6605 Discussions
Re: Re:OneAPI Dev cloud account not able to run OpenVi...
Max_L_Intel
Hi @Daya
Have you verified OpenVINO being installed properly and that it is able to successfully run the verification script demo_squeezenet_download_convert_run.sh, as per https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#run-the-demos
Please confirm that first.
Best regards, Max.
Daya
Hi @Max_L_Intel ,
  Thank you for the support,  since we are using devcloud (OneAPI) we have limited privilege, please find the below details when we try to run the sample script.
u44141@login-2:/opt/intel/openvino/deployment_tools/demo$ ./demo_squeezenet_download_convert_run.sh
target_precision = FP16
[setupvars.sh] OpenVINO environment initialized
Downloading the Caffe model and the prototxt
Installing dependencies
Dear User,
this server does not allow you to run "sudo".
If you need to install a dependency, please put it in your home directory.
* For autotools, you can do it with "./configure --prefix=~/my-path"
* For Python packages, use "pip install <package_name> --user" or create a Conda environment.
Sincerely,
Admins
Error on or near line 113; exiting with status 1
Daya
