Run Layers in CPU and FPGA using OpenVINO
Malhar
I am looking for the python code implementation / reference where we can infer the respective layers using OpenVINO ? For Example-
after loading IR into Plugin
for l in net.layers.values():
    if l.name == "Layer1":
        l.affinity = "FPGA"
    if l.name == "Layer2":
        l.affinity = "CPU"
exec_net = plugin.load(network=net)
res = exec_net.infer(inputs={input_blob: image})
Is it possible to do ?
Shubha_R_Intel
Under deployment_tools\inference_engine\samples\python_samples there is affinity_setting_demo.py which should give you a good starting point.
Malhar
Thank you for the response. How to read the inputs and output data passing for layers during inference ? Is there any API to check ?
