6593 Discussions
Runtime issue with the usage of vaapi elements which is added as a part OpenVINO 2020.3 runtime container
SandeshKum_S_Intel
$ docker run -u root -it --device /dev/dri:/dev/dri --device-cgroup-rule='c 189:* rmw' -v /dev/bus/usb:/dev/bus/usb --rm openvino/ubuntu18_runtime:2020.3 /bin/bash
[setupvars.sh] OpenVINO environment initialized
root@dd79863d62d3:/opt/intel/openvino_2020.3.194# gst-inspect-1.0 vaapi
Plugin Details:
  Name                     vaapi
  Description              VA-API based elements
  Filename                 /opt/intel/openvino/data_processing/gstreamer/lib/gstreamer-1.0/libgstvaapi.so
  Version                  1.16.2
  License                  LGPL
  Source module            gstreamer-vaapi
  Binary package           gstreamer-vaapi
  Origin URL               http://bugzilla.gnome.org/enter_bug.cgi?product=GStreamer
  0 features:
root@dd79863d62d3:/opt/intel/openvino_2020.3.194# echo $GST_PLUGIN_PATH
/opt/intel/openvino/data_processing/dl_streamer/lib:/opt/intel/openvino/data_processing/gstreamer/lib/gstreamer-1.0
There is some missing libraries/dependencies which is causing the issues with vaapi elements
SandeshKum_S_Intel
Gentle Reminder for this topic
Luis_at_Intel
Hi SandeshKum_S_Intel,
Thanks for reaching out. Can you share what are some of the issues you are running into? Are there any errors or warnings you are seeing? Please provide any details that could help us reproduce such problem.
Luis
