Route OpenVINO logging to file
wsla
Is there an option to route all OpenVINO logging to a file, or should I do this by changing stdout/stderr?
Rizal_Intel
Hi wsla,
You could try to write it to a text file using something similar to
Program.exe > mylog.txt
on the command line or terminal.
If you require further details, I would recommend you to compile OpenVINO from source in Debug mode to get more info.
Rizal
Rizal_Intel
Hi wsla,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Rizal
