6597 Discussions
Problem working with faster_rcnn_resnet50 using movidius
Stankov__Stanko
So i have been struggling with this for a while and i decided to ask here.
When i try to run object detection using faster_rcnn_resnet50 i get the following error -
Traceback (most recent call last):
  File "openvino_real_time_object_detection.py", line 74, in <module>
    detections = net.forward()
cv2.error: OpenCV(4.1.0-openvino) /home/jenkins/workspace/OpenCV/OpenVINO/build/opencv/modules/dnn/src/dnn.cpp:2299: error: (-215:Assertion failed) inp.total() in function 'allocateLayers'
I successfully get the xml and bin file using the following command
python mo_tf.py --input_model=D:/Software_development_tools/tensorflow/models-master/research/object_detection/inference_graph/frozen_inference_graph.pb --tensorflow_use_custom_operations_config C:/IntelSWTools/openvino_2019.1.133/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support_api_v1.13.json  --tensorflow_object_detection_api_pipeline_config D:/Software_development_tools/tensorflow/models-master/research/object_detection/inference_graph/pipeline.config --reverse_input_channels --data_type=FP16
In additional i have tried using the xml and bin files on the openvino_fd_myriad.py code provided on this page - https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_raspbian.html and i still get the same result.
I have attached the config file, the xml and bin as well as the source code.
Thank you for your time !
Stanko Stankov
Shubha_R_Intel
Dear Stankov, Stanko
This is not a traditional OpenVino problem which is concerned with only Inference Engine or Model Optimizer. But I googled your OpenCV issue and found the following (it looks exactly like your error).
https://github.com/opencv/opencv/issues/13751
OpenCV github is the best place to post your OpenCV issues.
Also there is OpenCV Questions .
Thanks !
Shubha
Stankov__Stanko
Dear Shubha,
Thank you for your reply!
I will do some more research and write there as well and let you know the results.
Edit : I would also like to point out that running the code with the following configuration i get a different error
net = cv2.dnn.readNetFromTensorflow('frozen_inference_graph.pb','frozen_inference_graph.pbtxt')
net.setPreferableTarget(cv2.dnn.DNN_TARGET_MYRIAD)
message :
terminate called after throwing an instance of 'InferenceEngine::details::InferenceEngineException'
  what():  ConfidenceThreshold parameter is wrong in layer detection_out. It should be > 0.
Aborted
Aborted
Stanko Stankov
Shubha_R_Intel
Thanks for sharing back to the community. Perhaps one of those OpenCV forums will set you straight.
Thanks for your patience !
Shubha
Stankov__Stanko
Dear Shubha,
I have opened a thread about this in the OpenCV community and this issue is already labeled as a bug.
In case someone else has the same issue this is the link to the thread - https://github.com/opencv/opencv/issues/14839
Thank you for your time!
Stanko Stankov
Shubha_R_Intel
Dearest Stanko Stankov,
Wow. I really appreciate your sharing your findings back to the community. It's very thoughtful of you !
Thanks again for using OpenVino,
Shubha
Sapiain__Roberto
Hi.
Thank you for this thread. I'm having the same issue with Openvino 2019.R2,
Neural-net: Faster-RCNN topology, trained TFOD-API v1.12, with Tensorflow 1.12.3 (CUDA 9.0 patch level 4, cuDNN v7.5). 3 categories only.
Hope there is a fix soon.
