6605 Discussions
Run object_detection_demo_ssd_async sample with Movidius NCS on Ubuntu16.04: Unknown device
Monica__WU
I was trying CV SDK in version 2018.2.319 on Ubuntu16.04, running the object_detection_demo_ssd_async  sample with myriadPlugin, but I got problem shown as below:
End with [ERROR] Unknown device
What could be the problem?
sudo ./object_detection_demo_ssd_async -i /dev/video0 -m MobileNetSSD_deploy.xml -d MYRIAD
InferenceEngine:
    API version ............ 1.1
    Build .................. 12419
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading plugin
    Description ....... myriadPlugin
[ INFO ] Loading network files
[ INFO ] Batch size is forced to  1.
[ INFO ] Checking that the inputs are as the sample expects
[ INFO ] Checking that the outputs are as the sample expects
[ INFO ] Loading model to the plugin
[ ERROR ] Unknown device
Monique_J_Intel
Hi Monica,
Have you loaded the usb rules for the MYRIAD device. They can be found in /opt/intel/computer_vision_sdk/deployment_tools/documentation, click OpenVINO_Deployment_Tools_documentation.html, click Inference Engine Developers Guide, and then scroll down and click MYRIAD at the bottom of the page are instructions on how to load the USB rules for MYRIAD. Let me know if this helps as I've successfully ran the sample on MYRIAD but i'm also on R3 which is now the latest OpenVINO release.
Kind Regards,
Monique Jones
Monica__WU
Hi Monique,
I'm sure I have loaded the 97-usbboot.rules in /etc/udev/rules.d.
I've successfully run the hello_ncs_cpp in NCSDK2 :
/workspace/ncsdk2/examples/apps/hello_ncs_cpp/cpp$ ./hello_ncs_cpp
Hello NCS! Device opened normally.
Goodbye NCS!  Device Closed normally.
NCS device working.
In fact, I succeeded in running the samples before I reinstalled the openvino R2.
I have tested in so some ways:
1) reinstall R2 with root privilege (fail)
2)run ncsdk2 (success )
3)  lsusb (success)(with 2 movidius sticks)
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 8087:0a2a Intel Corp.
Bus 001 Device 004: ID 05c8:038e Cheng Uei Precision Industry Co., Ltd (Foxlink)
Bus 001 Device 057: ID 03e7:2150
Bus 001 Device 055: ID 03e7:2150
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I am so confused about the problem. Looking forward to your reply.
Monica Wu.
