'PriorBoxParameter' object has no attribute 'width'
hsing__hj
I use model optimizer to to generate IR files from caffe model.
I got an error like this:
[ 2018-05-22 18:16:16,146 ] [ ERROR ] [ main:230 ]  -------------------------------------------------
[ 2018-05-22 18:16:16,146 ] [ ERROR ] [ main:231 ]  ----------------- INTERNAL ERROR ----------------
[ 2018-05-22 18:16:16,146 ] [ ERROR ] [ main:232 ]  Unexpected exception happened.
[ 2018-05-22 18:16:16,146 ] [ ERROR ] [ main:233 ]  Please contact Model Optimizer developers and forward the following information:
[ 2018-05-22 18:16:16,147 ] [ ERROR ] [ main:234 ]  'PriorBoxParameter' object has no attribute 'width'
[ 2018-05-22 18:16:16,147 ] [ ERROR ] [ main:235 ]  Traceback (most recent call last):
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/main.py", line 222, in main
    return driver(argv)
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/main.py", line 202, in driver
    custom_layers_mapping_path=custom_layers_mapping_path)
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/pipeline/caffe.py", line 106, in driver
    extract_node_attrs(graph, lambda node: caffe_extractor(node, check_for_duplicates(caffe_type_extractors)))
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/front/extractor.py", line 413, in extract_node_attrs
    supported, new_attrs = extractor(Node(graph, node))
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/pipeline/caffe.py", line 106, in <lambda>
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/front/caffe/extractor.py", line 127, in caffe_extractor
    result.update(caffe_type_extractors[name](node))
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/front/common/register_custom_ops.py", line 95, in <lambda>
    node, cls, disable_omitting_optional, enable_flattening_optional_params),
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/front/common/register_custom_ops.py", line 27, in extension_extractor
    supported = ex.extract(node)
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/extensions/front/caffe/priorbox_ext.py", line 42, in extract
    'width': list(param.width),
AttributeError: 'PriorBoxParameter' object has no attribute 'width'
[ 2018-05-22 18:16:16,147 ] [ ERROR ] [ main:236 ]  ---------------- END OF BUG REPORT --------------
[ 2018-05-22 18:16:16,147 ] [ ERROR ] [ main:237 ]  -------------------------------------------------
My CVSDK version is 2018.0.234.
My model is trained by intel caffe.
Attachment is my caffe.proto from intel caffe. There is no "width" attribute in PriorBoxParameter.
Hj
Zhen_Z_Intel
Hi hsing,
Thanks for posting the issue, we will escalate to fix.
Fiona
Zhen_Z_Intel
Hi hsing,
We will fix it in next release, currently you may can avoid error by modifying  the source code of priorbox_ext.py, removing attribute 'width' & 'height' or any other attributes, you are not set for PriorBoxLayer in your prototxt.
Fiona
