6614 Discussions
ProgramBuilder build failed on Gemini Lake iGPU
TheD
Hi, I am trying to use openvino with a Gemini Lake iGPU, but the build process keeps on failing. OpenVino is used within a frigate docker-container (image: ghcr.io/blakeblackshear/frigate:stable).
I would appreciate every help!
benchmark_app -m /openvino-model/ssdlite_mobilenet_v2.xml -d CPU is fine, but
benchmark_app -m /openvino-model/ssdlite_mobilenet_v2.xml -d GPU
[Step 1/11] Parsing and validating input arguments
[ INFO ] Parsing input parameters
[Step 2/11] Loading OpenVINO Runtime
[ INFO ] OpenVINO:
[ INFO ] Build ................................. 2024.1.0-15008-f4afc983258-releases/2024/1
[ INFO ]
[ INFO ] Device info:
[ INFO ] GPU
[ INFO ]
[ INFO ]
[Step 3/11] Setting device configuration
[ WARNING ] Performance hint was not explicitly specified in command line. Device(GPU) performance hint will be set to PerformanceMode.THROUGHPUT.
[Step 4/11] Reading model files
[ INFO ] Loading model files
[ INFO ] Read model took 42.19 ms
[ INFO ] Original model I/O parameters:
[ INFO ] Model inputs:
[ INFO ] image_tensor:0 (node: image_tensor) : u8 / [...] / [1,300,300,3]
[ INFO ] Model outputs:
[ INFO ] detection_boxes:0 (node: DetectionOutput) : f32 / [...] / [1,1,100,7]
[Step 5/11] Resizing model to match image sizes and given batch
[ INFO ] Model batch size: 1
[Step 6/11] Configuring input of the model
[ INFO ] image_tensor:0 (node: image_tensor) : u8 / [N,H,W,C] / [1,300,300,3]
[Step 7/11] Loading the model to the device
[ ERROR ] Exception from src/inference/src/cpp/core.cpp:106:
Exception from src/inference/src/dev/plugin.cpp:54:
Check 'false' failed at src/plugins/intel_gpu/src/plugin/program_builder.cpp:178:
[GPU] ProgramBuilder build failed!
Exception from src/plugins/intel_gpu/src/runtime/ocl/ocl_stream.cpp:433:
[GPU] clWaitForEvents, error code: -14
Traceback (most recent call last):
File "/usr/local/lib/python3.9/dist-packages/openvino/tools/benchmark/main.py", line 408, in main
compiled_model = benchmark.core.compile_model(model, benchmark.device, device_config)
File "/usr/local/lib/python3.9/dist-packages/openvino/runtime/ie_api.py", line 521, in compile_model
super().compile_model(model, device_name, {} if config is None else config),
RuntimeError: Exception from src/inference/src/cpp/core.cpp:106:
kernel is 6.8.12-3-pve
export gfx_version=$(dpkg-query --showformat='${Version}' --show intel-opencl-icd)
echo $gfx_version
22.43.24595.41-1
benchmark_app -h delivers Available target devices:  CPU  GPU
vainfo: VA-API version: 1.17 (libva 2.10.0)
vainfo: Driver version: Intel i965 driver for Intel(R) Gemini Lake - 2.4.1
CPU is Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
python3 hello_query_device.py
[ INFO ] Available devices:
[ INFO ] CPU :
[ INFO ] SUPPORTED_PROPERTIES:
[ INFO ] AVAILABLE_DEVICES:
[ INFO ] RANGE_FOR_ASYNC_INFER_REQUESTS: 1, 1, 1
[ INFO ] RANGE_FOR_STREAMS: 1, 4
[ INFO ] EXECUTION_DEVICES: CPU
[ INFO ] FULL_DEVICE_NAME: Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
