pypy3 with OpenVINO
timofeev__vasil
Please help me, i can`t load cv2 and ie into pypy3
Variables (setupvars) are loaded
Ubuntu 18.04 LTS
[setupvars.sh] OpenVINO environment initialized
(venv) imt@imt-G7-7790:~/cs$ pypy3
Python 3.6.9 (1608da62bfc7, Dec 23 2019, 10:50:04)
[PyPy 7.3.0 with GCC 7.3.1 20180303 (Red Hat 7.3.1-5)] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>>> import cv2
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'cv2'
(venv) imt@imt-G7-7790:~/cs$ source /opt/intel/openvino/bin/setupvars.sh
>>>> import cv2
JAIVIN_J_Intel
Hi Vasil,
Have you tried using python3 instead of pypy3?
It is recommended to use the supported python versions
Jaivin
timofeev__vasil
Hello!
Sure with python3 it works, but i want more...
i don't understand how to show pypy3 to look for cv2 and ie libraries! load variables seems to has no effect
Thank you!
timofeev__vasil
Hello!
Thank you!
JAIVIN_J_Intel
Hi Vasil,
As mentioned in the documentation OpenVINO on Ubuntu* 18.04 supports only 2.7, 3.5, 3.6 and 3.7 standard versions of Python. The PyPy3 implementation of Python may not be compatible with OpenVINO.
Jaivin
timofeev__vasil
Hi James!
sorry for the bad explication, the problem was not the run-time failure by using pypy but that a can't set local variables for pypy to see cv2 and ie.
Vasili
