TensorFlow pb file retrained
HI there,
I am a newbie. By using Tensorflow on my Linux desktop, I have retrained inception's final layer on my own categories and I followed the tutorial: https://www.tensorflow.org/tutorials/image_retraining
This process creates output_graph.pb and output_labels.txt files. How can I use these files for the interference procedure with Movidius?
Thank you.
@daddym1985, here's a quick example of how to run TF slim models on NCS - https://movidius.github.io/ncsdk/TensorFlow.html
@daddym1985 , did you solve your problem? I got exactly the same, and it seems that the error, related to the BUILD file, was in fact coming from the file itself. Check online on github for the BUILD file, and for me some lines (about "label_image" file) was missing.
Hope it can help you,
Kat
@Kat_Klinex No I have not solved my probem. I think that it may be related to the tensor input name in my *.pb file
Hi there,
by using TensorBoard tool, I found that the parameters for mvNCCompile are:
mvNCCompile output_graph.pb -s 12 -in=import/DecodeJpeg/contents -on=import/final_result -is 224 224
but this give me the error:
$ mvNCCompile output_graph.pb -s 12 -in=import/DecodeJpeg/contents -on=import/final_result -is 224 224
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py:766: DeprecationWarning: builtin type EagerTensor has no module attribute
EagerTensor = c_api.TFE_Py_InitEagerTensor(_EagerTensorBase)
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
if d.decorator_argspec is not None), _inspect.getargspec(target))
TypeError: expected bytes, float found
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1302, in _run_fn
status, run_metadata)
SystemError: returned a result with an error set
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1323, in _do_call
return fn(*args)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/errors_impl.py", line 473, in exit
c_api.TF_GetCode(self.status.status))
tensorflow.python.framework.errors_impl.InternalError: Unable to get element as bytes.
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 229, in parse_tensor
res = outputTensor.eval(feed_dict={inputnode + ':0': input_data})
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 570, in eval
return _eval_using_default_session(self, feed_dict, self.graph, session)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 4455, in _eval_using_default_session
return session.run(tensors, feed_dict)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 889, in run
run_metadata_ptr)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1120, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1317, in _do_run
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1336, in _do_call
raise type(e)(node_def, op, message)
Any idea?
Anyone find a way to get this to work?
