6583 Discussions
Problems installing the Intel® Graphics Compute Runtime for OpenCL™ driver components
Nair__Adarsh
I tried installing the drivers to use my GPU for OpenVINO and executed the commands as mentioned in the docs:
 /opt/intel/openvino/install_dependencies$ ./install_NEO_OCL_driver.sh
Intel OpenCL graphics driver installer
ERROR: you must run this script as root.
Please try again with sudo -E ./install_NEO_OCL_driver.sh, or as root.
doctor_s@doc-Predator:/opt/intel/openvino/install_dependencies$ sudo -E ./install_NEO_OCL_driver.sh
Looking for previously installed user-mode driver...
dpkg-query: no packages found matching intel-opencl
dpkg-query: no packages found matching intel-ocloc
dpkg-query: no packages found matching intel-gmmlib
Found intel-igc-core installed, uninstalling...
dpkg: dependency problems prevent removal of intel-igc-core:
 intel-igc-opencl depends on intel-igc-core (= 1.0.10-2407).
dpkg: error processing package intel-igc-core (--purge):
 dependency problems - not removing
Errors were encountered while processing:
 intel-igc-core
ERROR: unable to remove intel-igc-core
       please resolve it manually and try to launch the script again.
Specs:
OS: Ubuntu 18.04 LTS
Processor: Intel® Core™ i5-8300H CPU @ 2.30GHz × 8
GPU: Mesa Intel® UHD Graphics 630 (CFL GT2)
I'm still learning and do not know how to proceed, kindly help me out. Thank you in anticipation!
Iffa_Intel
Greetings,
You need to run the install command as root. The installer require access as root/admin because there are certain modification it needs to do.
Try:  sudo ./install_NEO_OCL_driver.sh
Hope my answer helps!
Sincerely,
Iffa
Weizixiu
Hi,Nair
If you run the script as root, and it still doesn't work .
you can try this :
1:apt remove intel-igc-opencl
2:apt remove intel-igc-core
Then,try the script again!
