Syntax error on Line 17: /opt/intel/openvino/bin/setupvars.sh
Dar__Nadeem
Following the instructions below to setup my Ubuntu VM for Environment Variable step:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#install-external-dependencies
I am getting the following error:
Could you please check and guide how to fix this issue??
Dar__Nadeem
I have fixed the issue now by defining the 'INSTALLDIR' in the 'setupvars.sh' file.
Shubha_R_Intel
Dear Dar, Nadeem,
Thanks for reporting your success and findings back to the OpenVino community !
Shubha
MIfil
Trying to set up openvino on Raspberry Pi and running into the same problem. However, it will not allow me to make any changes to the setupvars.sh file and I will not allow me to change the permissions for the file either. Can you help me find a solution?
Dar__Nadeem
I think I used "sudo nano setupvars.sh" to edit the line and it worked.
MIfil
Thank you, that fixed the problem.
Gh__Fad
Could you please tell me to where INSTALLDIR should point out?
The openvino directory?
