Stuck at "Loading model to the plugin" when using NCSV2
Tse__Ho_Cheong_Edwin
Hi everyone.
I used faster-rcnn-inception-v2-coco to train my model and successfully transforming to IR using Openvino.
However, when I try to run the object_detection_sample_ssd using NCSV2, it stuck at here:
[ INFO ] Loading model to the plugin
I have added more info message to debug and finds out that it probably stuck at :
ExecutableNetwork executable_network = plugin.LoadNetwork(network, {});
I am using VM with Ubuntu and have no problem running demo_security_barrier_camera and demo_squeezenet_download_convert_run with NCSV2 but get stuck with my own model.
Thank you.
Shubha_R_Intel
How does it work outside of a VM environment ? You can try it on Windows 10 (it works).
No, it also stuck at "[ INFO ] Loading model to the plugin" when using Windows 10.
Shubha_R_Intel
Hello Ho Cheong. Here's a debugging technique. Can you kindly try with -d GPU first on Windows 10 ? (I assume you have an Intel GPU). Or if not GPU, try -d CPU. Let us know what happens.
Thank you for your reply.
I’ve tried to generate two xml with Datatype FP16 and FP32.
Since cpu doesn’t support FP16, I used FP32 with cpu and it works, a bmp image was successfully created without any problem.
But when I use NCSV2 with a FP16 xml, no matter I’m running on a Ubuntu VM or Windows 10, both stuck at loading model to the plugin.
It seems that the program is running since the NCSV2 become warmer, but I tried to let it run for 8 hours and still no hope.
Thank you.
om77
it's very possible that your network reaches a some resource limitation for stick (cpu, memory).
To ensure if this is the case, try to reduce network inputs array.
E.g. in the case of faster-rcnn-inception-v2-coco
https://github.com/tensorflow/models/blob/master/research/object_detection/samples/configs/faster_rcnn_inception_v2_coco.config
try to reduce image_resizer parameters e.g. to 480-576.
Thank you om77.
I have reduced the  image_resizer parameters to 480-576 but still stuck at the [ INFO ] Loading model to the plugin.
It is a little bit strange because it works perfectly on CPU.
Here is the log info:
C:\Users\XXXXXXXX\Documents\intel\OpenVINO\inference_engine_samples_2017\intel64\Debug>object_detection_sample_ssd.exe
-i "c:\Users\XXXXXXXX\Desktop\photo\000241.jpg"
-m "c:\Users\XXXXXXXX\Desktop\inference\inference_smaller_16\frozen_inference_graph.xml" -d MYRIAD
[ INFO ] InferenceEngine:
        API version ............ 1.4
        Build .................. 19154
Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     c:\Users\XXXXXXXX\Desktop\photo\000241.jpg
[ INFO ] Loading plugin
        API version ............ 1.5
        Description ....... myriadPlugin
[ INFO ] Loading network files:
        c:\Users\XXXXXXXX\Desktop\inference\inference_smaller_16\frozen_inference_graph.bin
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
I also tried to downgrade from R5.01 to R5 but still get stuck at the same place.
Thank you.
nikos1
Valued Contributor I
Hello Tse, Ho Cheong Edwin
Could you try the following command so that we can debug the issue further
Copy contents including sub-folders of C:\Intel\computer_vision_sdk_2018.5.456\deployment_tools\inference_engine\bin\intel64\Debug
over to C:\Users\XXXXXXXX\Documents\intel\OpenVINO\inference_engine_samples_2017\intel64\Debug
and then open command prompt in C:\Users\XXXXXXXX\Documents\intel\OpenVINO\inference_engine_samples_2017\intel64\Debug and run from there - NCS still stuck?
If that fails for Debug try same steps for Release
BTW are you using FP32 or FP16 for NCS ?
Cheers,
nikos
whatthisismyname
Did you find the solution to this? i change the image_size too but the problem persisted?
