6614 Discussions
Openvino 2022 - using multiple NCS2 asynchrounously
gaudibert
I'm trying to update my stack to Openvino 2022 to benefit from the latest news. And I'm using this update to gain a little performance by trying to use multiple NCS2 asynchrounously.
However I'm a bit stuck despite reading quite some documentation on your website and the community. I'm finding a lot of examples of this on 2021 version but I can't manage to pass it to 2022 2.0 API.
The closest example I found is this : https://github.com/openvinotoolkit/openvino/tree/master/samples/cpp/classification_sample_async but it doesn't manage multiple devices.
Would you have a very basic example of a model loaded and called by batch on more than 1 NCS2 ? That would be immensely helpful for me.
Greg
Wan_Intel
Hi Gaudibert,
For your information, you can use multiple Intel® Neural Compute Stick 2 asynchronously as shown as follows:
1.   Run Hello Query Device Python Sample script which is located in the following directory:
cd <INSTALL_DIR>\samples\python\hello_query_device
python hello_query_device.py
2.   Use Multi-device plugin with the following command:
python classification_sample_async.py -m "<path_to_model>\alexnet.xml" -i "path_to_input_1" "path_to_input_2" -d MULTI:MYRIAD.5.2-ma2480,MYRIAD.5.3-ma2480
For more information, please refer to Running on multiple devices simultaneously and Multi-Device Plugin with the Intel® Neural Compute Stick 2.
Wan
gaudibert
Hello Wan,
Thank you for your quick reply. That is exactly what I needed.
I should have taken a look inside the openvino repository and not only online, sorry about that !
Cheers,
Greg
Wan_Intel
Hi Gaudibert,
Thanks for your question.
This thread will no longer be monitored since we have provided information.
If you need any additional information from Intel, please submit a new question.
Wan
