Running ncappzoo on ubuntu ver. 17.10
I started to use Movidius on ubuntu ver. 17.10, The error that I get is on: skimage.io.imshow( IMAGE_PATH ) Dispite adding thIs line: according to the not of "AshwinVijayakumar edited November 2017 " amirm@t460s:~/~workspace/ncappzoo/apps/image-classifier$ make run \making ilsvrc12 (cd ../../data/ilsvrc12; make;) make[1]: Entering directory '/home/amirm/~workspace/ncappzoo/data/ilsvrc12' make[1]: Leaving directory '/home/amirm/~workspace/ncappzoo/data/ilsvrc12' making gendernet (cd ../../caffe/GenderNet; make compile;) make[1]: Entering directory '/home/amirm/~workspace/ncappzoo/caffe/GenderNet' make[2]: Entering directory '/home/amirm/~workspace/ncappzoo/data/age_gender' make[2]: Leaving directory '/home/amirm/~workspace/ncappzoo/data/age_gender' test -f deploy.prototxt || (wget -P . https://raw.githubusercontent.com/GilLevi/AgeGenderDeepLearning/master/gender_net_definitions/deploy.prototxt; awk 'NR <2 {print}' < deploy.prototxt > temp; cat input_shape.prototxt >> temp; awk 'NR > 6 {print}' < deploy.prototxt >> temp; mv temp deploy.prototxt) test -f gender_net.caffemodel || wget -P . -N https://github.com/GilLevi/AgeGenderDeepLearning/raw/master/models/gender_net.caffemodel mvNCCompile -w gender_net.caffemodel -s 12 deploy.prototxt mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 /usr/local/lib/python3.6/dist-packages/skimage/__init__.py:60: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses import imp /usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance "Consider reducing your data sizes for best performance\033[0m") make[1]: Leaving directory '/home/amirm/~workspace/ncappzoo/caffe/GenderNet' making googlenet (cd ../../caffe/GoogLeNet; make compile;) make[1]: Entering directory '/home/amirm/~workspace/ncappzoo/caffe/GoogLeNet' making prereqs (cd ../../data/ilsvrc12; make) make[2]: Entering directory '/home/amirm/~workspace/ncappzoo/data/ilsvrc12' make[2]: Leaving directory '/home/amirm/~workspace/ncappzoo/data/ilsvrc12' making prototxt Prototxt file already exists making caffemodel caffemodel file already exists making compile mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 /usr/local/lib/python3.6/dist-packages/skimage/__init__.py:60: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses import imp Layer inception_3b/1x1 forced to im2col_v2, because its output is used in concat Layer inception_3b/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4a/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4a/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4b/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4b/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4c/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4c/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4d/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4d/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_4e/1x1 forced to im2col_v2, because its output is used in concat Layer inception_4e/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_5a/1x1 forced to im2col_v2, because its output is used in concat Layer inception_5a/pool_proj forced to im2col_v2, because its output is used in concat Layer inception_5b/1x1 forced to im2col_v2, because its output is used in concat Layer inception_5b/pool_proj forced to im2col_v2, because its output is used in concat /usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance "Consider reducing your data sizes for best performance\033[0m") make[1]: Leaving directory '/home/amirm/~workspace/ncappzoo/caffe/GoogLeNet' making squeezenet (cd ../../caffe/SqueezeNet; make compile;) make[1]: Entering directory '/home/amirm/~workspace/ncappzoo/caffe/SqueezeNet' making prereqs (cd ../../data/ilsvrc12; make) make[2]: Entering directory '/home/amirm/~workspace/ncappzoo/data/ilsvrc12' make[2]: Leaving directory '/home/amirm/~workspace/ncappzoo/data/ilsvrc12' LICENSE file already exists making prototxt Prototxt file already exists making caffemodel caffemodel file already exists making compile mvNCCompile -w squeezenet_v1.0.caffemodel -s 12 deploy.prototxt mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 /usr/local/lib/python3.6/dist-packages/skimage/__init__.py:60: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses import imp /usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance "Consider reducing