TRY to compile MTCNN with SDK2.05
hello,
I want to compile MTCNN with SDK2.05,
It seems I only needs one stick with the fifo quene in SDK2.05,
So , I begin to find a proper .meta to convert it to graph,
the I found a MTCNN demo in ncappzoo master branch,
then I try to
mvNCCompile model.metal -s -o ograph
And I get this:
KeyError: "The name 'input:0' refers to a Tensor which does not exist. The operation, 'input', does not exist in the graph."
emmmm
where should I start with,
thanks for any discussion
@zufeifei
I put it here.
https://github.com/PINTO0309/MobileNet-SSD-RealSense
o.graph
p.graph
I have not verified whether it can be used.
@PINTO
OH!
Such a Great Work!!
That helps a lot for me.
@PINTO
it seems NCSDK does not support xavier layer in caffe,
the prototxt can not be checked by mvNCCheck normally
oh , the essential problem is PRelu layer can not inplace,
I assign it a new Blob,
porblem solves
@zufeifei
I just did it yesterday and it was unverified.
Sorry, I wasted your time.
I will try it a bit.
@PINTO
OH! Bro! Don't think that any more,
It's so common to meet problem when we translant models,
Just take it easy
@PINTO
can you tell me where you get the graph's original file,
such as .prototxt(in caffe) or .meta (in tensorflow),
now, I am troubled with generate pgrath and ograth with SDK 2.05,
my .meta file comes from the follow link:
https://github.com/ihere1/movidius-face
@zufeifei
Umm…
I think that it is the same repository.
Maybe I misunderstood and compiled in v1 environment …
$ git clone https://github.com/movidius/ncappzoo.git $ cd ncappzoo/tensorflow/MTCNN $ make compile
I may have been looking for the following.
I can not remember …
https://github.com/CongWeilin/mtcnn-caffe
