] PWLAproximationTest.forSigmoidOnUniformAlgoWithPrecisionThresholdIsSuccess
[       OK ] PWLAproximationTest.forSigmoidOnUniformAlgoWithPrecisionThresholdIsSuccess (3 ms)
[ RUN      ] PWLAproximationTest.forClampOnUniformAlgoWithPrecisionThresholdIsSuccess
[       OK ] PWLAproximationTest.forClampOnUniformAlgoWithPrecisionThresholdIsSuccess (3 ms)
[ RUN      ] PWLAproximationTest.forSigmoidonRecursiveAlgoWithSegmentThresholdIsSuccess
[       OK ] PWLAproximationTest.forSigmoidonRecursiveAlgoWithSegmentThresholdIsSuccess (5 ms)
[ RUN      ] PWLAproximationTest.forTanhonRecursiveAlgoWithSegmentThresholdIsSuccess
[       OK ] PWLAproximationTest.forTanhonRecursiveAlgoWithSegmentThresholdIsSuccess (4 ms)
[ RUN      ] PWLAproximationTest.forReLUonRecursiveAlgoWithSegmentThresholdIsSuccess
[       OK ] PWLAproximationTest.forReLUonRecursiveAlgoWithSegmentThresholdIsSuccess (1 ms)
[ RUN      ] PWLAproximationTest.forLeakyReLUonRecursiveAlgoWithSegmentThresholdIsSuccess
[       OK ] PWLAproximationTest.forLeakyReLUonRecursiveAlgoWithSegmentThresholdIsSuccess (1 ms)
[ RUN      ] PWLAproximationTest.forClampOnRecursiveAlgoWithSegmentThresholdIsSuccess
[       OK ] PWLAproximationTest.forClampOnRecursiveAlgoWithSegmentThresholdIsSuccess (3 ms)
[ RUN      ] PWLAproximationTest.forSigmoidonUniformAlgoWithSegmentThresholdIsSuccess
[       OK ] PWLAproximationTest.forSigmoidonUniformAlgoWithSegmentThresholdIsSuccess (4 ms)
[ RUN      ] PWLAproximationTest.forTanhonUniformAlgoWithSegmentThresholdIsSuccess
[       OK ] PWLAproximationTest.forTanhonUniformAlgoWithSegmentThresholdIsSuccess (2 ms)
[ RUN      ] PWLAproximationTest.forClampOnUniformAlgoWithSegmentThresholdIsSuccess
[       OK ] PWLAproximationTest.forClampOnUniformAlgoWithSegmentThresholdIsSuccess (3 ms)
[----------] 16 tests from PWLAproximationTest (47 ms total)
[----------] 2 tests from QueryStateTest
[ RUN      ] QueryStateTest.returnEmptyCollectionOfStatesIfNoMemoryInIR
[       OK ] QueryStateTest.returnEmptyCollectionOfStatesIfNoMemoryInIR (2 ms)
[ RUN      ] QueryStateTest.returnNonEmptyCollectionOfStatesForMemoryIR
[       OK ] QueryStateTest.returnNonEmptyCollectionOfStatesForMemoryIR (1 ms)
[----------] 2 tests from QueryStateTest (3 ms total)
[----------] 4 tests from GNAHWPrecisionTest
[ RUN      ] GNAHWPrecisionTest.defaultPrecisionIsInt16
[       OK ] GNAHWPrecisionTest.defaultPrecisionIsInt16 (0 ms)
[ RUN      ] GNAHWPrecisionTest.canPassInt8Precision
[       OK ] GNAHWPrecisionTest.canPassInt8Precision (0 ms)
[ RUN      ] GNAHWPrecisionTest.canPassInt16Precision
[       OK ] GNAHWPrecisionTest.canPassInt16Precision (0 ms)
[ RUN      ] GNAHWPrecisionTest.failToCreatePluginWithUnsuportedPrecision
[       OK ] GNAHWPrecisionTest.failToCreatePluginWithUnsuportedPrecision (0 ms)
[----------] 4 tests from GNAHWPrecisionTest (1 ms total)
[----------] 10 tests from GNAConfigTest
[ RUN      ] GNAConfigTest.reportAnErrorIfConfigNotFound
[       OK ] GNAConfigTest.reportAnErrorIfConfigNotFound (0 ms)
[ RUN      ] GNAConfigTest.canFindConfiguration
[       OK ] GNAConfigTest.canFindConfiguration (0 ms)
[ RUN      ] GNAConfigTest.canPassTroughNetworkAfterFindConfiguration
[       OK ] GNAConfigTest.canPassTroughNetworkAfterFindConfiguration (0 ms)
[ RUN      ] GNAConfigTest.canNotMatchWithDefaultDevice
[       OK ] GNAConfigTest.canNotMatchWithDefaultDevice (0 ms)
[ RUN      ] GNAConfigTest.canMatchWithDefaultDevice
[       OK ] GNAConfigTest.canMatchWithDefaultDevice (0 ms)
[ RUN      ] GNAConfigTest.canMatchWith1AsyncThread
[       OK ] GNAConfigTest.canMatchWith1AsyncThread (1 ms)
[ RUN      ] GNAConfigTest.canMatchWith4AsyncThreads
[       OK ] GNAConfigTest.canMatchWith4AsyncThreads (0 ms)
[ RUN      ] GNAConfigTest.canNOTMatchWith0AsyncThreads
[       OK ] GNAConfigTest.canNOTMatchWith0AsyncThreads (0 ms)
[ RUN      ] GNAConfigTest.canNOTMatchWith128AsyncThreads
[       OK ] GNAConfigTest.canNOTMatchWith128AsyncThreads (0 ms)
[ RUN      ] GNAConfigTest.canMatchWithSingleMultipleOMPThreads
[       OK ] GNAConfigTest.canMatchWithSingleMultipleOMPThreads (1 ms)
[----------] 10 tests from GNAConfigTest (2 ms total)
[----------] 20 tests from GNAMemoryTest
[ RUN      ] GNAMemoryTest.canStoreActualBlob
[       OK ] GNAMemoryTest.canStoreActualBlob (0 ms)
[ RUN      ] GNAMemoryTest.canStore2Blobs
[       OK ] GNAMemoryTest.canStore2Blobs (0 ms)
[ RUN      ] GNAMemoryTest.canStoreBlobsALIGNED
[       OK ] GNAMemoryTest.canStoreBlobsALIGNED (0 ms)
[ RUN      ] GNAMemoryTest.canStore2BlobsALIGNED
[       OK ] GNAMemoryTest.canStore2BlobsALIGNED (0 ms)
[ RUN      ] GNAMemoryTest.canReserveData
[       OK ] GNAMemoryTest.canReserveData (0 ms)
[ RUN      ] GNAMemoryTest.canReserveDataByVoid
[       OK ] GNAMemoryTest.canReserveDataByVoid (0 ms)
[ RUN      ] GNAMemoryTest.canReserveAndPushData
[       OK ] GNAMemoryTest.canReserveAndPushData (0 ms)
[ RUN      ] GNAMemoryTest.canBindAndResolve
[       OK ] GNAMemoryTest.canBindAndResolve (0 ms)
[ RUN      ] GNAMemoryTest.canBindTransitevlyAndResolve
[       OK ] GNAMemoryTest.canBindTransitevlyAndResolve (0 ms)
[ RUN      ] GNAMemoryTest.canBindTransitevlyWithOffsetsAndResolve
[       OK ] GNAMemoryTest.canBindTransitevlyWithOffsetsAndResolve (0 ms)
[ RUN      ] GNAMemoryTest.canBindWithOffsetAndResolve
[       OK ] GNAMemoryTest.canBindWithOffsetAndResolve (0 ms)
[ RUN      ] GNAMemoryTest.canPushLocal
[       OK ] GNAMemoryTest.canPushLocal (0 ms)
[ RUN      ] GNAMemoryTest.canPushValue
[       OK ] GNAMemoryTest.canPushValue (0 ms)
[ RUN      ] GNAMemoryTest.canPushReadOnlyValue
[       OK ] GNAMemoryTest.canPushReadOnlyValue (0 ms)
[ RUN      ] GNAMemoryTest.canCalculateReadWriteSectionSize
[       OK ] GNAMemoryTest.canCalculateReadWriteSectionSize (0 ms)
[ RUN      ] GNAMemoryTest.canCalculateReadWriteSectionSizeWithAlignment
[       OK ] GNAMemoryTest.canCalculateReadWriteSectionSizeWithAlignment (0 ms)
[ RUN      ] GNAMemoryTest.canSetUpReadWriteSectionPtr
[       OK ] GNAMemoryTest.canSetUpReadWriteSectionPtr (0 ms)
[ RUN      ] GNAMemoryTest.canUpdateSizeOfPushRequestWithBindRequest
[       OK ] GNAMemoryTest.canUpdateSizeOfPushRequestWithBindRequest (0 ms)
[ RUN      ] GNAMemoryTest.canUpdateSizeOfPushRequestWithBindRequestWhenPush
[       OK ] GNAMemoryTest.canUpdateSizeOfPushRequestWithBindRequestWhenPush (0 ms)
[ RUN      ] GNAMemoryTest.canUpdateSizeOfPushRequestWithBindRequestWhenAlloc
[       OK ] GNAMemoryTest.canUpdateSizeOfPushRequestWithBindRequestWhenAlloc (0 ms)
[----------] 20 tests from GNAMemoryTest (0 ms total)
[----------] 4 tests from GNAProcTypeTest
[ RUN      ] GNAProcTypeTest.defaultProcTypeIsSWEXACT
[       OK ] GNAProcTypeTest.defaultProcTypeIsSWEXACT (1 ms)
[ RUN      ] GNAProcTypeTest.canPassHWProcTypeToGNA
[       OK ] GNAProcTypeTest.canPassHWProcTypeToGNA (0 ms)
[ RUN      ] GNAProcTypeTest.canPassSWProcTypeToGNA
[       OK ] GNAProcTypeTest.canPassSWProcTypeToGNA (0 ms)
[ RUN      ] GNAProcTypeTest.canPassSWEXACTProcTypeToGNA
[       OK ] GNAProcTypeTest.canPassSWEXACTProcTypeToGNA (1 ms)
[----------] 4 tests from GNAProcTypeTest (2 ms total)
[----------] 32 tests from I16QuantisationTest
[ RUN      ] I16QuantisationTest.canQuantizeFCLayer
[       OK ] I16QuantisationTest.canQuantizeFCLayer (0 ms)
[ RUN      ] I16QuantisationTest.canQuantizeActivation
[       OK ] I16QuantisationTest.canQuantizeActivation (0 ms)
[ RUN      ] I16QuantisationTest.outputAffinePrecisionIs32Bits
[       OK ] I16QuantisationTest.outputAffinePrecisionIs32Bits (0 ms)
[ RUN      ] I16QuantisationTest.canQuantizeLstmLikeTopology
[       OK ] I16QuantisationTest.canQuantizeLstmLikeTopology (0 ms)
[ RUN      ] I16QuantisationTest.OnlyAffine_NoActivationInsertion
[       OK ] I16QuantisationTest.OnlyAffine_NoActivationInsertion (1 ms)
[ RUN      ] I16QuantisationTest.OnlyAffine_NoActivationInsertion_ProfilingEnabled
[       OK ] I16QuantisationTest.OnlyAffine_NoActivationInsertion_ProfilingEnabled (0 ms)
[ RUN      ] I16QuantisationTest.OnlyAffineWithNanScaleFactorFails
[       OK ] I16QuantisationTest.OnlyAffineWithNanScaleFactorFails (0 ms)
[ RUN      ] I16QuantisationTest.OnlyAffineWithInfScaleFactorFails
[       OK ] I16QuantisationTest.OnlyAffineWithInfScaleFactorFails (0 ms)
[ RUN      ] I16QuantisationTest.AffineToMemoryWillResultInActivationInsertion
[       OK ] I16QuantisationTest.AffineToMemoryWillResultInActivationInsertion (1 ms)
[ RUN      ] I16QuantisationTest.EltwiseToMemoryWithNoOutputActivationInsertion
[       OK ] I16QuantisationTest.EltwiseToMemoryWithNoOutputActivationInsertion (1 ms)
[ RUN      ] I16QuantisationTest.EltwiseToMemory_ActivationInsertion
[       OK ] I16QuantisationTest.EltwiseToMemory_ActivationInsertion (0 ms)
[ RUN      ] I16QuantisationTest.SplitFollowedByActivation_DummyDiagonalAffineInsertion
[       OK ] I16QuantisationTest.SplitFollowedByActivation_DummyDiagonalAffineInsertion (1 ms)
[ RUN      ] I16QuantisationTest.SplitFollowedByFCAndEltwiseOnCPU
[       OK ] I16QuantisationTest.SplitFollowedByFCAndEltwiseOnCPU (1 ms)
[ RUN      ] I16QuantisationTest.SliceFollowedByFCAndEltwiseOnCPU
[       OK ] I16QuantisationTest.SliceFollowedByFCAndEltwiseOnCPU (0 ms)
[ RUN      ] I16QuantisationTest.SliceFollowedByAlignedFCAndEltwiseOnCPU
[       OK ] I16QuantisationTest.SliceFollowedByAlignedFCAndEltwiseOnCPU (0 ms)
[ RUN      ] I16QuantisationTest.SliceFollowedBy2FCsAnd2EltwisesOnCPU
[       OK ] I16QuantisationTest.SliceFollowedBy2FCsAnd2EltwisesOnCPU (1 ms)
[ RUN      ] I16QuantisationTest.EltwiseSumm_onlyOneIdentityInsertion
[       OK ] I16QuantisationTest.EltwiseSumm_onlyOneIdentityInsertion (1 ms)
[ RUN      ] I16QuantisationTest.canDetectLeakyRelu
[       OK ] I16QuantisationTest.canDetectLeakyRelu (5 ms)
[ RUN      ] I16QuantisationTest.MaxPool_followedAfterActivation
[       OK ] I16QuantisationTest.MaxPool_followedAfterActivation (9 ms)
[ RUN      ] I16QuantisationTest.EltwiseMull_willInsertTwoIdentities
[       OK ] I16QuantisationTest.EltwiseMull_willInsertTwoIdentities (0 ms)
[ RUN      ] I16QuantisationTest.ConcatPropagateForwardWithSuccessOnCPU
[       OK ] I16QuantisationTest.ConcatPropagateForwardWithSuccessOnCPU (1 ms)
[ RUN      ] I16QuantisationTest.DoubleConcatPropageteForwardWithSuccessOnCPU
[       OK ] I16QuantisationTest.DoubleConcatPropageteForwardWithSuccessOnCPU (1 ms)
[ RUN      ] I16QuantisationTest.ScaleShift_Affine_WillResultInIdentityInsertion
[       OK ] I16QuantisationTest.ScaleShift_Affine_WillResultInIdentityInsertion (0 ms)
[ RUN      ] I16QuantisationTest.ClampFollowedByTanh_ResultInDiagonalInsertion
[       OK ] I16QuantisationTest.ClampFollowedByTanh_ResultInDiagonalInsertion (2 ms)
[ RUN      ] I16QuantisationTest.EltwiseWithMemoryAndActivationInput_ResultInDiagonalInsertion
[       OK ] I16QuantisationTest.EltwiseWithMemoryAndActivationInput_ResultInDiagonalInsertion (2 ms)
[ RUN      ] I16QuantisationTest.AffineWith2AffineOutputs_ResultInOnlyOneIdentityInsertion
[       OK ] I16QuantisationTest.AffineWith2AffineOutputs_ResultInOnlyOneIdentityInsertion (1 ms)
[ RUN      ] I16QuantisationTest.CropWithoutOffsetPropagateForwardWithSuccessOnCPU
[       OK ] I16QuantisationTest.CropWithoutOffsetPropagateForwardWithSuccessOnCPU (1 ms)
