6597 Discussions
TensorFlow SSD MobileNet V2 - head detector model conversion error
abhi_jci
I'm using openvino version 2021 2021.4 and tensorflow version 1.15.5 in my virtual env.
The model i was trying to convert is "HEAD_DETECTION_300x300_ssd_mobilenetv2.pb", which I'm attaching a link here to download the model:
https://github.com/Varat7v2/Human-Head-Detection/tree/master/models
I'm using this conversion command:
python3 /opt/intel/openvino_2021/deployment_tools/model_optimizer/mo_tf.py \
--input_model=HEAD_DETECTION_300x300_ssd_mobilenetv2.pb \
--tensorflow_use_custom_operations_config ssd_v2_support.json \
--tensorflow_object_detection_api_pipeline_config pipeline.config \
--batch 1 \
--reverse_input_channels
However, i'm getting error
[ ERROR ] Cannot infer shapes or values for node "Postprocessor/ToFloat".
Then i chnaged the "Postprocessor/Cast_1" to "Postprocessor/ToFloat" inside ssd_v2_support.json
However, i'm now getting a different error:
[ ERROR ] Cannot infer shapes or values for node "BoxPredictor_0/ClassPredictor/BiasAdd/Reshape".
[ ERROR ] Number of elements in input [ 1 19 19 6] and output [1, 23, 91] of reshape node BoxPredictor_0/ClassPredictor/BiasAdd/Reshape mismatch
Can i have some help regarding this problem please? Thank you very much.
abhi_jci
Solved the issue by editing "pipeline.config" to have:
num_classes: 1
Thank you
abhi_jci
num_classes: 1
Thank you
Megat_Intel
Hi abhi_jci,
Thank you for sharing your solution with our Community. I'm glad to hear that. Hope everything is going well for you. This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Megat
