Problem while following the OpenVINO 2019_R3.1 documentation
neilyoung
I'm a total newbie to this material. I'm having here a brand new Neural Compute Stick 2. Trying to find a use case for it.
After I was failing an installation on macOS Catalina ("Detected operating system is not supported. Supported operating systems for this release are macOS 1.13 and 10.14" -- welcome in 2020, Intel) and a completely fail of the installation in a "mature" (aka messed up) Ubuntu 16.04 I created an 18.04 VM and was completely able to install everything.
I was also able to run the first couple of demo apps, running on the CPU. I'm referring to this document http://docs.openvinotoolkit.org/2019_R3.1/_docs_install_guides_installing_openvino_linux.html#additional-NCS-steps.
I blindly followed all advises here given in this section "Steps for Intel® Movidius™ Neural Compute Stick and Intel® Neural Compute Stick 2" and finally came to this step: "Set Up a Neural Network Model". I created the required directory and run the python script:
The result is:
decades@decades-VirtualBox:/opt/intel/openvino/deployment_tools/demo$ python3 /opt/intel/openvino/deployment_tools/model_optimizer/mo.py --input_model /home/decades/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel --data_type FP16 --output_dir .
[ ERROR ]  The "/home/decades/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel" is not existing file
And the script is right. There is no such a directory/file, although all required samples have been passed before. What am I doing wrong?
TIA
Max_L_Intel
Hi, young, neil.
We've tested this section, and it seems the user guide on our web-site got outdated, since the latest version of model downloader component within OpenVINO toolkit puts Squeezenet model into the folder  /home/<user>/openvino_models/models/public/squeezenet1.1/
Hence the correct command would be:
python3 /opt/intel/openvino/deployment_tools/model_optimizer/mo.py --input_model /home/<user>/openvino_models/models/public/squeezenet1.1/squeezenet1.1.caffemodel --data_type FP16 --output_dir .
Let us escalate this case, so we can update the correct folder path in the user guide.
Max_L_Intel
With regards to macOS Catalina support, unfortunately this is not officially validated with currently available build (2019 R3.1). However, in order to suppress this warning message, please use Shift + right mouse click to launch the installer. So you'll be able to install OpenVINO on macOS Catalina.
nyoun7
Hi Max,
top 1: Yes, I also noticed this confusion. But after the installation of the October 2019 R3.1 version of the OpenVINO toolkit I had several folders. One in /opt/intel/openvino and in my home directory was also something. Cannot check it right now, since I messed my system up and needed to re-install everything. Will let you know.
top 2: No, you got me wrong. This is not a Catalina problem. I could launch the installer w/o problem. The error message is given from within the installer.
nyoun7
Regarding the python script:
Indeed, your changed command line was a bit more successful, but it revealed a new problem:
decades@ubuntu:~/squeezenet1.1_FP16$ python3 /opt/intel/openvino/deployment_tools/model_optimizer/mo.py --input_model /home/decades/openvino_models/models/public/squeezenet1.1/squeezenet1.1.caffemodel --data_type FP16 --output_dir .
Model Optimizer arguments:
Common parameters:
	- Path to the Input Model: 	/home/decades/openvino_models/models/public/squeezenet1.1/squeezenet1.1.caffemodel
	- Path for generated IR: 	/home/decades/squeezenet1.1_FP16/.
	- IR output name: 	squeezenet1.1
	- Log level: 	ERROR
	- Batch: 	Not specified, inherited from the model
	- Input layers: 	Not specified, inherited from the model
	- Output layers: 	Not specified, inherited from the model
	- Input shapes: 	Not specified, inherited from the model
	- Mean values: 	Not specified
	- Scale values: 	Not specified
	- Scale factor: 	Not specified
	- Precision of IR: 	FP16
	- Enable fusing: 	True
	- Enable grouped convolutions fusing: 	True
	- Move mean values to preprocess section: 	False
	- Reverse input channels: 	False
Caffe specific parameters:
	- Path to Python Caffe* parser generated from caffe.proto: 	/opt/intel/openvino/deployment_tools/model_optimizer/mo/front/caffe/proto
	- Enable resnet optimization: 	True
	- Path to the Input prototxt: 	/home/decades/openvino_models/models/public/squeezenet1.1/squeezenet1.1.prototxt
	- Path to CustomLayersMapping.xml: 	Default
	- Path to a mean file: 	Not specified
	- Offsets for a mean file: 	Not specified
Model Optimizer version: 	2019.3.0-408-gac8584cb7
[ WARNING ]
Detected not satisfied dependencies:
	protobuf: installed: 3.0.0, required: 3.6.1
Please install required versions of components or use install_prerequisites script
/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/install_prerequisites/install_prerequisites_caffe.sh
Note that install_prerequisites scripts may install additional components.