[ RUN      ] I16QuantisationTest.CropWithAlignedOffsetPropagateForwardWithSuccessOnCPU
[       OK ] I16QuantisationTest.CropWithAlignedOffsetPropagateForwardWithSuccessOnCPU (0 ms)
[ RUN      ] I16QuantisationTest.CropWithOffsetPropagateForwardWithSuccessOnCPU
[       OK ] I16QuantisationTest.CropWithOffsetPropagateForwardWithSuccessOnCPU (0 ms)
[ RUN      ] I16QuantisationTest.CropWithMaxOffsetPropagateForwardWithSuccessOnCPU
[       OK ] I16QuantisationTest.CropWithMaxOffsetPropagateForwardWithSuccessOnCPU (1 ms)
[ RUN      ] I16QuantisationTest.CropWithOffsetAfterFCPropagateForwardWithSuccessOnCPU
[       OK ] I16QuantisationTest.CropWithOffsetAfterFCPropagateForwardWithSuccessOnCPU (0 ms)
[ RUN      ] I16QuantisationTest.CopySimpleCasePropagateForwardWithSuccessOnCPU
[       OK ] I16QuantisationTest.CopySimpleCasePropagateForwardWithSuccessOnCPU (0 ms)
[----------] 32 tests from I16QuantisationTest (31 ms total)
[----------] 7 tests from MKLDNNDumpTests
[ RUN      ] MKLDNNDumpTests.UnallocatedBlob_NoDump
[       OK ] MKLDNNDumpTests.UnallocatedBlob_NoDump (0 ms)
[ RUN      ] MKLDNNDumpTests.EmptyBlob_NoDump
[       OK ] MKLDNNDumpTests.EmptyBlob_NoDump (0 ms)
[ RUN      ] MKLDNNDumpTests.Ser
[       OK ] MKLDNNDumpTests.Ser (1 ms)
[ RUN      ] MKLDNNDumpTests.SerDeser
[       OK ] MKLDNNDumpTests.SerDeser (0 ms)
[ RUN      ] MKLDNNDumpTests.SerDeserWithScales
[       OK ] MKLDNNDumpTests.SerDeserWithScales (0 ms)
[ RUN      ] MKLDNNDumpTests.SerU8AsTxt
[       OK ] MKLDNNDumpTests.SerU8AsTxt (0 ms)
[ RUN      ] MKLDNNDumpTests.SerAsTxt
[       OK ] MKLDNNDumpTests.SerAsTxt (0 ms)
[----------] 7 tests from MKLDNNDumpTests (1 ms total)
[----------] 1 test from MKLDNNConstantPropagationTests
[ RUN      ] MKLDNNConstantPropagationTests.ConcatAfterConstLayers
MEM_USAGE=221736KB
[       OK ] MKLDNNConstantPropagationTests.ConcatAfterConstLayers (1 ms)
[----------] 1 test from MKLDNNConstantPropagationTests (1 ms total)
[----------] 2 tests from MKLDNNLayersTests
[ RUN      ] MKLDNNLayersTests.DumpSimpleGraph
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/dumper_test.cpp:76: Failure
      Expected: layers.size()
      Which is: 3
To be equal to: 4
[  FAILED  ] MKLDNNLayersTests.DumpSimpleGraph (6 ms)
[ RUN      ] MKLDNNLayersTests.DumpSimpleGraphToDot
strict digraph Network {
	layer_Input0 [shape="box", style="filled", fillcolor="#D9EAD3", fillcolor="#D9EAD3", label="Input0\ntype: Input\nimpl: unknown\nprecision: FP32"];
	data_Input0_out0 [shape="ellipse", style="filled", fillcolor="#FCF6E3", label="Input0_out0\ndims: [16, 16, 3, 2]\nprecision: FP32"];
	layer_Input0 -> data_Input0_out0;
	layer_Convolution1 [shape="box", style="filled", fillcolor="#D9EAD3", fillcolor="#D9EAD3", label="Convolution1\ntype: Conv_Activ\nimpl: jit_gemm_FP32\nprecision: FP32"];
	data_Convolution1_out0 [shape="ellipse", style="filled", fillcolor="#FCF6E3", label="Convolution1_out0\ndims: [16, 16, 16, 2]\nprecision: FP32"];
	layer_Convolution1 -> data_Convolution1_out0;
	data_Input0_out0 -> layer_Convolution1;
	layer_out_Relu2 [shape="box", style="filled", fillcolor="#D9EAD3", fillcolor="#D9EAD3", label="out_Relu2\ntype: Output\nimpl: unknown_FP32\nprecision: FP32"];
	data_Convolution1_out0 -> layer_out_Relu2;
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/dumper_test.cpp:96: Failure
      Expected: std::count(dot.begin(), dot.end(), '[')
      Which is: 7
To be equal to: 10
[  FAILED  ] MKLDNNLayersTests.DumpSimpleGraphToDot (4 ms)
[----------] 2 tests from MKLDNNLayersTests (10 ms total)
[----------] 10 tests from MKLDNNGraphGenericTests
[ RUN      ] MKLDNNGraphGenericTests.canGetPrimitiveDescriptorsList
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.canGetPrimitiveDescriptorsList (0 ms)
[ RUN      ] MKLDNNGraphGenericTests.DontCreateGPUGenericPrimitive
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.DontCreateGPUGenericPrimitive (0 ms)
[ RUN      ] MKLDNNGraphGenericTests.ExecuteConstGenericPrimitive
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.ExecuteConstGenericPrimitive (1 ms)
[ RUN      ] MKLDNNGraphGenericTests.ExecuteGenericPrimitive
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.ExecuteGenericPrimitive (0 ms)
[ RUN      ] MKLDNNGraphGenericTests.ExecuteGenericPrimitiveWithTwoOutputs
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.ExecuteGenericPrimitiveWithTwoOutputs (2 ms)
[ RUN      ] MKLDNNGraphGenericTests.ExecuteGenericInPlaceConcat
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.ExecuteGenericInPlaceConcat (0 ms)
[ RUN      ] MKLDNNGraphGenericTests.ExecuteGenericInPlaceSplit
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.ExecuteGenericInPlaceSplit (14 ms)
[ RUN      ] MKLDNNGraphGenericTests.ExecuteGenericPrimitiveWithDynamicBatch
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.ExecuteGenericPrimitiveWithDynamicBatch (1 ms)
[ RUN      ] MKLDNNGraphGenericTests.ExecuteNotInLineGRN
MEM_USAGE=287272KB
[       OK ] MKLDNNGraphGenericTests.ExecuteNotInLineGRN (10 ms)
[ RUN      ] MKLDNNGraphGenericTests.ExecuteInLineGRN
MEM_USAGE=296224KB
[       OK ] MKLDNNGraphGenericTests.ExecuteInLineGRN (6 ms)
[----------] 10 tests from MKLDNNGraphGenericTests (35 ms total)
[----------] 1 test from MKLDNNGraphConstInputTests
[ RUN      ] MKLDNNGraphConstInputTests.TestsConstInput
MEM_USAGE=296224KB
72
[       OK ] MKLDNNGraphConstInputTests.TestsConstInput (1 ms)
[----------] 1 test from MKLDNNGraphConstInputTests (1 ms total)
[----------] 3 tests from MKLDNNGraphReorderTests
[ RUN      ] MKLDNNGraphReorderTests.cannotCreatePrimitiveDescriprorsWithoutOtherLayers
MEM_USAGE=296224KB
[       OK ] MKLDNNGraphReorderTests.cannotCreatePrimitiveDescriprorsWithoutOtherLayers (0 ms)
[ RUN      ] MKLDNNGraphReorderTests.CreateReorder
MEM_USAGE=296224KB
[       OK ] MKLDNNGraphReorderTests.CreateReorder (14 ms)
[ RUN      ] MKLDNNGraphReorderTests.CreateInPlaceReorder
MEM_USAGE=296224KB
[       OK ] MKLDNNGraphReorderTests.CreateInPlaceReorder (2 ms)
[----------] 3 tests from MKLDNNGraphReorderTests (18 ms total)
[----------] 1 test from MKLDNNGraphLeaksTests
[ RUN      ] MKLDNNGraphLeaksTests.MKLDNN_not_release_outputs_fp32
[       OK ] MKLDNNGraphLeaksTests.MKLDNN_not_release_outputs_fp32 (302 ms)
[----------] 1 test from MKLDNNGraphLeaksTests (302 ms total)
[----------] 1 test from MKLDNNGraphTwoInputInConcatTests
[ RUN      ] MKLDNNGraphTwoInputInConcatTests.TestSecondInputToConcat
MEM_USAGE=644400KB
[       OK ] MKLDNNGraphTwoInputInConcatTests.TestSecondInputToConcat (2 ms)
[----------] 1 test from MKLDNNGraphTwoInputInConcatTests (2 ms total)
[----------] 30 tests from MKLDNNGraphStructureTests
[ RUN      ] MKLDNNGraphStructureTests.TestNoRedundantReorders
MEM_USAGE=644400KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_structure_test.cpp:194: Failure
      Expected: reorders_num
      Which is: 0
To be equal to: 1
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReorders (145 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestRedundantReorderBeforeConvWithC_3
MEM_USAGE=644400KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_structure_test.cpp:308: Failure
      Which is: 0
To be equal to: 3
[  FAILED  ] MKLDNNGraphStructureTests.TestRedundantReorderBeforeConvWithC_3 (79 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestNoRedundantReordersBeforeConcat
MEM_USAGE=656524KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_structure_test.cpp:471: Failure
      Which is: 0
To be equal to: 2
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReordersBeforeConcat (20 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestNoRedundantReordersBeforeDWConvolution
MEM_USAGE=656524KB
[       OK ] MKLDNNGraphStructureTests.TestNoRedundantReordersBeforeDWConvolution (10 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestSeveralOutputToNextLayer
MEM_USAGE=656524KB
[       OK ] MKLDNNGraphStructureTests.TestSeveralOutputToNextLayer (1 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestOutputAfterInplacePlusConcat
MEM_USAGE=656524KB
[       OK ] MKLDNNGraphStructureTests.TestOutputAfterInplacePlusConcat (22 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestResnetPart
MEM_USAGE=656524KB
[       OK ] MKLDNNGraphStructureTests.TestResnetPart (3617 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestConcatAfterConcat
MEM_USAGE=656524KB
[       OK ] MKLDNNGraphStructureTests.TestConcatAfterConcat (7 ms)
[ RUN      ] MKLDNNGraphStructureTests.Test2ConcatFromConcat
MEM_USAGE=656524KB
[       OK ] MKLDNNGraphStructureTests.Test2ConcatFromConcat (4 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestResultsAfterGroupedConvWithStrides
MEM_USAGE=656524KB
[       OK ] MKLDNNGraphStructureTests.TestResultsAfterGroupedConvWithStrides (2312 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestLoadTopologyWithConstLayer
MEM_USAGE=656808KB
[       OK ] MKLDNNGraphStructureTests.TestLoadTopologyWithConstLayer (5 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestLoadTopologyWithEltwiseBeforeConcat
MEM_USAGE=656808KB
[       OK ] MKLDNNGraphStructureTests.TestLoadTopologyWithEltwiseBeforeConcat (11 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestNoRedundantReordersRmnet_SSSSD
MEM_USAGE=656808KB
unknown file: Failure
C++ exception with description "Supported primitive descriptors list is empty for node: bottleneck1_1/dim_red/conv" thrown in the test body.
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReordersRmnet_SSSSD (7 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestFailedPartDPN92
MEM_USAGE=656808KB
[       OK ] MKLDNNGraphStructureTests.TestFailedPartDPN92 (627 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestNoRedundantReordersForXceptionTopology
MEM_USAGE=656808KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_structure_test.cpp:3821: Failure
      Which is: 0
To be equal to: 1
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReordersForXceptionTopology (107 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestNoRedundantReordersForGrayscaleInput
MEM_USAGE=656808KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_structure_test.cpp:3889: Failure
      Which is: 0
To be equal to: 1
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReordersForGrayscaleInput (4 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestFailedPartPlateRecognitionBarrier0001
MEM_USAGE=656808KB
[       OK ] MKLDNNGraphStructureTests.TestFailedPartPlateRecognitionBarrier0001 (379 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestFailedVNect0001
MEM_USAGE=660376KB
[       OK ] MKLDNNGraphStructureTests.TestFailedVNect0001 (53 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestFailedVNect0002
MEM_USAGE=660376KB
[       OK ] MKLDNNGraphStructureTests.TestFailedVNect0002 (21 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestFailedVNect0003
MEM_USAGE=660376KB
[       OK ] MKLDNNGraphStructureTests.TestFailedVNect0003 (4 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestConvolutionDWConvolutionSumFusing
MEM_USAGE=660376KB
C++ exception with description "Supported primitive descriptors list is empty for node: conv0" thrown in the test body.
