Simultaneous RTSP stream analysis
I am considering using the Movidius X platform for analysing 6 simultaneous H.264 encoded video streams for facial detection and basic image anlytics for a commercial surveillance application. Wanted to get an opinion if the device has enough juice to run. What about Movidius 2?
Yes, i did that at home with NCSv1, using a pretrained model and work just fine i am getting between 4-7 fps. i can share all details about that if you help me port my TF trained model into NCS. i just dont understand how that works.
@masterchop
what model you used? Does TF has a deploy model?
BTW,can you getting 4-7 fps, I am so curious how you achieve it?
I would also be very interested in seeing this as well.
