Is there anyway to detect the OpenVINO release version at runtime in the Python API?
I notice that the CPU target now accepts FP16 models whereas the previous (2019r1.1 specifically) release apparently did not.
This means I could dispense with the FP32 models and reduce the size of my package significantly, but this could be a backward compatability nightmare for me.
Dear Kulecz, Walter,
Checking on this. Will get back to you.
Thanks for using OpenVino !
Shubha
The below method is common for all Python modules:
import openvino.inference_engine as ie print(ie.__version__)
Also:
core = IECore()
version = core.get_versions('CPU')
print('Plugin {}. Version: {}.{}.{}'.format(version.description, version.major, version.minor, version.build_number))
Hope it helps,
Shubha
