6594 Discussions
Tensorflow Model conversion Error _ Faster RCNN INception trained on my data set
KKar01
Hello, I followed your instruction for converting my frozen inference graph, but it gives the following error:
The model works fine in Python environment and I am able t predict with the model.  Can you please let me know how to fix this issue.  Thanks.
root@pop-os:/opt/intel/openvino/deployment_tools/model_optimizer# python3 mo_tf.py --input_model frozen_inference_graph.pb
Model Optimizer arguments:
Common parameters:
    - Path to the Input Model:     /opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/frozen_inference_graph.pb
    - Path for generated IR:     /opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/.
    - IR output name:     frozen_inference_graph
    - Log level:     ERROR
    - Batch:     Not specified, inherited from the model
    - Input layers:     Not specified, inherited from the model
    - Output layers:     Not specified, inherited from the model
    - Input shapes:     Not specified, inherited from the model
    - Mean values:     Not specified
    - Scale values:     Not specified
    - Scale factor:     Not specified
    - Precision of IR:     FP32
    - Enable fusing:     True
    - Enable grouped convolutions fusing:     True
    - Move mean values to preprocess section:     False
    - Reverse input channels:     False
TensorFlow specific parameters:
    - Input model in text protobuf format:     False
    - Path to model dump for TensorBoard:     None
    - List of shared libraries with TensorFlow custom layers implementation:     None
    - Update the configuration file with input/output node names:     None
    - Use configuration file used to generate the model with Object Detection API:     None
    - Operations to offload:     None
    - Patterns to offload:     None
    - Use the config file:     None
Model Optimizer version:     2019.3.0-408-gac8584cb7
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint8 = np.dtype([("qint8", np.int8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint16 = np.dtype([("qint16", np.int16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint32 = np.dtype([("qint32", np.int32, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  np_resource = np.dtype([("resource", np.ubyte, 1)])
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
[ FRAMEWORK ERROR ]  Error parsing message
TensorFlow cannot read the model file: "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/frozen_inference_graph.pb" is incorrect TensorFlow model file.
The file should contain one of the following TensorFlow graphs:
1. frozen graph in text or binary format
2. inference graph for freezing with checkpoint (--input_checkpoint) in text or binary format
3. meta graph
Make sure that --input_model_is_text is provided for a model in text format. By default, a model is interpreted in binary format. Framework error details: Error parsing message.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #43.
Cannot load input model: Error parsing message
3. meta graph
KKar01
I tried a new model which is generated by openvino - facenet 20180408-102900.pb - when I try to convert thsi model I also ran into error - please let me know if I am doing something wrong?
(base) krishkar:/opt/intel/openvino/deployment_tools/model_optimizer$ sudo python3 mo_tf.py --input_model 20180408-102900.pb
Common parameters:
    - Path to the Input Model:     /opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/20180408-102900.pb
    - IR output name:     20180408-102900
    - Log level:     ERROR
/home/krishkar/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/krishkar/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/krishkar/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/krishkar/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/krishkar/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/krishkar/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
[ ERROR ]  FusedBatchNorm doesn't support is_training=True. Node InceptionResnetV1/Repeat_1/block17_10/Branch_1/Conv2d_0b_1x7/BatchNorm/cond/FusedBatchNorm
Exception occurred during running replacer "Fused_Batch_Norm_is_training_true_catcher" (<class 'extensions.middle.FusedBatchNormTrainingCatch.FusedBatchNormTrainingCatch'>): FusedBatchNorm doesn't support is_training=True. Node InceptionResnetV1/Repeat_1/block17_10/Branch_1/Conv2d_0b_1x7/BatchNorm/cond/FusedBatchNorm
Luis_at_Intel
Hi Kar, Krish,
Thanks for reaching out, if you can please provide more details about your model. How are you freezing the model? If possible it would be great if you can share your files so we can attempt to convert it as well, I can send you a PM in case you don't want to share this publicly.
Luis