[  FAILED  ] MKLDNNGraphStructureTests.TestConvolutionDWConvolutionSumFusing (3 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestConstantLayerAsOutput
MEM_USAGE=660376KB
[       OK ] MKLDNNGraphStructureTests.TestConstantLayerAsOutput (31 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestGemmConvolutionWithConcat
MEM_USAGE=660376KB
[       OK ] MKLDNNGraphStructureTests.TestGemmConvolutionWithConcat (518 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestRefPoolingWithConcat
MEM_USAGE=660376KB
performance counts:
conv1                         EXECUTED       layerType: Convolution        realTime: 15575      cpu: 15575          execType: jit_gemm_FP32
fire2/concat                  EXECUTED       layerType: Concat             realTime: 1          cpu: 1              execType: unknown_FP32
fire2/expand1x1               EXECUTED       layerType: Convolution        realTime: 2551       cpu: 2551           execType: jit_gemm_FP32
fire2/expand3x3               EXECUTED       layerType: Pooling            realTime: 1060       cpu: 1060           execType: ref_any_FP32
fire2/relu_expand1x1          NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire2/relu_squeeze1x1         NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
fire2/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 1114       cpu: 1114           execType: jit_gemm_FP32
out_fire2/concat              NOT_RUN        layerType: Output             realTime: 0          cpu: 0              execType: unknown_FP32
pool1                         EXECUTED       layerType: Pooling            realTime: 37627      cpu: 37627          execType: ref_any_FP32
relu_conv1                    NOT_RUN        layerType: ReLU               realTime: 0          cpu: 0              execType: undef
Total time: 57928    microseconds
performance counts:
conv1                         EXECUTED       layerType: Convolution        realTime: 10724      cpu: 10724          execType: jit_gemm_FP32
fire2/expand1x1               EXECUTED       layerType: Convolution        realTime: 1078       cpu: 1078           execType: jit_gemm_FP32
fire2/expand3x3               EXECUTED       layerType: Pooling            realTime: 1080       cpu: 1080           execType: ref_any_FP32
fire2/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 1151       cpu: 1151           execType: jit_gemm_FP32
out_fire2/concat              EXECUTED       layerType: Output             realTime: 1          cpu: 1              execType: unknown_FP32
pool1                         EXECUTED       layerType: Pooling            realTime: 12315      cpu: 12315          execType: ref_any_FP32
Total time: 26350    microseconds
performance counts:
conv1                         EXECUTED       layerType: Convolution        realTime: 13257      cpu: 13257          execType: jit_gemm_FP32
fire2/expand1x1               EXECUTED       layerType: Convolution        realTime: 1126       cpu: 1126           execType: jit_gemm_FP32
fire2/expand3x3               EXECUTED       layerType: Pooling            realTime: 1061       cpu: 1061           execType: ref_any_FP32
fire2/squeeze1x1              EXECUTED       layerType: Convolution        realTime: 1093       cpu: 1093           execType: jit_gemm_FP32
pool1                         EXECUTED       layerType: Pooling            realTime: 11296      cpu: 11296          execType: ref_any_FP32
Total time: 27835    microseconds
[       OK ] MKLDNNGraphStructureTests.TestRefPoolingWithConcat (187 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestConvolutionWith2DepthwiseOpFusing
MEM_USAGE=660376KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_structure_test.cpp:5678: Failure
      Expected: nodes.size()
      Which is: 3
To be equal to: 5
[  FAILED  ] MKLDNNGraphStructureTests.TestConvolutionWith2DepthwiseOpFusing (65 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestConvolutionWith2EltwiseOpFusing
MEM_USAGE=660376KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_structure_test.cpp:5817: Failure
      Which is: 3
To be equal to: 4
[  FAILED  ] MKLDNNGraphStructureTests.TestConvolutionWith2EltwiseOpFusing (63 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestGemmConvolutionWith2DepthwiseOpFusing
MEM_USAGE=660376KB
[       OK ] MKLDNNGraphStructureTests.TestGemmConvolutionWith2DepthwiseOpFusing (121 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestCreateGraphWithSplit
MEM_USAGE=685376KB
[       OK ] MKLDNNGraphStructureTests.TestCreateGraphWithSplit (1 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestCreateGraphWithFakeOutput
MEM_USAGE=685376KB
[       OK ] MKLDNNGraphStructureTests.TestCreateGraphWithFakeOutput (5 ms)
[ RUN      ] MKLDNNGraphStructureTests.TestCreateGraphWithMultipleData
MEM_USAGE=685376KB
[       OK ] MKLDNNGraphStructureTests.TestCreateGraphWithMultipleData (10 ms)
[----------] 30 tests from MKLDNNGraphStructureTests (8440 ms total)
[----------] 3 tests from MKLDNNGraphOptimizationTests
[ RUN      ] MKLDNNGraphOptimizationTests.TestNoFuseConvSumWithOneInput
MEM_USAGE=685376KB
[       OK ] MKLDNNGraphOptimizationTests.TestNoFuseConvSumWithOneInput (5 ms)
[ RUN      ] MKLDNNGraphOptimizationTests.TestNoCrashForFuseConvSumAndInput
MEM_USAGE=685376KB
[       OK ] MKLDNNGraphOptimizationTests.TestNoCrashForFuseConvSumAndInput (23 ms)
[ RUN      ] MKLDNNGraphOptimizationTests.TestNoFuseCustomActivation
MEM_USAGE=685376KB
[       OK ] MKLDNNGraphOptimizationTests.TestNoFuseCustomActivation (32 ms)
[----------] 3 tests from MKLDNNGraphOptimizationTests (61 ms total)
[----------] 26 tests from Task/TaskCommonTests
[ RUN      ] Task/TaskCommonTests.canCreateTask/BASE_TASK
[       OK ] Task/TaskCommonTests.canCreateTask/BASE_TASK (4 ms)
[ RUN      ] Task/TaskCommonTests.canCreateTask/STAGED_TASK
[       OK ] Task/TaskCommonTests.canCreateTask/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canSetBusyStatus/BASE_TASK
[       OK ] Task/TaskCommonTests.canSetBusyStatus/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canSetBusyStatus/STAGED_TASK
[       OK ] Task/TaskCommonTests.canSetBusyStatus/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.firstOccupyReturnTrueSecondFalse/BASE_TASK
[       OK ] Task/TaskCommonTests.firstOccupyReturnTrueSecondFalse/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.firstOccupyReturnTrueSecondFalse/STAGED_TASK
[       OK ] Task/TaskCommonTests.firstOccupyReturnTrueSecondFalse/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canRunDefaultTask/BASE_TASK
[       OK ] Task/TaskCommonTests.canRunDefaultTask/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canRunDefaultTask/STAGED_TASK
[       OK ] Task/TaskCommonTests.canRunDefaultTask/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.throwIfFunctionNull/BASE_TASK
[       OK ] Task/TaskCommonTests.throwIfFunctionNull/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.throwIfFunctionNull/STAGED_TASK
[       OK ] Task/TaskCommonTests.throwIfFunctionNull/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canWaitWithoutRun/BASE_TASK
[       OK ] Task/TaskCommonTests.canWaitWithoutRun/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canWaitWithoutRun/STAGED_TASK
[       OK ] Task/TaskCommonTests.canWaitWithoutRun/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canRunTaskFromThread/BASE_TASK
[       OK ] Task/TaskCommonTests.canRunTaskFromThread/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canRunTaskFromThread/STAGED_TASK
[       OK ] Task/TaskCommonTests.canRunTaskFromThread/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canRunTaskFromThreadWithoutWait/BASE_TASK
[       OK ] Task/TaskCommonTests.canRunTaskFromThreadWithoutWait/BASE_TASK (500 ms)
[ RUN      ] Task/TaskCommonTests.canRunTaskFromThreadWithoutWait/STAGED_TASK
[       OK ] Task/TaskCommonTests.canRunTaskFromThreadWithoutWait/STAGED_TASK (501 ms)
[ RUN      ] Task/TaskCommonTests.waitReturnNotStartedIfTaskWasNotRun/BASE_TASK
[       OK ] Task/TaskCommonTests.waitReturnNotStartedIfTaskWasNotRun/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.waitReturnNotStartedIfTaskWasNotRun/STAGED_TASK
[       OK ] Task/TaskCommonTests.waitReturnNotStartedIfTaskWasNotRun/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canCatchIEException/BASE_TASK
[       OK ] Task/TaskCommonTests.canCatchIEException/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canCatchIEException/STAGED_TASK
[       OK ] Task/TaskCommonTests.canCatchIEException/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.waitReturnErrorIfException/BASE_TASK
[       OK ] Task/TaskCommonTests.waitReturnErrorIfException/BASE_TASK (1 ms)
[ RUN      ] Task/TaskCommonTests.waitReturnErrorIfException/STAGED_TASK
[       OK ] Task/TaskCommonTests.waitReturnErrorIfException/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canCatchStdException/BASE_TASK
[       OK ] Task/TaskCommonTests.canCatchStdException/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canCatchStdException/STAGED_TASK
[       OK ] Task/TaskCommonTests.canCatchStdException/STAGED_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canCleanExceptionPtr/BASE_TASK
[       OK ] Task/TaskCommonTests.canCleanExceptionPtr/BASE_TASK (0 ms)
[ RUN      ] Task/TaskCommonTests.canCleanExceptionPtr/STAGED_TASK
[       OK ] Task/TaskCommonTests.canCleanExceptionPtr/STAGED_TASK (0 ms)
[----------] 26 tests from Task/TaskCommonTests (1010 ms total)
[----------] 5 tests from BuiltInImplsFake2/BuiltInShapeInferImplFakeTest
[ RUN      ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/0
[       OK ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/0 (2 ms)
[ RUN      ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/1
[       OK ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/1 (1 ms)
[ RUN      ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/2
[       OK ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/2 (1 ms)
[ RUN      ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/3
[       OK ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/3 (1 ms)
[ RUN      ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/4
[       OK ] BuiltInImplsFake2/BuiltInShapeInferImplFakeTest.reshaper/4 (0 ms)
[----------] 5 tests from BuiltInImplsFake2/BuiltInShapeInferImplFakeTest (5 ms total)
[----------] 24 tests from BuiltInEqualImpls/BuiltInShapeInferImplTest
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/0
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/0 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/1
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/1 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/2
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/2 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/3
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/3 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/4
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/4 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/5
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/5 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/6
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/6 (1 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/7
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/7 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/8
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/8 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/9
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/9 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/10
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/10 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/11
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.impl/11 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/0
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/0 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/1
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/1 (1 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/2
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/2 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/3
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/3 (1 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/4
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/4 (1 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/5
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/5 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/6
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/6 (1 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/7
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/7 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/8
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/8 (1 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/9
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/9 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/10
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/10 (0 ms)
[ RUN      ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/11
[       OK ] BuiltInEqualImpls/BuiltInShapeInferImplTest.reshaper/11 (2 ms)
[----------] 24 tests from BuiltInEqualImpls/BuiltInShapeInferImplTest (9 ms total)
[----------] 100 tests from BuiltInGeneralImpls/BuiltInShapeInferImplTest
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/0
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/0 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/1
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/1 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/2
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/2 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/3
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/3 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/4
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/4 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/5
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/5 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/6
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/6 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/7
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/7 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/8
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/8 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/9
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/9 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/10
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/10 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/11
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/11 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/12
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/12 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/13
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/13 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/14
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/14 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/15
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/15 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/16
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/16 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/17
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/17 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/18
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/18 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/19
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/19 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/20
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/20 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/21
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/21 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/22
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/22 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/23
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/23 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/24
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/24 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/25
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/25 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/26
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/26 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/27
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/27 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/28
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/28 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/29
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/29 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/30
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/30 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/31
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/31 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/32
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/32 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/33
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/33 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/34
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/34 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/35
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/35 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/36
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/36 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/37
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/37 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/38
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/38 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/39
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/39 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/40
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/40 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/41
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/41 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/42
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/42 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/43
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/43 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/44
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/44 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/45
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/45 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/46
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/46 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/47
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/47 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/48
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/48 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/49
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.impl/49 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/0
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/0 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/1
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/1 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/2
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/2 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/3
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/3 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/4
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/4 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/5
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/5 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/6
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/6 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/7
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/7 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/8
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/8 (10 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/9
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/9 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/10
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/10 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/11
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/11 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/12
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/12 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/13
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/13 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/14
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/14 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/15
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/15 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/16
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/16 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/17
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/17 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/18
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/18 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/19
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/19 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/20
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/20 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/21
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/21 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/22
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/22 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/23
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/23 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/24
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/24 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/25
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/25 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/26
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/26 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/27
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/27 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/28
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/28 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/29
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/29 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/30
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/30 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/31
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/31 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/32
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/32 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/33
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/33 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/34
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/34 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/35
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/35 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/36
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/36 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/37
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/37 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/38
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/38 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/39
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/39 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/40
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/40 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/41
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/41 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/42
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/42 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/43
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/43 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/44
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/44 (0 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/45
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/45 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/46
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/46 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/47
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/47 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/48
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/48 (1 ms)
[ RUN      ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/49
[       OK ] BuiltInGeneralImpls/BuiltInShapeInferImplTest.reshaper/49 (0 ms)
[----------] 100 tests from BuiltInGeneralImpls/BuiltInShapeInferImplTest (49 ms total)
[----------] 16 tests from BuiltInGeneralImpls2/BuiltInShapeInferImplTest
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/0
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/0 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/1
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/1 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/2
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/2 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/3
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/3 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/4
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/4 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/5
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/5 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/6
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/6 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/7
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.impl/7 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/0
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/0 (1 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/1
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/1 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/2
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/2 (1 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/3
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/3 (1 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/4
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/4 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/5
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/5 (1 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/6
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/6 (0 ms)
[ RUN      ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/7
[       OK ] BuiltInGeneralImpls2/BuiltInShapeInferImplTest.reshaper/7 (1 ms)
[----------] 16 tests from BuiltInGeneralImpls2/BuiltInShapeInferImplTest (5 ms total)
[----------] 2 tests from Reshape/LayerValidatorNegativeTests
[ RUN      ] Reshape/LayerValidatorNegativeTests.reshaper/0
[       OK ] Reshape/LayerValidatorNegativeTests.reshaper/0 (0 ms)
[ RUN      ] Reshape/LayerValidatorNegativeTests.reshaper/1
[       OK ] Reshape/LayerValidatorNegativeTests.reshaper/1 (1 ms)
[----------] 2 tests from Reshape/LayerValidatorNegativeTests (1 ms total)
[----------] 2 tests from CPUExtGeneralImpls/CPUExtShapeInferTests
[ RUN      ] CPUExtGeneralImpls/CPUExtShapeInferTests.impl/0
[       OK ] CPUExtGeneralImpls/CPUExtShapeInferTests.impl/0 (0 ms)
[ RUN      ] CPUExtGeneralImpls/CPUExtShapeInferTests.reshaper/0
[       OK ] CPUExtGeneralImpls/CPUExtShapeInferTests.reshaper/0 (1 ms)
[----------] 2 tests from CPUExtGeneralImpls/CPUExtShapeInferTests (1 ms total)
[----------] 1 test from NotSupported/ShapeInferNotSupportedTest
[ RUN      ] NotSupported/ShapeInferNotSupportedTest.returnNotFoundOnNotSupported/0
[       OK ] NotSupported/ShapeInferNotSupportedTest.returnNotFoundOnNotSupported/0 (0 ms)
[----------] 1 test from NotSupported/ShapeInferNotSupportedTest (0 ms total)
[----------] 72 tests from BuiltInImplsConv/BuiltInShapeInferConvImplTest
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/0
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/0 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/1
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/1 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/2
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/2 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/3
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/3 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/4
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/4 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/5
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/5 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/6
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/6 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/7
