Run Inference Engine classification sample
SC_Huang
초급자
1,532 조회수
Hi
I'm trying openVINO R4,
After installation, run the "sudo -E ./demo_squeezenet_download_convert_run.sh",
then, I get the error
[ ERROR ] Error reading network: cannot parse future versions: 3
Error on or near line 215; exiting with status 1
what cause this error? How to Fix it?
0 포인트
1 솔루션
Severine_H_Intel
1,532 조회수
Dear Huang,
have you used a previous openvino version before? If yes, you should withdraw the folder ~/openvino_models. Old model version might interfere with the R4 release.
Best,
Severine
원본 게시물의 솔루션 보기
0 포인트
4 응답
Severine_H_Intel
1,533 조회수
Dear Huang,
Best,
Severine
0 포인트
Omar_L_1
초급자
1,532 조회수
Dear Huang
                    On Linux, Every time you execute your program, you must use the run bin/setupvars.sh to set the environment variables.
Setting Up the Environment
On Ubuntu 16.04: source <INSTALL_DIR>/bin/setupvars.sh
Best
Omar Lan
0 포인트
SC_Huang
초급자
1,532 조회수
Thanks Habert, Severine
It works after remove the old version model and inference engine example folder!
Thanks Omar,
You're right.
0 포인트
SSola8
새로운 기여자 I
1,532 조회수
Hi @SC Huang, As you can see in the installation of Openvino here (https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#install-openvino) the last paragraph, they have mentioned deleting these folders, you do the same and it will good to go. I have tried it. It worked.
0 포인트
응답