[ SUCCESS ] Generated IR model.
[ SUCCESS ] XML file: /home/decades/squeezenet1.1_FP16/./squeezenet1.1.xml
[ SUCCESS ] BIN file: /home/decades/squeezenet1.1_FP16/./squeezenet1.1.bin
[ SUCCESS ] Total execution time: 2.63 seconds.
I did run the update script
but the problem remains.
nyoun7
BTW: Step 4 fails too of course.
cp /home/<user>/openvino_models/ir/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.labels .
In real life:
decades@ubuntu:~/squeezenet1.1_FP16$ cp /home/decades/openvino_models/ir/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.labels .
cp: cannot stat '/home/decades/openvino_models/ir/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.labels': No such file or directory
nyoun7
And finally running the sample on an NCS2 gives this:
decades@ubuntu:~/inference_engine_samples_build/intel64/Release$ ./classification_sample_async -i /opt/intel/openvino/deployment_tools/demo/car.png -m /home/decades/squeezenet1.1_FP16/squeezenet1.1.xml -d MYRIAD
[ INFO ] InferenceEngine:
    API version ............ 2.1
    Build .................. custom_releases/2019/R3_ac8584cb714a697a12f1f30b7a3b78a5b9ac5e05
    Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
    MYRIAD
    myriadPlugin version ......... 2.1
    Build ........... 32974
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Loading model to the device
E: [ncAPI] [    567270] [classification_] ncDeviceOpen:859    Device doesn't appear after boot
[ ERROR ] Can not init Myriad device: NC_ERROR
I have seen things like that a couple of times already with the Intel Realsense T.265. Same procedure?
nyoun7
OK, disregard the last post please (NC_ERROR). I forgot to reboot after the USB updates.
Max_L_Intel
Hi Neil.
As mentioned before, Catalina macOS is not officially supported by 2019 R3.1 build. So OpenVINO toolkit installer notifies about that fact.
Yes, this is not a Catalina OS problem.
In real life:
With regards to Step 4 in setting up a NN model, of course we'll fix the folder path here as well. Thank you for heads-up.
However, for macOS installation and set up we recommend to use exactly macOS guide - https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_macos.html
[ WARNING ]
With regards to the warning message you get, so you haven't updated protobuf package on your system.
If you run install_prerequisites_caffe.sh or install_prerequisites.sh script, it should be updating protobuf to 3.6.1 version.
If that doesn't work anyway, try running the specific command from the script:
python3 -m pip install protobuf
If it's still doesn't get installed, please share bash output with us here.
Max_L_Intel
Hello Neil.
We would like to inform you that the latest 2020.1 build of OpenVINO toolkit that has been released today officially supports macOS Catalina.
You can download it here https://software.intel.com/en-us/openvino-toolkit/choose-download/free-download-macos
Best regards, Max.
