Tensorflow to IR convertion
Corvid__Zabeth
There is .pb file with tf model. It needs to convert him to IR format.
I run the command (in admin-privilegies terminal):
mo_tf.py --input_model final_combined_alpha0.5_weights.pb
And it returns an error:
[ ERROR ]
Detected not satisfied dependencies:
        tensorflow: not installed, required: 1.2.0
Please install required versions of components or use install_prerequisites script
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites\install_prerequisites_tf.bat
Note that install_prerequisites scripts may install additional components.
Earlier I run install_prerequisites\install_prerequisites_tf.bat. I try it run secondary, and it notify, that all components are installed:
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>install_prerequisites_tf.bat
Python 3.7.3
ECHO is off.
Requirement already satisfied: tensorflow<2.0.0,>=1.2.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from -r ..\requirements_tf.txt (line 1)) (1.14.0)
Requirement already satisfied: networkx>=1.11 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from -r ..\requirements_tf.txt (line 2)) (2.3)
Requirement already satisfied: numpy>=1.12.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from -r ..\requirements_tf.txt (line 3)) (1.16.4)
Requirement already satisfied: test-generator==0.1.1 in c:\users\pveryovkin\appdata\roaming\python\python37\site-packages (from -r ..\requirements_tf.txt (line 4)) (0.1.1)
Requirement already satisfied: defusedxml>=0.5.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from -r ..\requirements_tf.txt (line 5)) (0.6.0)
Requirement already satisfied: protobuf>=3.6.1 in c:\users\pveryovkin\appdata\roaming\python\python37\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (3.6.1)
Requirement already satisfied: astor>=0.6.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.8.0)
Requirement already satisfied: keras-applications>=1.0.6 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.0.8)
Requirement already satisfied: google-pasta>=0.1.6 in c:\users\pveryovkin\appdata\roaming\python\python37\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.1.7)
Requirement already satisfied: termcolor>=1.1.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.1.0)
Requirement already satisfied: grpcio>=1.8.6 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.16.1)
Requirement already satisfied: wheel>=0.26 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.33.4)
Requirement already satisfied: absl-py>=0.7.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.7.1)
Requirement already satisfied: tensorflow-estimator<1.15.0rc0,>=1.14.0rc0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.14.0)
Requirement already satisfied: six>=1.10.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.12.0)
Requirement already satisfied: keras-preprocessing>=1.0.5 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.1.0)
Requirement already satisfied: wrapt>=1.11.1 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.11.2)
Requirement already satisfied: gast>=0.2.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.2.2)
Requirement already satisfied: tensorboard<1.15.0,>=1.14.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.14.0)
Requirement already satisfied: decorator>=4.3.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from networkx>=1.11->-r ..\requirements_tf.txt (line 2)) (4.4.0)
Requirement already satisfied: setuptools in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from protobuf>=3.6.1->tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (41.0.1)
Requirement already satisfied: h5py in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from keras-applications>=1.0.6->tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (2.9.0)
Requirement already satisfied: markdown>=2.6.8 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorboard<1.15.0,>=1.14.0->tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (3.1.1)
Requirement already satisfied: werkzeug>=0.11.15 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorboard<1.15.0,>=1.14.0->tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.15.4)
Warning: please expect that Model Optimizer conversion might be slow.
You can boost conversion speed by installing protobuf-*.egg located in the
"model-optimizer\install_prerequisites" folder or building protobuf library from sources.
For more information please refer to Model Optimizer FAQ, question #80.
