6584 Discussions
Tensorflow Model Zoo item that I would to use on NCS2
Mason__Mike
Quick questions I would like to use one of the iNaturalist models (faster_rcnn_resnet101_fgvc) for bird recognition.
1. Would this model run - if correctly run through the Model Optimizer, and
2. How would I go about creating the prototxt and model to gt it to run.
(I'm struggling on the translation of models in the TF model zoo to IR format.
Thanks for any help.
Shubha_R_Intel
Dearest Mike,  OpenVino's Model Optimizer does support several varieties of Faster R-CNN. Please check the following online documentation and search for the text "Faster R-CNN" within the page.
https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
Fortunately you don't need to create your own prototxt and trained model in most cases. You may simply convert an existing trained model into Model Optimizer IR.
Under deployment_tools\intel_models there are also several models trained by Intel which you can use, though I don't think any of them are targeted toward bird recognition.
Using Model Optimizer is often as simple and straightforward as python mo_tf.py  --input_model <frozen.pb> but it's not always that simple. For NCS2 you'd need to add --data_type FP16.
Model Optimizer requires a frozen tensorflow protobuf as input to --input_model. There are a few ways to get a frozen.pb , but a common method is to simply use freeze_graph.py which comes with the Tensorflow distribution.
Be sure to always add --log_level DEBUG so that you can see detailed errors if MO fails !
And as always, feel free to post your findings here.
Thanks for using OpenVino !
Shubha