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/7 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/8
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/8 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/9
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/9 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/10
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/10 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/11
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl/11 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/0
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/0 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/1
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/1 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/2
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/2 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/3
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/3 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/4
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/4 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/5
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/5 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/6
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/6 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/7
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/7 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/8
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/8 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/9
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/9 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/10
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/10 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/11
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch/11 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/0
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/0 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/1
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/1 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/2
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/2 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/3
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/3 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/4
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/4 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/5
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/5 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/6
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/6 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/7
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/7 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/8
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/8 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/9
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/9 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/10
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/10 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/11
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper/11 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/0
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/0 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/1
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/1 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/2
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/2 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/3
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/3 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/4
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/4 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/5
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/5 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/6
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/6 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/7
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/7 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/8
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/8 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/9
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/9 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/10
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/10 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/11
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.impl_IRv3/11 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/0
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/0 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/1
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/1 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/2
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/2 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/3
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/3 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/4
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/4 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/5
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/5 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/6
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/6 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/7
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/7 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/8
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/8 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/9
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/9 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/10
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/10 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/11
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.batch_IRv3/11 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/0
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/0 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/1
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/1 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/2
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/2 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/3
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/3 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/4
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/4 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/5
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/5 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/6
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/6 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/7
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/7 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/8
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/8 (1 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/9
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/9 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/10
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/10 (0 ms)
[ RUN      ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/11
[       OK ] BuiltInImplsConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/11 (1 ms)
[----------] 72 tests from BuiltInImplsConv/BuiltInShapeInferConvImplTest (42 ms total)
[----------] 72 tests from BuiltInImplsDeConv/BuiltInShapeInferConvImplTest
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/0
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/0 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/1
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/1 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/2
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/2 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/3
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/3 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/4
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/4 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/5
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/5 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/6
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/6 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/7
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/7 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/8
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/8 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/9
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/9 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/10
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/10 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/11
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl/11 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/0
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/0 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/1
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/1 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/2
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/2 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/3
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/3 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/4
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/4 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/5
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/5 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/6
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/6 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/7
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/7 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/8
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/8 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/9
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/9 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/10
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/10 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/11
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch/11 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/0
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/0 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/1
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/1 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/2
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/2 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/3
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/3 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/4
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/4 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/5
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/5 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/6
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/6 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/7
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/7 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/8
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/8 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/9
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/9 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/10
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/10 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/11
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper/11 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/0
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/0 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/1
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/1 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/2
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/2 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/3
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/3 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/4
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/4 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/5
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/5 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/6
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/6 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/7
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/7 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/8
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/8 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/9
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/9 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/10
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/10 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/11
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.impl_IRv3/11 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/0
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/0 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/1
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/1 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/2
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/2 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/3
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/3 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/4
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/4 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/5
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/5 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/6
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/6 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/7
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/7 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/8
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/8 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/9
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/9 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/10
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/10 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/11
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.batch_IRv3/11 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/0
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/0 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/1
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/1 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/2
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/2 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/3
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/3 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/4
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/4 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/5
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/5 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/6
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/6 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/7
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/7 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/8
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/8 (1 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/9
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/9 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/10
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/10 (0 ms)
[ RUN      ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/11
[       OK ] BuiltInImplsDeConv/BuiltInShapeInferConvImplTest.reshaper_IRv3/11 (1 ms)
[----------] 72 tests from BuiltInImplsDeConv/BuiltInShapeInferConvImplTest (42 ms total)
[----------] 48 tests from BuiltInImpls/BuiltInShapeInferPoolImplTest
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/0
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/0 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/1
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/1 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/2
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/2 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/3
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/3 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/4
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/4 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/5
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/5 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/6
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/6 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/7
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body/7 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/0
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/0 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/1
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/1 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/2
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/2 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/3
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/3 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/4
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/4 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/5
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/5 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/6
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/6 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/7
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper/7 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/0
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/0 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/1
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/1 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/2
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/2 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/3
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/3 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/4
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/4 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/5
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/5 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/6
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/6 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/7
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch/7 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/0
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/0 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/1
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/1 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/2
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/2 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/3
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/3 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/4
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/4 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/5
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/5 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/6
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/6 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/7
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.body_IRv3/7 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/0
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/0 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/1
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/1 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/2
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/2 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/3
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/3 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/4
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/4 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/5
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/5 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/6
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/6 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/7
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.reshaper_IRv3/7 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/0
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/0 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/1
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/1 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/2
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/2 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/3
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/3 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/4
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/4 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/5
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/5 (0 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/6
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/6 (1 ms)
[ RUN      ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/7
[       OK ] BuiltInImpls/BuiltInShapeInferPoolImplTest.batch_IRv3/7 (1 ms)
[----------] 48 tests from BuiltInImpls/BuiltInShapeInferPoolImplTest (23 ms total)
[----------] 12 tests from TestsConvertation/MKLDNN2TensorDescConvertTests
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/0
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/0 (0 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/1
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/1 (0 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/2
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/2 (0 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/3
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/3 (1 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/4
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/4 (2 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/5
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/5 (0 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/6
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/6 (2 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/7
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/7 (2 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/8
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/8 (0 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/9
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/9 (1 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/10
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/10 (2 ms)
[ RUN      ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/11
MEM_USAGE=685376KB
[       OK ] TestsConvertation/MKLDNN2TensorDescConvertTests.TestsConvertation/11 (1 ms)
[----------] 12 tests from TestsConvertation/MKLDNN2TensorDescConvertTests (11 ms total)
[----------] 7 tests from TestsConvertation/TensorDesc2MKLDNNConvertTests
[ RUN      ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/0
MEM_USAGE=685376KB
[       OK ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/0 (0 ms)
[ RUN      ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/1
MEM_USAGE=685376KB
[       OK ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/1 (0 ms)
[ RUN      ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/2
MEM_USAGE=685376KB
[       OK ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/2 (1 ms)
[ RUN      ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/3
MEM_USAGE=685376KB
[       OK ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/3 (0 ms)
[ RUN      ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/4
MEM_USAGE=685376KB
[       OK ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/4 (1 ms)
[ RUN      ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/5
MEM_USAGE=685376KB
[       OK ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/5 (2 ms)
[ RUN      ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/6
MEM_USAGE=685376KB
[       OK ] TestsConvertation/TensorDesc2MKLDNNConvertTests.TestsConvertation/6 (0 ms)
[----------] 7 tests from TestsConvertation/TensorDesc2MKLDNNConvertTests (4 ms total)
[----------] 2 tests from TestsInterp/MKLDNNCPUExtInterpTests
[ RUN      ] TestsInterp/MKLDNNCPUExtInterpTests.TestsInterp/0
MEM_USAGE=685376KB
[       OK ] TestsInterp/MKLDNNCPUExtInterpTests.TestsInterp/0 (41 ms)
[ RUN      ] TestsInterp/MKLDNNCPUExtInterpTests.TestsInterp/1
MEM_USAGE=685376KB
[       OK ] TestsInterp/MKLDNNCPUExtInterpTests.TestsInterp/1 (4 ms)
[----------] 2 tests from TestsInterp/MKLDNNCPUExtInterpTests (46 ms total)
[----------] 18 tests from TestsResample/MKLDNNCPUExtResampleTests
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/0
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/0 (12 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/1
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/1 (14 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/2
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/2 (50 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/3
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/3 (40 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/4
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/4 (48 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/5
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/5 (666 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/6
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/6 (5 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/7
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/7 (6 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/8
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/8 (17 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/9
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/9 (4 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/10
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/10 (5 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/11
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/11 (5 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/12
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/12 (5 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/13
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/13 (16 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/14
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/14 (34 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/15
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/15 (3 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/16
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/16 (11 ms)
[ RUN      ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/17
MEM_USAGE=685376KB
[       OK ] TestsResample/MKLDNNCPUExtResampleTests.TestsResample/17 (4 ms)
[----------] 18 tests from TestsResample/MKLDNNCPUExtResampleTests (946 ms total)
[----------] 12 tests from TestsGather/MKLDNNCPUExtGatherTests
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/0
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/0 (4 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/1
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/1 (4 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/2
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/2 (4 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/3
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/3 (4 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/4
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/4 (4 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/5
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/5 (8 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/6
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/6 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/7
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/7 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/8
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/8 (20 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/9
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/9 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/10
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/10 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/11
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTests.TestsGather/11 (25 ms)
[----------] 12 tests from TestsGather/MKLDNNCPUExtGatherTests (81 ms total)
[----------] 10 tests from TestsGather/MKLDNNCPUExtGatherTFTests
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/0
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/0 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/1
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/1 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/2
