6616 Discussions
Problem when converting RealDiv layer [Tensorflow]
Medhat__Amr
Hey,
I have a problem when converting my own .pb file,
when I get deeper into the error occured I found out that the problem is with RealDiv layer as I can cut the model before this layer and converting it successfully. But strting from  this layer I face a problem that I got an empty tensor which yields to the error below :
NODE NAME =  GlobalContext/div_3/reciprocal_
tensor shape  =  []
op shape  =  []
[ ERROR ]  -------------------------------------------------
[ ERROR ]  ----------------- INTERNAL ERROR ----------------
[ ERROR ]  Unexpected exception happened.
[ ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID (<class 'extensions.middle.EltwiseChecker.EltwiseChecker'>)": index -1 is out of bounds for axis 0 with size 0
[ ERROR ]  Traceback (most recent call last):
  File "/opt/intel/openvino_2019.2.275/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 273, in apply_replacements
    for_graph_and_each_sub_graph_recursively(graph, replacer.find_and_replace_pattern)
  File "/opt/intel/openvino_2019.2.275/deployment_tools/model_optimizer/mo/middle/pattern_match.py", line 58, in for_graph_and_each_sub_graph_recursively
    func(graph)
  File "/opt/intel/openvino_2019.2.275/deployment_tools/model_optimizer/extensions/middle/EltwiseChecker.py", line 82, in find_and_replace_pattern
    np.put(possible_shape, feature_dim, tensor_shape.item(feature_dim))
IndexError: index -1 is out of bounds for axis 0 with size 0
The above exception was the direct cause of the following exception:
  File "/opt/intel/openvino_2019.2.275/deployment_tools/model_optimizer/mo/main.py", line 302, in main
    return driver(argv)
  File "/opt/intel/openvino_2019.2.275/deployment_tools/model_optimizer/mo/main.py", line 251, in driver
    is_binary=not argv.input_model_is_text)
  File "/opt/intel/openvino_2019.2.275/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 134, in tf2nx
    class_registration.apply_replacements(graph, class_registration.ClassType.MIDDLE_REPLACER)
  File "/opt/intel/openvino_2019.2.275/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 299, in apply_replacements
    )) from err
Exception: Exception occurred during running replacer "REPLACEMENT_ID (<class 'extensions.middle.EltwiseChecker.EltwiseChecker'>)": index -1 is out of bounds for axis 0 with size 0
[ ERROR ]  ---------------- END OF BUG REPORT --------------
Is there any special note about this layer in R2 ?  I'm using Tensorflow 1.14
Shubha_R_Intel
Dear Medhat, Amr,
First, please kindly upgrade to OpenVIno 2019R3. We just released it a couple of days ago.
The critical error I am seeing is this:
Here is how to debug this issue. Print a text version of your frozen pb.  For instance tensor shape = [] and op shape [] will cause trouble for the Model Optimizer.
tensor shape  =  []
op shape  =  []
When you print out your pb, look for layers in the neighborhood of GlobalContext/div_3/reciprocal_ including GlobalContext/div_3/reciprocal_ itself. Do you see any -1 in the input or output shape dimensions ?  If you do, you need to replace those with positive values. numpy knows how to deal with -1 in shape dimensions but Model Optimizer does not.
Something that can help is to pass --input_shape in with all positive values.
Hope it helps,
Shubha
Medhat__Amr
Dear Shubha,
I have already passed the input shape to be postive integers. I have printed a text version of my pb and I havn't found any -1 dimension.
I seems to be a problem with the reciprocal module within RealDiv layer as it yields an empty tensor !
Medhat__Amr
Could you please help me with this problem as it affects all my work and I tried everything that I can do.
Thanks in advance
Shubha_R_Intel
Dear Medhat, Amr,
Have you tried on the just released OpenVino 2019R3 ?
If not, please do. And report the results here.
Thanks for your patience,
Shubha
Medhat__Amr
Yes I have tried and the same error appears.
I have tried editing the source file of the division operation ( div.py) and have edited the graph connection to skip the reciprocal and it worked well. but this is not what I want.
yang__ming
dear Shubha
I met same problem as Medhat do, i put --input_shape [1280,1280,3], and i still got this node with tensor shape and op shape =[]
thx
Shubha_R_Intel
Dear Medhat, Amr and/or yang, ming,
If you can attach each of your individual models as a *.zip, as well as the MO command(s) you used, that would be helpful. Tensorflow RealDiv is definitely supported by Model Optimizer so it could be a bug.
Thanks for trying it on R3 and also, thanks for your patience !
Shubha
Medhat__Amr
Dear Shubha, Could you please PM me so that I could send you the model as I can't release it in public.
Thanks in advance
yang__ming
python3 mo_tf.py --input_model /Users/myang/oss_model/detectforinvoice.pb --output_dir /Users/myang/oss_model --log_level=DEBUG --input_shape '[1280,1280,3]' --reverse_input_channels
im using tensflow 1.8.0 python3.6.5 and optimizer versioin is 2019.2.0-436-gf5827d4
above is the commomd used
thx
yang__ming
if i summerize the grpah i got 2 op All,Assert which not supported, is that the reason?
