6582 Discussions
Running the Sample Project with OpenVINO R 3.1 (Windows 10)
Blues-sptn
The following error will occur when the operation is executed referring to the following site.
Please tell me how to deal with it.
*reference site
https://docs.openvinotoolkit.org/latest/_demos_crossroad_camera_demo_README.html
*Execution Commands
crossroad_camera_demo.exe -m./person-vehicle-bike-detection-crossroad-0078.xml -m _ pa./person-attributes-recognition-crossroad-0230.xml -m _ reid./person-reidentification-report-0079.xml
​*Error Log
InferenceEngine:
API Version............ 2.1
Build.............. 32974
Description.... API
[INFO] Parsing input parameters
[INFO] Reading input
[INFO: 0] global C : \jenkins \workspace \OpenCV \OpenVINO \build \opencv \modules \videoio \src \videoio _ registry.cpp (187) cv : : `anonymous - namespace ' : : VideoBackendRegistry : : VideoBackendRegistry VIDEOIO : Enabled backends (7, sorted by priority) : FFMPEG (1000); GSTREAMER (990); INTEL _ MFX (980); MSMF (970); DSHOW (960); CV _ IMAGES (950); CV _ MJPEG (940)
[INFO: 0] global C: \jenkins \workspace \OpenCV \OpenVINO \build \opencv \modules \videoio \src \backend _ plugin.cpp (340) cv:: impl:: getPluginCandidates Found2plugin (s) for GSTREAMER
[INFO: 0] global C: \jenkins \workspace \OpenCV \OpenVINO \build \opencv \modules \videoio \src \backend _ plugin.cpp (172) cv:: impl: DynamicLib:: libraryLoad C: \Users \Kawashima \Documents \Intel \OpenVINO \inference _ engine _ samples _ build \intel 64 \Debug \opencv _ videoio _ gstreamer 412 _ 64 .dll = FAILED
[INFO: 0] global C: \jenkins \workspace \OpenCV \OpenVINO \build \opencv \modules \videoio \src \backend _ plugin.cpp (172) cv:: impl: DynamicLib:: libraryLoad load opencv _ videoio _ gstreamer 64 _ 412 .dll = > FAILED
[INFO] Loading device CPU
CPU
MKLDNPlugin version...... 2.1
Build........... 32974
[INFO] Loading network files for PersonDetection
[INFO] Batch size is forced to 1
[INFO] Checking Person Detection inputs
[INFO] Checking Person Detection outputs
[INFO] Loading Person Detection model to the CPU device
[WARN: 0] global C: \jenkins \workspace \OpenCV \OpenVINO \build \opencv \modules \videoio \src \cap _ msmf.cpp (674) SourceReaderCB: ~ SourceReaderCB terminating async callback
[ERROR] Unsupported primitive of type: PriorBoxClustered name: x08 _ priorbox
.. \src \mkldnn _ plugin \mkldnn _ node.cpp: 171
../include/details/ie _ exception _ conversion.hpp: 71
JAVIERJOSE_A_Intel
Hi Blues-sptn,
Thank you for reaching out.
We already tested the demo from our end and it worked successfully. Did you install the latest OpenVINO™ toolkit version from scratch or was it updated from an older version?
Javier A.
Intel Customer Support Technician
A Contingent Worker at Intel
JAVIERJOSE_A_Intel
Hi Blues-sptn,
I hope you are doing well.
Could you please answer my previous message to continue with the assistance?
Javier A.
Blues-sptn
I apologize for the late reply.
I installed the latest version of OpenVINO.
It is not an update.
Is the dependency with the PC environment a problem?
*It is not an update.
■PC Environment
・Windows 10 Pro
・CPU: Intel Core (TM) i7 -8650 U CPU @ 1.9 GHz
JAVIERJOSE_A_Intel
Hi Blues-sptn,
Thank you for your response.
Did you follow the official installation guide of the Intel® Distribution of OpenVINO™ toolkit for Windows 10?
In addition to confirming your installation was successful, try to run the "demo_squeezenet_download_convert_run.bat" and "demo_security_barrier_camera.bat".
Javier A.
JAVIERJOSE_A_Intel
Hi Blues-sptn,
Could you please tell me if you were able to run the demos "demo_squeezenet_download_convert_run.bat" and "demo_security_barrier_camera.bat" successfully?
Javier A.
Blues-sptn
The following was successful.
Some samples work fine in this environment.
*demo _ squeezenet _ download _ convert _ run.bat
*demo _ security _ barrier _ camera.bat
*interactive _ face _ detection _ demo sample
JAVIERJOSE_A_Intel
Hi Blues-sptn,
Thank you for your response. Just to make sure, did you followed the official installation guide of the Intel® Distribution of OpenVINO™ toolkit for Windows* 10 and installed all the pre-requisites?
Also, you must install dependencies and complete configuration steps:
Javier A.
Blues-sptn
The following procedures were followed.
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_windows.html
The only thing that bothers me is the Python version.
I'm using Python 3.7. 3, not Python 3.6. 5.
Is there any height that can affect it?
JAVIERJOSE_A_Intel
Hi Blues-sptn,
Could you try to run the crossroad demo again using Python 3.6.5?
Did you set the environment variables permanently as shown here?
Javier A.
JAVIERJOSE_A_Intel
Hi Blues-sptn,
Could you please tell me if you were able to run the crossroad demo using Python 3.5.6 and set the environment variables permanently?
Javier A.
Blues-sptn
Thank you for contacting me.
I haven't tried it yet.
I will let you know the result after I try it.
JAVIERJOSE_A_Intel
Hi Blues-sptn,
We will wait for your outcomes.
Javier A.
JAVIERJOSE_A_Intel
Hi Blues-sptn,
Have you tested the demo again applying our recommendations?
Javier A.
