6586 Discussions
Porting 'multi_camera_multi_person_tracking' sample application from Python to C++
KG0001
Hello Intel Team,
We are from ZOHO corp R&D team, and working on openvino hardware acceleration part of it.
'multi_camera_multi_person_tracking' sample application is already as part of the openvino demo package and implemented in python language.  But we are in  need of same application in C++ language to do custom changes to obtain more hardware acceleration.
Do you have respective C++ implementation or Could you support for that ?
Regards, Kalyan-G.
Max_L_Intel
Hi @KG0001
Do you also get this error message when running Multi-Channel Face Detection C++ Demo and Pedestrian Tracker C++ Demo separately from each other? If not, then this might be related to incorrect input image size, and that the dimensions on your mat objects do not match. You need to check if your ROI is placed within the dimensions of the image.
Please check these topics: Assertion failed roi out of rangewhy am i getting so many roi crashesError with OpenCV ROI.
Iffa_Intel
Greetings,
We don't have the exact model for C++ as in Python. However, we do have these 3 samples in C++:
https://docs.openvinotoolkit.org/latest/omz_demos_multi_channel_README.html
Hope this somehow could help with your implementation.
Sincerely,
Iffa
KG0001
To bring the multi-channel-multi-person-tracking in C++,  we integrated the 'pedestrian_tracker_demo c++ implementation ' with 'multi_channel_face_detection c++' .
But getting this below error. It seems some pixel issue while parsing the frame. Could you share you comment on this error.
terminate called after throwing an instance of 'cv::Exception'
what(): OpenCV(4.3.0-openvino-2020.3.0) ../opencv/modules/core/src/matrix.cpp:466: error: (-215:Assertion failed) 0 <= roi.x && 0 <= roi.width && roi.x + roi.width <= m.cols && 0 <= roi.y && 0 <= roi.height && roi.y + roi.height <= m.rows in function 'Mat'
Max_L_Intel
Hi @KG0001
KG0001
Thanks for your support.
I will look into this further.. You can close this ticket.
Thanks & Regards,
Kalyan-G.