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/2 (10 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/3
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/3 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/4
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/4 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/5
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/5 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/6
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/6 (12 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/7
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/7 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/8
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/8 (2 ms)
[ RUN      ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/9
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherTFTests.TestsGather/9 (4 ms)
[----------] 10 tests from TestsGather/MKLDNNCPUExtGatherTFTests (40 ms total)
[----------] 1 test from TestsGather/MKLDNNCPUExtGatherHolesTests
[ RUN      ] TestsGather/MKLDNNCPUExtGatherHolesTests.TestsGather/0
MEM_USAGE=685376KB
[       OK ] TestsGather/MKLDNNCPUExtGatherHolesTests.TestsGather/0 (3 ms)
[----------] 1 test from TestsGather/MKLDNNCPUExtGatherHolesTests (3 ms total)
[----------] 25 tests from TestsMVN/MKLDNNCPUExtMVNTests
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/0
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/0 (10 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/1
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/1 (18 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/2
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/2 (11 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/3
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/3 (6 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/4
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/4 (10 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/5
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/5 (17 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/6
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/6 (16 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/7
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/7 (7 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/8
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/8 (9 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/9
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/9 (17 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/10
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/10 (20 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/11
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/11 (9 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/12
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/12 (21 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/13
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/13 (9 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/14
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/14 (82 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/15
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/15 (17 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/16
MEM_USAGE=685376KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/16 (1532 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/17
MEM_USAGE=703328KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/17 (1350 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/18
MEM_USAGE=657248KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/18 (1368 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/19
MEM_USAGE=703328KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/19 (1360 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/20
MEM_USAGE=657248KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/20 (622 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/21
MEM_USAGE=703328KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/21 (752 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/22
MEM_USAGE=657248KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/22 (596 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/23
MEM_USAGE=703328KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/23 (636 ms)
[ RUN      ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/24
MEM_USAGE=657248KB
[       OK ] TestsMVN/MKLDNNCPUExtMVNTests.TestsMVN/24 (570 ms)
[----------] 25 tests from TestsMVN/MKLDNNCPUExtMVNTests (9081 ms total)
[----------] 1 test from TestsTile/MKLDNNGraphTileTests
[ RUN      ] TestsTile/MKLDNNGraphTileTests.TestsTile/0
MEM_USAGE=698212KB
[       OK ] TestsTile/MKLDNNGraphTileTests.TestsTile/0 (3 ms)
[----------] 1 test from TestsTile/MKLDNNGraphTileTests (3 ms total)
[----------] 1 test from TestsDynBatchTile/MKLDNNGraphDynBatchTileTests
[ RUN      ] TestsDynBatchTile/MKLDNNGraphDynBatchTileTests.TestsDynBatchTile/0
MEM_USAGE=698212KB
[       OK ] TestsDynBatchTile/MKLDNNGraphDynBatchTileTests.TestsDynBatchTile/0 (7 ms)
[----------] 1 test from TestsDynBatchTile/MKLDNNGraphDynBatchTileTests (7 ms total)
[----------] 4 tests from TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests
[ RUN      ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/0
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_batchnorm_scaleshift_test.cpp:203: Failure
Expected: (p.num_prim_desc) <= (nodes->getSupportedPrimitiveDescriptors().size()), actual: 5 vs 4
[  FAILED  ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/0, where GetParam() = 112-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 02-00 00-00 2F-75 6E-69 05-00 00-00 00-00 00-00 00-01 00-00 6C-64 6E-6E 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (32 ms)
[ RUN      ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/1
MEM_USAGE=698212KB
[  FAILED  ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/1, where GetParam() = 112-byte object <04-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 E3-00 00-00 00-00 00-00 E3-00 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 02-00 00-00 2F-75 6E-69 05-00 00-00 00-00 00-00 00-01 00-00 6C-64 6E-6E 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (12 ms)
[ RUN      ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/2
MEM_USAGE=698212KB
[  FAILED  ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/2, where GetParam() = 112-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 02-00 00-00 2F-75 6E-69 05-00 00-00 00-00 00-00 80-00 00-00 6C-64 6E-6E 00-B0 DC-A8 24-56 00-00 04-B0 DC-A8 24-56 00-00 04-B0 DC-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (22 ms)
[ RUN      ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/3
MEM_USAGE=698212KB
[  FAILED  ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/3, where GetParam() = 112-byte object <04-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 E3-00 00-00 00-00 00-00 E3-00 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 02-00 00-00 2F-75 6E-69 05-00 00-00 00-00 00-00 80-00 00-00 6C-64 6E-6E 00-B0 DC-A8 24-56 00-00 04-B0 DC-A8 24-56 00-00 04-B0 DC-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (15 ms)
[----------] 4 tests from TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests (82 ms total)
[----------] 4 tests from TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests
[ RUN      ] TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests.TestsDynBatchBatchNormWithScaleShift/0
MEM_USAGE=698212KB
[       OK ] TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests.TestsDynBatchBatchNormWithScaleShift/0 (3325 ms)
[ RUN      ] TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests.TestsDynBatchBatchNormWithScaleShift/1
MEM_USAGE=698212KB
[       OK ] TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests.TestsDynBatchBatchNormWithScaleShift/1 (1006 ms)
[ RUN      ] TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests.TestsDynBatchBatchNormWithScaleShift/2
MEM_USAGE=698212KB
[       OK ] TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests.TestsDynBatchBatchNormWithScaleShift/2 (3124 ms)
[ RUN      ] TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests.TestsDynBatchBatchNormWithScaleShift/3
MEM_USAGE=698212KB
[       OK ] TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests.TestsDynBatchBatchNormWithScaleShift/3 (995 ms)
[----------] 4 tests from TestsDynBatchBatchNormWithScaleShift/MKLDNNGraphDynBatchBatchNormScaleShiftTests (8451 ms total)
[----------] 4 tests from TestCrop/MKLDNNGraphCropTests
[ RUN      ] TestCrop/MKLDNNGraphCropTests.TestCrop/0
MEM_USAGE=698212KB
[       OK ] TestCrop/MKLDNNGraphCropTests.TestCrop/0 (17 ms)
[ RUN      ] TestCrop/MKLDNNGraphCropTests.TestCrop/1
MEM_USAGE=698212KB
[       OK ] TestCrop/MKLDNNGraphCropTests.TestCrop/1 (5 ms)
[ RUN      ] TestCrop/MKLDNNGraphCropTests.TestCrop/2
MEM_USAGE=698212KB
[       OK ] TestCrop/MKLDNNGraphCropTests.TestCrop/2 (18 ms)
[ RUN      ] TestCrop/MKLDNNGraphCropTests.TestCrop/3
MEM_USAGE=698212KB
[       OK ] TestCrop/MKLDNNGraphCropTests.TestCrop/3 (8 ms)
[----------] 4 tests from TestCrop/MKLDNNGraphCropTests (49 ms total)
[----------] 3 tests from TestsDynBatchCrop/MKLDNNGraphDynBatchCropTests
[ RUN      ] TestsDynBatchCrop/MKLDNNGraphDynBatchCropTests.TestsDynBatchCrop/0
MEM_USAGE=698212KB
[       OK ] TestsDynBatchCrop/MKLDNNGraphDynBatchCropTests.TestsDynBatchCrop/0 (18 ms)
[ RUN      ] TestsDynBatchCrop/MKLDNNGraphDynBatchCropTests.TestsDynBatchCrop/1
MEM_USAGE=698212KB
[       OK ] TestsDynBatchCrop/MKLDNNGraphDynBatchCropTests.TestsDynBatchCrop/1 (19 ms)
[ RUN      ] TestsDynBatchCrop/MKLDNNGraphDynBatchCropTests.TestsDynBatchCrop/2
MEM_USAGE=698212KB
[       OK ] TestsDynBatchCrop/MKLDNNGraphDynBatchCropTests.TestsDynBatchCrop/2 (23 ms)
[----------] 3 tests from TestsDynBatchCrop/MKLDNNGraphDynBatchCropTests (60 ms total)
[----------] 26 tests from TestsDepthwise/MKLDNNGraphDepthwiseTests
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/0
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_depthwise_test.cpp:247: Failure
      Expected: p.selectedType
      Which is: 256
To be equal to: nodes->getSelectedPrimitiveDescriptor()->getImplementationType() & p.selectedType
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/0, where GetParam() = 104-byte object <64-00 00-00 F9-7F 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (16 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/1
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/1, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (12 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/2
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/2, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (25 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/3
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/3, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (13 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/4
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/4, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 01-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (7 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/5
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/5, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 01-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (8 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/6
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/6, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (13 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/7
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/7, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (10 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/8
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/8, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (4 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/9
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/9, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (5 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/10
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/10, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 01-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (17 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/11
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/11, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 01-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (9 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/12
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/12 (375 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/13
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/13 (195 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/14
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/14 (20 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/15
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/15 (4 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/16
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/16 (7 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/17
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/17 (300 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/18
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/18 (467 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/19
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/19 (284 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/20
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/20 (32 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/21
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/21 (6 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/22
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/22 (31 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/23
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/23 (314 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/24
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/24 (4 ms)
[ RUN      ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/25
MEM_USAGE=698212KB
[       OK ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/25 (9 ms)
[----------] 26 tests from TestsDepthwise/MKLDNNGraphDepthwiseTests (2190 ms total)
[----------] 24 tests from TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/0
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/0 (3390 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/1
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/1 (1135 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/2
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/2 (7 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/3
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/3 (9 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/4
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/4 (13 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/5
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/5 (3418 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/6
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/6 (3174 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/7
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/7 (969 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/8
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/8 (5 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/9
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/9 (4 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/10
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/10 (12 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/11
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/11 (3208 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/12
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/12 (3516 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/13
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/13 (1026 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/14
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/14 (10 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/15
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/15 (12 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/16
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/16 (18 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/17
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/17 (3389 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/18
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/18 (3204 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/19
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/19 (1085 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/20
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/20 (4 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/21
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/21 (17 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/22
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/22 (33 ms)
[ RUN      ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/23
MEM_USAGE=698212KB
[       OK ] TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests.TestsDynBatchDepthwise/23 (3309 ms)
[----------] 24 tests from TestsDynBatchDepthwise/MKLDNNGraphDynBatchDepthwiseTests (30974 ms total)
[----------] 2 tests from TestsRelu/MKLDNNGraphReluTests
[ RUN      ] TestsRelu/MKLDNNGraphReluTests.TestsRelu/0
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_relu_test.cpp:150: Failure
Expected: (p.num_prim_desc) <= (nodes->getSupportedPrimitiveDescriptors().size()), actual: 5 vs 3
[  FAILED  ] TestsRelu/MKLDNNGraphReluTests.TestsRelu/0, where GetParam() = 72-byte object <B0-36 DE-A8 24-56 00-00 D0-36 DE-A8 24-56 00-00 D0-36 DE-A8 24-56 00-00 00-00 00-00 24-56 00-00 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 50-CC DE-A8 24-56 00-00 90-CC DE-A8 24-56 00-00 90-CC DE-A8 24-56 00-00> (3 ms)
[ RUN      ] TestsRelu/MKLDNNGraphReluTests.TestsRelu/1
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_relu_test.cpp:247: Failure
      Expected: InferenceEngine::Layout::NCDHW
      Which is: 3
To be equal to: impl.getConfig().inConfs.at(0).desc.getLayout()
      Which is: BLOCKED
[  FAILED  ] TestsRelu/MKLDNNGraphReluTests.TestsRelu/1, where GetParam() = 72-byte object <B0-36 DE-A8 24-56 00-00 D8-36 DE-A8 24-56 00-00 D8-36 DE-A8 24-56 00-00 00-00 00-00 24-56 00-00 03-00 00-00 00-00 00-00 80-80 00-00 00-00 00-00 50-CC DE-A8 24-56 00-00 90-CC DE-A8 24-56 00-00 90-CC DE-A8 24-56 00-00> (257 ms)
[----------] 2 tests from TestsRelu/MKLDNNGraphReluTests (260 ms total)
[----------] 4 tests from TestsBatchNorm/MKLDNNGraphBatchNormTests
[ RUN      ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/0
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_batchnorm_test.cpp:172: Failure
[  FAILED  ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/0, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 05-00 00-00 00-00 00-00 00-01 00-00 65-73 74-73 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (11 ms)
[ RUN      ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/1
MEM_USAGE=698212KB
[  FAILED  ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/1, where GetParam() = 104-byte object <03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 05-00 00-00 00-00 00-00 00-01 00-00 65-73 74-73 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (7 ms)
[ RUN      ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/2
MEM_USAGE=698212KB
[  FAILED  ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/2, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 05-00 00-00 00-00 00-00 80-00 00-00 65-73 74-73 00-5B DD-A8 24-56 00-00 04-5B DD-A8 24-56 00-00 04-5B DD-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (18 ms)
[ RUN      ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/3
MEM_USAGE=698212KB
[  FAILED  ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/3, where GetParam() = 104-byte object <03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 05-00 00-00 00-00 00-00 80-00 00-00 65-73 74-73 00-5B DD-A8 24-56 00-00 04-5B DD-A8 24-56 00-00 04-5B DD-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (15 ms)
[----------] 4 tests from TestsBatchNorm/MKLDNNGraphBatchNormTests (52 ms total)
[----------] 4 tests from TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests
[ RUN      ] TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests.TestsDynBatchBatchNorm/0
MEM_USAGE=698212KB
[       OK ] TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests.TestsDynBatchBatchNorm/0 (3251 ms)
[ RUN      ] TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests.TestsDynBatchBatchNorm/1
MEM_USAGE=698212KB
[       OK ] TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests.TestsDynBatchBatchNorm/1 (517 ms)
[ RUN      ] TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests.TestsDynBatchBatchNorm/2
MEM_USAGE=698212KB
[       OK ] TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests.TestsDynBatchBatchNorm/2 (3312 ms)
[ RUN      ] TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests.TestsDynBatchBatchNorm/3
MEM_USAGE=698212KB
[       OK ] TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests.TestsDynBatchBatchNorm/3 (574 ms)
[----------] 4 tests from TestsDynBatchBatchNorm/MKLDNNGraphDynBatchBatchNormTests (7656 ms total)
[----------] 16 tests from TestConvolution/MKLDNNGraphConvolutionTests
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/0
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_conv_test.cpp:271: Failure
Expected: (p.num_prim_desc) <= (node->getSupportedPrimitiveDescriptors().size()), actual: 6 vs 4
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/0, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 A0-C7 DD-A8 24-56 00-00 B0-C7 DD-A8 24-56 00-00 ... 06-00 00-00 00-00 00-00 00-01 01-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (37 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/1
MEM_USAGE=698212KB
Expected: (p.num_prim_desc) <= (node->getSupportedPrimitiveDescriptors().size()), actual: 5 vs 4
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/1, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (50 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/2
MEM_USAGE=698212KB
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/2, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (31 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/3
MEM_USAGE=698212KB
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/3, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (26 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/4
MEM_USAGE=698212KB
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/4, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (22 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/5
MEM_USAGE=698212KB
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/5, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (15 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/6
MEM_USAGE=698212KB
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/6, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 80-80 00-00 00-00 00-00 20-64 DE-A8 24-56 00-00 24-64 DE-A8 24-56 00-00 24-64 DE-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (24 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/7
MEM_USAGE=698212KB
jit_gemm ref_any ref_any ref_any
[       OK ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/7 (1688 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/8
MEM_USAGE=698212KB
[       OK ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/8 (526 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/9
MEM_USAGE=698212KB
[       OK ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/9 (3801 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/10
MEM_USAGE=698212KB
[       OK ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/10 (4950 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/11
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_conv_test.cpp:291: Failure
      Which is: 256
To be equal to: node->getSelectedPrimitiveDescriptor()->getImplementationType() & p.selectedType
      Which is: 0
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/11, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 88-D8 DD-A8 24-56 00-00 ... 02-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (14 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/12
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/12, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 88-D8 DD-A8 24-56 00-00 ... 02-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (44 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/13
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/13, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 88-D8 DD-A8 24-56 00-00 ... 02-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (52 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/14
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/14, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 88-D8 DD-A8 24-56 00-00 ... 02-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (44 ms)
[ RUN      ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/15
MEM_USAGE=698212KB
[       OK ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/15 (34262 ms)
[----------] 16 tests from TestConvolution/MKLDNNGraphConvolutionTests (45586 ms total)
[----------] 8 tests from TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests
[ RUN      ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/0
MEM_USAGE=698212KB
[       OK ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/0 (88 ms)
[ RUN      ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/1
MEM_USAGE=698212KB
[       OK ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/1 (289 ms)
[ RUN      ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/2
MEM_USAGE=698212KB
[       OK ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/2 (180 ms)
[ RUN      ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/3
MEM_USAGE=698212KB
[       OK ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/3 (220 ms)
[ RUN      ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/4
MEM_USAGE=698212KB
[       OK ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/4 (105 ms)
[ RUN      ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/5
MEM_USAGE=698212KB
[       OK ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/5 (63 ms)
[ RUN      ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/6
MEM_USAGE=698212KB
[       OK ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/6 (83 ms)
[ RUN      ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/7
MEM_USAGE=698212KB
[       OK ] TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests.TestsDynBatchConvolution/7 (304 ms)
[----------] 8 tests from TestDynBatchConvolution/MKLDNNGraphDynBatchConvolutionTests (1339 ms total)
[----------] 1 test from TestsInput/MKLDNNGraphInputTests
[ RUN      ] TestsInput/MKLDNNGraphInputTests.TestsInput/0
MEM_USAGE=698212KB
[       OK ] TestsInput/MKLDNNGraphInputTests.TestsInput/0 (3 ms)
[----------] 1 test from TestsInput/MKLDNNGraphInputTests (3 ms total)
[----------] 23 tests from TestsPermute/MKLDNNGraphPermuteTests
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/0
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/0 (4 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/1
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/1 (26 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/2
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/2 (4 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/3
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/3 (22 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/4
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/4 (3 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/5
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/5 (13 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/6
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/6 (14 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/7
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/7 (2 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/8
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/8 (5 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/9
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/9 (3 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/10
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/10 (2 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/11
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/11 (20 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/12
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/12 (2 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/13
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/13 (8 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/14
