Openvino with Intel Core graphics probelm
Deng__Fucheng
I tried to do inference with -d GPU. The error shows:
ERROR: failed to create engine:Device lookup failed - unsupported device id:0x3E9B, Note:HD5xx+ devices are supported.
My CPU is i5 8300H, I checked , the processor graphics is UHD graphics 630. So openvino only supports HD graphics 5xxx, not others?
The official website shows supported hardware includes 6th-8th generation Intel Core processors with Iris Pro graphics and Intel HD Graphics. But I tried HD Graphics 6000, it still did not work.
anyone could tell which ones  exactly openvino can support? Have anyone compared the performance for inference between CPU version and GPU version? Thanks
Shaoqiang_C_Intel
do you have another video card and have the integrated card disabled? If not, try reboot. (seriously) If yes, you should switch on the integrated card. (from BIOS)
Deng__Fucheng
Hi, Shaoqiang, I tried it on two computers. One is NUC, ubuntu16.04LTS, Processor Intel Core i5-5250U, Graphics Intel HD Graphics 6000(Broadwell GT3); the other is laptop ubuntu 16.04LTS, Processor Intel Core i5-8300H, Graphics Gallium0.4 on llvmpipe(LLVM 4.0,256bits)(I removed the Nvidia driver for another video card). However, the results are same.
Could you tell me some sysetems or CPU configurations that work fine with integrated card under openvino? Because there is no clear official instruction. Thanks
Shaoqiang_C_Intel
From OpenVINO doc, it needs 6th-8th generation Core. I think that's why your NUC with Core i5-5250U doesn't work. For your Core i5-8300H laptop, I recommand completely removing mesa drivers for Nvidia card. You can try this way:
1) Uninstall nouvea drivers:
$ sudo apt-get remove --purge nvidia*
2) Disable nouvea
$ sudo vi /etc/modprobe.d/blacklist-nouveau.conf
Add:
blacklist nouveau
options nouveau modeset=0
$sudo update-initramfs -u
$ reboot
3) if you still want to use Nvidia card, you can install driver from Nvidia.
$ sudo ./NVIDIA-Linux-x86_64-*.run  -no-nouveau-check -no-opengl-files
Good luck!
Shaoqiang
Yaniv
I'm getting the same error: Device lookup failed - unsupported device id: 0x3E9B. Note: HD5xx+ devices are supported
I have a win10 core i7 8750H with UHD 630.
The device id 0x3E9B is actually the UHD 630.
Any advice?
nikos1
Valued Contributor I
Same issue here in one of our systems.
clDNN device ID bug or multi-GPU system issue?
 @ Yaniv
Do you have a discrete GPU in your system?
cheers,
nikos
nikos1
I remember now - this will be solved when OpenVino gets the new clDNN
UHD 630 is a good GPU for OpenVino
Please refer to
https://github.com/intel/clDNN/issues/47
and
https://github.com/intel/clDNN/issues/48
You could also build clDNN from source.
nikos
nikos1
Solution verified now and is the same as in https://software.intel.com/en-us/forums/computer-vision/topic/800809
- git checkout cldnn drop 9.1
( git checkout 049acb9ddac8d3ca11dae8513b9c16e2b7f9e53a )
- modify clDNN/src/caps/public/gpu_devices.inc
- build from source
- replace libclDNN64.so with the new one you built
FWIW it works with both GPUs ; no need to disable or modify nouveau or any other BIOS settings
Cheers,
nikos
Yaniv
Thanks nikos that's great help.
I'll try it next week.
Yaniv
- build from source
Cheers,
nikos
Solved my problem.
Thanks nikos.
BTW, version 5.0.1 still didn't fix it.
nikos1
> Solved my problem.
Good to hear!
Correct, also realized this.
Cheers,
Nikos
