RPI Support for openVino 2019
Kirkbride__Shane
Is there RPI 3+ support for openVino 2019?
I keep getting an error when installing.
~Shane
Shubha_R_Intel
Dear Shane,
Hopefully these doc links will help you. You need a raspbian stretch image flashed onto your raspberry pi:
https://software.intel.com/en-us/articles/OpenVINO-Install-RaspberryPI
https://github.com/opencv/opencv/wiki/Intel%27s-Deep-Learning-Inference-Engine-backend#raspbian-stretch
Thanks for using OpenVino
Shubha
Kirkbride__Shane
Here is the error I get I've followed all the instructions.
pi@raspberrypi:~/Downloads/l_openvino_toolkit_p_2019.1.094 $ ./install.sh
./install.sh: 60: [: -lt: unexpected operator
./install.sh: 63: [: -eq: unexpected operator
The IA-32 architecture host installation is no longer supported.
The product cannot be installed on this system.
Please refer to product documentation for more information.
Quitting!
Here are my RPI system details:
login as: pi
pi@169.254.153.47's password:
Linux raspberrypi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Apr  3 23:08:14 2019 from 169.254.230.32
[setupvars.sh] OpenVINO environment initialized
pi@raspberrypi:~ $
Any guidance would be helpful.
~Shane
Kirkbride__Shane
I think the solution is to download this build: probably the better build for RPI
Kirkbride__Shane
I downloaded the build here:
http://registrationcenter-download.intel.com/akdlm/irc_nas/15381/l_openvino_toolkit_raspbi_p_2019.1.094.tgz ;
but i'm still getting this error
pi@raspberrypi:~/inference_engine_samples_build/armv7l/Release $ ./object_detection_sample_ssd -m ~/Downloads/face-detection-adas-0001.xml -d MYRIAD -i /home/pi/Downloads/faces94/male/9326871/9326871.10.bmp
[ INFO ] InferenceEngine:
        API version ............ 1.6
        Build .................. 22443
Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /home/pi/Downloads/faces94/male/9326871/9326871.10.bmp
[ INFO ] Loading plugin
        Description ....... myriadPlugin
[ INFO ] Loading network files:
        /home/pi/Downloads/face-detection-adas-0001.xml
        /home/pi/Downloads/face-detection-adas-0001.bin
Segmentation fault
pi@raspberrypi:~/inference_engine_samples_build/armv7l/Release $ ./interactive_face_detection_demo -i ~/Videos/inputVideo.mp4 -m ~/Downloads/face-detection-adas-0001.xml -d MYRIAD          InferenceEngine:
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading plugin MYRIAD
[ INFO ] Loading network files for Face Detection
Segmentation fault
Any ideas on what I should do?
~Shane
Kirkbride__Shane
These steps work. That is they execute successfully:
Go to the folder with samples source code:
cd inference_engine_vpu_arm/deployment_tools/inference_engine/samples
Create build directory:
mkdir build && cd build
Build the Object Detection Sample:
cmake .. -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_FLAGS="-march=armv7-a"
Copy Code
make -j2 object_detection_sample_ssd
These steps generate the .sh files with the segmentation fault:
Optional: Build all samples:
Navigate to samples directory:
cd~/Downloads/inference_engine_vpu_arm/deployment_tools/inference_engine/samples
Run script that will build and place samples in $HOME/inference_engine_samples_build/armv71/Release:
./build_samples.sh
I think this issue can be closed with the workaround above.
~Shane