I try run "pip install tensorflow", it also notify, that tf is installed:
PS C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites> pip install tensorflow
Requirement already satisfied: tensorflow in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (1.14.0)
Requirement already satisfied: termcolor>=1.1.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.1.0)
Requirement already satisfied: grpcio>=1.8.6 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.16.1)
Requirement already satisfied: keras-preprocessing>=1.0.5 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.1.0)
Requirement already satisfied: keras-applications>=1.0.6 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.0.8)
Requirement already satisfied: astor>=0.6.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (0.8.0)
Requirement already satisfied: google-pasta>=0.1.6 in c:\users\pveryovkin\appdata\roaming\python\python37\site-packages (from tensorflow) (0.1.7)
Requirement already satisfied: wheel>=0.26 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (0.33.4)
Requirement already satisfied: numpy<2.0,>=1.14.5 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.16.4)
Requirement already satisfied: wrapt>=1.11.1 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.11.2)
Requirement already satisfied: protobuf>=3.6.1 in c:\users\pveryovkin\appdata\roaming\python\python37\site-packages (from tensorflow) (3.6.1)
Requirement already satisfied: six>=1.10.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.12.0)
Requirement already satisfied: absl-py>=0.7.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (0.7.1)
Requirement already satisfied: tensorboard<1.15.0,>=1.14.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.14.0)
Requirement already satisfied: tensorflow-estimator<1.15.0rc0,>=1.14.0rc0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (1.14.0)
Requirement already satisfied: gast>=0.2.0 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorflow) (0.2.2)
Requirement already satisfied: h5py in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from keras-applications>=1.0.6->tensorflow) (2.9.0)
Requirement already satisfied: setuptools in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from protobuf>=3.6.1->tensorflow) (41.0.1)
Requirement already satisfied: markdown>=2.6.8 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorboard<1.15.0,>=1.14.0->tensorflow) (3.1.1)
Requirement already satisfied: werkzeug>=0.11.15 in c:\users\pveryovkin\appdata\local\continuum\anaconda3\lib\site-packages (from tensorboard<1.15.0,>=1.14.0->tensorflow) (0.15.4)
Where is my fail?
Kenneth_C_Intel
Hi could you try to run this in the terminal
pip install --upgrade tensorflow==1.2 .0
it could be that your model has a hard requirement on that version.
Corvid__Zabeth
It returns an error:
PS C:\WINDOWS\system32> pip install --upgrade tensorflow==1.2.0
Collecting tensorflow==1.2.0
  ERROR: Could not find a version that satisfies the requirement tensorflow==1.2.0 (from versions: 1.13.0rc1, 1.13.0rc2, 1.13.1, 1.13.2, 1.14.0rc0, 1.14.0rc1, 1.14.0, 1.15.0rc0, 1.15.0rc1, 2.0.0a0, 2.0.0b0, 2.0.0b1, 2.0.0rc0, 2.0.0rc1)
ERROR: No matching distribution found for tensorflow==1.2.0
HemanthKum_G_Intel
Hi Zabeth,
For the latest wheel from Tensorflow site, you can try something like -
python3 -m pip install --upgrade https://storage.googleapis.com/tensorflow/linux/cpu/tensorflow-1.14.0-cp37-cp37m-linux_x86_64.whl
For python 3.7x, if no pip install works, try downgrading to python 3.6
Corvid__Zabeth
This link is for linux, I try for windows:
pip install --upgrade https://storage.googleapis.com/tensorflow/windows/cpu/tensorflow-1.14.0-cp37-cp37m-windows_x86_64.whl
And this returns an error:
ERROR: tensorflow-1.14.0-cp37-cp37m-windows_x86_64.whl is not a supported wheel on this platform.
Shubha_R_Intel
Dear Zabeth -cp37 means Python 3.7 so you likely don't have Python 3.7 on your machine. Also windows_x86_64 means 64-bit OS, which if you're using the supported Windows OS for OpenVino (Windows 10), should be OK.
Shubha
Corvid__Zabeth
I installed Python 3.7 (and added it to PATH) . OS is Windows 10 64bit, but this error appears again.
Corvid__Zabeth
I found temporary solution of the problem - renamed folder with anaconda3 to "anaconda3.BAK". Then pip didn't found tensorflow library (it was installed as part of anaconda) and installed it again, but as part of Python 3.7 . Then optimizer script succesfully run. But it fails with another problem (it will be new forum topic).
I hope you will create method for overcoming of this problem by regularly method, without dirty tricks with renaming of anaconda :)
Shubha_R_Intel
Dear Corvid, Zabeth,
I'm super glad you found a workaround. But honestly Model Optimizer works just fine within Anaconda. So do all of the OpenVino Python based tools.
My feeling is that somehow your Python environment is messed up. I have also been in this situation (messed up Python environment). What I do is pretty much uninstall all the versions of Python I have except for Anaconda. I also delete various unused site-packages directories laying around after formal Python un-installation. Model Optimizer doesn't care whether Python came from a standalone Python installation or from Anaconda.
Hope it helps,
Shubha
Krunal_Lathiya
I totally agree with the intel employee.
This kind of error occurs when your Python development environment is not set up correctly.
If you are working with pip then upgrade pip to latest version which is pip3.
That is why we have to use virtualenv or pipenv or venv to separate the project dependencies.
The isolated environment is very useful when every coding stack demands different types of dependencies.
Next time, please do think about the virtual environment in your system.
