Hi All,
I've been trying to convert a very basic model (realising matrix multiplication) into IR representation, but I keep getting the following error. I'm confused right now because AFAIK matrix multiplication should be supported by model optimizer.
I'm attaching my model - if someone wants to give it a try on their side.
The command I'm running is: python mo_tf.py --input_model matrix_mul.pb --input_shape (1,72)
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\matrix_mul.pb
- Path for generated IR: C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\.
- IR output name: matrix_mul
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: (1,72)
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
TensorFlow specific parameters:
- Input model in text protobuf format: False
- Path to model dump for TensorBoard: None
- List of shared libraries with TensorFlow custom layers implementation: None
- Update the configuration file with input/output node names: None
- Use configuration file used to generate the model with Object Detection API: None
- Operations to offload: None
- Patterns to offload: None
- Use the config file: None
Model Optimizer version: 2019.2.0-436-gf5827d4
[ ERROR ] List of operations that cannot be converted to Inference Engine IR:
[ ERROR ] MatMul (1)
[ ERROR ] mat_mul/MatMul
[ ERROR ] Part of the nodes was not converted to IR. Stopped.
For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #24.
链接已复制
Karol Duzinkiewicz,
MatMul should be supported for Tensorflow in OpenVino R2. But it gets transformed into a FullyConnected layer according to the Supported Framework Layers document
It very well could be bug.
Since you work for intel I'm going to forward you a link so that you can try it on R3 (which external customers don't have accoess to).
Shubha
Hi All,
after installing OpenVino R3 I still see the same error. Any other advise?
c:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer>python mo_tf.py --input_model matrix_mul.pb --input_shape (1,72)
Common parameters:
- Path to the Input Model: c:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\matrix_mul.pb
- Path for generated IR: c:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\.
- Log level: ERROR
Model Optimizer version: 2019.3.0-313-g5404e5d36
Dear Karol Duzinkiewicz ,
This looks like a bug. Sorry about that. I will file it on your behalf. PS, you have access to R3 because you are an intel employee. But most OpenVino community members don't have it yet. :)
Shubha
