Problem in make examples in NCSDk-2
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 35, in
from Controllers.Scheduler import load_myriad_config, load_network
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 24, in
from Controllers.Optimizer import postParsingOptimizations, selectImplementations, streamEverythingSchedule, fixTensors, eliminateNoOps
File "/usr/local/bin/ncsdk/Controllers/Optimizer.py", line 25, in
from Controllers.Parsers.Parser.Conversion import Conversion
File "/usr/local/bin/ncsdk/Controllers/Parsers/init.py", line 3, in
from .Caffe import CaffeParser
File "/usr/local/bin/ncsdk/Controllers/Parsers/Caffe.py", line 30, in
import caffe
File "/opt/movidius/caffe/python/caffe/init.py", line 1, in
from .pycaffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, RMSPropSolver, AdaDeltaSolver, AdamSolver
File "/opt/movidius/caffe/python/caffe/pycaffe.py", line 15, in
import caffe.io
File "/opt/movidius/caffe/python/caffe/io.py", line 2, in
import skimage.io
File "/usr/local/lib/python3.5/dist-packages/skimage/init.py", line 158, in
from .util.dtype import *
File "/usr/local/lib/python3.5/dist-packages/skimage/util/init.py", line 7, in
from .arraycrop import crop
File "/usr/local/lib/python3.5/dist-packages/skimage/util/arraycrop.py", line 8, in
from numpy.lib.arraypad import _validate_lengths
ImportError: cannot import name '_validate_lengths'
Makefile:80: recipe for target 'compile' failed
make[4]: *** [compile] Error 1
make[4]: Leaving directory '/home/narveeryadav/ncsdk-2.05.00.02/examples/caffe/GoogLeNet'
cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
Makefile:9: recipe for target 'googlenet' failed
make[3]: *** [googlenet] Error 1
make[3]: Leaving directory '/home/narveeryadav/ncsdk-2.05.00.02/examples/apps/multistick_cpp'
Makefile:13: recipe for target 'multistick_cpp/.' failed
make[2]: *** [multistick_cpp/.] Error 2
make[2]: Leaving directory '/home/narveeryadav/ncsdk-2.05.00.02/examples/apps'
Makefile:12: recipe for target 'apps/.' failed
make[1]: *** [apps/.] Error 2
make[1]: Leaving directory '/home/narveeryadav/ncsdk-2.05.00.02/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
Hi @Narveer_241
It looks like you are using on older version of the NCSDK v2. Could you try with version 2.10.01.01?
git clone -b ncsdk2 https://github.com/movidius/ncsdk.git cd <ncs dirrectory> make install make examples
Jesus
Hi @Jesus_at_Intel ,
I'm facing the same problem. I followed the instruction as given by you. The only thing I had to change was the if/fi condition in the install.sh that checks for AVX support (lines 42-45 in install.sh) because if was failing with the error "Intel Advanced Vector Extensions support required but not detected". I referred to this post https://ncsforum.movidius.com/discussion/comment/4607/#Comment_4607 on this forum where someone else had this issue and I commented out those lines and it installed successfully.
But when I go to "make examples" it throws me the same error as given by OP. Specifically, it's giving the "recipe for target X failed" where X is:
1) googlenet
2) apps/.
3) multistick_cpp/.
3) examples
(Sorry I'm on a different machine else I would've copy-pasted the error).
Can you please recommend the path forward. Since it does not give an pre-requisites (e.g. googlenet, TF, Caffee) that need to be installed, I did not install these.
Hi @anshulvj
It's hard to pinpoint what the issue may be without the full error/log. Could you please share the whole error message and the NCSDK version you are installing?
Give the following a try as I had a similar issue with the make examples.
Uninstall the current SDK, run the following commands in the NCSDK directory
make clean && make uninstall
Remove the NCSDK directory and pull from github again.
sudo rm -r <NCSDK Dir> git clone -b ncsdk2 https://github.com/movidius/ncsdk
Remove any numpy packages & verify
pip3 uninstall numpy pip3 list | grep numpy
Install and make examples, run the following commands in the new NCSDK directory.
Jesus
