6605 Discussions
PermissionError when i use OVModelForCausalLM
MansonHua
I want to switch huggingface model to Openvino model, like the tutorial did: "https://docs.openvino.ai/2024/learn-openvino/llm_inference_guide/llm-inference-hf.html"
When I run the following code,
from optimum.intel import OVModelForCausalLM
model_id = "TinyLlama/TinyLlama-1.1B-Chat-v1.0"
model = OVModelForCausalLM.from_pretrained(model_id, export=True)
The error is reported as follows :
Compiling the model to CPU ...
Exception ignored in: <finalize object at 0x2728ab83e40; dead>
Traceback (most recent call last):
File "D:\miniconda3\envs\npu-cu121\Lib\weakref.py", line 590, in __call__
return info.func(*info.args, **(info.kwargs or {}))
File "D:\miniconda3\envs\npu-cu121\Lib\tempfile.py", line 933, in _cleanup
cls._rmtree(name, ignore_errors=ignore_errors)
File "D:\miniconda3\envs\npu-cu121\Lib\tempfile.py", line 929, in _rmtree
_shutil.rmtree(name, onerror=onerror)
File "D:\miniconda3\envs\npu-cu121\Lib\shutil.py", line 787, in rmtree
return _rmtree_unsafe(path, onerror)
File "D:\miniconda3\envs\npu-cu121\Lib\shutil.py", line 634, in _rmtree_unsafe
onerror(os.unlink, fullname, sys.exc_info())
File "D:\miniconda3\envs\npu-cu121\Lib\tempfile.py", line 893, in onerror
_os.unlink(path)
PermissionError: [WinError 32] The process cannot access the file "C:\\Users\\super\\AppData\\Local\\Temp\\tmp8iwe25fe\\openvino_model.bin" because it is being used by another process
Based on the output, it seems that compression of the model has been completed:
What should I do to successfully run the code?
Peh_Intel
Hi MansonHua,
For your information, I am able to load TinyLlama-1.1B-Chat-v1.0 model from Hugging Face Model to Optimum Intel without having issue. I am running the code in Command Prompt with Python 3.11.5.
Please have a look at the directory:
If the temp folder has the config file and converted IR files, you can load the model from the directory
and save in a new folder called llma_model with the LLM in OpenVINO IR format inside.
model = OVModelForCausalLM.from_pretrained("C:\\Users\\super\\AppData\\Local\\Temp\\tmp8iwe25fe")
model.save_pretrained("llma_model")
Peh
Peh_Intel
Hi MansonHua,
This thread will no longer be monitored since we have provided a suggestion. If you need any additional information from Intel, please submit a new question.
Peh