[ INFO ] OPTIMIZATION_CAPABILITIES: FP32, FP16, INT8, BIN, EXPORT_IMPORT
[ INFO ] DEVICE_TYPE: Type.INTEGRATED
[ INFO ] DEVICE_ARCHITECTURE: intel64
[ INFO ] NUM_STREAMS: 1
[ INFO ] AFFINITY: Affinity.CORE
[ INFO ] INFERENCE_NUM_THREADS: 0
[ INFO ] PERF_COUNT: False
[ INFO ] INFERENCE_PRECISION_HINT: <Type: 'float32'>
[ INFO ] PERFORMANCE_HINT: PerformanceMode.LATENCY
[ INFO ] EXECUTION_MODE_HINT: ExecutionMode.PERFORMANCE
[ INFO ] PERFORMANCE_HINT_NUM_REQUESTS: 0
[ INFO ] ENABLE_CPU_PINNING: True
[ INFO ] SCHEDULING_CORE_TYPE: SchedulingCoreType.ANY_CORE
[ INFO ] MODEL_DISTRIBUTION_POLICY: set()
[ INFO ] ENABLE_HYPER_THREADING: True
[ INFO ] DEVICE_ID:
[ INFO ] CPU_DENORMALS_OPTIMIZATION: False
[ INFO ] LOG_LEVEL: Level.NO
[ INFO ] CPU_SPARSE_WEIGHTS_DECOMPRESSION_RATE: 1.0
[ INFO ] DYNAMIC_QUANTIZATION_GROUP_SIZE: 0
[ INFO ] KV_CACHE_PRECISION: <Type: 'float16'>
[ INFO ]
[ INFO ] GPU :
[ INFO ] AVAILABLE_DEVICES: 0
[ INFO ] RANGE_FOR_ASYNC_INFER_REQUESTS: 1, 2, 1
[ INFO ] RANGE_FOR_STREAMS: 1, 2
[ INFO ] OPTIMAL_BATCH_SIZE: 1
[ INFO ] MAX_BATCH_SIZE: 1
[ INFO ] DEVICE_ARCHITECTURE: GPU: vendor=0x8086 arch=v9.0.0
[ INFO ] FULL_DEVICE_NAME: Intel(R) UHD Graphics 605 [0x3184] (iGPU)
[ INFO ] DEVICE_UUID: 86800000843100000000000000000000
[ INFO ] DEVICE_LUID: 409a0000499a0000
[ INFO ] DEVICE_GOPS: {<Type: 'float16'>: 460.8000183105469, <Type: 'float32'>: 230.40000915527344, <Type: 'int8_t'>: 230.40000915527344, <Type: 'uint8_t'>: 230.40000915527344}
[ INFO ] OPTIMIZATION_CAPABILITIES: FP32, BIN, FP16, EXPORT_IMPORT
[ INFO ] GPU_DEVICE_TOTAL_MEM_SIZE: 3435970560
[ INFO ] GPU_UARCH_VERSION: 9.0.0
[ INFO ] GPU_EXECUTION_UNITS_COUNT: 18
[ INFO ] GPU_MEMORY_STATISTICS: {}
[ INFO ] MODEL_PRIORITY: Priority.MEDIUM
[ INFO ] GPU_HOST_TASK_PRIORITY: Priority.MEDIUM
[ INFO ] GPU_QUEUE_PRIORITY: Priority.MEDIUM
[ INFO ] GPU_QUEUE_THROTTLE: Priority.MEDIUM
[ INFO ] GPU_ENABLE_LOOP_UNROLLING: True
[ INFO ] GPU_DISABLE_WINOGRAD_CONVOLUTION: False
[ INFO ] CACHE_DIR:
[ INFO ] CACHE_MODE: CacheMode.OPTIMIZE_SPEED
[ INFO ] COMPILATION_NUM_THREADS: 4
[ INFO ] INFERENCE_PRECISION_HINT: <Type: 'float16'>
[ INFO ] ENABLE_CPU_PINNING: False
[ INFO ] DEVICE_ID: 0
[ INFO ]
clinfo
Number of platforms 1
Platform Name Intel(R) OpenCL HD Graphics
Platform Vendor Intel(R) Corporation
Platform Version OpenCL 3.0
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_byte_addressable_store cl_khr_device_uuid cl_khr_fp16 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_intel_command_queue_families cl_intel_subgroups cl_intel_required_subgroup_size cl_intel_subgroups_short cl_khr_spir cl_intel_accelerator cl_intel_driver_diagnostics cl_khr_priority_hints cl_khr_throttle_hints cl_khr_create_command_queue cl_intel_subgroups_char cl_intel_subgroups_long cl_khr_il_program cl_intel_mem_force_host_memory cl_khr_subgroup_extended_types cl_khr_subgroup_non_uniform_vote cl_khr_subgroup_ballot cl_khr_subgroup_non_uniform_arithmetic cl_khr_subgroup_shuffle cl_khr_subgroup_shuffle_relative cl_khr_subgroup_clustered_reduce cl_intel_device_attribute_query cl_khr_suggested_local_work_size cl_intel_split_work_group_barrier cl_khr_fp64 cl_intel_planar_yuv cl_intel_packed_yuv cl_intel_motion_estimation cl_intel_device_side_avc_motion_estimation cl_intel_advanced_motion_estimation cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_3d_image_writes cl_intel_media_block_io cl_intel_va_api_media_sharing cl_intel_sharing_format_query cl_khr_pci_bus_info
