Reshape YOLOV3 Input dims error
Gao__Jack
HI everyone,
    I'm using the sample code "object_detection_demo_yolov3_async" and trying to reshape the input size of the network by adding the code below.
		SizeVector input_dims = input->getInputData()->getTensorDesc().getDims();
		printf("input dims[%d,%d,%d,%d]\n", input_dims[0], input_dims[1], input_dims[2], input_dims[3]);
		std::map<std::string, SizeVector> input_shapes;
		input_shapes[inputName] = input_dims;
		netReader.getNetwork().reshape(input_shapes);
I just take the input size from the network and reshape the "same" shape. I got the error [ ERROR ] Dims and format are inconsistent.
The model is convert by following the steps from Openvino documentation.
Anyone can help me to solve this error?
Shubha_R_Intel
Dear Jack, may I know what device you're running inference on ? Also I assume that you have not loaded the network anywhere in code yet ? According to this forum post reshapes should always occur BEFORE  the network is loaded to the plugin.
https://software.intel.com/en-us/forums/computer-vision/topic/797651
Shubha
Gao__Jack
Dear Shubha,
    The attachment is my code. I have tried to use CPU, GPU, Movidius to run inference on but all of them have the same error if I use reshape function. I reshape the input size with reference to the sample code Smart Classroom demo.
Jack
Shubha_R_Intel
Dear Jack,  Thanks for attaching your code !
let me debug this for you and I will report back here. Thanks for using OpenVino !
Shubha
Shubha_R_Intel
Dear Jack, you will be happy to know that I reproduced your issue. I will keep you posted !
Shubha
