Run OpenVINO demo with GPU failed (ubuntu 16.04 with NVIDIA display card)
ke__xu
I try the demo in ubuntu 16.04, when I run it with CPU, it is OK, with GPU, it failed.
run : /opt/intel/computer_vision_sdk/deployment_tools/demo$ ./demo_security_barrier_camera.sh -d GPU
OpenCL is installed, when OpenCL is not installed, the log do not show " Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz: invalid device type"
[ INFO ] Loading Vehicle Detection model to the GPU plugin
[ ERROR ] failed to create engine: No OpenCL device found which would match provided configuration:
    TITAN Xp: invalid vendor type
Error on or near line 142; exiting with status 1
Log when not install OpenCL:
ke__xu
I am afraid that the Intel HD graph is not work, for I use a Nvidia display card as primary device.
When I use "lspci |grep VGA" to show, but not found any word about "Intel HD" at all.
ke__xu
nikos1
Valued Contributor I
You should be able to see the Intel HD Graphics 630 GPU too. Sometimes it can be tricky with dual GPU systems like yours. You may have to enable Intel GPU from BIOS and you may also have to connect a monitor to the system DVI/HDMI port (not on the discrete graphics ports).
FWIW I had a similar system and GPU configuration and my Intel HD worked fine when using the same sample with -d GPU.
nikos1
BTW there was a similar issue on Windows https://software.intel.com/en-us/forums/computer-vision/topic/785425
ke__xu
Hi Nikos,
  Thanks you very much!
  For current development env is co-used with workmates, he is trying a CUDA program, so I will not do more trying to config this env.
Ke
nikos1
Hi Ka,
You are welcome.
BTW I am also doing a lot of CUDA work and OpenCL development and AI work and I have both GPUs happily co-existing in my system. It is possible. You may have to connect one monitor to the discrete GPU and a second monitor to your motherboard. Your HD Graphics 630 GPU is a nice AI accelerator and will run at high framerates with very low CPU load.
Cheers,
Nikos
