6594 Discussions
Sample configuration files for Calibration Tool
Edward_S_Intel1
Hi guys,
You can find announced in 2019 R1 OpenVINO™ Calibration Tool sample configuration files in attached ZIP.
ZIP file includes
  • definitions.yml - definition file
  • inception_v1.yml - configuration file for Tensorflow* Inception v1 model
  • ssd_mobilenet_v1_coco.yml - configuration file for Tensorflow* SSD Mobilenet v1 model
  • unet2d.yml - configuration file for Unet2D mode in in OpenVINO* Inference Engine Intermediate Representation format
Let me know if you have any questions.
Best regards, Edward
ChunShen_S_Intel
May I ask since the configuration files available inside openVINO are so limited, how can I get the configuration file for other model for example SSD MobileNetV2?
Roy_A_Intel
Hi Sea,
There are additional config files (13)  available under C:\Program Files (x86)\IntelSWTools\openvino_2019.2.242\deployment_tools\open_model_zoo\tools\accuracy_checker\configs.
Roy_A_Intel
And for custom models that don't have config files yet, here is the workflow for handling this:
  1. Convert annotation of your dataset. Use one of the converters from annotation-converters, or write your own if there is no converter for your dataset. You can find detailed instruction how to use converters in Annotation Conversion Guide.
  2. Choose one of adapters or write your own. Adapter converts raw output produced by framework to high level problem specific representation (e.g. ClassificationPrediction, DetectionPrediction, etc).
  3. Reproduce preprocessing, metrics and postprocessing from canonical paper.
  4. Create entry in config file and execute.