nyoun7
Thanks for the info. Indeed, install worked. Then I came until
Run the Image Classification Verification Script
Go to the Inference Engine demo directory:
cd /opt/intel/openvino/deployment_tools/demo
Run the Image Classification verification script:
./demo_squeezenet_download_convert_run.sh
/opt/intel/openvino/deployment_tools/demo $ ./demo_squeezenet_download_convert_run.sh
target_precision = FP16
[setupvars.sh] OpenVINO environment initialized
Downloading the Caffe model and the prototxt
Installing dependencies
Requirement already satisfied: pyyaml in /usr/local/lib/python3.7/site-packages (from -r /opt/intel/openvino/deployment_tools/demo/../open_model_zoo/tools/downloader/requirements.in (line 1)) (5.3)
Requirement already satisfied: requests in /usr/local/lib/python3.7/site-packages (from -r /opt/intel/openvino/deployment_tools/demo/../open_model_zoo/tools/downloader/requirements.in (line 2)) (2.22.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/site-packages (from requests->-r /opt/intel/openvino/deployment_tools/demo/../open_model_zoo/tools/downloader/requirements.in (line 2)) (2019.11.28)
Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.7/site-packages (from requests->-r /opt/intel/openvino/deployment_tools/demo/../open_model_zoo/tools/downloader/requirements.in (line 2)) (2.8)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.7/site-packages (from requests->-r /opt/intel/openvino/deployment_tools/demo/../open_model_zoo/tools/downloader/requirements.in (line 2)) (1.25.7)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.7/site-packages (from requests->-r /opt/intel/openvino/deployment_tools/demo/../open_model_zoo/tools/downloader/requirements.in (line 2)) (3.0.4)
Run python3.7 /opt/intel//openvino_2020.1.023/deployment_tools/open_model_zoo/tools/downloader/downloader.py --name squeezenet1.1 --output_dir /Users/decades/openvino_models/models --cache_dir /Users/decades/openvino_models/cache
################|| Downloading models ||################
========== Retrieving /Users/decades/openvino_models/models/public/squeezenet1.1/squeezenet1.1.prototxt from the cache
========== Retrieving /Users/decades/openvino_models/models/public/squeezenet1.1/squeezenet1.1.caffemodel from the cache
################|| Post-processing ||################
========== Replacing text in /Users/decades/openvino_models/models/public/squeezenet1.1/squeezenet1.1.prototxt
Target folder /Users/decades/openvino_models/ir/public/squeezenet1.1/FP16 already exists. Skipping IR generation  with Model Optimizer.If you want to convert a model again, remove the entire /Users/decades/openvino_models/ir/public/squeezenet1.1/FP16 folder. Then run the script again
Build Inference Engine samples
-- The C compiler identification is AppleClang 11.0.0.11000033
-- The CXX compiler identification is AppleClang 11.0.0.11000033
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Looking for C++ include unistd.h
-- Looking for C++ include unistd.h - found
-- Looking for C++ include stdint.h
-- Looking for C++ include stdint.h - found
-- Looking for C++ include sys/types.h
-- Looking for C++ include sys/types.h - found
-- Looking for C++ include fnmatch.h
-- Looking for C++ include fnmatch.h - found
-- Looking for strtoll
-- Looking for strtoll - found
-- Found InferenceEngine: /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libinference_engine.dylib (Required is at least version "2.1")
-- Configuring done
CMake Warning (dev):
  Policy CMP0042 is not set: MACOSX_RPATH is enabled by default.  Run "cmake
  --help-policy CMP0042" for policy details.  Use the cmake_policy command to
  set the policy and suppress this warning.
  MACOSX_RPATH is not specified for the following targets:
   format_reader
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Generating done
-- Build files have been written to: /Users/decades/inference_engine_samples_build
[ 36%] Built target gflags_nothreads_static
[ 81%] Built target format_reader
[100%] Built target classification_sample_async
Run Inference Engine classification sample
Run ./classification_sample_async -d CPU -i /opt/intel/openvino/deployment_tools/demo/car.png -m /Users/decades/openvino_models/ir/public/squeezenet1.1/FP16/squeezenet1.1.xml
Build .................. 37988
[ ERROR ] Failed to create plugin /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libMKLDNNPlugin.dylib for device CPU
Please, check your environment
Cannot load library '/opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libMKLDNNPlugin.dylib': dlopen(/opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libMKLDNNPlugin.dylib, 1): Library not loaded: @rpath/libmkl_tiny_tbb.dylib
  Referenced from: /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libMKLDNNPlugin.dylib
  Reason: no suitable image found.  Did find:
/opt/intel//openvino_2020.1.023/deployment_tools/inference_engine/external/mkltiny_mac/lib/libmkl_tiny_tbb.dylib: code signature in (/opt/intel//openvino_2020.1.023/deployment_tools/inference_engine/external/mkltiny_mac/lib/libmkl_tiny_tbb.dylib) not valid for use in process using Library Validation: library load disallowed by system policy
Error on or near line 217; exiting with status 1
This was accompanied by a system dialog, which said, that the software must be updated, since Apple cannot check it for malicious software.
