Sum output shape is resulting collision
Genc__Sahika
I am getting an error on the output shape after Sum layer. It seems like the output is transposed:
Model Optimizer arguments:
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: [1,120,160,2]
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
TensorFlow specific parameters:
- Input model in text protobuf format: False
- Path to model dump for TensorBoard: None
- List of shared libraries with TensorFlow custom layers implementation: None
- Update the configuration file with input/output node names: None
- Use configuration file used to generate the model with Object Detection API: None
- Operations to offload: None
- Patterns to offload: None
- Use the config file: None
Model Optimizer version: 2019.3.0-408-gac8584cb7
[ ERROR ]  After partial shape inference were found shape collision for node main_level/agent/main/online/network_1/stereo/Sum (old shape: [ 1 13 64], new shape: [ 1 64 13])
