Python openvino IECORE()
KIM__SangMo
I am using python to test the inference engine.
When I 'run module' , the program will stop at " ie = IECORE()", but no error information is given.
I added some "print" funtions and they can only work before this line.
Below is the program code.
import sys
from openvino.inference_engine import IECore
print("before IECore():")
ie = IECore()
print("Available devices:")
1."w_openvino_toolkit_p_2019.3.379.exe" install
2.Microsoft Windows 10 Enterprise (64bit)
   Intel® Core™ i5-8250U CPU @ 1.60GHz
   Intel® UHD Graphics 620
I'm really confused. Thank you for any help.
JesusE_Intel
Hi SangMo,
I just ran a quick test with the following python code and did not see any issues.
import sys
ie=IECore()
print("End of test")
Are you running the setupvars.bat script prior to running the python script?
"C:\Program Files (x86)\IntelSWTools\openvino\bin\setupvars.bat"
Also, could you share the software version of the following components?
  • CMake
  • Python
  • Visual Studio
Jesus
