Raspberry Pi 3 Model B+ crashing
Hi there,
I'm trying to install Movidius Neural Compute SDK on my new Raspberry Pi 3 Model b+ with Raspbian Stretch and during the installation my raspberry just reboots every time.
I followed the installation instructions from github:
https://github.com/movidius/ncsdk
I tried the same on my Dell notebook with Ubuntu 16.04 and everything is working fine also all the examples are working.
I attached two jpg files. On the raspberry.jpg you can see on what point the raspberry stops and reboots. The other image is from my Dell notebook.
@navi2607
From the logs I can not read the problem point at all.
It is a prediction, experience has shown that when such symptoms occur, the supply voltage and current are often insufficient.
Since Model B + should have increased power consumption further, why not try reviewing the power adapter?
Example)
AC adapter that can supply 5 V / 3A
https://www.amazon.com/Gowoops-Charger-Blackberry-Bluetooth-Certified/dp/B07B8HYBBY/ref=sr_1_1?ie=UTF8&qid=1531563834&sr=8-1&keywords=%EF%BC%95V%2B3A%2Badapter%2Busb&th=1
https://www.physical-computing.jp/product/1171
The important point is that the AC adapter can not demonstrate sufficient performance unless the USB cable is high quality.
@PINTO
Thanks for the suggestion. I connected a AC adapter with output 5V / 2A and it is working fine.
