Openvino 2022.3.1 Pi Camera Raspeberry pi
fpardo
I have run some demos on raspberry pi 4 using OPENVINO 2022.3.1. I would like to know wheter the demos can run using Raspberry Pi Camera Module V2. Thanks in advance for your time.
Nando
Wan_Intel
Hi Nando,
Yes, you can run your demos when using Raspberry Pi Camera Module V2. For example, please refer to the following sample as it uses the --input command to specify the camera id as input for the demo:
https://docs.openvino.ai/2023.1/omz_demos_object_detection_demo_python.html
Hope it helps.
Wan
fpardo
Thanks ! I had to enable legacy interface in raspbian bullseye and then run the commanda
sudo modprobe bcm2835-v4l2
In this way the Camera Pi worked with the demos.
Wan_Intel
Hi Nando,
Thanks for sharing the solution in the OpenVINO™ community.
Glad to know the Raspberry Pi Camera worked with the demos. We'll close this case now since the issue has been resolved.
Please open a new question if additional information is needed and we'll be happy to help.
Wan
