RuntimeError
wangyigao
When I run this case, the following error appears, I want to know how to solve it.
RuntimeError: Exception from src\inference\src\core.cpp:100: Check 'false' failed at src\frontends\common\src\frontend.cpp:54: Converting input model [ GENERAL_ERROR ] Incorrect weights in bin file!
Zulkifli_Intel
Hi wangyigao,
Thank you for reaching out to Intel Customer Support.
I'm able to run without any issues.
Please share your environment details:
  1. Python version
  2. Operating System
  3. Did you custom/change any lines of code?
  4. Are you using Anaconda?
Sincerely,
Zulkifli
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
