6598 Discussions
Run pedesetrian tracker demo use MYRIAD has some error message
Hung__Edwin
environment : ubuntu 16.04
version : "l_openvino_toolkit_p_2019.1.144"
CPU : N4200
It can run on CPU
./pedestrian_tracker_demo -i /home/asrock/inference_engine_samples_build/intel64/PexelsVideos1338590.mp4 -m_det /home/asrock/inference_engine_samples_build/intel64/persion-detection-retail-0013/FP16/person-detection-retail-0013.xml -d_det MYRIAD -m_reid /home/asrock/inference_engine_samples_build/intel64/person-reidentification-retail-0031/FP16/person-reidentification-retail-0031.xml -d_reid MYRIAD
InferenceEngine:
    API version ............ 1.6
    Build .................. custom_releases/2019/R1.1_28dfbfdd28954c4dfd2f94403dd8dfc1f411038b
[ INFO ] Parsing input parameters
Loading plugin MYRIAD
    Build .................. 23780
    Description ....... myriadPlugin
[ ERROR ] Failed to infer shapes for Reshape layer (mbox_conf1/out/conv/flat/reshape) with error: Invalid reshape mask (dim attribute): number of elements in input: [1,16320] and output: [1,16320,32758213790559855] mismatch
HemanthKum_G_Intel
Hi Edwin,
This is shape infer issue.
Either you can just remove that reshape from IR or refer the following documentation to update the shape in inference code -
 https://docs.openvinotoolkit.org/latest/_docs_IE_DG_ShapeInference.html
