6585 Discussions
Problem loading tensorflow ssd model for openvino on a raspberry
FSern
I want to run the ssd_mobilenet from tensorflow models api on a raspberry with movidius using openvino but I have problems loading the IR file.
I installed the lastest version of openvino on my pc (ubuntu 16) following this guide https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html
then I used the model optimizer to create the IR file and tested it no problem.
then I installed openvino for raspbian following this guide https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_raspbian.html
but, while running the sample I got an error
RuntimeError: Check 'axis < static_cast<size_t>(input_rank)' failed at /teamcity/work/scoring_engine_build/releases_2020_1/ngraph/src/ngraph/op/gather.cpp:140:
While validating node 'Gather[Gather_1718](patternLabel_1714: float{10,20,30}, patternLabel_1715: int64_t{5}, patternLabel_1717: int64_t{1}) -> (??)':
The axis must => 0 and <= input_rank (axis: 4294967295)
and I found that this guy had the same problem https://software.intel.com/en-us/forums/intel-distribution-of-openvino-toolkit/topic/848966
using the model form 2019 to run the sample worked perfectly but I still get the error when I try to use my bin and xml
David_C_Intel
Hi FSern,
Thanks for reaching out.
As you can check on the thread you referred to, this is an issue with the latest OpenVINO™ toolkit version (2020.1). The "axis" error is caused by the new IR v10 format.
Could you please generate the model with the following parameter and tell us if it works:
--generate_deprecated_IR_V7
If it does not work, we recommend you installing the previous version of OpenVINO™ toolkit (2019 R3.1) on your Ubuntu 16 system, convert the model there, which will generate the IR v7 format and that should work successfully with the Intel® Neural Compute Stick 2 on the raspberry pi.
Please, as this post is a duplicate from this thread, reply to us on that forum and we will continue to give you assistance there.
David C.
A Contingent Worker at Intel
