6614 Discussions
What is the minimal installation set needed for deploying models on windows machines for inference only
Silbert__Ohad
I want to run a costume model I had built and pre-trained inside an application. My application runs on machines without GPU (Intel CPU only) running Windows 7 or 10. What should I install on the user's computer? I want the minimal installation set since I try to avoid heavy installations on the user's computers.
Ohad
nikos1
Valued Contributor I
C++ or Python?
For C++ CPU inference the following dlls are enough - you may or may not need cpu extension dll depending on topology
inference_engine.dll
MKLDNNPlugin.dll
mkl_tiny_omp.dll
cpu_extension.dll
In addition you would also need the obvious: IR (.bin and .xml) and application .exe .
Cheers,
Nikos
Kulecz__Walter
I'd like to know the answer too.
I can answer this question for Python apps using the NCS v1 SDK on Ubuntu or Raspbian but for OpenVINO I've no idea.
On problem I foresee with OpenVINO minimal binary installations is "optimizations".  I installed OpenVINO R5 on Ubuntu 16.04 on an i7 4500U, cloned the hard drive and moved it to an i5 4300U, everything worked.  But when I moved the drive to a "weaker" i5 540M the example code failed with "illegal instruction"  I had to repeat the installation on the 540M to get the examples to run and the inference time went from ~40 fps to ~9 fps, presumably because the 540M lacks AVX and AVX2.
Are there build options to make a "universal" library binary where it falls back to software emulation when hardware features are missing from the CPU?
nikos1
C++ or Python?
MKLDNNPlugin.dll
mkl_tiny_omp.dll
cpu_extension.dll
Cheers,
Nikos
Kulecz__Walter
Thanks, what also needs to be added to the set for Python and for both on Linux?
Is there a "universal" version of the CPU dll?
I ask because I installed OpenVINO on Linux i5 4200U and later "cloned" the drive and installed it on a "weaker" i5 M540 and got illeagal instruction errors running the demos, presumably from the lack of AVX and AVX2 instructions.  Re-installing OpenVINO on the M540 solved the problem.
I can see a real issue with binary only installations/distributions here.
Silbert__Ohad
Thank you for the answer.
