Run Inference Engine classification sample
SC_Huang
Hi
I'm trying openVINO R4,
After installation, run the "sudo -E ./demo_squeezenet_download_convert_run.sh",
then, I get the error
[ ERROR ] Error reading network: cannot parse future versions: 3
Error on or near line 215; exiting with status 1
what cause this error? How to Fix it?
Severine_H_Intel
Dear Huang,
have you used a previous openvino version before? If yes, you should withdraw the folder ~/openvino_models. Old model version might interfere with the R4 release.
Best,
Severine
Severine_H_Intel
Dear Huang,
Best,
Severine
Omar_L_1
Dear Huang
                    On Linux, Every time you execute your program, you must use the run bin/setupvars.sh to set the environment variables.
Setting Up the Environment
On Ubuntu 16.04: source <INSTALL_DIR>/bin/setupvars.sh
Best
Omar Lan
SC_Huang
Thanks Habert, Severine
It works after remove the old version model and inference engine example folder!
Thanks Omar,
You're right.
SSola8
Hi @SC Huang, As you can see in the installation of Openvino here (https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#install-openvino) the last paragraph, they have mentioned deleting these folders, you do the same and it will good to go. I have tried it. It worked.