(Screenshot attached)
nyoun7
I would really appreciate, if someone could fix the documentation. This part simply does not work.
If you are running inference on hardware other than VPU-based devices, you already have the required FP32 neural network model converted to an optimized Intermediate Representation (IR). Follow the steps in the Run the Sample Application section to run the sample.
If you want to run inference on a VPU device (Intel® Movidius™ Neural Compute Stick, Intel® Neural Compute Stick 2 or Intel® Vision Accelerator Design with Intel® Movidius™ VPUs), you'll need an FP16 version of the model, which you will set up in this paragraph.
To convert the FP32 model to a FP16 IR suitable for VPU-based hardware accelerators, follow the steps below:
Make a directory for the FP16 SqueezeNet Model:
mkdir /home/<user>/squeezenet1.1_FP16
Go to /home/<user>/squeezenet1.1_FP16:
cd /home/<user>/squeezenet1.1_FP16
Run the Model Optimizer to convert the FP32 Squeezenet Caffe* model delivered with the installation into an optimized FP16 Intermediate Representation (IR):
python3 /opt/intel/openvino/deployment_tools/model_optimizer/mo.py --input_model /home/<user>/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel --data_type FP16 --output_dir .
The squeezenet1.1.labels file contains the classes that ImageNet uses. This file is included so that the inference results show text instead of classification numbers. Copy squeezenet1.1.labels to your optimized model location:
Now your neural network setup is complete and you're ready to run the sample application.
While I was able (with your help) to resolve the path problem to the model: Where is the .labels file, which needs to be copied???
Then: The requirement installation of 2020.1 clearly stated, that protobuf 6.1 was installed (whereas during the installation it was told, that protobuf 6.13 was installed). Anyway: Some script is still complaining, that 6.1 is not installed. What a mess...
Model Optimizer version:     2020.1.0-61-gd349c3ba4a
[ WARNING ]
    protobuf: installed: 3.0.0, required: == 3.6.1
Max_L_Intel
Hello Neil.
Labels file for squeezenet model should be located in the directory /home/<user>/openvino_models/ir/public/squeezenet1.1/FP16/squeezenet1.1.labels
We are also planning to fix this in our documentation.
Please make sure that you don't have multiple protobuf versions installed on your system. Run these:
sudo pip3 uninstall -y protobuf
brew remove protobuf
brew cleanup -s protobuf
Then the following command should not show any output if they are all uninstalled
pip3 show protobuf
So after then just reinstall with one of the install_prerequisites scripts.
For this one you need to manually allow an access to libmkl_tiny_tbb.dylib app in System Preferences > Security & Privacy > General.
Please use this workaround from Apple under the section "How to open an app that hasn’t been notarized or is from an unidentified developer" - https://support.apple.com/en-us/HT202491
We'll also report this in order to get fixed. Thank you for letting us know.
nyoun7
I'm not on a mac, so this suggestion is not making any sense.
Ok, maybe. Thank you very much. I have abandoned this stick. Some performance checks with ncapzopp (?) did show me, that the stick will not even reach the processing power of my middle class Asus Intel i5 laptop. That was what I wanted to achieve.
Max_L_Intel
Hello Neil.
Homebrew commands were provided for Catalina OS. In case of Ubuntu instead of these commands you could use
sudo apt-get purge --remove libprotobuf*
The ncpappzoo is a just repository of demos created by a community to show the functionality.
In order to measure the performance please use benchmark_app tool instead - https://docs.openvinotoolkit.org/latest/_inference_engine_tools_benchmark_tool_README.html
Intel Neural Compute Sticks are targeted for AI inference applications in low power segment. So you could check performance comparison (including efficiency in FPS per Watt) on different hardware devices here - https://docs.openvinotoolkit.org/latest/_docs_performance_benchmarks.html
Best regards, Max.