Platform Extensions with Version cl_khr_byte_addressable_store 0x400000 (1.0.0)
cl_khr_device_uuid 0x400000 (1.0.0)
cl_khr_fp16 0x400000 (1.0.0)
cl_khr_global_int32_base_atomics 0x400000 (1.0.0)
cl_khr_global_int32_extended_atomics 0x400000 (1.0.0)
cl_khr_icd 0x400000 (1.0.0)
cl_khr_local_int32_base_atomics 0x400000 (1.0.0)
cl_khr_local_int32_extended_atomics 0x400000 (1.0.0)
cl_intel_command_queue_families 0x400000 (1.0.0)
cl_intel_subgroups 0x400000 (1.0.0)
cl_intel_required_subgroup_size 0x400000 (1.0.0)
cl_intel_subgroups_short 0x400000 (1.0.0)
cl_khr_spir 0x400000 (1.0.0)
cl_intel_accelerator 0x400000 (1.0.0)
cl_intel_driver_diagnostics 0x400000 (1.0.0)
cl_khr_priority_hints 0x400000 (1.0.0)
cl_khr_throttle_hints 0x400000 (1.0.0)
cl_khr_create_command_queue 0x400000 (1.0.0)
cl_intel_subgroups_char 0x400000 (1.0.0)
cl_intel_subgroups_long 0x400000 (1.0.0)
cl_khr_il_program 0x400000 (1.0.0)
cl_intel_mem_force_host_memory 0x400000 (1.0.0)
cl_khr_subgroup_extended_types 0x400000 (1.0.0)
cl_khr_subgroup_non_uniform_vote 0x400000 (1.0.0)
cl_khr_subgroup_ballot 0x400000 (1.0.0)
cl_khr_subgroup_non_uniform_arithmetic 0x400000 (1.0.0)
cl_khr_subgroup_shuffle 0x400000 (1.0.0)
cl_khr_subgroup_shuffle_relative 0x400000 (1.0.0)
cl_khr_subgroup_clustered_reduce 0x400000 (1.0.0)
cl_intel_device_attribute_query 0x400000 (1.0.0)
cl_khr_suggested_local_work_size 0x400000 (1.0.0)
cl_intel_split_work_group_barrier 0x400000 (1.0.0)
cl_khr_fp64 0x400000 (1.0.0)
cl_intel_planar_yuv 0x400000 (1.0.0)
cl_intel_packed_yuv 0x400000 (1.0.0)
cl_intel_motion_estimation 0x400000 (1.0.0)
cl_intel_device_side_avc_motion_estimation 0x400000 (1.0.0)
cl_intel_advanced_motion_estimation 0x400000 (1.0.0)
cl_khr_image2d_from_buffer 0x400000 (1.0.0)
cl_khr_depth_images 0x400000 (1.0.0)
cl_khr_3d_image_writes 0x400000 (1.0.0)
cl_intel_media_block_io 0x400000 (1.0.0)
cl_intel_va_api_media_sharing 0x400000 (1.0.0)
cl_intel_sharing_format_query 0x400000 (1.0.0)
cl_khr_pci_bus_info 0x400000 (1.0.0)
Platform Numeric Version 0xc00000 (3.0.0)
Platform Extensions function suffix INTEL
Platform Host timer resolution 1ns
Number of devices 1
Device Name Intel(R) UHD Graphics 605 [0x3184]
Device Vendor Intel(R) Corporation
Device Vendor ID 0x8086
Device Version OpenCL 3.0 NEO
Device UUID 86800000-8431-0000-0000-000000000000
Driver UUID 32322e34-332e-3234-3539-350000000000
Valid Device LUID No
Device LUID b083-0bc6fd7f0000
Device Node Mask 0
Device Numeric Version 0xc00000 (3.0.0)
Driver Version 22.43.24595
Device OpenCL C Version OpenCL C 1.2
Device OpenCL C all versions OpenCL C 0x400000 (1.0.0)