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/14 (7 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/15
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/15 (4 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/16
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/16 (13 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/17
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/17 (3 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/18
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/18 (4 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/19
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/19 (31 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/20
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/20 (1 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/21
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/21 (4 ms)
[ RUN      ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/22
MEM_USAGE=698212KB
[       OK ] TestsPermute/MKLDNNGraphPermuteTests.TestsPermute/22 (15 ms)
[----------] 23 tests from TestsPermute/MKLDNNGraphPermuteTests (216 ms total)
[----------] 14 tests from TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/0
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/0 (9 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/1
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/1 (2 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/2
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/2 (7 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/3
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/3 (29 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/4
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/4 (3 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/5
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/5 (2 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/6
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/6 (19 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/7
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/7 (8 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/8
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/8 (7 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/9
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/9 (31 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/10
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/10 (4 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/11
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/11 (21 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/12
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/12 (3 ms)
[ RUN      ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/13
MEM_USAGE=698212KB
[       OK ] TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests.TestsDynBatchPermute/13 (19 ms)
[----------] 14 tests from TestsDynBatchPermute/MKLDNNGraphDynBatchPermuteTests (166 ms total)
[----------] 1 test from TestsRoiPooling/MKLDNNGraphRoiPoolingTests
[ RUN      ] TestsRoiPooling/MKLDNNGraphRoiPoolingTests.TestsRoiPooling/0
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_roi_pooling_test.cpp:243: Failure
[  FAILED  ] TestsRoiPooling/MKLDNNGraphRoiPoolingTests.TestsRoiPooling/0, where GetParam() = 112-byte object <01-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 27-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 96-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 06-00 00-00 00-00 00-00 06-00 00-00 00-00 00-00 00-00 80-3D 70-68 2F-6C 05-00 00-00 00-00 00-00 00-01 00-00 61-6C 2F-67 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (23 ms)
[----------] 1 test from TestsRoiPooling/MKLDNNGraphRoiPoolingTests (23 ms total)
[----------] 16 tests from TestsReshape/MKLDNNGraphReshapeTests
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/0
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/0 (47 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/1
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/1 (2 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/2
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/2 (1 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/3
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/3 (1 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/4
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/4 (1 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/5
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/5 (2 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/6
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/6 (2 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/7
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/7 (2 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/8
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/8 (2 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/9
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/9 (1 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/10
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/10 (2 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/11
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/11 (3 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/12
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/12 (4 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/13
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/13 (2 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/14
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/14 (2 ms)
[ RUN      ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/15
MEM_USAGE=698212KB
[       OK ] TestsReshape/MKLDNNGraphReshapeTests.TestsReshape/15 (3 ms)
[----------] 16 tests from TestsReshape/MKLDNNGraphReshapeTests (82 ms total)
[----------] 29 tests from TestsActivation/MKLDNNGraphActivationTests
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/0
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_activation_test.cpp:222: Failure
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/0, where GetParam() = 104-byte object <08-00 00-00 00-00 00-00 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (15 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/1
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/1, where GetParam() = 104-byte object <08-00 00-00 00-00 00-00 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (6 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/2
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/2, where GetParam() = 104-byte object <08-00 00-00 00-00 00-3F 00-00 00-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (7 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/3
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/3, where GetParam() = 104-byte object <08-00 00-00 00-00 00-3F 00-00 00-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (6 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/4
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/4, where GetParam() = 104-byte object <0A-00 00-00 00-00 00-3F 00-00 00-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (10 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/5
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/5, where GetParam() = 104-byte object <0A-00 00-00 00-00 00-3F 00-00 00-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (8 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/6
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/6, where GetParam() = 104-byte object <0A-00 00-00 00-00 80-3F 00-00 80-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (6 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/7
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/7, where GetParam() = 104-byte object <0A-00 00-00 00-00 80-3F 00-00 80-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (6 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/8
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/8, where GetParam() = 104-byte object <11-00 00-00 00-00 00-00 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (6 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/9
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/9, where GetParam() = 104-byte object <11-00 00-00 00-00 00-00 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (5 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/10
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/10, where GetParam() = 104-byte object <0F-00 00-00 00-00 C0-40 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (8 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/11
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/11, where GetParam() = 104-byte object <0F-00 00-00 00-00 C0-40 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (11 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/12
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/12, where GetParam() = 104-byte object <0F-00 00-00 CD-CC CC-3D 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (6 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/13
MEM_USAGE=698212KB
      Which is: 256
      Which is: 0
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/13, where GetParam() = 104-byte object <0F-00 00-00 CD-CC CC-3D 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (5 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/14
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/14 (139 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/15
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/15 (120 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/16
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/16 (170 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/17
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/17 (108 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/18
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/18 (261 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/19
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/19 (140 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/20
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/20 (285 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/21
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/21 (163 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/22
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/22 (293 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/23
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/23 (203 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/24
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/24 (182 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/25
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/25 (123 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/26
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/26 (251 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/27
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/27 (111 ms)
[ RUN      ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/28
MEM_USAGE=698212KB
[       OK ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/28 (126 ms)
[----------] 29 tests from TestsActivation/MKLDNNGraphActivationTests (2785 ms total)
[----------] 28 tests from TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/0
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/0 (2770 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/1
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/1 (829 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/2
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/2 (2767 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/3
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/3 (854 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/4
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/4 (2839 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/5
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/5 (852 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/6
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/6 (2736 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/7
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/7 (953 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/8
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/8 (2866 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/9
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/9 (865 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/10
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/10 (2696 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/11
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/11 (836 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/12
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/12 (2738 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/13
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/13 (839 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/14
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/14 (2693 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/15
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/15 (848 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/16
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/16 (2691 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/17
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/17 (849 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/18
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/18 (2717 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/19
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/19 (852 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/20
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/20 (2740 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/21
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/21 (851 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/22
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/22 (3017 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/23
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/23 (1042 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/24
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/24 (2891 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/25
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/25 (890 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/26
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/26 (2709 ms)
[ RUN      ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/27
MEM_USAGE=698212KB
[       OK ] TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests.TestsDynBatchActivation/27 (858 ms)
[----------] 28 tests from TestsDynBatchActivation/MKLDNNGraphDynBatchActivationTests (51093 ms total)
[----------] 26 tests from TestsPooling/MKLDNNGraphPoolingTests
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/0
MEM_USAGE=698212KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_pooling_test.cpp:296: Failure
Expected: (p.num_prim_desc) <= (nodes->getSupportedPrimitiveDescriptors().size()), actual: 6 vs 4
[  FAILED  ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/0, where GetParam() = 192-byte object <00-4F E0-A8 24-56 00-00 20-4F E0-A8 24-56 00-00 20-4F E0-A8 24-56 00-00 40-80 E0-A8 24-56 00-00 50-80 E0-A8 24-56 00-00 50-80 E0-A8 24-56 00-00 10-2F E1-A8 24-56 00-00 20-2F E1-A8 24-56 00-00 ... 06-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (5 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/1
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/1 (30 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/2
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/2 (38 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/3
MEM_USAGE=698212KB
[  FAILED  ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/3, where GetParam() = 192-byte object <00-4F E0-A8 24-56 00-00 20-4F E0-A8 24-56 00-00 20-4F E0-A8 24-56 00-00 40-80 E0-A8 24-56 00-00 50-80 E0-A8 24-56 00-00 50-80 E0-A8 24-56 00-00 10-2F E1-A8 24-56 00-00 20-2F E1-A8 24-56 00-00 ... 06-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 20-FC E0-A8 24-56 00-00 24-FC E0-A8 24-56 00-00 24-FC E0-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (5 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/4
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/4 (28 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/5
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/5 (35 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/6
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/6 (30 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/7
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/7 (15 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/8
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/8 (14 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/9
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/9 (31 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/10
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/10 (15 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/11
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/11 (13 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/12
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/12 (16 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/13
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/13 (45 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/14
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/14 (38 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/15
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/15 (50 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/16
MEM_USAGE=698212KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/16 (1318 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/17
MEM_USAGE=657248KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/17 (23 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/18
MEM_USAGE=657248KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/18 (957 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/19
MEM_USAGE=661344KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/19 (1036 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/20
MEM_USAGE=661344KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/20 (982 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/21
MEM_USAGE=661344KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/21 (960 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/22
MEM_USAGE=661344KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/22 (975 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/23
MEM_USAGE=661536KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/23 (979 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/24
MEM_USAGE=661740KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/24 (1057 ms)
[ RUN      ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/25
MEM_USAGE=661740KB
[       OK ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/25 (983 ms)
[----------] 26 tests from TestsPooling/MKLDNNGraphPoolingTests (9702 ms total)
[----------] 4 tests from TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests
[ RUN      ] TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests.TestsDynBatchPooling/0
MEM_USAGE=661740KB
[       OK ] TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests.TestsDynBatchPooling/0 (359 ms)
[ RUN      ] TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests.TestsDynBatchPooling/1
MEM_USAGE=661740KB
[       OK ] TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests.TestsDynBatchPooling/1 (451 ms)
[ RUN      ] TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests.TestsDynBatchPooling/2
MEM_USAGE=661740KB
[       OK ] TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests.TestsDynBatchPooling/2 (334 ms)
[ RUN      ] TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests.TestsDynBatchPooling/3
MEM_USAGE=661740KB
[       OK ] TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests.TestsDynBatchPooling/3 (412 ms)
[----------] 4 tests from TestsDynBatchPooling/MKLDNNGraphDynBatchPoolingTests (1558 ms total)
[----------] 3 tests from TestsPower/MKLDNNGraphPowerTests
[ RUN      ] TestsPower/MKLDNNGraphPowerTests.TestsPower/0
MEM_USAGE=661740KB
[       OK ] TestsPower/MKLDNNGraphPowerTests.TestsPower/0 (3 ms)
[ RUN      ] TestsPower/MKLDNNGraphPowerTests.TestsPower/1
MEM_USAGE=661740KB
[       OK ] TestsPower/MKLDNNGraphPowerTests.TestsPower/1 (6 ms)
[ RUN      ] TestsPower/MKLDNNGraphPowerTests.TestsPower/2
MEM_USAGE=661740KB
[       OK ] TestsPower/MKLDNNGraphPowerTests.TestsPower/2 (18 ms)
[----------] 3 tests from TestsPower/MKLDNNGraphPowerTests (27 ms total)
[----------] 3 tests from TestsDynBatchPower/MKLDNNGraphDynBatchPowerTests
[ RUN      ] TestsDynBatchPower/MKLDNNGraphDynBatchPowerTests.TestsDynBatchPower/0
MEM_USAGE=661740KB
[       OK ] TestsDynBatchPower/MKLDNNGraphDynBatchPowerTests.TestsDynBatchPower/0 (4 ms)
[ RUN      ] TestsDynBatchPower/MKLDNNGraphDynBatchPowerTests.TestsDynBatchPower/1
MEM_USAGE=661740KB
[       OK ] TestsDynBatchPower/MKLDNNGraphDynBatchPowerTests.TestsDynBatchPower/1 (8 ms)
[ RUN      ] TestsDynBatchPower/MKLDNNGraphDynBatchPowerTests.TestsDynBatchPower/2
MEM_USAGE=661740KB
[       OK ] TestsDynBatchPower/MKLDNNGraphDynBatchPowerTests.TestsDynBatchPower/2 (24 ms)
[----------] 3 tests from TestsDynBatchPower/MKLDNNGraphDynBatchPowerTests (36 ms total)
[----------] 6 tests from TestsEltwise/MKLDNNGraphEltwiseTests
[ RUN      ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/0
MEM_USAGE=661740KB
[       OK ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/0 (3 ms)
[ RUN      ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/1
MEM_USAGE=661740KB
[       OK ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/1 (4 ms)
[ RUN      ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/2
MEM_USAGE=661740KB
[       OK ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/2 (8 ms)
[ RUN      ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/3
MEM_USAGE=661740KB
[       OK ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/3 (7 ms)
[ RUN      ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/4
MEM_USAGE=661740KB
[       OK ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/4 (10 ms)
[ RUN      ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/5
MEM_USAGE=661740KB
[       OK ] TestsEltwise/MKLDNNGraphEltwiseTests.TestsEltwise/5 (74 ms)
[----------] 6 tests from TestsEltwise/MKLDNNGraphEltwiseTests (108 ms total)
[----------] 5 tests from TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests
[ RUN      ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/0
MEM_USAGE=661740KB
[       OK ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/0 (26 ms)
[ RUN      ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/1
MEM_USAGE=661740KB
[       OK ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/1 (26 ms)
[ RUN      ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/2
MEM_USAGE=661740KB
[       OK ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/2 (3 ms)
[ RUN      ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/3
MEM_USAGE=661740KB
[       OK ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/3 (24 ms)
[ RUN      ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/4
MEM_USAGE=661740KB
[       OK ] TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests.TestsDynBatchEltwise/4 (6 ms)
[----------] 5 tests from TestsDynBatchEltwise/MKLDNNGraphDynBatchEltwiseTests (88 ms total)
[----------] 4 tests from TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests
[ RUN      ] TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests.TestsEltwise2Precisions/0
MEM_USAGE=661740KB
[       OK ] TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests.TestsEltwise2Precisions/0 (1 ms)
[ RUN      ] TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests.TestsEltwise2Precisions/1
MEM_USAGE=661740KB
[       OK ] TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests.TestsEltwise2Precisions/1 (2 ms)
[ RUN      ] TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests.TestsEltwise2Precisions/2
MEM_USAGE=661740KB
[       OK ] TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests.TestsEltwise2Precisions/2 (1 ms)
[ RUN      ] TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests.TestsEltwise2Precisions/3
MEM_USAGE=661740KB
[       OK ] TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests.TestsEltwise2Precisions/3 (1 ms)
[----------] 4 tests from TestsEltwise2Precisions/MKLDNNGraphEltwise2PrecisionsTests (6 ms total)
[----------] 2 tests from TestsLrn/MKLDNNGraphLrnTests
[ RUN      ] TestsLrn/MKLDNNGraphLrnTests.TestsLrn/0
MEM_USAGE=661740KB
[       OK ] TestsLrn/MKLDNNGraphLrnTests.TestsLrn/0 (148 ms)
[ RUN      ] TestsLrn/MKLDNNGraphLrnTests.TestsLrn/1
MEM_USAGE=661740KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_lrn_test.cpp:160: Failure
      Expected: p.selectedType
      Which is: 256
To be equal to: nodes->getSelectedPrimitiveDescriptor()->getImplementationType() & p.selectedType
      Which is: 0
[  FAILED  ] TestsLrn/MKLDNNGraphLrnTests.TestsLrn/1, where GetParam() = 96-byte object <01-00 00-00 00-00 00-00 10-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 17-B7 D1-38 00-00 40-3F 01-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (27 ms)
[----------] 2 tests from TestsLrn/MKLDNNGraphLrnTests (175 ms total)
[----------] 2 tests from TestsDynBatchLrn/MKLDNNGraphDynBatchLrnTests
[ RUN      ] TestsDynBatchLrn/MKLDNNGraphDynBatchLrnTests.TestsDynBatchLrn/0
MEM_USAGE=663748KB
[       OK ] TestsDynBatchLrn/MKLDNNGraphDynBatchLrnTests.TestsDynBatchLrn/0 (536 ms)
[ RUN      ] TestsDynBatchLrn/MKLDNNGraphDynBatchLrnTests.TestsDynBatchLrn/1
MEM_USAGE=663748KB
[       OK ] TestsDynBatchLrn/MKLDNNGraphDynBatchLrnTests.TestsDynBatchLrn/1 (2458 ms)
[----------] 2 tests from TestsDynBatchLrn/MKLDNNGraphDynBatchLrnTests (2994 ms total)
[----------] 12 tests from TestsSoftMax/MKLDNNGraphSoftMaxTests
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/0
MEM_USAGE=683244KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_softmax_test.cpp:200: Failure
Expected: (p.num_prim_desc) <= (nodes->getSupportedPrimitiveDescriptors().size()), actual: 2 vs 1
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/0, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (3 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/1
MEM_USAGE=683244KB
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/1, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 80-00 00-00 24-56 00-00 90-43 E0-A8 24-56 00-00 94-43 E0-A8 24-56 00-00 94-43 E0-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (3 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/2
MEM_USAGE=683244KB
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/2, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 64-00 00-00 00-00 00-00 06-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (2 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/3
MEM_USAGE=683244KB
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/3, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 64-00 00-00 00-00 00-00 06-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 80-00 00-00 24-56 00-00 60-86 E1-A8 24-56 00-00 64-86 E1-A8 24-56 00-00 64-86 E1-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (3 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/4
MEM_USAGE=683244KB
[       OK ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/4 (4 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/5
MEM_USAGE=683244KB
[       OK ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/5 (5 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/6
MEM_USAGE=683244KB
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/6, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 13-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (3 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/7
MEM_USAGE=683244KB
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/7, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 13-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 80-00 00-00 24-56 00-00 00-71 E0-A8 24-56 00-00 04-71 E0-A8 24-56 00-00 04-71 E0-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (3 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/8
MEM_USAGE=683244KB
[       OK ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/8 (9 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/9
MEM_USAGE=683244KB
[       OK ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/9 (5 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/10
MEM_USAGE=683244KB
[       OK ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/10 (2 ms)
[ RUN      ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/11
MEM_USAGE=683244KB
[       OK ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/11 (6 ms)
