6582 Discussions
Relating openVino and NNCF onnx exporter
timosy
The following  is sequence of quantization
# Create a quantized model from a pre-trained FP32 model and configuration object.
compress_ctrl, compress_model = create_compressed_model(
model, nncf_config
#warnings.filterwarnings("ignore", category=TracerWarning) # Ignore export warnings
#warnings.filterwarnings("ignore", category=UserWarning)
compress_ctrl.export_model(str(outdir)+"model_int8.onnx")
When I quantiza a model, I'd like to use option: operator_export_type=torch.onnx.OperatorExportTypes.ONNX_ATEN_FALLBACK or opset_version becuase I'd like to avoid error: RuntimeError: Unsupported: ONNX export of operator adaptive_avg_pool2d, since output size ...
When I used the option above when converting  FP32 model to onnx, the option allowed me to convert w/o error.  I'd like to use the same option when converting INT8 model.
Is this acceptable? I cheked a function  compress_ctrl.export_model, but I could not find a proper  argument....
best regards,
Labels (3)
Peh_Intel
Hi timosy,
Yes, you can do so as well. The current positioning of NNCF is such that we target OpenVINO™ as the inference framework for the NNCF-created models and do not guarantee functionality for the other inferencing frameworks.
Peh
Peh_Intel
Hi timosy,
Unfortunately, I also not aware whether it is possible to have the operator_export_type option to be added to the compress_ctrl.export_model as it only takes a single parameter specifying the path to the output ONNX model. Anyway, you can post NNCF related questions on NNCF GitHub.
Sincerely,
Peh
timosy
Dear Peh_Intel
Thanks for your comment.
I'm also testing an alternate procedure, it means quantizing a model under onnx framework, then convert it to IR model, where NNCF is not necessary...
Peh_Intel
Hi timosy,
Peh
Peh_Intel
Hi timosy,
This thread will no longer be monitored since we have provided answers and suggestions. If you need any additional information from Intel, please submit a new question.
Peh