OpenCL C 0x401000 (1.1.0)
OpenCL C 0x402000 (1.2.0)
OpenCL C 0xc00000 (3.0.0)
Device OpenCL C features __opencl_c_int64 0xc00000 (3.0.0)
__opencl_c_3d_image_writes 0xc00000 (3.0.0)
__opencl_c_images 0xc00000 (3.0.0)
__opencl_c_read_write_images 0xc00000 (3.0.0)
__opencl_c_fp64 0xc00000 (3.0.0)
Latest comfornace test passed v2022-04-22-00
Device Type GPU
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 18
Max clock frequency 800MHz
Device Partition (core)
Max number of sub-devices 0
Supported partition types None
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 256x256x256
Max work group size 256
Preferred work group size multiple (device) 32
Preferred work group size multiple (kernel) 32
Max sub-groups per work group 0
Sub-group sizes (Intel) 8, 16, 32
Preferred / native vector sizes
char 16 / 16
short 8 / 8
int 4 / 4
long 1 / 1
half 8 / 8 (cl_khr_fp16)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (cl_khr_fp16)
Denormals Yes
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Support is emulated in software No
Single-precision Floating-point support (core)
Denormals Yes
Round to zero Yes
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Address bits 32, Little-Endian
Global memory size 3435970560 (3.2GiB)
Error Correction support No
Max memory allocation 1717985280 (1.6GiB)
Unified memory for Host and Device Yes
Shared Virtual Memory (SVM) capabilities (core)
Coarse-grained buffer sharing Yes
Fine-grained buffer sharing No
Fine-grained system sharing No
Atomics No
Minimum alignment for any data type 128 bytes
Alignment of base address 1024 bits (128 bytes)
Preferred alignment for atomics
SVM 64 bytes
Global 64 bytes
Local 64 bytes
Atomic memory capabilities relaxed, work-group scope
Atomic fence capabilities relaxed, acquire/release, work-group scope
Max size for global variable 0
Preferred total size of global vars 0
Global Memory cache type Read/Write
Global Memory cache size 393216 (384KiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 16
Max size for 1D images from buffer 107374080 pixels
Max 1D or 2D image array size 2048 images
Base address alignment for 2D image buffers 4 bytes
Pitch alignment for 2D image buffers 4 pixels
Max 2D image size 16384x16384 pixels
Max planar YUV image size 16384x16352 pixels
Max 3D image size 16384x16384x2048 pixels
Max number of read image args 128
Max number of write image args 128
Max number of read/write image args 128
Pipe support No
Max number of pipe args 0
Max active pipe reservations 0
Max pipe packet size 0
Local memory type Local
Local memory size 65536 (64KiB)
Max number of constant args 8
Max constant buffer size 1717985280 (1.6GiB)
Generic address space support No
Max size of kernel argument 2048 (2KiB)
Queue properties (on host)
Out-of-order execution Yes
Profiling Yes
Device enqueue capabilities (n/a)
Queue properties (on device)
Out-of-order execution No
Profiling No
Preferred size 0
Max size 0
Max queues on device 0
Max events on device 0
Prefer user sync for interop Yes
