6592 Discussions
RuntimeError: Unsupported primitive of type: PriorBoxClustered name: fc7_mbox_priorbox
Maurya__Shraddha
I am trying to run the face_recognition_demo.py from the PyCharm using the openvino library which I installed as follows:
conda install openvino-ie4py -c openvino
Then I try to run the face_recognition_demo.py script using the following command:
python face_recognition_demo.py -m_fd C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\face-detection-retail-0004.xml
 -m_lm C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\landmarks-regression-retail-0009.xml -m_reid C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\face-reidentification-retail-00
95.xml --verbose -fg "C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\faces_gallery"
After running this command, I get the following error:
[ DEBUG ] 2020-05-18 16:59:54,768 Namespace(allow_grow=False, cpu_lib='', crop_height=0, crop_width=0, d_fd='CPU', d_lm='CPU', d_reid='CPU', exp_r_fd=1.15, fd_input_height=0, fd_input_width
=0, fg='C:\\Users\\ShraddhaM\\PycharmProjects\\OpenVinoStreamlit\\faces_gallery', gpu_lib='', input='0', m_fd='C:\\Users\\ShraddhaM\\PycharmProjects\\OpenVinoStreamlit\\face-detection-retai
l-0004.xml', m_lm='C:\\Users\\ShraddhaM\\PycharmProjects\\OpenVinoStreamlit\\landmarks-regression-retail-0009.xml', m_reid='C:\\Users\\ShraddhaM\\PycharmProjects\\OpenVinoStreamlit\\face-re
identification-retail-0095.xml', match_algo='HUNGARIAN', no_show=False, output='', perf_stats=False, run_detector=False, t_fd=0.6, t_id=0.3, timelapse=False, verbose=True)
[ INFO ] 2020-05-18 16:59:54,788 Loading models
[ INFO ] 2020-05-18 16:59:54,789 Loading the model from 'C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\face-detection-retail-0004.xml'
[ INFO ] 2020-05-18 16:59:54,840 Model is loaded
[ INFO ] 2020-05-18 16:59:54,840 Loading the model from 'C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\landmarks-regression-retail-0009.xml'
[ INFO ] 2020-05-18 16:59:54,849 Model is loaded
[ INFO ] 2020-05-18 16:59:54,849 Loading the model from 'C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\face-reidentification-retail-0095.xml'
[ INFO ] 2020-05-18 16:59:54,873 Model is loaded
Traceback (most recent call last):
  File "face_recognition_demo.py", line 446, in <module>
    main()
  File "face_recognition_demo.py", line 441, in main
    visualizer = Visualizer(args)
  File "face_recognition_demo.py", line 240, in __init__
    self.frame_processor = FrameProcessor(args)
  File "face_recognition_demo.py", line 151, in __init__
    self.face_detector.deploy(args.d_fd, context)
  File "C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\ie_module.py", line 75, in deploy
    self.model, device, self.max_requests)
  File "C:\Users\ShraddhaM\PycharmProjects\OpenVinoStreamlit\ie_module.py", line 57, in deploy_model
    return self.ie_core.load_network(model, device, config=config, num_requests=max_requests)
  File "ie_api.pyx", line 85, in openvino.inference_engine.ie_api.IECore.load_network
  File "ie_api.pyx", line 92, in openvino.inference_engine.ie_api.IECore.load_network
Please help me resolve this issue. Following are the details of my system:
OS: Windows 10 Home, 64-bit
Python version: Python 3.7.7 (default, Mar 23 2020, 23:19:08) [MSC v.1916 64 bit (AMD64)] :: Anaconda, Inc. on win32
PyCharm Community Edition 2019.3.4
cv2 version: 4.2.0
Munesh_Intel
Hi Shraddha,
I would suggest you install the Intel® Distribution of OpenVINO™ toolkit for Windows 10.
The installation guide for Windows is available at the following page:
https://docs.openvinotoolkit.org/2020.3/_docs_install_guides_installing_openvino_windows.html
The download link is given here :
https://www.intel.com/content/www/us/en/develop/tools/openvino-toolkit/choose-download/windows.html
More information regarding interactive face recognition demo is available at following page:
https://docs.openvinotoolkit.org/2020.3/_demos_python_demos_face_recognition_demo_README.html
Munesh