your data sizes for best performance\033[0m") make[1]: Leaving directory '/home/amirm/~workspace/ncappzoo/caffe/SqueezeNet' making alexet (cd ../../caffe/AlexNet; make compile;) make[1]: Entering directory '/home/amirm/~workspace/ncappzoo/caffe/AlexNet' making prereqs (cd ../../data/ilsvrc12; make) make[2]: Entering directory '/home/amirm/~workspace/ncappzoo/data/ilsvrc12' make[2]: Leaving directory '/home/amirm/~workspace/ncappzoo/data/ilsvrc12' chmod +x run.py making prototxt Prototxt file already exists making caffemodel caffemodel file already exists making compile mvNCCompile -w bvlc_alexnet.caffemodel -s 12 deploy.prototxt mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 /usr/local/lib/python3.6/dist-packages/skimage/__init__.py:60: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses import imp /usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance "Consider reducing your data sizes for best performance\033[0m") make[1]: Leaving directory '/home/amirm/~workspace/ncappzoo/caffe/AlexNet' Running image-classifier.py python3 image-classifier.py /usr/local/lib/python3.6/dist-packages/skimage/__init__.py:60: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses import imp /usr/local/lib/python3.6/dist-packages/skimage/transform/_warps.py:84: UserWarning: The default mode, 'constant', will be changed to 'reflect' in skimage 0.15. warn("The default mode, 'constant', will be changed to 'reflect' in " ------- predictions -------- prediction04 0 is n02123159 tiger cat prediction04 1 is n02123045 tabby, tabby cat prediction04 2 is n02124075 Egyptian cat prediction04 3 is n02127052 lynx, catamount Traceback (most recent call last): File "image-classifier.py", line 98, in <module> skimage.io.imshow( IMAGE_PATH ) File "/usr/local/lib/python3.6/dist-packages/skimage/io/_io.py", line 156, in imshow return call_plugin('imshow', arr, plugin=plugin, **plugin_args) File "/usr/local/lib/python3.6/dist-packages/skimage/io/manage_plugins.py", line 198, in call_plugin raise RuntimeError(msg % kind) RuntimeError: No suitable plugin registered for imshow. You may load I/O plugins with the `skimage.io.use_plugin` command. A list of all available plugins are shown in the `skimage.io` docstring. Makefile:32: recipe for target 'run' failed make: *** [run] Error 1 amirm@t460s:~/~workspace/ncappzoo/apps/image-classifier$
@amazinani Did you encounter any issues while running the install script on Ubuntu 17? It may seem like you may be missing the scikit-image software package and I'm not sure if this was a side effect of installing the SDK on Ubuntu 17. If this is the case, then you may want to try installing scikit-image by using the following command pip3 install scikit-image.
Thanks Tome,
Is it posible that ubuntu ver. 17 has a problem?
I am using a separate partition (25GB) ubuntus boot able on my dual boot (Win-10 64-bit) laptop. all the other function of Linux works fine.
Should I remeve and reinstall ubuntu?
Here are what I did:
1- I installed scikit-image and reboot the laptop just in case; no improvement so far.
2- Then went through ubuntu boot-up and selected, Linux image generic [recovery mode]
It fixed 5 directories, but the problem is there.
3- next I tried:
sudo apt-get install --reinstall ubuntu-desktop
it did not fixed my problem, it just update one file, but still the problem is there.
The following is the terminal result:
File "/home/amirm/.local/lib/python3.6/site-packages/skimage/io/_io.py", line 156, in imshow
File "/home/amirm/.local/lib/python3.6/site-packages/skimage/io/manage_plugins.py", line 198, in call_plugin
You may load I/O plugins with the skimage.io.use_plugin command. A list of all available plugins are shown in the skimage.io docstring.
@amazinani Try using this fix mentioned by Karl at https://ncsforum.movidius.com/discussion/356/steps-for-installtion-for-raspberry-pi-3-new-sdk/p1. He mentions that the command apt-get install python3-tk worked for him.
Hi Tome,
I run the "apt-get install python3-tk"
and the terminal shows that python3-tk is already there.
I install the gnome-desktop and the ncappzoo is working now!
my guess is the permission for some directory changed through gnome-desktop.
Would you please let me know if this gnome-desktop is safe?
Regards, Amir
@Tome_at_Intel, it works.
worked for me as well :)
Why ncs sdk doesn't install it?
worked for me as well.