Profiling timer resolution 52ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Non-uniform work-groups Yes
Work-group collective functions No
Sub-group independent forward progress No
IL version SPIR-V_1.2
ILs with version SPIR-V 0x402000 (1.2.0)
SPIR versions 1.2
printf() buffer size 4194304 (4MiB)
Built-in kernels block_motion_estimate_intel;block_advanced_motion_estimate_check_intel;block_advanced_motion_estimate_bidirectional_check_intel;
Built-in kernels with version block_motion_estimate_intel 0x400000 (1.0.0)
block_advanced_motion_estimate_check_intel 0x400000 (1.0.0)
block_advanced_motion_estimate_bidirectional_check_intel 0x400000 (1.0.0)
Motion Estimation accelerator version (Intel) 2
Device-side AVC Motion Estimation version 1
Supports texture sampler use Yes
Supports preemption No
Device Extensions cl_khr_byte_addressable_store cl_khr_device_uuid cl_khr_fp16 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_intel_command_queue_families cl_intel_subgroups cl_intel_required_subgroup_size cl_intel_subgroups_short cl_khr_spir cl_intel_accelerator cl_intel_driver_diagnostics cl_khr_priority_hints cl_khr_throttle_hints cl_khr_create_command_queue cl_intel_subgroups_char cl_intel_subgroups_long cl_khr_il_program cl_intel_mem_force_host_memory cl_khr_subgroup_extended_types cl_khr_subgroup_non_uniform_vote cl_khr_subgroup_ballot cl_khr_subgroup_non_uniform_arithmetic cl_khr_subgroup_shuffle cl_khr_subgroup_shuffle_relative cl_khr_subgroup_clustered_reduce cl_intel_device_attribute_query cl_khr_suggested_local_work_size cl_intel_split_work_group_barrier cl_khr_fp64 cl_intel_planar_yuv cl_intel_packed_yuv cl_intel_motion_estimation cl_intel_device_side_avc_motion_estimation cl_intel_advanced_motion_estimation cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_3d_image_writes cl_intel_media_block_io cl_intel_va_api_media_sharing cl_intel_sharing_format_query cl_khr_pci_bus_info
Device Extensions with Version cl_khr_byte_addressable_store 0x400000 (1.0.0)
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) Intel(R) OpenCL HD Graphics
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [INTEL]
clCreateContext(NULL, ...) [default] Success [INTEL]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.3.1
ICD loader Profile OpenCL 3.0
Wan_Intel
Hi TheD,
I noticed that the version of Intel® Graphics Compute Runtime on your system is 22.43.24595.41-1
Could you please download the latest version of Intel® Graphics Compute Runtime from Release 24.39.31294.12 · intel/compute-runtime and see if the issue can be resolved?
Wan
Wan_Intel
Hi TheD,
Thanks for your question.
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
TheD
I've finally managed to install the newest compute-runtime:
echo $gfx_version
24.39.31294.12
but now
benchmark_app -h ends with "Illegal instruction (core dumped)"
also
vainfo: VA-API version: 1.22 (libva 2.10.0)
intel-gpu-top: Intel Geminilake (Gen9) @ /dev/dri/card0 -  106/ 107 MHz
    95% RC6;  0.09/ 1.49 W;       81 irqs/s
uname -r
6.8.12-4-pve
What is to do?
Daniel
