Problems with Linux OpenVINO R5 GPU
Kulecz__Walter
First off it could easily be I've not done this last step in the GPU option setup:
"If you use 8th Generation Intel® Core™ processor, you will need to add:
   i915.alpha_support=1
   to the 4.14 kernel command line, in order to enable OpenCL functionality for this platform."
I have kernel 4.15.0 and I don't have a clue as to if an i7-4500U is 8th generation.  I'd rather not mess with the system boot up unless I know its absolutely necessary.
Second is it even worth trying to use the GPU on this chip?
Here is my sample code command, I believe its correct as its just the command I've used for CPU with CPU replaced by GPU:
~/inference_engine_samples/intel64/Release$ ./interactive_face_detection_demo -d GPU -m ~/intel/computer_vision_sdk/deployment_tools/intel_models/face-detection-retail-0004/FP32/face-detection-retail-0004.xml -d_ag GPU -m_ag ~/intel/computer_vision_sdk/deployment_tools/intel_models/age-gender-recognition-retail-0013/FP32/age-gender-recognition-retail-0013.xml -d_em GPU -m_em ~/intel/computer_vision_sdk/deployment_tools/intel_models/emotions-recognition-retail-0003/FP32/emotions-recognition-retail-0003.xml -d_hp GPU -m_hp ~/intel/computer_vision_sdk/deployment_tools/intel_models/head-pose-estimation-adas-0001/FP32/head-pose-estimation-adas-0001.xml
Here is the error:
InferenceEngine:
    API version ............ 1.4
    Build .................. 19154
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading plugin GPU
    API version ............ 1.5
    Description ....... clDNNPlugin
[ INFO ] Loading network files for Face Detection
[ INFO ] Batch size is set to 1
[ INFO ] Checking Face Detection network inputs
[ INFO ] Checking Face Detection network outputs
[ INFO ] Loading Face Detection model to the GPU plugin
[ ERROR ] failed to create engine: clGetPlatformIDs error -1001
nikos1
Valued Contributor I
Sorry Walter,
It seems that i7-4500U has an unsupported clDNN GPU:
https://ark.intel.com/content/www/us/en/ark/products/75460/intel-core-i7-4500u-processor-4m-cache-up-to-3-00-ghz.html
There was another thread in this forum explaining the issues with Intel HD Graphics 4400 or similar gen GPUs.
https://software.intel.com/comment/1931157
basically lacks OpenCL out-of-order execution
cheers,
nikos
nikos1
Sorry Walter,
cheers,
nikos
Kulecz__Walter
Thanks a lot, saves me much effort and wasted time, any insight as to how much a supported GPU improves on CPU only?
Initially for my purposes its looking like on i3 or better CPU outperforms the original NCS, and is still a bit better than the NCS2, but the NCS2 is about 2.5X faster than the original NCS.
My next task is to test on the Raspberry Pi3B+ where I know an NCS will be required, and if I can get a 2.5X improvement in frame rate all this OpenVINO stuff will have been worth it.
nikos1
It really depends on the CPU and GPU model.
Some GPUs like the GT4 in the Core i7-6770HQ for example are much faster than GT2 (like the (U)HD 630 ) ; all depends on how many EUs and GPU clock.
https://ark.intel.com/content/www/us/en/ark/products/93341/intel-core-i7-6770hq-processor-6m-cache-up-to-3-50-ghz.html
Comparing CPU to GPU again it depends how many CPU cores and what clock. If you compare to a dual core Atom CPU then GPU will be faster. There is also the power efficiency part.  It really depends on your application and fps vs. power requirements.
Cheers,
nikos