[----------] 12 tests from TestsSoftMax/MKLDNNGraphSoftMaxTests (49 ms total)
[----------] 12 tests from TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/0
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/0 (728 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/1
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/1 (724 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/2
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/2 (5 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/3
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/3 (5 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/4
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/4 (6 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/5
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/5 (14 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/6
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/6 (1479 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/7
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/7 (1470 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/8
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/8 (91 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/9
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/9 (3 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/10
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/10 (3 ms)
[ RUN      ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/11
MEM_USAGE=683244KB
[       OK ] TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests.TestsDynBatchSoftMax/11 (17 ms)
[----------] 12 tests from TestsDynBatchSoftMax/MKLDNNGraphDynBatchSoftMaxTests (4546 ms total)
[----------] 24 tests from TestDeconvolution/MKLDNNGraphDeconvolutionalTests
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/0
MEM_USAGE=683244KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_deconv_test.cpp:305: Failure
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/0, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 90-43 E0-A8 24-56 00-00 A0-43 E0-A8 24-56 00-00 A0-43 E0-A8 24-56 00-00 00-79 E1-A8 24-56 00-00 10-79 E1-A8 24-56 00-00 ... 54-0D E2-A8 24-56 00-00 54-0D E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (9 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/1
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/1, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (17 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/2
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/2, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (8 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/3
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/3, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (9 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/4
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/4, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (19 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/5
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/5, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (13 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/6
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/6, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (9 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/7
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/7, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (14 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/8
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/8, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (11 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/9
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/9, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (18 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/10
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/10, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (18 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/11
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/11, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (16 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/12
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/12, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (10 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/13
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/13, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (11 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/14
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/14, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (14 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/15
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/15, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (14 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/16
MEM_USAGE=683244KB
[       OK ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/16 (23 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/17
MEM_USAGE=683244KB
[       OK ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/17 (11 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/18
MEM_USAGE=683244KB
[       OK ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/18 (18 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/19
MEM_USAGE=683244KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/layers/internal/graph_deconv_test.cpp:296: Failure
Expected: (p.num_prim_desc) <= (node->getSupportedPrimitiveDescriptors().size()), actual: 4 vs 3
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/19, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (11 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/20
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/20, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (18 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/21
MEM_USAGE=683244KB
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/21, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (18 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/22
MEM_USAGE=683244KB
Value of: good_prim
  Actual: false
Expected: true
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/22, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00> (19 ms)
[ RUN      ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/23
MEM_USAGE=683244KB
[       OK ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/23 (44 ms)
[----------] 24 tests from TestDeconvolution/MKLDNNGraphDeconvolutionalTests (373 ms total)
[----------] 9 tests from TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/0
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/0 (23 ms)
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/1
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/1 (41 ms)
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/2
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/2 (9 ms)
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/3
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/3 (36 ms)
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/4
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/4 (35 ms)
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/5
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/5 (36 ms)
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/6
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/6 (18 ms)
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/7
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/7 (48 ms)
[ RUN      ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/8
MEM_USAGE=683244KB
[       OK ] TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests.TestsDynBatchDeconvolutional/8 (24 ms)
[----------] 9 tests from TestsDynBatchDeconvolutional/MKLDNNGraphDynBatchDeconvolutionalTests (270 ms total)
[----------] 8 tests from TestsFullyConnected/MKLDNNGraphFullyConnectedTests
[ RUN      ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/0
MEM_USAGE=683244KB
[       OK ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/0 (4990 ms)
[ RUN      ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/1
MEM_USAGE=683244KB
[       OK ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/1 (548 ms)
[ RUN      ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/2
MEM_USAGE=683244KB
[       OK ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/2 (770 ms)
[ RUN      ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/3
MEM_USAGE=683244KB
[       OK ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/3 (6619 ms)
[ RUN      ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/4
MEM_USAGE=683244KB
[       OK ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/4 (849 ms)
[ RUN      ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/5
MEM_USAGE=683244KB
[       OK ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/5 (1176 ms)
[ RUN      ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/6
MEM_USAGE=683244KB
[       OK ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/6 (556 ms)
[ RUN      ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/7
MEM_USAGE=683244KB
[       OK ] TestsFullyConnected/MKLDNNGraphFullyConnectedTests.TestsFullyConnected/7 (4649 ms)
[----------] 8 tests from TestsFullyConnected/MKLDNNGraphFullyConnectedTests (20158 ms total)
[----------] 6 tests from TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests
[ RUN      ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/0
MEM_USAGE=683244KB
[       OK ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/0 (5301 ms)
[ RUN      ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/1
MEM_USAGE=683244KB
[       OK ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/1 (1028 ms)
[ RUN      ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/2
MEM_USAGE=683244KB
[       OK ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/2 (1166 ms)
[ RUN      ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/3
MEM_USAGE=683244KB
[       OK ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/3 (9821 ms)
[ RUN      ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/4
MEM_USAGE=683244KB
[       OK ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/4 (1515 ms)
[ RUN      ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/5
MEM_USAGE=683244KB
[       OK ] TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests.TestsDynBatchFullyConnected/5 (1793 ms)
[----------] 6 tests from TestsDynBatchFullyConnected/MKLDNNGraphDynBatchFullyConnectedTests (20625 ms total)
[----------] 26 tests from TestsGemm/MKLDNNGraphGemmTests
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/0
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/0 (10 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/1
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/1 (10 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/2
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/2 (23 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/3
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/3 (7 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/4
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/4 (6 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/5
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/5 (21 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/6
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/6 (6 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/7
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/7 (27 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/8
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/8 (6 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/9
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/9 (8 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/10
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/10 (14 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/11
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/11 (6 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/12
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/12 (13 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/13
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/13 (8 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/14
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/14 (23 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/15
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/15 (27 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/16
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/16 (12 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/17
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/17 (13 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/18
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/18 (9 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/19
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/19 (6 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/20
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/20 (28 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/21
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/21 (8 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/22
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/22 (24 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/23
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/23 (8 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/24
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/24 (15 ms)
[ RUN      ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/25
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphGemmTests.TestsGemm/25 (16 ms)
[----------] 26 tests from TestsGemm/MKLDNNGraphGemmTests (359 ms total)
[----------] 2 tests from TestsDynBatchGemm/MKLDNNGraphDynBatchGemmTests
[ RUN      ] TestsDynBatchGemm/MKLDNNGraphDynBatchGemmTests.TestsDynBatchGemm/0
MEM_USAGE=683244KB
[       OK ] TestsDynBatchGemm/MKLDNNGraphDynBatchGemmTests.TestsDynBatchGemm/0 (28 ms)
[ RUN      ] TestsDynBatchGemm/MKLDNNGraphDynBatchGemmTests.TestsDynBatchGemm/1
MEM_USAGE=683244KB
[       OK ] TestsDynBatchGemm/MKLDNNGraphDynBatchGemmTests.TestsDynBatchGemm/1 (9 ms)
[----------] 2 tests from TestsDynBatchGemm/MKLDNNGraphDynBatchGemmTests (38 ms total)
[----------] 12 tests from TestsGemm/MKLDNNGraphSingleBatchDimGemmTests
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/0
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/0 (10 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/1
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/1 (5 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/2
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/2 (8 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/3
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/3 (4 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/4
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/4 (3 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/5
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/5 (17 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/6
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/6 (4 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/7
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/7 (9 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/8
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/8 (5 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/9
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/9 (12 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/10
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/10 (4 ms)
[ RUN      ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/11
MEM_USAGE=683244KB
[       OK ] TestsGemm/MKLDNNGraphSingleBatchDimGemmTests.TestsGemm/11 (3 ms)
[----------] 12 tests from TestsGemm/MKLDNNGraphSingleBatchDimGemmTests (84 ms total)
[----------] 19 tests from TestsSplit/MKLDNNGraphSplitTests
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/0
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/0 (3 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/1
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/1 (6 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/2
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/2 (4 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/3
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/3 (7 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/4
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/4 (3 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/5
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/5 (4 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/6
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/6 (4 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/7
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/7 (7 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/8
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/8 (5 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/9
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/9 (9 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/10
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/10 (6 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/11
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/11 (5 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/12
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/12 (9 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/13
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/13 (12 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/14
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/14 (9 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/15
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/15 (8 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/16
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/16 (8 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/17
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/17 (268 ms)
[ RUN      ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/18
[       OK ] TestsSplit/MKLDNNGraphSplitTests.TestsSplit/18 (54 ms)
[----------] 19 tests from TestsSplit/MKLDNNGraphSplitTests (435 ms total)
[----------] 14 tests from TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/0
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/0 (5 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/1
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/1 (4 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/2
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/2 (27 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/3
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/3 (4 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/4
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/4 (5 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/5
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/5 (10 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/6
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/6 (7 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/7
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/7 (4 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/8
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/8 (5 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/9
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/9 (6 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/10
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/10 (6 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/11
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/11 (17 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/12
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/12 (12 ms)
[ RUN      ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/13
[       OK ] TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests.TestsDynBatchSplit/13 (14 ms)
[----------] 14 tests from TestsDynBatchSplit/MKLDNNGraphDynBatchSplitTests (129 ms total)
[----------] 5 tests from TestsConcat/MKLDNNGraphConcatTests
[ RUN      ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/0
MEM_USAGE=683244KB
[       OK ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/0 (7 ms)
[ RUN      ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/1
MEM_USAGE=683244KB
[       OK ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/1 (3 ms)
[ RUN      ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/2
MEM_USAGE=683244KB
[       OK ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/2 (3 ms)
[ RUN      ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/3
MEM_USAGE=683244KB
[       OK ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/3 (6 ms)
[ RUN      ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/4
MEM_USAGE=683244KB
[       OK ] TestsConcat/MKLDNNGraphConcatTests.TestsConcat/4 (258 ms)
[----------] 5 tests from TestsConcat/MKLDNNGraphConcatTests (277 ms total)
[----------] 7 tests from TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests
[ RUN      ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/0
MEM_USAGE=683244KB
[       OK ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/0 (2 ms)
[ RUN      ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/1
MEM_USAGE=683244KB
[       OK ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/1 (4 ms)
[ RUN      ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/2
MEM_USAGE=683244KB
[       OK ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/2 (18 ms)
[ RUN      ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/3
MEM_USAGE=683244KB
[       OK ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/3 (13 ms)
[ RUN      ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/4
MEM_USAGE=683244KB
[       OK ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/4 (18 ms)
[ RUN      ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/5
MEM_USAGE=683244KB
[       OK ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/5 (4 ms)
[ RUN      ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/6
MEM_USAGE=683244KB
[       OK ] TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests.TestsDynBatchConcat/6 (9 ms)
[----------] 7 tests from TestsDynBatchConcat/MKLDNNGraphDynBatchConcatTests (68 ms total)
[----------] 6 tests from TestsTwoConcat/MKLDNNGraphTwoConcatTests
[ RUN      ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/0
MEM_USAGE=683244KB
[       OK ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/0 (20 ms)
[ RUN      ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/1
MEM_USAGE=683244KB
[       OK ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/1 (22 ms)
[ RUN      ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/2
MEM_USAGE=683244KB
[       OK ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/2 (23 ms)
[ RUN      ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/3
MEM_USAGE=683244KB
[       OK ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/3 (22 ms)
[ RUN      ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/4
MEM_USAGE=683244KB
[       OK ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/4 (22 ms)
[ RUN      ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/5
MEM_USAGE=683244KB
[       OK ] TestsTwoConcat/MKLDNNGraphTwoConcatTests.TestsTwoConcat/5 (20 ms)
[----------] 6 tests from TestsTwoConcat/MKLDNNGraphTwoConcatTests (131 ms total)
[----------] 2 tests from TestsIncorrectConcat/MKLDNNGraphIncorrectConcatTests
[ RUN      ] TestsIncorrectConcat/MKLDNNGraphIncorrectConcatTests.TestsIncorrectConcat/0
MEM_USAGE=683244KB
[       OK ] TestsIncorrectConcat/MKLDNNGraphIncorrectConcatTests.TestsIncorrectConcat/0 (2 ms)
[ RUN      ] TestsIncorrectConcat/MKLDNNGraphIncorrectConcatTests.TestsIncorrectConcat/1
MEM_USAGE=683244KB
[       OK ] TestsIncorrectConcat/MKLDNNGraphIncorrectConcatTests.TestsIncorrectConcat/1 (2 ms)
[----------] 2 tests from TestsIncorrectConcat/MKLDNNGraphIncorrectConcatTests (4 ms total)
[----------] 1 test from TestsDwConvFusing/MKLDNNGraphDWConvFusingTests
[ RUN      ] TestsDwConvFusing/MKLDNNGraphDWConvFusingTests.TestsDwConvFusing/0
MEM_USAGE=683244KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_dw_conv_fusing_test.cpp:326: Failure
Failed
Supported primitive descriptors list is empty for node: conv1
[  FAILED  ] TestsDwConvFusing/MKLDNNGraphDWConvFusingTests.TestsDwConvFusing/0, where GetParam() = 160-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 A0-00 00-00 00-00 00-00 40-01 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 ... 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 18-00 00-00 00-00 00-00 18-00 00-00 00-00 00-00> (16 ms)
[----------] 1 test from TestsDwConvFusing/MKLDNNGraphDWConvFusingTests (16 ms total)
[----------] 16 tests from TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/0
MEM_USAGE=683244KB
/home/matt/intel/dldt/inference-engine/tests/unit/engines/mkldnn/graph/structure/graph_conv_depthwise_fusing_test.cpp:265: Failure
      Expected: nodes.size()
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/0, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 64-00 00-00 00-56 00-00> (13 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/1
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/1, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 65-00 00-00 00-56 00-00> (19 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/2
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/2, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 64-00 00-00 01-00 00-00> (14 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/3
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/3, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 65-00 00-00 01-56 00-00> (21 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/4
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/4, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 09-00 00-00 00-00 00-00 09-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 64-00 00-00 00-56 00-00> (26 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/5
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/5, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 09-00 00-00 00-00 00-00 09-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 65-00 00-00 00-56 00-00> (25 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/6
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/6, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 09-00 00-00 00-00 00-00 09-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 64-00 00-00 01-7F 00-00> (34 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/7
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/7, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 09-00 00-00 00-00 00-00 09-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 65-00 00-00 01-7F 00-00> (27 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/8
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/8, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 0B-00 00-00 00-00 00-00 0B-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 64-00 00-00 00-56 00-00> (21 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/9
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/9, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 0B-00 00-00 00-00 00-00 0B-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 65-00 00-00 00-56 00-00> (18 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/10
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/10, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 0B-00 00-00 00-00 00-00 0B-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 64-00 00-00 01-00 00-00> (36 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/11
MEM_USAGE=683244KB
      Which is: 3
To be equal to: 5
[  FAILED  ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/11, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 0B-00 00-00 00-00 00-00 0B-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 30-00 00-00 00-00 00-00 65-00 00-00 01-7F 00-00> (30 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/12
MEM_USAGE=683244KB
[       OK ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/12 (50 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/13
MEM_USAGE=683244KB
[       OK ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/13 (41 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/14
MEM_USAGE=683244KB
[       OK ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/14 (20 ms)
[ RUN      ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/15
MEM_USAGE=683244KB
[       OK ] TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests.TestsConvDepthwiseFusing/15 (24 ms)
[----------] 16 tests from TestsConvDepthwiseFusing/MKLDNNGraphConvDepthwiseFusingTests (425 ms total)
[----------] Global test environment tear-down
[==========] 1662 tests from 145 test cases ran. (238222 ms total)
[  PASSED  ] 1561 tests.
