Parallels Toolkit Error
I'm getting " [Error 7] Toolkit Error: USB Failure. Code: Error opening device " on my Ubuntu VM using Parallels (Mac).
I read somewhere else that someone had gotten this to work with Parallels (but not VirtualBox): https://ncsforum.movidius.com/discussion/123/ncs-sdk-virtual-machine-support#latest
In addition, when I run dmesg | tail , I see the Movidius NCS as shown in the image.
Any pointers to how I can get this to work?
@georgievm_cms the link you posted simply refers back to the link that i posted, which says that VM is not recommended due to unstability of USB connection.
However, as you can see from my image, that the NCS is connected and detected, which is why I'm wondering why I'm still getting this problem.
@modx07 you did not mentioned which Ubuntu VM you use. Is it 16.04 LTS ?
That's right, 16.04 LTS
Same here - when running 'make examples' I get: [Error 7] Toolkit Error: USB Failure. Code: No devices found
Both dmesg and lsusb show that the device is found by the OS (Ubuntu 16.04 LTS).