[  FAILED  ] 101 tests, listed below:
[  FAILED  ] MKLDNNLayersTests.DumpSimpleGraph
[  FAILED  ] MKLDNNLayersTests.DumpSimpleGraphToDot
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReorders
[  FAILED  ] MKLDNNGraphStructureTests.TestRedundantReorderBeforeConvWithC_3
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReordersBeforeConcat
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReordersRmnet_SSSSD
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReordersForXceptionTopology
[  FAILED  ] MKLDNNGraphStructureTests.TestNoRedundantReordersForGrayscaleInput
[  FAILED  ] MKLDNNGraphStructureTests.TestConvolutionDWConvolutionSumFusing
[  FAILED  ] MKLDNNGraphStructureTests.TestConvolutionWith2DepthwiseOpFusing
[  FAILED  ] MKLDNNGraphStructureTests.TestConvolutionWith2EltwiseOpFusing
[  FAILED  ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/0, where GetParam() = 112-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 02-00 00-00 2F-75 6E-69 05-00 00-00 00-00 00-00 00-01 00-00 6C-64 6E-6E 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/1, where GetParam() = 112-byte object <04-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 E3-00 00-00 00-00 00-00 E3-00 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 02-00 00-00 2F-75 6E-69 05-00 00-00 00-00 00-00 00-01 00-00 6C-64 6E-6E 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/2, where GetParam() = 112-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 02-00 00-00 2F-75 6E-69 05-00 00-00 00-00 00-00 80-00 00-00 6C-64 6E-6E 00-B0 DC-A8 24-56 00-00 04-B0 DC-A8 24-56 00-00 04-B0 DC-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsBatchNormWithScaleShift/MKLDNNGraphBatchNormScaleShiftTests.TestsBatchNormWithScaleShift/3, where GetParam() = 112-byte object <04-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 E3-00 00-00 00-00 00-00 E3-00 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 02-00 00-00 2F-75 6E-69 05-00 00-00 00-00 00-00 80-00 00-00 6C-64 6E-6E 00-B0 DC-A8 24-56 00-00 04-B0 DC-A8 24-56 00-00 04-B0 DC-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/0, where GetParam() = 104-byte object <64-00 00-00 F9-7F 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/1, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/2, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/3, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/4, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 01-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/5, where GetParam() = 104-byte object <64-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 01-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/6, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/7, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/8, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/9, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 00-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/10, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 01-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsDepthwise/MKLDNNGraphDepthwiseTests.TestsDepthwise/11, where GetParam() = 104-byte object <65-00 00-00 00-00 00-00 A0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 C0-6E DD-A8 24-56 00-00 01-69 66-74 2F-4D 4B-4C 03-00 00-00 00-00 00-00 00-01 00-00 61-74 63-68 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsRelu/MKLDNNGraphReluTests.TestsRelu/0, where GetParam() = 72-byte object <B0-36 DE-A8 24-56 00-00 D0-36 DE-A8 24-56 00-00 D0-36 DE-A8 24-56 00-00 00-00 00-00 24-56 00-00 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 50-CC DE-A8 24-56 00-00 90-CC DE-A8 24-56 00-00 90-CC DE-A8 24-56 00-00>
[  FAILED  ] TestsRelu/MKLDNNGraphReluTests.TestsRelu/1, where GetParam() = 72-byte object <B0-36 DE-A8 24-56 00-00 D8-36 DE-A8 24-56 00-00 D8-36 DE-A8 24-56 00-00 00-00 00-00 24-56 00-00 03-00 00-00 00-00 00-00 80-80 00-00 00-00 00-00 50-CC DE-A8 24-56 00-00 90-CC DE-A8 24-56 00-00 90-CC DE-A8 24-56 00-00>
[  FAILED  ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/0, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 05-00 00-00 00-00 00-00 00-01 00-00 65-73 74-73 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/1, where GetParam() = 104-byte object <03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 05-00 00-00 00-00 00-00 00-01 00-00 65-73 74-73 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/2, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 20-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 05-00 00-00 00-00 00-00 80-00 00-00 65-73 74-73 00-5B DD-A8 24-56 00-00 04-5B DD-A8 24-56 00-00 04-5B DD-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsBatchNorm/MKLDNNGraphBatchNormTests.TestsBatchNorm/3, where GetParam() = 104-byte object <03-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 8D-ED B5-A0 F7-C6 B0-3E 05-00 00-00 00-00 00-00 80-00 00-00 65-73 74-73 00-5B DD-A8 24-56 00-00 04-5B DD-A8 24-56 00-00 04-5B DD-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/0, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 A0-C7 DD-A8 24-56 00-00 B0-C7 DD-A8 24-56 00-00 ... 06-00 00-00 00-00 00-00 00-01 01-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/1, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/2, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/3, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/4, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/5, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/6, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 60-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 30-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 80-D8 DD-A8 24-56 00-00 ... 05-00 00-00 00-00 00-00 80-80 00-00 00-00 00-00 20-64 DE-A8 24-56 00-00 24-64 DE-A8 24-56 00-00 24-64 DE-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/11, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 88-D8 DD-A8 24-56 00-00 ... 02-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/12, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 88-D8 DD-A8 24-56 00-00 ... 02-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/13, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 88-D8 DD-A8 24-56 00-00 ... 02-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestConvolution/MKLDNNGraphConvolutionTests.TestsConvolution/14, where GetParam() = 232-byte object <40-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 68-10 DE-A8 24-56 00-00 20-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 38-CD DE-A8 24-56 00-00 70-D8 DD-A8 24-56 00-00 88-D8 DD-A8 24-56 00-00 ... 02-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsRoiPooling/MKLDNNGraphRoiPoolingTests.TestsRoiPooling/0, where GetParam() = 112-byte object <01-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 27-00 00-00 00-00 00-00 40-00 00-00 00-00 00-00 96-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 06-00 00-00 00-00 00-00 06-00 00-00 00-00 00-00 00-00 80-3D 70-68 2F-6C 05-00 00-00 00-00 00-00 00-01 00-00 61-6C 2F-67 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/0, where GetParam() = 104-byte object <08-00 00-00 00-00 00-00 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/1, where GetParam() = 104-byte object <08-00 00-00 00-00 00-00 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/2, where GetParam() = 104-byte object <08-00 00-00 00-00 00-3F 00-00 00-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/3, where GetParam() = 104-byte object <08-00 00-00 00-00 00-3F 00-00 00-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/4, where GetParam() = 104-byte object <0A-00 00-00 00-00 00-3F 00-00 00-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/5, where GetParam() = 104-byte object <0A-00 00-00 00-00 00-3F 00-00 00-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/6, where GetParam() = 104-byte object <0A-00 00-00 00-00 80-3F 00-00 80-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/7, where GetParam() = 104-byte object <0A-00 00-00 00-00 80-3F 00-00 80-3F F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/8, where GetParam() = 104-byte object <11-00 00-00 00-00 00-00 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/9, where GetParam() = 104-byte object <11-00 00-00 00-00 00-00 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/10, where GetParam() = 104-byte object <0F-00 00-00 00-00 C0-40 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/11, where GetParam() = 104-byte object <0F-00 00-00 00-00 C0-40 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/12, where GetParam() = 104-byte object <0F-00 00-00 CD-CC CC-3D 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsActivation/MKLDNNGraphActivationTests.TestsActivation/13, where GetParam() = 104-byte object <0F-00 00-00 CD-CC CC-3D 00-00 00-00 F9-7F 00-00 60-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 80-7A E0-A8 24-56 00-00 03-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/0, where GetParam() = 192-byte object <00-4F E0-A8 24-56 00-00 20-4F E0-A8 24-56 00-00 20-4F E0-A8 24-56 00-00 40-80 E0-A8 24-56 00-00 50-80 E0-A8 24-56 00-00 50-80 E0-A8 24-56 00-00 10-2F E1-A8 24-56 00-00 20-2F E1-A8 24-56 00-00 ... 06-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsPooling/MKLDNNGraphPoolingTests.TestsPooling/3, where GetParam() = 192-byte object <00-4F E0-A8 24-56 00-00 20-4F E0-A8 24-56 00-00 20-4F E0-A8 24-56 00-00 40-80 E0-A8 24-56 00-00 50-80 E0-A8 24-56 00-00 50-80 E0-A8 24-56 00-00 10-2F E1-A8 24-56 00-00 20-2F E1-A8 24-56 00-00 ... 06-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 20-FC E0-A8 24-56 00-00 24-FC E0-A8 24-56 00-00 24-FC E0-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsLrn/MKLDNNGraphLrnTests.TestsLrn/1, where GetParam() = 96-byte object <01-00 00-00 00-00 00-00 10-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 05-00 00-00 00-00 00-00 17-B7 D1-38 00-00 40-3F 01-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 00-01 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/0, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/1, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 03-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 E4-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 80-00 00-00 24-56 00-00 90-43 E0-A8 24-56 00-00 94-43 E0-A8 24-56 00-00 94-43 E0-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/2, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 64-00 00-00 00-00 00-00 06-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/3, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 64-00 00-00 00-00 00-00 06-00 00-00 00-00 00-00 01-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 80-00 00-00 24-56 00-00 60-86 E1-A8 24-56 00-00 64-86 E1-A8 24-56 00-00 64-86 E1-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/6, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 13-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 00-01 00-00 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestsSoftMax/MKLDNNGraphSoftMaxTests.TestsSoftMax/7, where GetParam() = 104-byte object <01-00 00-00 00-00 00-00 13-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 80-00 00-00 00-00 00-00 01-00 00-00 30-30 2D-30 02-00 00-00 00-00 00-00 80-00 00-00 24-56 00-00 00-71 E0-A8 24-56 00-00 04-71 E0-A8 24-56 00-00 04-71 E0-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/0, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 90-43 E0-A8 24-56 00-00 A0-43 E0-A8 24-56 00-00 A0-43 E0-A8 24-56 00-00 00-79 E1-A8 24-56 00-00 10-79 E1-A8 24-56 00-00 ... 54-0D E2-A8 24-56 00-00 54-0D E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/1, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/2, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/3, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/4, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/5, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/6, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/7, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/8, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/9, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/10, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/11, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/12, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 58-42 E2-A8 24-56 00-00 58-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/13, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/14, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/15, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/19, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/20, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/21, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
[  FAILED  ] TestDeconvolution/MKLDNNGraphDeconvolutionalTests.TestsDeconvolution/22, where GetParam() = 256-byte object <20-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 40-94 E2-A8 24-56 00-00 30-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 40-3C E2-A8 24-56 00-00 70-F6 E1-A8 24-56 00-00 80-F6 E1-A8 24-56 00-00 ... 54-42 E2-A8 24-56 00-00 54-42 E2-A8 24-56 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00 00-00>
101 FAILED TESTS
  YOU HAVE 20 DISABLED TESTS
nikos1
Valued Contributor I
Hello Matt,
> Here's the result of the tests:
I think your unit test results explain why SSD fails on the CPU that has no SSSE3, SSE4.x or AVX.  Again this is not a supported or recommended OpenVino environment. How would you like to proceed?  I can see a few options (we are lucky to have the source) but is it worth pursuing this further? Even if it works it will be slow and you may be better off running on MYRIAD or other SSE/AVX CPU or Intel GPU system. (Similar issue to what we investigated with clDNN on an older Intel GPU that had no support for some new OpenCL extensions; eventually we decided it was not worth it trying to run on unsupported hardware - ref: https://software.intel.com/comment/1931449).
Cheers,
nikos
